Audi A3 8V Cruise control retrofit
riccoa
Denmark
C?ID=57750
Hi. Tried to retrofit a cruise control unit in my brand new Audi A3 8V, but when coding 01_Engine I get errors on Engine and ABS control modules. Attached Auto scan after coding of 16_Steering wheel and Engine control unit. Please help if anyone knows how to fix this issue?
Coding of Engine control unit:
https://www.dropbox.com/s/mf4hqyapeqqveyx/01-Engine_CCS_Coding.PNG?dl=0
Coding of Steering wheel unit:
https://www.dropbox.com/s/vax5f0q9g8218sn/16-SteeringWheel_CCS_Coding.PNG?dl=0
Autoscan after coding attempt:
https://www.dropbox.com/s/x0dg14ppq...ZZ8V5GA025186-1170km-727mi_CCS_Error.txt?dl=0
Dropbox links are rather annoying. Is there some reason you don't want to post the Auto-Scan in-line, like this?
Sunday,04,October,2015,10:08:34:02286
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ8V5GA025186   License Plate: AS55395
Mileage: 1170km-727mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 20 42 44 52 55 5F
VIN: WAUZZZ8V5GA0xxxxx   Mileage: 1170km-727miles
Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H22 2326
   Revision: R6H22---
   Coding: 02190012242401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FE610E4B695E246B4-803A
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 1170 km
                    Date: 2015.10.04
                    Time: 09:58:41
17921 - Databus
          U1122 00 [039] - Implausible Message
                    Mileage: 1170 km
                    Date: 2015.10.04
                    Time: 09:58:40
Readiness: 1110 0001
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61865000006411
   Coding: 12F16AA224222A710178060841C9294856245480608294F2002100788008
   VCID: 79F22EBCF8D1BCF61A-802C
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [008] - -
                    Reset counter: 68
                    Mileage: 1170 km
                    Date: 2015.10.04
                    Time: 09:58:41
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000682330
   Coding: 03000004000000011000000000001100
   VCID: 336EDC949A3D86A690-8066
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061517504665
   Coding: 04040B46C24122FD43D44004001C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 09125E7CA831AC760A-805C
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150620  042 0580
   Serial number:         150626102109
   Coding: 0A47F7
   Slave 2:
   Serial number: 24057393
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 27 04 2015  00000565
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R0WZU1N
   Coding: 98CCC0000C0000005C540000004800000065
   VCID: 4B9EA474E2CDFE66F8-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 207 15
   Serial number: 35767000000ACAB83512
   Subsystem 2 - Part No SW: -----------    HW: 480 000 207 15
   Serial number: 358670000009CAB83512
   Subsystem 3 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3516502A51C52F32E25C
   Subsystem 4 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3526502A51C52F325333
   Subsystem 5 - Part No SW: -----------    HW: 480 402 705 15
   Serial number: 3556502B71A14CC14148
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 206 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A11B65D507187
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 206 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029F1B65D5520CO
   Subsystem 8 - Part No SW: -----------    HW: 480 402 206 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C31B5A8805252
   Part No SW: 8V0 953 521 EF    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 03071508491185
   Coding: A408
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 020049509507FF2E4B-8056
   Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
   Component: KOMBI         H03 6420
   Coding: 078409002B8000080100A8001000000000000000
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003715096
   Coding: 030100043F0857005B000248080B00000001010000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 75EA228CD4C9D8967E-8020
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 18 06 2015  C0052034
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001506243745
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0202000700000000000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_AU37.rod
   VCID: 3972EEBCB8517CF65A-806C
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 060615BF608422
   Coding: 00100B204000040000001002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 4182865CD081243612-8014
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000006679281
   Coding: 110000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 438E8C54CA9D362600-8016
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 070615BF616323
   Coding: 001003204000040000001002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 40848358DB8B2D3E1D-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000006624347
   Coding: 090000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 019A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   Part No SW: 8V0 035 864 C    HW: 8V0 035 864 B
   Component: MU-S-N-ER     042 0461
   Serial number: A3F02606150133
   Coding: 01730301FF0A000021110001000A00032F0001040100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3B7EF4B4B26D4EE648-806E
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30BYYY
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000011051500040337
End-------------------------(Elapsed Time: 03:24)--------------------------
riccoa
Denmark
C?ID=57750
Got my CCS coded by Audi. Hope someone can use this.
Saturday,24,October,2015,12:14:17:02286
Mileage: 3563km-2213mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 20 42 44 52 55 5F 6C
VIN: WAUZZZ8V5GA025186   Mileage: 3563km-2213miles
   Revision: R6H22---
   Shop #: WSC 29842 001 1048576
   Coding: 12F16AA224222A710178060841C9294856245480608294F2022100788008
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: A408
   Coding: 07A409002B8000080100A8001000000000000000
   Revision: AA001001
   Coding: 110000
   Coding: 8103
   Coding: 090000
   Sound System:
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 5Q0 907 441     HW: 5Q0 907 441
   Component: MQB RVC Mid   H04 0120
   Coding: 027300010201000300
   Shop #: WSC 06798 128 28888
   ROD: EV_CamSysRearPANAAU914.rod
13705478 - Databus
             U1121 06 [009] - Missing Message
                    Fault Frequency: 39
                    Reset counter: 66
                    Mileage: 2822 km
                    Date: 2015.10.23
                    Time: 13:17:10
End-------------------------(Elapsed Time: 03:36)--------------------------
