Misfires, is it a lambda sensor problem?
CineXMike
C?ID=222249
I can tell you that with my 1.4 TSI it really listens to the ecu FW installed, one FW causes a misfire on cilinder 4. While another FW version on the same ECU makes the engine run smoothly. This indeed can easily be the ecu doing funky things.
I could only suggest upgrading/downgrading your FW to eliminate it from the equation. Any decent tuner should be able to help with this.
   #22
Gibu78
C?ID=533456
Thanks for the sugestion. I will contact a tuner.
   #23
Gibu78
C?ID=533456
Hi all,
Is there a way to finetune the timing of the distribution with vcds?
