Misfires, is it a lambda sensor problem?
Gibu78
C?ID=533456
Hi all,
I,ve having misfire problems with my Audi 1.4TFSI 122HP 2013.
There are several things replaced and cleaned.
Sparkplugs replaced
coils replaced
injectors replaced
walnut blasting done.
the misfires only happens when the engine runs idle.
and the the engine light blinks for several times, and after that, the light is gone again.
Please help...
Sorry for my bad English:rolleyes:
See my scan, is the oxygen sensor value ok?
Thanks in advance!!!
Tuesday,27,February,2024,16:58:58:52471
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ8V0EA013217   License Plate: 6-KTR-77
Mileage: 222190km-138062mi   Repair Order: 27-2-2024
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 47 52 55 5F BB BC
VIN: WAUZZZ8V0EA013217   Mileage: 222190km-138062miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H08 9024
   Revision: WAH08---    CVN: B247CEC6
   Coding: 02250032242401082000
   Shop #: WSC 57636 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016DF 002007
   ROD: EV_ECM14TFS01104E906016DF.rod
   VCID: 698EBC75E9F52D3298D-803C
   VINID: 9D196AAAA2260154400430811C2B006A57
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [01100000] - -
                    Mileage: 222101 km
                    Date: 2024.02.24
                    Time: 16:32:07
                    Engine RPM: 665.00 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 13.122 V
                    Unlearning counter according OBD: 36
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    O2 sensor 2: B1: internal resistance limit: 79230 Ohm
                    Long-term fuel trim bank 1 at idle: -1.27 %
10591 - Cylinder 1
          P0301 00 [01100000] - Misfire Detected
                    Mileage: 222101 km
                    Date: 2024.02.24
                    Time: 16:32:08
                    Voltage terminal 30: 13.216 V
                    Misfire recognition reference moment: 5.597 %
                    Misfire totalizer: 97
                    Counter: implaus. short-term adapt. values: misfire detection: 2
10592 - Cylinder 2
          P0302 00 [01100000] - Misfire Detected
                    Mileage: 222101 km
                    Date: 2024.02.24
                    Time: 16:32:07
                    Misfire recognition reference moment: 5.721 %
                    Misfire totalizer: 96
   Part No SW: 0CW 300 045 M    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501305205913 CVN: 00008937
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 43D24EDDAB191762721-8016
   Revision: 00000000    Serial number: 61533000000608
   Coding: 12F16AA22421126F0179060141CA294856244880608294F2022100788508
   Shop #: WSC 06314 790 00021
   VCID: 7BA2F63D9369AFA27A1-802E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0031
   Revision: 20021000    Serial number: 00000000096121
   Coding: 03000004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBAD26DD711C302C69-803A
   Humidity sensor: exterior:
   Serial number: 30688FA6000000000001
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011315701582 Dataset Number: 8V0909514C  0063
   Coding: 04001A42C2C122FD43844004001C07A8001C000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77AAEA0DAF418BC21E9-8022
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130526  041 0580
   Serial number:         130529111612
   Coding: 0A47F7
   Serial number: 21377869
   Coding: 03006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 08 05 2013  00001131
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231315501596 Dataset Number: 8V0909526C  0033
   Coding: 0030051051
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3B22363DD3E96FA23A1-806E
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R01V718 Dataset Number: 8V0909602C  0007
   Coding: 98CCC0000C0000005C5400CA004800000065
   VCID: 4BC266FD8349DF228A1-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 406 13
   Serial number: 35767000000AD6E03D01
   Subsystem 2 - Part No SW: -----------    HW: 480 000 406 13
   Serial number: 35867000000D89703D0$
   Subsystem 3 - Part No SW: -----------    HW: 480 400 806 13
   Serial number: 3516502C9105EDC2512C
   Subsystem 4 - Part No SW: -----------    HW: 480 400 806 13
   Serial number: 3526502C7105EDC5527K
   Subsystem 5 - Part No SW: -----------    HW: 480 402 604 13
   Serial number: 3556502B31050653425S
   Subsystem 6 - Part No SW: -----------    HW: 480 400 606 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502AD10CBDF2219S
   Subsystem 7 - Part No SW: -----------    HW: 480 400 606 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029D10CBDF4B20V
   Subsystem 8 - Part No SW: -----------    HW: 480 400 606 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502AB10CBDF1532G
   Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 06061308490652 Dataset Number: ----------
   Coding: A418
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 392E2C35D9D55DB228D-806C
   Part No SW: 8V0 920 870 G    HW: 8V0 920 870 G
   Component: KOMBI         H03 2210
   Coding: 07AD09082B8000080D01EA00000000
   VCID: 3FDA422DC7F17382169-806A
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000634028 Dataset Number: 8V0909515C  0044
   Coding: 030100042B0864005B0002481C0B00000001000000000000000000000000
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 30 06 2021  E0000070
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051502312
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 26051301100798 Dataset Number: 8V0909872D  0025
   Coding: 005D8F204000040000001002
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: 8V0909852F  0015
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D263825CDFD6192045-8068
   Part No SW: 8V0 035 465 A    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0370
   Serial number: AUZ8ZAD0900BBPP Dataset Number: 8V0909510B  0014
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 36342709E8CBB2CAC5F-8062
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 24051306070852 Dataset Number: 8V0909873D  0024
   Coding: 005D87204C00040000001002
   VCID: 3E243F29C0FB7A8A1DF-806A
   Component: LWR-ECU       005 0070
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865D  0028
   Coding: 019A000001000000
   VCID: 75B6E005B54DF9D20C5-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 043 B    HW: 8V0 035 043
   Component: MU-H-N-EU     H41 0171
   Serial number: A303E0DB001911 Dataset Number: 8V2909545C  0027
   Coding: 017303010000000021110002000A00002F00022501000100DE
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 2F3A126D17918302869-807A
   Subsystem 1 - Part No SW: V03 959 800 PP    HW: -----------
   Component: ECE 2013/2014  --- 0062
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 604 A    HW: 8V0 919 604 A
   Component: DU High  H48 0013
   Serial number: AUZ8Z9DG5006B6
   Subsystem 3 - Part No SW: 8V0 919 614 H    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0764
   Serial number: C1000020051300020539
   Compact disc data bank:
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 21051302090355 Dataset Number: 8V0909897B  0012
   Coding: 004D87204000040000001002
   VCID: 41DE44D5B105057260D-8014
   Component: TSG HBFS      010 0006
   Serial number: 21051301100357 Dataset Number: 8V0909896B  0012
End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V)-----------
Zenerdiode
Newcastle, England
C?ID=24330
Nothing wrong with your English. ;)
Fuel trim looks good, the sensor values are just a snapshot at the time of the freeze frame. So you’ve changed sparks, coils and injectors. Where did you get them from?
Have you done a compression and leak down test on each cylinder? You may have a hanging/chipped/burnt valve or seat. Head gasket may be blown between cylinder 1 and cylinder 2. So comp./leak test next.
I agree, next step a compression test. When I have been to Holland I have always been very impressed by Dutch peoples English and when you ask, often they have never been here. The universal use of English has made us very lazy in learning foreign languages and many people even born here have a poorer command of it.
Gibu78
C?ID=533456
Haha, thanks for the compliments on my english.
I forgot to mention that the compression test had already been done. each cylinder approximately 14.5 bar.
So I thought, maybe because it's only at idle, and the car runs perfectly while driving.
So maybe the heating element of the lambda sensor, because the gases get colder during idle?
And the sparksplugs and injectors are OEM. The coils are ngk from winparts (online shop), but also tried others, without succes.
Gibu78
C?ID=533456
Nobody any suggestions?
My mechanic says it must be the ecu, is this possible?
Please help.
Try clearing fault codes directly in the engine three or even five times in rapid succession. Sometimes this resets things. I don't have much confidence it will work, but it doesn't cost much to try either.
Gibu78
C?ID=533456
Thanks Uwe,
I gonna try this.
Running it in Basic Settings 099 turns off the lambda control so the exhaust Lambda without trim can be measured.
Gibu78
C?ID=533456
I also changed some start/stop settings in the past.
and sometimes get the (automatic start/stop: system fault! function unavailable) in the screen between the speedometers
Could that be something causing the misfires?
This is what i did (got it from a webside):
Purpose: Allows you to completely deactivate
Start/Stop.
Attention!! There are, here, 2 lines of coding to be shown 1 following the method.
Proceed:
1 - With the engine off, ignition off, plug your official VAG-COM VCDS cable into the
computer then plug the other end into your vehicle's diagnostic socket.
2 - Switch on the ignition then start the VCDS program.
Method 1 (Voltage method):
Line 1:
3- Click on " Select " then click on " 19 - CAN Gateway ".
4 - Click on " Adaptation - 10".
85
Opties V
5 - On this page, at the very top, there is a drop-down menu.
In this drop-down menu, choose "Start/Stop voltage limit" / "Start/Stop voltage limit"
6 - On this same page, there is a second dropdown menu but towards the bottom of the page.
On the latter, choose " 12 " (default value = 7.6V) then validate.
Line 1 :
1.      Click on " Select " then click on " 19 - CAN Gateway".
2.        Click on " Adaptation - 10".
3.      On this page, at the very top, there is a drop-down menu.
In this drop-down menu, choose" (1)-Start/Stop Auntemperaturvorgabe-
Minimaltemperatur "
of the page.
On the latter, choose " 50 " (default value =
-50.0 ) then validate.
Line 2:
1.      Click on " Select " then click on " 19-CAN Gateway".
In this drop-down menu, choose" (2)-Start/Stop Auntemperaturvorgabe-
Maximaltemperatur "
Gibu78
C?ID=533456
Thanks! gonna try this too
Uhm.... There's no "Basic Settings 099" on a UDS ECU, nor do I see an equivalent in this ECU.
That’s a point, too late for that feature which was very useful.
Larry Manton
C?ID=112505
would be doing a smoke test for a leak as this happens at idle, JMO. Trims with lambda a 1.00 looks spot on. -1.2LTFT, could go up or down depending on how it was run just before you stopped.
Gibu78
C?ID=533456
Thanks,
Car is in workshop for now, so i have to wait.
They say, it is because of the ecu. They ordered a new one.
Larry Manton
C?ID=112505
ECU failure is very very rare and the absolute last resort.
I guess I would have liked to see them validate that in some way, JMO.
TINTIN13
C?ID=540018
injectors are common for cracking
Gibu78
C?ID=533456
Hi all, an update on the problem. it turned out that the distribution was not on time. now the misfires are almost gone. The garage is now charging me a lot of research costs. but had read this through VCDS before they started the whole problem. Is it possible this wasn't showing up in VCDS? The garage says that the car may need a new crankshaft sensor, so that the car is completely misfire free. Can this also be ruled out via VCDS? thank you in advance..
That is suspicious as a valve timing error should have come up as a fault code, VCDS isn't responsible for generating the codes or data, it just reads it. Anyway, told you it wouldn't be the ECU, never is... except when it is!
Gibu78
C?ID=533456
Hi,
I got my car back, but now it is still not running smooth.
Can anybody tell me if this is ok?
See my scan:
Wednesday,10,April,2024,12:03:34:52471
Mileage: 223711km-139007mi   Repair Order: nokkenas sensor
                Address 01: Engine  (04E 906 016 DF)
12:02:45
  IDE00178   Camshaft adjustment intake bank 1: specified value 16.766 °
  IDE00179   Camshaft adjustment intake bank 1: actual value 16.523 °
  IDE00182   Camshaft adaptation intake bank 1: phase position 5.41 °
  IDE01884   Camshaft adjustment intake bank 1: activation 30.363 %
  IDE09925-ENG188621   Intake camshaft bank 1: adaption error cause-Bits 0-7 0
  IDE09929   Intake camshaft bank 1: adaption value hardware offset active -5.234 °
