Resolved Which steering column module is the correct upgrade for retrofit cruise control install?
Resolved
danws4
England
C?ID=555090
Hi there,
I'm looking to retrofit a cruise control upgrade to my daughters 2011 Eos Exclusive and need a bit of help with confirming the correct selection of the steering wheel control module required to be installed for the retrofit.
As original fit, her car has steering wheel control module ref 5K0 953 569 A.
I believe as well as changing out the column stalks to have the cruise control available via a switch on top of the indicator lever, I also need to change the steering wheel module, before coding everything to the car
Please can anyone confirm what steering wheel module I should be obtaining to get the retrofit on track?
Bruce
Near Philadelphia, PA, USA
In order to help with the request, likely information about other modules will be required. Please post a full autoscan of the vehicle so we can have that information.
Don't know how? See the "How To" menu in the blue bar at the top of the page.
danws4
England
C?ID=555090
Thanks for the heads up Bruce, scan as requested!
One thing to note, the squib ring has failed hence the faults logged in section 16!
Wednesday,06,September,2023,19:13:14:65142
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WVWZZZ1FZBV014209   License Plate: A17XXA
Mileage: 173840km-108019mi   Repair Order:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 2E 42 44 46 52 56 61 62 72
          77
VIN: WVWZZZ1FZBV014209   Mileage: 173840km-108019miles
   Part No SW: 03L 906 018 GA    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9977
   Revision: 41H24---    Serial number:                CVN: D0187299
   Coding: 00190012042501080000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TDI01103L906018GA 003006
   ROD: EV_ECM20TDI01103L906018GA_VW36.rod
   VCID: 6FBBC14F2712EB12E61-803A
   VINID: 9E69EAAAA056A9298004408024F210B4AF
12002 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [100] - Implausible Signal
                    Mileage: 173752 km
                    Date: 2023.09.06
                    Time: 15:45:00
                    Engine RPM: 0.00 /min
                    Coolant temperature: 83 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.960 V
                    Sensor for particle filter differential press: raw value: -201 hPa
                    Particle filter: difference pressure: -201 hPa
                    DPF: offset for differential pressure: -74 hPa
                    Particle filter: differential pressure: dynamic offset: 0 hPa
                    Outside temperature: 24.0 °C
                    Particle filter: soot mass measured: -13.94 g
                    Particle filter: soot mass calculated: 10.93 g
5262 - Particulate Filter; Differential Pressure Sensor
          P2454 00 [168] - Short to GND
                    Fault Frequency: 86
                    Mileage: 173776 km
                    Engine RPM: 186.00 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 57 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 10.740 V
                    Sensor for particle filter differential press: raw value: -214 hPa
                    Particle filter: difference pressure: 150 hPa
                    Particle filter: differential pressure: dynamic offset: -150 hPa
                    Outside temperature: 22.0 °C
                    Particle filter: soot mass calculated: 9.83 g
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [101] - Electrical Fault
                    Mileage: 173682 km
                    Date: 2023.09.06
                    Time: 21:22:09
                    Engine RPM: 1128.50 /min
                    Normed load value: 89.0 %
                    Coolant temperature: 14 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.080 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 1400 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 8
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 4
                    Outside temperature: 15.0 °C
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 173682 km
                    Date: 2023.09.06
                    Time: 21:21:50
                    Voltage terminal 30: 11.760 V
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    selected gear-Bits 0-7: 0
4891 - EGR Valve (N18)
          P0403 00 [109] - Malfunction
                    Mileage: 173729 km
                    Date: 2023.09.06
                    Time: 14:43:01
                    Engine RPM: 1667.00 /min
                    Vehicle speed: 106 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.540 V
                    Air mass: actual value (mg/stroke): 605.8 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 97.57 %
                    EGR valve: offset closed: 5.96 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    Actuator for high pressure EGR: status-Bits 0-7: 4
                    High press EGR actuator: actual unconditioned volt val: 894.2 mV
Readiness: 1 2 0 0 0
   Revision: 00H31001
   Coding: 563B6008092300FE6A0D06E490220092350000
   Shop #: WSC 00020 790 00000
   VCID: 76B5F42B58C8DADA257-8022
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00020 999 00000
   VCID: 6E85DC4B2018E21AED7-803A
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 46000A3B8A23F06040080080310081EC47715E08602005606480C7000041
   Shop #: WSC 00020 790 12345
   VCID: 3B23251F236A47B21A9-806E
   Subsystem 1 - Part No: 1Q2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 02031  26  0512
   Coding: 009795
   Component: RLS 250311 05  54  0403
   Coding: 0330CD
   Subsystem 3 - Part No: 1Q0 951 177 C
   Component: Innenraumuebe  200 0203
   Subsystem 5 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 59
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:21:56
                    Voltage: 11.80 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 59
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:24:13
                    Voltage: 12.90 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 1Q0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H02 0005
   Revision: --------    Serial number: 32901106204518
   Coding: 10C001
   ASAM Dataset: EV_EPHVA14VW4650000 001003
   ROD: EV_EPHVA14VW4650000.rod
   VCID: 75B7F327454ED1C22CD-8020
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 B    HW: 1Q0 959 655 B
   Component: 0Z Airbag VW8C      0210
   Revision: 92011021    Serial number: 003G2000HPS5
   Coding: 0012378
   VCID: 3B23251F2F6A47B21A9-806E
   Subsystem 1 - Serial number: 6332SRB40D4A07A32
   Subsystem 2 - Serial number: 6342SRB40D4A108B3
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
                    Fault Status: 11100001
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:21:58
   Part No SW: 1K5 953 521 AH    HW: 5K0 953 569 A
   Revision: FF010040    Serial number: 20110328300330
   Coding: 0082040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 73B3CD3F4B3ACFF2029-8026
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 66
                    Mileage: 173847 km
                    Date: 2023.09.06
                    Time: 00:01:28
   Part No SW: 1Q0 920 975 A    HW: 1Q0 920 975 A
   Coding: 471F01
   VCID: 33330D3F0BBA8FF2C29-8066
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 090411F2000028
   Coding: 355001
   VCID: 313F0737F126BDE2B05-8064
   Component: IMMO          H20 0420
   VCID: 6A8DD05B1CF00E3AB1F-803E
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 F    HW: 1Q0 959 255 F
   Component: Verdecksteuergeraet 0854
   Revision: 0033100Q    Serial number: 110750137
   Coding: 0655374
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669689665
   VCID: 2809EA53C2FCFC2A67B-807C
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2152
   Coding: 0152247
   VCID: 392F3F17255675A2085-806C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 34310E23023488CADB3-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.7 V
                        PD
                    Temperature: 53.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0152502
   VCID: 3A2D201B20507EBA01F-806E
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L9215649
   Coding: 0100040004
   VCID: 6597A367F56E21429CD-8030
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71BFC73731A6FDE2F05-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370138555
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 105
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 02:45:25
   Part No SW: 1Q0 959 811 B    HW: 1Q0 959 811 B
   Component: Tuer-SG         004 0602
   Coding: 0131216
   Shop #: WSC 00020 790 1012544
   VCID: 35373327094E91C2ECD-8060
   Part No SW: 1Q0 959 812 B    HW: 1Q0 959 812 B
   Coding: 0131216
   VCID: 3635342B14489ADAE57-8062
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669599329 Dataset Number: 5K0035730B  0001
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2411FE63BE54184A4B3-8070
End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
Wednesday,06,September,2023,19:17:59:65142
          77
                    Mileage: 173752 km
                    Date: 2023.09.06
                    Time: 15:45:00
                    Fault Frequency: 86
                    Mileage: 173776 km
                    Mileage: 173682 km
                    Date: 2023.09.06
                    Time: 21:22:09
                    Mileage: 173682 km
                    Date: 2023.09.06
                    Time: 21:21:50
          P0403 00 [044] - Malfunction
                    Mileage: 173729 km
                    Date: 2023.09.06
                    Time: 14:43:01
   Revision: 00H31001
   Revision: 00003001
   Coding: 0000000003
   Revision: BC011001
   Coding: 009795
   Coding: 0330CD
                    Reset counter: 59
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:21:56
                    Voltage: 11.80 V
                    Reset counter: 59
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:24:13
                    Voltage: 12.90 V
   Coding: 10C001
   Coding: 0012378
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 21:21:58
   Coding: 0082040000
                    Reset counter: 66
                    Mileage: 173847 km
                    Date: 2023.09.06
                    Time: 00:01:28
   Coding: 471F01
   Coding: 355001
   Coding: 0655374
   Coding: 0152247
   Revision: 00H20000
            000 - - - MIL ON
                        PD
                    Temperature: 53.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   Coding: 0152502
   Coding: 0100040004
   Coding: 030B185A
                    Reset counter: 105
                    Mileage: 173682 km
                    Date: 2018.01.27
                    Time: 02:45:25
   Coding: 0131216
   Coding: 0131216
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:39, VBatt start/end: 13.1V/13.2V)-----------
siLc
Tallinn, Estonia
C?ID=330192
This should be anyone’s first reference on what SWCM to get. Coincidentally installing a new one will also fix the current issue of slip ring failure, as they are a single unit. The ones ending in B, AH and maybe some others may be suitable.
danws4
England
C?ID=555090
Hi SiLc, appreciate the response. I have looked through the other control module versions but just wanted a sanity check before committing to purchase new parts as most often electronics can't be returned if they turn out to have been incorrectly ordered!
danws4
England
C?ID=555090
Just want to confirm I followed up on siLc's advice, purchased a used AH version module and all is now resolved!
