MB different from BS
mikeme
Alexandria/fairfax county VA
C?ID=99408
I read on the VCDS demo that the info displayed in the Basic settings screen matches data in measuring blocks.
seems like this is not quite 100% accurate, (or I made an error someplace)
units for the MB 78, 1-4: RPM, (no units), Pressure, Lambda
units for the BS 78, 1-4: mbar, [blank], mbar, °C
here are a couple segments of my logs:
first from measuring blocks:
Wednesday 23 September 2015 13:27:06:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
03L 997 016 P R4 2.0L EDC G000AG 8681
Group A: '078
RPM (no units) Pressure Lambda
TIME
Marker STAMP /min mbar %
0.17 828 20.4 0 99.4
0.56 828 25.5 0 99.4
0.95 828 25.5 0 99.4
1.34 828 25.5 0 99.4
1.71 828 25.5 0 99.4
2.1 828 25.5 0 99.4
2.49 828 25.5 0 99.4​
and from basic settings:
Saturday 26 September 2015 10:59:51:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
at idle 820 rpm, basic settings 78 before pressing on/off/next (my added comment)
Group A: '078
TIME
Marker STAMP mbar mbar °C
0.04 3 20.4 -3 282
0.17 3 20.4 -3 282
0.28 3 20.4 -3 282
0.39 3 20.4 -3 282
0.51 3 20.4 -3 282
0.62 3 20.4 -3 282
0.75 3 20.4 -3 282
0.87 3 20.4 -3 282​
also from basic settings:
Saturday 26 September 2015 11:00:13:51928-VCID:3FA390536EB764C664-806A VCDS Version: Release 15.7.1 (x64)
1320 rpm or so basic settings 78 after pressing on/off/next (also my inserted comment)
Group A: '078
TIME
0.04 85 45.9 -3 282
0.16 85 51 -3 282
0.28 85 45.9 -3 282
0.39 85 45.9 -3 282
0.51 85 45.9 -3 282
0.62 85 45.9 -3 282
0.73 85 45.9 -3 282
0.84 87 45.9 -3 282​
Is there some place the various measuring blocks are spelled out, or is it all hidden on the VW corporate network someplace?
a little birdie told me that the basic settings 78 reveal the LP EGR filter health, and that the difference between field 1 and 3 when basic settings on/off/next selected should be under 100
I wanted to run a log of the egr filter pressure on a drive but now am confused. (there seems to be a lot of that going around)
Sounds like the manual needs updating. It does indeed state that,
Basic Settings Mode is very similar to Measuring Blocks, and the contents of each display group is the same.
I think that was true when the manual was originally written way back when, but it isn't necessarily true today. The data shown in some groups of Basic Settings in some modules is indeed quite different than the data shown in the corresponding Measuring Block Group. Please understand, it's the module that's in control of the data (and units) that are displayed in each group, not VCDS.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Scratching my head, what basic setting are you running in Block 078? :)
// Update 1: Nevermind, missed your comment on that. I'll do some digging and see if I can find additional details on this. :)
// Update 2: This is the layout for the regular meas. values...
MVB 078/1 = Engine RPM
MVB 078/2 = Mass Air Flow Sensor (actual)
MVB 078/3 = Differential Pressure Sensor (G450)
MVB 078/4 = Exhaust Flap (actual)
NEtech
Denmark
C?ID=56995
Do you maybe have the same measurement values from MWB 067 to 076 ?
Please make 2 controller maps, 1 with Ignition ON and 1 in idle.
Important Basic settings are in 067 068 and 078
It is my understanding that you can only test the EGR filter pressure, by doing the Basic setting 078.
Temperature reading below 200°C !
Correct
mikeme
C?ID=99408
Thanks Sebastian!
don't suppose you have a full list of the MVB nomenclature, do you?
perhaps one that reports the Low Pressure Exhaust Gas Recirculation (EGR) Pressure
Sensor
mikeme
C?ID=99408
I can get a log with MVB 67 and 76 later today.
will post.
thought the temp for the basic settings 78 difference was for temp above 200C. have to read it again.
mikeme
C?ID=99408
Correct
I must not quite understand. how would I get the controller map?
I logged some MVB for 67 and 76, and there is no values for my car for 76
Wednesday,30,September,2015,15:06:45:51928-VCID:3FA390536EB764C664-806A,VCDS Version: Release 15.7.1 (x64),Data version: 20150904
03L 997 016 P,,R4 2.0L EDC G000AG 8681,
,Group A:,'067,,,,Group B:,'076,,,,Group C:, Not Running
,,RPM,Load,Lambda,Lambda,, , , , ,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, %, %, %,STAMP,,,,,STAMP,,,,
,0.11,0,100.0,100.2,0.0,0.24, , , , ,,,,,
,0.36,0,100.0,100.2,0.0,0.49, , , , ,,,,,
,0.63,0,100.0,100.2,0.0,0.75, , , , ,,,,,
,0.88,0,100.0,100.2,0.0,1.00, , , , ,,,,,
,1.14,0,100.0,100.2,0.0,1.27, , , , ,,,,,
,1.39,0,100.0,100.2,0.0,1.52, , , , ,,,,,
,1.66,0,100.0,100.2,0.0,1.78, , , , ,,,,,
,1.91,0,100.0,100.2,0.0,2.03, , , , ,,,,,
,2.17,0,100.0,100.2,0.0,2.30, , , , ,,,,,
after starting:
,20.19,805,100.0,99.4,12.6,20.31, , , , ,,,,,
,20.44,828,100.0,99.4,12.6,20.56, , , , ,,,,,
,20.71,805,100.0,99.4,12.6,20.83, , , , ,,,,,
,20.95,828,100.0,99.4,12.6,21.08, , , , ,,,,,
,21.21,805,100.0,99.4,12.6,21.34, , , , ,,,,,
,21.47,828,100.0,99.4,12.6,21.59, , , , ,,,,,
,21.73,828,100.0,99.4,12.6,21.86, , , , ,,,,,
,21.98,828,100.0,99.4,12.6,22.11, , , , ,,,,,
mikeme
C?ID=99408
Wednesday,30,September,2015,15:08:32:51928-VCID:3FA390536EB764C664-806A,VCDS Version: Release 15.7.1 (x64),Data version: 20150904
,Group A:,'078,,,,Group B:,'104,,,,Group C:,'099
,,RPM,(no units),Pressure,Lambda,,0xFF02=Done,Hex Value,Bin. Bits,Bin. Bits,,Engine Speed,Temperature prior,Temperature prior,Temperature after
,TIME,,,,,TIME,,,,,TIME,(G28),Turbo Charger,Particle Filter,Particle Filter
Marker,STAMP, /min,, mbar, %,STAMP,,,,,STAMP, /min,°C,°C,°C
,0.32,828,25.5,0,99.4,0.06,0xFF01,0xFF21,00000000,00000000,0.19,828,186.0,108.0,72.0
,0.71,828,25.5,0,99.4,0.44,0xFF01,0xFF21,00000000,00000000,0.57,828,186.0,108.0,72.0
,1.08,828,25.5,0,99.4,0.83,0xFF01,0xFF21,00000000,00000000,0.95,828,186.0,108.0,72.0
,1.47,828,25.5,0,99.4,1.22,0xFF01,0xFF21,00000000,00000000,1.34,828,186.0,108.0,72.0
,1.86,828,25.5,0,99.4,1.60,0xFF01,0xFF21,00000000,00000000,1.74,828,186.0,108.0,72.0
,2.25,828,25.5,0,100.2,1.98,0xFF01,0xFF21,00000000,00000000,2.11,828,186.0,108.0,72.0
,2.63,828,25.5,0,99.4,2.37,0xFF01,0xFF21,00000000,00000000,2.50,805,186.0,108.0,72.0
,3.02,828,25.5,0,99.4,2.76,0xFF01,0xFF21,00000000,00000000,2.89,828,186.0,108.0,72.0
,3.41,828,25.5,0,99.4,3.14,0xFF01,0xFF21,00000000,00000000,3.28,828,186.0,108.0,72.0
,3.79,805,25.5,0,99.4,3.53,0xFF01,0xFF21,00000000,00000000,3.65,828,186.0,114.0,72.0
,4.17,805,25.5,0,99.4,3.92,0xFF01,0xFF21,00000000,00000000,4.05,805,186.0,114.0,72.0
,4.56,805,25.5,0,99.4,4.31,0xFF01,0xFF21,00000000,00000000,4.44,805,186.0,114.0,72.0
,4.95,805,25.5,0,99.4,4.68,0xFF01,0xFF21,00000000,00000000,4.82,805,186.0,114.0,72.0
,5.34,805,25.5,0,99.4,5.08,0xFF01,0xFF21,00000000,00000000,5.20,805,192.0,114.0,72.0
,5.71,805,25.5,0,99.4,5.46,0xFF01,0xFF21,00000000,00000000,5.59,805,192.0,114.0,72.0
,6.11,782,35.7,0,99.4,5.86,0xFF01,0xFF21,00000000,00000000,5.98,782,192.0,114.0,72.0
,6.49,828,30.6,3,99.4,6.23,0xFF01,0xFF21,00000000,00000000,6.37,805,192.0,114.0,72.0
,6.89,828,30.6,3,99.4,6.62,0xFF01,0xFF21,00000000,00000000,6.75,828,198.0,114.0,78.0
,7.26,828,30.6,0,99.4,7.01,0xFF01,0xFF21,00000000,00000000,7.13,828,204.0,114.0,78.0
,7.65,805,30.6,3,99.4,7.40,0xFF01,0xFF21,00000000,00000000,7.53,805,204.0,114.0,78.0
,8.04,851,30.6,3,99.4,7.77,0xFF01,0xFF21,00000000,00000000,7.91,828,210.0,114.0,78.0
,8.43,851,25.5,0,99.4,8.17,0xFF01,0xFF21,00000000,00000000,8.29,851,210.0,114.0,78.0
,8.80,828,25.5,0,99.4,8.55,0xFF01,0xFF21,00000000,00000000,8.68,828,210.0,114.0,78.0
,9.19,828,30.6,0,99.4,8.94,0xFF01,0xFF21,00000000,00000000,9.07,828,216.0,114.0,78.0
,9.58,828,25.5,0,99.4,9.32,0xFF01,0xFF21,00000000,00000000,9.46,828,216.0,114.0,78.0
,9.97,828,25.5,0,99.4,9.71,0xFF01,0xFF21,00000000,00000000,9.83,828,216.0,114.0,78.0
and later
,284.46,1472,35.7,23,14.2,284.20,0xFF01,0xFF10,00000000,00000000,284.34,1495,294.0,306.0,270.0
,284.85,1495,40.8,23,25.3,284.59,0xFF01,0xFF10,00000000,00000000,284.72,1495,276.0,306.0,270.0
,285.23,1472,56.1,21,30.8,284.98,0xFF01,0xFF10,00000000,00000000,285.10,1495,270.0,300.0,270.0
,285.63,1495,71.4,23,37.1,285.37,0xFF01,0xFF10,00000000,00000000,285.50,1495,270.0,300.0,276.0
,286.01,1495,76.5,23,27.6,285.74,0xFF10,0xFF12,00000000,00000000,285.88,1495,270.0,300.0,276.0
,286.40,1495,71.4,33,26.0,286.13,0xFF10,0xFF12,00000000,00000000,286.25,1495,270.0,300.0,276.0
,286.77,1495,76.5,44,26.0,286.52,0xFF10,0xFF12,00000000,00000000,286.65,1495,282.0,294.0,276.0
,287.16,1495,81.6,51,25.3,286.91,0xFF10,0xFF12,00000000,00000000,287.04,1495,288.0,294.0,282.0
,287.55,1518,76.5,56,28.4,287.29,0xFF10,0xFF12,00000000,00000000,287.43,1495,300.0,294.0,282.0
,287.94,1495,81.6,51,31.6,287.68,0xFF10,0xFF12,00000000,00000000,287.80,1495,312.0,300.0,282.0
,288.32,1495,81.6,49,31.6,288.07,0xFF10,0xFF12,00000000,00000000,288.19,1495,342.0,300.0,282.0
,288.71,1518,86.7,46,33.1,288.46,0xFF10,0xFF12,00000000,00000000,288.58,1518,372.0,306.0,282.0
,289.10,1518,86.7,46,33.1,288.83,0xFF10,0xFF12,00000000,00000000,288.97,1518,390.0,306.0,282.0
,289.49,1541,102.0,49,37.1,289.22,0xFF10,0xFF12,00000000,00000000,289.35,1541,420.0,312.0,288.0
,289.86,1564,102.0,51,37.1,289.61,0xFF10,0xFF12,00000000,00000000,289.74,1541,450.0,312.0,288.0
,290.25,1564,102.0,56,33.9,290.00,0xFF10,0xFF12,00000000,00000000,290.13,1564,474.0,318.0,288.0
,290.64,1587,96.9,56,33.9,290.38,0xFF10,0xFF12,00000000,00000000,290.52,1587,504.0,324.0,288.0
,291.03,1587,96.9,56,33.1,290.77,0xFF10,0xFF12,00000000,00000000,290.89,1587,522.0,324.0,288.0
,291.41,1587,91.8,54,33.1,291.15,0xFF10,0xFF12,00000000,00000000,291.28,1587,546.0,330.0,294.0
,291.79,1633,102.0,54,37.9,291.55,0xFF10,0xFF12,00000000,00000000,291.67,1610,558.0,336.0,294.0
,292.19,1633,117.3,59,40.2,291.92,0xFF10,0xFF12,00000000,00000000,292.06,1633,576.0,336.0,294.0
,292.58,1656,122.4,64,41.0,292.31,0xFF10,0xFF12,00000000,00000000,292.44,1656,594.0,342.0,294.0
,292.95,1679,122.4,69,41.0,292.70,0xFF10,0xFF12,00000000,00000000,292.83,1679,606.0,342.0,294.0
,293.34,1702,132.6,74,47.3,293.09,0xFF10,0xFF12,00000000,00000000,293.22,1702,612.0,348.0,300.0
,293.73,1725,158.1,69,83.6,293.47,0xFF10,0xFF12,00000000,00000000,293.61,1725,618.0,348.0,300.0
,294.12,1794,153.0,64,92.3,293.85,0xFF10,0xFF12,00000000,00000000,293.98,1771,618.0,354.0,300.0
,294.50,1840,158.1,64,91.5,294.24,0xFF10,0xFF12,00000000,00000000,294.37,1817,618.0,354.0,300.0
,294.88,1863,163.2,64,91.5,294.63,0xFF01,0xFF10,00000000,00000000,294.76,1863,630.0,360.0,306.0
,295.28,1932,183.6,72,52.9,295.01,0xFF01,0xFF10,00000000,00000000,295.15,1909,642.0,366.0,306.0
,295.67,1955,198.9,79,89.2,295.40,0xFF01,0xFF10,00000000,00000000,295.53,1955,654.0,372.0,306.0
,296.04,2001,204.0,85,78.9,295.79,0xFF10,0xFF12,00000000,00000000,295.91,2001,648.0,372.0,312.0
,296.43,2070,219.3,90,92.3,296.18,0xFF10,0xFF12,00000000,00000000,296.31,2047,630.0,372.0,312.0
,296.82,2116,198.9,92,92.3,296.55,0xFF10,0xFF12,00000000,00000000,296.70,2093,624.0,372.0,318.0
,297.21,2162,198.9,95,92.3,296.94,0xFF10,0xFF12,00000000,00000000,297.07,2139,624.0,372.0,318.0
,297.59,2185,198.9,95,92.3,297.33,0xFF01,0xFF10,00000000,00000000,297.46,2185,624.0,378.0,318.0
,297.97,2047,198.9,108,52.1,297.73,0xFF01,0xFF10,00000000,00000000,297.85,2208,624.0,378.0,324.0
,298.37,1840,153.0,92,89.2,298.10,0xFF01,0xFF10,00000000,00000000,298.24,1840,624.0,384.0,324.0
,298.75,1794,142.8,77,90.0,298.49,0xFF01,0xFF10,00000000,00000000,298.61,1817,600.0,378.0,330.0
,299.13,1725,147.9,64,89.2,298.88,0xFF01,0xFF10,00000000,00000000,299.00,1725,576.0,378.0,330.0
that MVB 78/4 is listed as lambda in %. and it seems to dance around more that I would think a motor driven flap would.
I logged these looking for more validation of my guess that the MVB 104/1 value of 0xFF10 is associated with an NOX regen.
mikeme
C?ID=99408
as requested. first with key to on but engine stationary
;SW:03L-997-016-P   HW:03L-906-022-J ---  Engine
;Component:R4 2,0L EDC G000AG  8681, Coding:0050078
;Thursday,01,October,2015,07:57:03:51928
;VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
;VCID: 3FA390536EB764C664-806A
1,0,,
1,1,,,
;0 /min,,
1,2,,,
;0.0 mg/str,,
1,3,,,
;8.0 bar,,
1,4,,,
;90.0°C,,
2,0,,
2,1,,,
;0 /min,,
2,2,,,
;0.0 %,,
2,3,,,
; 0 00  0,,
2,4,,,
;90.0°C,,
3,0,,
3,1,,,
;0 /min,,
3,2,,,
;1100.0 mg/str,,
3,3,,,
;0.0 mg/str,,
3,4,,,
;100.0 %,,
4,0,,
4,1,,,
;0 /min,,
4,2,,,
;0.0 °BTDC,,
4,3,,,
;0.0,,
4,4,,,
;8.0 bar,,
5,0,,
5,1,,,
;0 /min,,
5,2,,,
;0.0 mg/str,,
5,3,,,
;1.0,,
5,4,,,
;90.0°C,,
6,0,,
6,1,,,
;0.0 km/h,,
6,2,,,
;00101100,,
6,3,,,
;0.0 km/h,,
6,4,,,
;10000001,,
7,0,,
7,1,,,
;34.2°C,,
7,2,,,
7,3,,,
;30.6°C,,
7,4,,,
;90.0°C,,
8,0,,
8,1,,,
;0 /min,,
8,2,,,
;219.0 Nm,,
8,3,,,
;0.0 Nm,,
8,4,,,
;615.0 Nm,,
9,0,,
9,1,,,
;0 /min,,
9,2,,,
;-1280.0 Nm,,
9,3,,,
;615.0 Nm,,
9,4,,,
;0.0 Nm,,
10,0,,
10,1,,,
;0.0 mg/str,,
10,2,,,
;999.6 mbar,,
10,3,,,
;989.4 mbar,,
10,4,,,
;0.0 %,,
11,0,,
11,1,,,
;0 /min,,
11,2,,,
;1009.8 mbar,,
11,3,,,
;989.4 mbar,,
11,4,,,
;9.8 %,,
12,0,,
12,1,,,
;01010000,,
12,2,,,
;0.00 s,,
12,3,,,
;12.39 V,,
12,4,,,
;90.0°C,,
13,0,,
13,1,,,
;0.00 mg/str,,
13,2,,,
;0.00 mg/str,,
13,3,,,
;0.00 mg/str,,
13,4,,,
;0.00 mg/str,,
15,0,,
15,1,,,
;0 /min,,
15,2,,,
;-150.0 Nm,,
15,3,,,
;0.00 l/h,,
15,4,,,
;219.0 Nm,,
16,0,,
16,1,,,
;0.0 %,,
16,2,,,
;00000001,,
16,3,,,
;0.0,,
16,4,,,
;12.39 V,,
17,0,,
17,1,,,
;0.0,,
17,2,,,
;0.00,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;0 /min,,
18,2,,,
;34.2°C,,
18,3,,,
;0.0,,
18,4,,,
19,0,,
19,1,,,
;0 /min,,
19,2,,,
;290.70,,
19,3,,,
;0.0 bar,,
19,4,,,
20,0,,
20,1,,,
;0 /min,,
20,2,,,
;296.0 bar,,
20,3,,,
;8.0 bar,,
20,4,,,
;7.9 %,,
21,0,,
21,1,,,
;0 /min,,
21,2,,,
;296.0 bar,,
21,3,,,
;8.0 bar,,
21,4,,,
;15.0 %,,
22,0,,
22,1,,,
;0 /min,,
22,2,,,
; 0001000,,
22,3,,,
; 0000000,,
22,4,,,
; 0111000,,
23,0,,
23,1,,,
;0 /min,,
23,2,,,
;0.0 °BTDC,,
23,3,,,
;0.0,,
23,4,,,
;3.0,,
24,0,,
24,1,,,
;0 /min,,
24,2,,,
;0.0 °BTDC,,
24,3,,,
;0.0,,
24,4,,,
;0.0 bar,,
25,0,,
25,1,,,
;0 /min,,
25,2,,,
;0.0 °BTDC,,
25,3,,,
;0.0,,
25,4,,,
;8.0 bar,,
26,0,,
26,1,,,
;0 /min,,
26,2,,,
;0.0 °BTDC,,
26,3,,,
;0.0,,
26,4,,,
;8.0 bar,,
27,0,,
27,1,,,
;0 /min,,
27,2,,,
;0.0 °BTDC,,
27,3,,,
;0.0,,
27,4,,,
;8.0 bar,,
28,0,,
28,1,,,
;0 /min,,
28,2,,,
;0.0 °BTDC,,
28,3,,,
;0.0,,
28,4,,,
;8.0 bar,,
29,0,,
29,1,,,
;0 /min,,
29,2,,,
;0.0 °BTDC,,
29,3,,,
;0.0,,
29,4,,,
;8.0 bar,,
30,0,,
30,1,,,
;0.684 V,,
30,2,,,
;0.380 V,,
30,3,,,
; 0 00  0,,
30,4,,,
;0.0 %,,
31,0,,
31,1,,,
;5B16,,
32,0,,
32,1,,,
;0 /min,,
32,2,,,
;1009.8 mbar,,
32,3,,,
;989.4 mbar,,
32,4,,,
;4.7 %,,
33,0,,
33,1,,,
;0 /min,,
33,2,,,
;198.0°C,,
33,3,,,
;1.00,,
33,4,,,
;1.00,,
34,0,,
34,1,,,
;0 /min,,
34,2,,,
;9.8 %,,
34,3,,,
;14.2 %,,
34,4,,,
;4.7 %,,
35,0,,
35,1,,,
;0 /min,,
35,2,,,
;1100.0 mg/str,,
35,3,,,
;0.0 mg/str,,
35,4,,,
;100.0 %,,
36,0,,
36,1,,,
;0 /min,,
36,2,,,
;100.0 %,,
36,3,,,
;99.4 %,,
36,4,,,
;0.0 %,,
38,0,,
38,1,,,
;0 /min,,
38,2,,,
;100.0 %,,
38,3,,,
;99.4 %,,
38,4,,,
;0.0 %,,
39,0,,
39,1,,,
;0 /min,,
39,2,,,
;0.0 mg/str,,
39,3,,,
;30.6°C,,
39,4,,,
;4.7 %,,
40,0,,
40,1,,,
;0 /min,,
40,2,,,
;100.0 %,,
40,3,,,
;99.4 %,,
40,4,,,
;4.7 %,,
41,0,,
41,1,,,
;12 ohms,,
41,2,,,
;0.000 V,,
41,3,,,
;0.01,,
41,4,,,
;1.0,,
42,0,,
42,1,,,
;0.01,,
42,2,,,
;1.6 %,,
42,3,,,
;3.300 V,,
42,4,,,
;25.40,,
43,0,,
43,1,,,
;0.0,,
43,2,,,
;13.5°C,,
43,3,,,
;00000000,,
43,4,,,
;0.000 V,,
44,0,,
44,1,,,
;0 /min,,
44,2,,,
;11001000,,
44,3,,,
;0.0,,
44,4,,,
;0.0,,
45,0,,
45,1,,,
;90.0°C,,
45,2,,,
;0.0 %,,
45,3,,,
;9.5 %,,
45,4,,,
;0.0 %,,
46,0,,
46,1,,,
;13.5°C,,
46,2,,,
;90.0°C,,
46,3,,,
;29.7°C,,
46,4,,,
;00000001,,
47,0,,
47,1,,,
;94.5°C,,
47,2,,,
;29.7°C,,
47,3,,,
;0.0 %,,
47,4,,,
;9.5 %,,
48,0,,
48,1,,,
;0 /min,,
48,2,,,
;5865 /min,,
48,3,,,
;       1,,
48,4,,,
;1270.0 Nm,,
50,0,,
50,1,,,
;0 /min,,
50,2,,,
;0.0 mg/str,,
50,3,,,
;0.00 mg/str,,
50,4,,,
;      10,,
51,0,,
51,1,,,
;0 /min,,
51,2,,,
;0 /min,,
51,3,,,
;1.0,,
51,4,,,
;0.0°KW,,
52,0,,
52,1,,,
;0 /min,,
52,2,,,
;0xFF02,,
52,3,,,
;0xFF00,,
52,4,,,
;27.0°C,,
53,0,,
53,1,,,
;00000000,,
53,2,,,
;00000000,,
53,3,,,
;00000000,,
53,4,,,
;00000100,,
54,0,,
54,1,,,
;1.0,,
54,2,,,
;1587 /min,,
54,3,,,
;40.9 mg/str,,
54,4,,,
;0.00 mg/str,,
59,0,,
59,1,,,
;0 /min,,
59,2,,,
;-150.0 Nm,,
59,3,,,
;21.0 Nm,,
59,4,,,
;0.0 Nm,,
60,0,,
60,1,,,
;21.0 Nm,,
60,2,,,
;-24.0 Nm,,
60,3,,,
;0.0 Nm,,
60,4,,,
;0.0 %,,
61,0,,
61,1,,,
;0 /min,,
61,2,,,
61,3,,,
61,4,,,
62,0,,
62,1,,,
;0 /min,,
62,2,,,
;0.0 mg/str,,
62,3,,,
;0.0,,
62,4,,,
;0.0,,
63,0,,
63,1,,,
;0 /min,,
63,2,,,
;0 /min,,
63,3,,,
;0 /min,,
63,4,,,
;0 /min,,
64,0,,
64,1,,,
;0.70,,
64,2,,,
;0.83,,
64,3,,,
;1.00,,
64,4,,,
;1.00,,
65,0,,
65,1,,,
;1.00,,
65,2,,,
;1.00,,
65,3,,,
;1.01,,
65,4,,,
;1.06,,
66,0,,
66,1,,,
;994.5 mbar,,
66,2,,,
;969.0 mbar,,
66,3,,,
;0.0,,
66,4,,,
;0.0,,
67,0,,
67,1,,,
;0 /min,,
67,2,,,
;100.0 %,,
67,3,,,
;99.4 %,,
67,4,,,
;0.0 %,,
68,0,,
68,1,,,
;0 /min,,
68,2,,,
;100.0 %,,
68,3,,,
;100.2 %,,
68,4,,,
;0.0 %,,
69,0,,
69,1,,,
;10100010,,
69,2,,,
;00000100,,
69,3,,,
;10100011,,
69,4,,,
;00000100,,
70,0,,
70,1,,,
;10100011,,
70,2,,,
;00000100,,
70,3,,,
70,4,,,
;0.11,,
71,0,,
71,1,,,
;11111111,,
71,2,,,
;00001111,,
71,3,,,
71,4,,,
;0.0,,
72,0,,
72,1,,,
;-1.00,,
72,2,,,
;-2.00,,
72,3,,,
;4.00,,
72,4,,,
73,0,,
73,1,,,
;-3.00,,
73,2,,,
;11.00,,
73,3,,,
;7.00,,
73,4,,,
74,0,,
74,1,,,
;-3.00,,
74,2,,,
;1.00,,
74,3,,,
;-6.00,,
74,4,,,
75,0,,
75,1,,,
;18.00,,
75,2,,,
;11.00,,
75,3,,,
;5.00,,
75,4,,,
78,0,,
78,1,,,
;0 /min,,
78,2,,,
;0.0,,
78,3,,,
;-3 mbar,,
78,4,,,
;100.2 %,,
79,0,,
79,1,,,
;0 /min,,
79,2,,,
;0.0 mg/str,,
79,3,,,
;-3 mbar,,
79,4,,,
;99.4 %,,
80,0,,
80,1,,,
;BPG-810 25.05.08 --H01--- 1334 0048,,
81,0,,
81,1,,,
;3VWPL71K89M272852 VWX7Z0H72491JO        ,,
82,0,,
82,1,,,
;5897644409454 00.00.00 78       79  <>  ,,
85,0,,
85,1,,,
;244040 km,,
85,2,,,
;50,,
85,3,,,
;3081,,
85,4,,,
;6653,,
86,0,,
86,1,,,
;00110010,,
86,2,,,
;10000110,,
86,3,,,
;11100100,,
86,4,,,
;11100100,,
87,0,,
87,1,,,
;11111111,,
87,2,,,
;11111111,,
87,3,,,
;11111111,,
87,4,,,
89,0,,
89,1,,,
;00000000,,
89,2,,,
;00001111,,
89,3,,,
;10000011,,
89,4,,,
;00000000,,
90,0,,
90,1,,,
;0 /min,,
90,2,,,
;0.0 mg/str,,
90,3,,,
;1100.0 mg/str,,
90,4,,,
;00000000,,
91,0,,
91,1,,,
;323.85,,
91,2,,,
;-326.40,,
91,3,,,
;1100.0 mg/str,,
91,4,,,
;323.85,,
93,0,,
93,1,,,
;00000000,,
93,2,,,
;3.97,,
93,3,,,
;0.0,,
93,4,,,
;0.0,,
95,0,,
95,1,,,
;00000000,,
95,2,,,
;00000001,,
95,3,,,
;0.0,,
95,4,,,
96,0,,
96,1,,,
;00000000,,
96,2,,,
;      00,,
96,3,,,
;00000000,,
96,4,,,
;12.39 V,,
97,0,,
97,1,,,
;-3 mbar,,
97,2,,,
;0 mbar,,
97,3,,,
;-3 mbar,,
97,4,,,
;-3 mbar,,
99,0,,
99,1,,,
;0 /min,,
99,2,,,
;192.0°C,,
99,3,,,
;204.0°C,,
99,4,,,
;204.0°C,,
100,0,,
100,1,,,
;204.0°C,,
100,2,,,
;168.0°C,,
100,3,,,
;-3 mbar,,
100,4,,,
;-3 mbar,,
101,0,,
101,1,,,
;0 /min,,
101,2,,,
;0.0,,
101,3,,,
;0.0,,
101,4,,,
;0.0,,
102,0,,
102,1,,,
;00000000,,
102,2,,,
;00000001,,
102,3,,,
;00000000,,
102,4,,,
;00000000,,
103,0,,
103,1,,,
;00000000,,
103,2,,,
;00000000,,
103,3,,,
;00000000,,
103,4,,,
;00000000,,
104,0,,
104,1,,,
;0xFF01,,
104,2,,,
;0xFF10,,
104,3,,,
;00000000,,
104,4,,,
;00000000,,
105,0,,
105,1,,,
;00000000,,
105,2,,,
;3.0,,
105,3,,,
;186.0°C,,
105,4,,,
;0.0,,
107,0,,
107,1,,,
;45.0,,
107,2,,,
;39.9,,
107,3,,,
;18.3,,
107,4,,,
108,0,,
108,1,,,
;159 ml,,
108,2,,,
108,3,,,
108,4,,,
110,0,,
110,1,,,
110,2,,,
;00000110,,
110,3,,,
;0.0 km/h,,
110,4,,,
111,0,,
111,1,,,
;0 /min,,
111,2,,,
;0.0 km/h,,
111,3,,,
;0.00,,
111,4,,,
;0.0,,
112,0,,
112,1,,,
;2.10,,
112,2,,,
;1270.0 Nm,,
112,3,,,
;-1280.0 Nm,,
112,4,,,
;0.0 Nm,,
113,0,,
113,1,,,
;00000110,,
113,2,,,
;0.0,,
113,3,,,
;0.0,,
113,4,,,
;0.0,,
114,0,,
114,1,,,
;255.0,,
114,2,,,
;255.0,,
114,3,,,
;2.10,,
114,4,,,
;0.00,,
115,0,,
115,1,,,
;234.0,,
115,2,,,
;90.0°C,,
115,3,,,
;-276.0°C,,
115,4,,,
;0.0,,
117,0,,
117,1,,,
117,2,,,
;30.6°C,,
117,3,,,
117,4,,,
118,0,,
118,1,,,
;-0.8 %,,
118,2,,,
;00000100,,
118,3,,,
;00000010,,
118,4,,,
;0.988 V,,
119,0,,
119,1,,,
;0.0 %,,
119,2,,,
;0.0 %,,
119,3,,,
;00000100,,
119,4,,,
;4.408 V,,
120,0,,
120,1,,,
;-0.8 %,,
120,2,,,
;0.0 %,,
120,3,,,
;00000000,,
120,4,,,
;3.572 V,,
121,0,,
121,1,,,
;1.6 %,,
121,2,,,
;1.6 %,,
121,3,,,
;00000100,,
121,4,,,
;0.684 V,,
123,0,,
123,1,,,
;0.8 %,,
123,2,,,
;00000100,,
123,3,,,
;00000010,,
123,4,,,
;0.684 V,,
124,0,,
124,1,,,
124,2,,,
124,3,,,
;00000000,,
124,4,,,
125,0,,
125,1,,,
;Transm. 1,,
125,2,,,
;ABS 1,,
125,3,,,
;Instruments 1,,
125,4,,,
;Airbag 1,,
126,0,,
126,1,,,
;HVAC 1,,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
127,4,,,
;St. Wheel 1,,
128,0,,
128,1,,,
;Gateway 1,,
128,2,,,
128,3,,,
128,4,,,
136,0,,
136,1,,,
;20 ohms,,
136,2,,,
;0.000 V,,
136,3,,,
;0.01,,
136,4,,,
;1.0,,
137,0,,
137,1,,,
;0.01,,
137,2,,,
;0.0 %,,
137,3,,,
;3.300 V,,
137,4,,,
;25.40,,
138,0,,
138,1,,,
;0.0,,
138,2,,,
138,3,,,
;00000000,,
138,4,,,
;0.000 V,,
139,0,,
139,1,,,
139,2,,,
;11001000,,
139,3,,,
;0.0,,
139,4,,,
;0.0,,
140,0,,
140,1,,,
;0.0 Nm,,
140,2,,,
;0.0 Nm,,
140,3,,,
;0.0 Nm,,
140,4,,,
;0.0 Nm,,
141,0,,
141,1,,,
;0.0 bar,,
141,2,,,
;0.0 bar,,
141,3,,,
;0.0 bar,,
141,4,,,
;0.0 bar,,
142,0,,
142,1,,,
;0.00,,
142,2,,,
;0.00,,
142,3,,,
;0.00,,
142,4,,,
;0.00,,
143,0,,
143,1,,,
;0.0 °BTDC,,
143,2,,,
;0.0 °BTDC,,
143,3,,,
;0.0 °BTDC,,
143,4,,,
;0.0 °BTDC,,
144,0,,
144,1,,,
;0.0 °BTDC,,
144,2,,,
;0.0 °BTDC,,
144,3,,,
;0.0 °BTDC,,
144,4,,,
;0.0 °BTDC,,
145,0,,
145,1,,,
;0.0 °BTDC,,
145,2,,,
;0.0 °BTDC,,
145,3,,,
;0.0 °BTDC,,
145,4,,,
;0.0 °BTDC,,
146,0,,
146,1,,,
;7.20,,
146,2,,,
;1.60,,
146,3,,,
;13.60,,
146,4,,,
;5.20,,
147,0,,
147,1,,,
;00000000,,
147,2,,,
;00000000,,
147,3,,,
;00000000,,
147,4,,,
;00000000,,
148,0,,
148,1,,,
;00000000,,
148,2,,,
;00000000,,
148,3,,,
;00000000,,
148,4,,,
;00000000,,
149,0,,
149,1,,,
;00000000,,
149,2,,,
;00000000,,
149,3,,,
;00000000,,
149,4,,,
;00000000,,
150,0,,
150,1,,,
;0.06,,
150,2,,,
;0.06,,
150,3,,,
;0.06,,
150,4,,,
;0.03,,
166,0,,
166,1,,,
;0.06,,
166,2,,,
;0.06,,
166,3,,,
;0.06,,
166,4,,,
;0.03,,
214,0,,
214,1,,,
;6.0°C,,
214,2,,,
;6.0°C,,
214,3,,,
;6.0°C,,
214,4,,,
;6.0°C,,
215,0,,
215,1,,,
;84.0°C,,
215,2,,,
215,3,,,
215,4,,,
216,0,,
216,1,,,
;0xFF80,,
216,2,,,
;0xFF10,,
216,3,,,
;0xFF00,,
216,4,,,
;0xFF01,,
217,0,,
217,1,,,
;0.0,,
217,2,,,
;0.0,,
217,3,,,
;0.0,,
217,4,,,
;0.0,,
218,0,,
218,1,,,
;0.0,,
218,2,,,
218,3,,,
218,4,,,
;0.0,,
219,0,,
219,1,,,
;-276.0°C,,
219,2,,,
;-276.0°C,,
219,3,,,
;0.0 km/h,,
219,4,,,
;0.0 km/h,,
220,0,,
220,1,,,
;0.0,,
220,2,,,
220,3,,,
220,4,,,
;0.0,,
225,0,,
225,1,,,
;0.0,,
225,2,,,
;0.0,,
225,3,,,
;0.0,,
225,4,,,
;0.0,,
226,0,,
226,1,,,
;0.0,,
226,2,,,
226,3,,,
;0.0,,
226,4,,,
;0.0,,
227,0,,
227,1,,,
;0.0,,
227,2,,,
;0.0,,
227,3,,,
;0.0,,
227,4,,,
;0.0,,
228,0,,
228,1,,,
;0.0,,
228,2,,,
;0.0,,
228,3,,,
;0.0,,
228,4,,,
;0.0,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,,
229,4,,,
;0.0,,
240,0,,
240,1,,,
240,2,,,
;11.6 l,,
240,3,,,
;160 km,,
240,4,,,
;276.0,,
241,0,,
241,1,,,
;159 ml,,
241,2,,,
;14.1,,
241,3,,,
;5.4,,
241,4,,,
242,0,,
242,1,,,
;0.0,,
242,2,,,
;0 km,,
242,3,,,
;0.0,,
242,4,,,
;0.0,,
243,0,,
243,1,,,
;0.0,,
243,2,,,
243,3,,,
;3.97,,
243,4,,,
;0.0,,
and at idle (after a ten mile drive)
;Thursday,01,October,2015,07:54:44:51928
1,0,,
1,1,,,
;828 /min,,
1,2,,,
;7.7 mg/str,,
1,3,,,
;288.0 bar,,
1,4,,,
;91.8°C,,
2,0,,
2,1,,,
;828 /min,,
2,2,,,
;0.0 %,,
2,3,,,
; 0 01  1,,
2,4,,,
;91.8°C,,
3,0,,
3,1,,,
;828 /min,,
3,2,,,
;260.0 mg/str,,
3,3,,,
;265.0 mg/str,,
3,4,,,
;44.3 %,,
4,0,,
4,1,,,
;828 /min,,
4,2,,,
;4.3 °ATDC,,
4,3,,,
;550.0,,
4,4,,,
;248.0 bar,,
5,0,,
5,1,,,
;828 /min,,
5,2,,,
;15.1 mg/str,,
5,3,,,
;48.0,,
5,4,,,
;91.8°C,,
6,0,,
6,1,,,
;0.0 km/h,,
6,2,,,
;00101100,,
6,3,,,
;0.0 km/h,,
6,4,,,
;10000001,,
7,0,,
7,1,,,
;30.6°C,,
7,2,,,
7,3,,,
;27.0°C,,
7,4,,,
;91.8°C,,
8,0,,
8,1,,,
;828 /min,,
8,2,,,
;0.0 Nm,,
8,3,,,
;186.0 Nm,,
8,4,,,
;105.0 Nm,,
9,0,,
9,1,,,
;828 /min,,
9,2,,,
;-1280.0 Nm,,
9,3,,,
;615.0 Nm,,
9,4,,,
;102.0 Nm,,
10,0,,
10,1,,,
;265.0 mg/str,,
10,2,,,
;999.6 mbar,,
10,3,,,
;999.6 mbar,,
10,4,,,
;0.0 %,,
11,0,,
11,1,,,
;828 /min,,
11,2,,,
;1009.8 mbar,,
11,3,,,
;999.6 mbar,,
11,4,,,
;100.0 %,,
12,0,,
12,1,,,
;11111111,,
12,2,,,
;0.00 s,,
12,3,,,
;14.06 V,,
12,4,,,
;91.8°C,,
13,0,,
13,1,,,
;-0.14 mg/str,,
13,2,,,
;0.14 mg/str,,
13,3,,,
;0.05 mg/str,,
13,4,,,
;-0.09 mg/str,,
15,0,,
15,1,,,
;828 /min,,
15,2,,,
;42.0 Nm,,
15,3,,,
;0.84 l/h,,
15,4,,,
;0.0 Nm,,
16,0,,
16,1,,,
;42.6 %,,
16,2,,,
;00000001,,
16,3,,,
;0.0,,
16,4,,,
;13.98 V,,
17,0,,
17,1,,,
;0.0,,
17,2,,,
;0.00,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;828 /min,,
18,2,,,
;30.6°C,,
18,3,,,
;15.0,,
18,4,,,
19,0,,
19,1,,,
;828 /min,,
19,2,,,
;-15.30,,
19,3,,,
;240.0 bar,,
19,4,,,
20,0,,
20,1,,,
;828 /min,,
20,2,,,
;272.0 bar,,
20,3,,,
;256.0 bar,,
20,4,,,
;17.4 %,,
21,0,,
21,1,,,
;828 /min,,
21,2,,,
;272.0 bar,,
21,3,,,
;248.0 bar,,
21,4,,,
;30.8 %,,
22,0,,
22,1,,,
;828 /min,,
22,2,,,
; 0111000,,
22,3,,,
; 0111000,,
22,4,,,
; 0111000,,
23,0,,
23,1,,,
;828 /min,,
23,2,,,
;4.7 °ATDC,,
23,3,,,
;480.0,,
23,4,,,
;3.0,,
24,0,,
24,1,,,
;828 /min,,
24,2,,,
;2.2 °BTDC,,
24,3,,,
;250.0,,
24,4,,,
;280.0 bar,,
25,0,,
25,1,,,
;828 /min,,
25,2,,,
;11.2 °BTDC,,
25,3,,,
;255.0,,
25,4,,,
;264.0 bar,,
26,0,,
26,1,,,
;828 /min,,
26,2,,,
;0.0 °BTDC,,
26,3,,,
;0.0,,
26,4,,,
;288.0 bar,,
27,0,,
27,1,,,
;828 /min,,
27,2,,,
;0.0 °BTDC,,
27,3,,,
;250.0,,
27,4,,,
;256.0 bar,,
28,0,,
28,1,,,
;828 /min,,
28,2,,,
;0.0 °BTDC,,
28,3,,,
;0.0,,
28,4,,,
;288.0 bar,,
29,0,,
29,1,,,
;828 /min,,
29,2,,,
;0.0 °BTDC,,
29,3,,,
;0.0,,
29,4,,,
;280.0 bar,,
30,0,,
30,1,,,
;0.684 V,,
30,2,,,
;0.380 V,,
30,3,,,
; 0 01  1,,
30,4,,,
;0.0 %,,
31,0,,
31,1,,,
;5B16,,
32,0,,
32,1,,,
;828 /min,,
32,2,,,
;1009.8 mbar,,
32,3,,,
;999.6 mbar,,
32,4,,,
;93.9 %,,
33,0,,
33,1,,,
;828 /min,,
33,2,,,
;222.0°C,,
33,3,,,
;1.00,,
33,4,,,
;1.00,,
34,0,,
34,1,,,
;828 /min,,
34,2,,,
;100.0 %,,
34,3,,,
;99.4 %,,
34,4,,,
;93.9 %,,
35,0,,
35,1,,,
;828 /min,,
35,2,,,
;260.0 mg/str,,
35,3,,,
;255.0 mg/str,,
35,4,,,
;4.7 %,,
36,0,,
36,1,,,
;828 /min,,
36,2,,,
;4.7 %,,
36,3,,,
;4.7 %,,
36,4,,,
;-19.7 %,,
38,0,,
38,1,,,
;828 /min,,
38,2,,,
;45.5 %,,
38,3,,,
;45.8 %,,
38,4,,,
;-19.7 %,,
39,0,,
39,1,,,
;828 /min,,
39,2,,,
;255.0 mg/str,,
39,3,,,
;27.0°C,,
39,4,,,
;4.7 %,,
40,0,,
40,1,,,
;828 /min,,
40,2,,,
;100.0 %,,
40,3,,,
;99.4 %,,
40,4,,,
;4.7 %,,
41,0,,
41,1,,,
;12 ohms,,
41,2,,,
;0.000 V,,
41,3,,,
;0.01,,
41,4,,,
;1.0,,
42,0,,
42,1,,,
;0.12,,
42,2,,,
;37.9 %,,
42,3,,,
;0.975 V,,
42,4,,,
;2.19,,
43,0,,
43,1,,,
;0.0,,
43,2,,,
;13.5°C,,
43,3,,,
;00000001,,
43,4,,,
;0.600 V,,
44,0,,
44,1,,,
;828 /min,,
44,2,,,
;10001000,,
44,3,,,
;0.0,,
44,4,,,
;0.0,,
45,0,,
45,1,,,
;91.8°C,,
45,2,,,
;30.2 %,,
45,3,,,
;33.9 %,,
45,4,,,
;0.0 %,,
46,0,,
46,1,,,
;13.5°C,,
46,2,,,
;91.8°C,,
46,3,,,
;26.1°C,,
46,4,,,
;00000000,,
47,0,,
47,1,,,
;94.5°C,,
47,2,,,
;26.1°C,,
47,3,,,
;0.0 %,,
47,4,,,
;33.9 %,,
48,0,,
48,1,,,
;828 /min,,
48,2,,,
;5865 /min,,
48,3,,,
;       1,,
48,4,,,
;1270.0 Nm,,
50,0,,
50,1,,,
;828 /min,,
50,2,,,
;7.7 mg/str,,
50,3,,,
;0.00 mg/str,,
50,4,,,
;      00,,
51,0,,
51,1,,,
;828 /min,,
51,2,,,
;410 /min,,
51,3,,,
;48.0,,
51,4,,,
;-0.5°KW,,
52,0,,
52,1,,,
;828 /min,,
52,2,,,
;0xFF00,,
52,3,,,
;0xFF00,,
52,4,,,
;27.0°C,,
53,0,,
53,1,,,
;00000000,,
53,2,,,
;00000000,,
53,3,,,
;00000000,,
53,4,,,
;00000100,,
54,0,,
54,1,,,
;1.0,,
54,2,,,
;989 /min,,
54,3,,,
;26.9 mg/str,,
54,4,,,
;0.00 mg/str,,
59,0,,
59,1,,,
;828 /min,,
59,2,,,
;45.0 Nm,,
59,3,,,
;30.0 Nm,,
59,4,,,
;9.0 Nm,,
60,0,,
60,1,,,
;30.0 Nm,,
60,2,,,
;-33.0 Nm,,
60,3,,,
;18.0 Nm,,
60,4,,,
;41.8 %,,
61,0,,
61,1,,,
;828 /min,,
61,2,,,
61,3,,,
61,4,,,
62,0,,
62,1,,,
;828 /min,,
62,2,,,
;7.7 mg/str,,
62,3,,,
;0.0,,
62,4,,,
;0.0,,
63,0,,
63,1,,,
;0 /min,,
63,2,,,
;0 /min,,
63,3,,,
;0 /min,,
63,4,,,
;0 /min,,
64,0,,
64,1,,,
;0.70,,
64,2,,,
;0.83,,
64,3,,,
;1.00,,
64,4,,,
;1.00,,
65,0,,
65,1,,,
;1.00,,
65,2,,,
;1.00,,
65,3,,,
;1.01,,
65,4,,,
;1.06,,
66,0,,
66,1,,,
;1045.5 mbar,,
66,2,,,
;943.5 mbar,,
66,3,,,
;25.5,,
66,4,,,
;40.8,,
67,0,,
67,1,,,
;828 /min,,
67,2,,,
;100.0 %,,
67,3,,,
;99.4 %,,
67,4,,,
;12.6 %,,
68,0,,
68,1,,,
;828 /min,,
68,2,,,
;100.0 %,,
68,3,,,
;99.4 %,,
68,4,,,
;7.1 %,,
69,0,,
69,1,,,
;10100010,,
69,2,,,
;00000100,,
69,3,,,
;10100011,,
69,4,,,
;00000100,,
70,0,,
70,1,,,
;10100011,,
70,2,,,
;00000100,,
70,3,,,
70,4,,,
;0.11,,
71,0,,
71,1,,,
;11111111,,
71,2,,,
;00001111,,
71,3,,,
71,4,,,
;0.0,,
72,0,,
72,1,,,
;-1.00,,
72,2,,,
;-2.00,,
72,3,,,
;4.00,,
72,4,,,
73,0,,
73,1,,,
;-3.00,,
73,2,,,
;11.00,,
73,3,,,
;7.00,,
73,4,,,
74,0,,
74,1,,,
;-3.00,,
74,2,,,
;1.00,,
74,3,,,
;-6.00,,
74,4,,,
75,0,,
75,1,,,
;18.00,,
75,2,,,
;11.00,,
75,3,,,
;5.00,,
75,4,,,
78,0,,
78,1,,,
;828 /min,,
78,2,,,
;25.5,,
78,3,,,
;3 mbar,,
78,4,,,
;99.4 %,,
79,0,,
79,1,,,
;828 /min,,
79,2,,,
;260.0 mg/str,,
79,3,,,
;3 mbar,,
79,4,,,
;99.4 %,,
80,0,,
80,1,,,
81,0,,
81,1,,,
82,0,,
82,1,,,
85,0,,
85,1,,,
;244040 km,,
85,2,,,
;50,,
85,3,,,
;3081,,
85,4,,,
;6653,,
86,0,,
86,1,,,
;11111111,,
86,2,,,
;10000110,,
86,3,,,
;11111111,,
86,4,,,
;11111111,,
87,0,,
87,1,,,
;11111111,,
87,2,,,
;11111111,,
87,3,,,
;11111111,,
87,4,,,
89,0,,
89,1,,,
;00000000,,
89,2,,,
;00001111,,
89,3,,,
;10000011,,
89,4,,,
;00000000,,
90,0,,
90,1,,,
;828 /min,,
90,2,,,
;7.7 mg/str,,
90,3,,,
;260.0 mg/str,,
90,4,,,
;00000001,,
91,0,,
91,1,,,
;79.05,,
91,2,,,
;-91.80,,
91,3,,,
;260.0 mg/str,,
91,4,,,
;2.55,,
93,0,,
93,1,,,
;00000000,,
93,2,,,
;1.59,,
93,3,,,
;25.5,,
93,4,,,
;40.8,,
95,0,,
95,1,,,
;00000000,,
95,2,,,
;00000001,,
95,3,,,
;2.0,,
95,4,,,
96,0,,
96,1,,,
;00000000,,
96,2,,,
;      00,,
96,3,,,
;00000001,,
96,4,,,
;13.98 V,,
97,0,,
97,1,,,
;-3 mbar,,
97,2,,,
;0 mbar,,
97,3,,,
;-3 mbar,,
97,4,,,
;-3 mbar,,
99,0,,
99,1,,,
;828 /min,,
99,2,,,
;222.0°C,,
99,3,,,
;210.0°C,,
99,4,,,
;222.0°C,,
100,0,,
100,1,,,
;222.0°C,,
100,2,,,
;228.0°C,,
100,3,,,
;5 mbar,,
100,4,,,
;-3 mbar,,
101,0,,
101,1,,,
;828 /min,,
101,2,,,
;0.0,,
101,3,,,
;0.0,,
101,4,,,
;0.0,,
102,0,,
102,1,,,
;00000000,,
102,2,,,
;00000001,,
102,3,,,
;00000000,,
102,4,,,
;00000000,,
103,0,,
103,1,,,
;00000000,,
103,2,,,
;00000000,,
103,3,,,
;00000000,,
103,4,,,
;00000000,,
104,0,,
104,1,,,
;0xFF01,,
104,2,,,
;0xFF21,,
104,3,,,
;00000000,,
104,4,,,
;00000000,,
105,0,,
105,1,,,
;00000001,,
105,2,,,
;3.0,,
105,3,,,
;228.0°C,,
105,4,,,
;35.7,,
107,0,,
107,1,,,
;45.0,,
107,2,,,
;39.9,,
107,3,,,
;18.3,,
107,4,,,
108,0,,
108,1,,,
;159 ml,,
108,2,,,
108,3,,,
108,4,,,
110,0,,
110,1,,,
110,2,,,
;00000110,,
110,3,,,
;0.0 km/h,,
110,4,,,
111,0,,
111,1,,,
;828 /min,,
111,2,,,
;0.0 km/h,,
111,3,,,
;0.00,,
111,4,,,
;0.0,,
112,0,,
112,1,,,
;2.10,,
112,2,,,
;-460.0 Nm,,
112,3,,,
;-1280.0 Nm,,
112,4,,,
;0.0 Nm,,
113,0,,
113,1,,,
;00000110,,
113,2,,,
;0.0,,
113,3,,,
;0.0,,
113,4,,,
;0.0,,
114,0,,
114,1,,,
;255.0,,
114,2,,,
;255.0,,
114,3,,,
;2.10,,
114,4,,,
;0.00,,
115,0,,
115,1,,,
;254.0,,
115,2,,,
;90.0°C,,
115,3,,,
;114.0°C,,
115,4,,,
;0.0,,
117,0,,
117,1,,,
117,2,,,
;27.0°C,,
117,3,,,
117,4,,,
118,0,,
118,1,,,
;-0.8 %,,
118,2,,,
;01010110,,
118,3,,,
;00000010,,
118,4,,,
;0.988 V,,
119,0,,
119,1,,,
;0.0 %,,
119,2,,,
;0.0 %,,
119,3,,,
;00000100,,
119,4,,,
;4.332 V,,
120,0,,
120,1,,,
;-1.6 %,,
120,2,,,
;0.8 %,,
120,3,,,
;01110110,,
120,4,,,
;0.760 V,,
121,0,,
121,1,,,
;1.6 %,,
121,2,,,
;1.6 %,,
121,3,,,
;00000100,,
121,4,,,
;4.104 V,,
123,0,,
123,1,,,
;0.8 %,,
123,2,,,
;00000100,,
123,3,,,
;00000010,,
123,4,,,
;2.660 V,,
124,0,,
124,1,,,
124,2,,,
124,3,,,
;00000000,,
124,4,,,
125,0,,
125,1,,,
;Transm. 1,,
125,2,,,
;ABS 1,,
125,3,,,
;Instruments 1,,
125,4,,,
;Airbag 1,,
126,0,,
126,1,,,
;HVAC 1,,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
127,4,,,
;St. Wheel 1,,
128,0,,
128,1,,,
;Gateway 1,,
128,2,,,
128,3,,,
128,4,,,
136,0,,
136,1,,,
;20 ohms,,
136,2,,,
;0.000 V,,
136,3,,,
;0.01,,
136,4,,,
;1.0,,
137,0,,
137,1,,,
;0.12,,
137,2,,,
;37.9 %,,
137,3,,,
;0.975 V,,
137,4,,,
;2.19,,
138,0,,
138,1,,,
;0.0,,
138,2,,,
138,3,,,
;00000001,,
138,4,,,
;0.600 V,,
139,0,,
139,1,,,
139,2,,,
;10001000,,
139,3,,,
;0.0,,
139,4,,,
;0.0,,
140,0,,
140,1,,,
;42.0 Nm,,
140,2,,,
;45.0 Nm,,
140,3,,,
;45.0 Nm,,
140,4,,,
;42.0 Nm,,
141,0,,
141,1,,,
;42.0 bar,,
141,2,,,
;42.0 bar,,
141,3,,,
;42.0 bar,,
141,4,,,
;42.0 bar,,
142,0,,
142,1,,,
;0.20,,
142,2,,,
;-0.70,,
142,3,,,
;0.00,,
142,4,,,
;-0.40,,
143,0,,
143,1,,,
;14.4 °ATDC,,
143,2,,,
;14.4 °ATDC,,
143,3,,,
;14.4 °ATDC,,
143,4,,,
;14.0 °ATDC,,
144,0,,
144,1,,,
;0.0 °BTDC,,
144,2,,,
;0.0 °BTDC,,
144,3,,,
;0.0 °BTDC,,
144,4,,,
;0.0 °BTDC,,
145,0,,
145,1,,,
;0.9 °BTDC,,
145,2,,,
;0.9 °BTDC,,
145,3,,,
;0.9 °BTDC,,
145,4,,,
;0.9 °BTDC,,
146,0,,
146,1,,,
;7.20,,
146,2,,,
;1.60,,
146,3,,,
;13.60,,
146,4,,,
;5.20,,
147,0,,
147,1,,,
;00000000,,
147,2,,,
;00000000,,
147,3,,,
;00000000,,
147,4,,,
;00000000,,
148,0,,
148,1,,,
;00000000,,
148,2,,,
;00000000,,
148,3,,,
;00000000,,
148,4,,,
;00000000,,
149,0,,
149,1,,,
;00000000,,
149,2,,,
;00000000,,
149,3,,,
;00000000,,
149,4,,,
;00000000,,
150,0,,
150,1,,,
;0.06,,
150,2,,,
;0.06,,
150,3,,,
;0.06,,
150,4,,,
;0.03,,
166,0,,
166,1,,,
;0.06,,
166,2,,,
;0.06,,
166,3,,,
;0.06,,
166,4,,,
;0.03,,
214,0,,
214,1,,,
;246.0°C,,
214,2,,,
;192.0°C,,
214,3,,,
;222.0°C,,
214,4,,,
;204.0°C,,
215,0,,
215,1,,,
;90.0°C,,
215,2,,,
215,3,,,
215,4,,,
216,0,,
216,1,,,
;0xFF00,,
216,2,,,
;0xFF21,,
216,3,,,
;0xFF00,,
216,4,,,
;0xFF01,,
217,0,,
217,1,,,
;0.0,,
217,2,,,
;0.0,,
217,3,,,
;0.0,,
217,4,,,
;0.0,,
218,0,,
218,1,,,
;0.0,,
218,2,,,
218,3,,,
218,4,,,
;0.0,,
219,0,,
219,1,,,
;-276.0°C,,
219,2,,,
;-276.0°C,,
219,3,,,
;0.0 km/h,,
219,4,,,
;0.0 km/h,,
220,0,,
220,1,,,
;0.0,,
220,2,,,
220,3,,,
220,4,,,
;0.0,,
225,0,,
225,1,,,
;0.0,,
225,2,,,
;0.0,,
225,3,,,
;0.0,,
225,4,,,
;0.0,,
226,0,,
226,1,,,
;0.0,,
226,2,,,
226,3,,,
;0.0,,
226,4,,,
;0.0,,
227,0,,
227,1,,,
;0.0,,
227,2,,,
;0.0,,
227,3,,,
;0.0,,
227,4,,,
;0.0,,
228,0,,
228,1,,,
;0.0,,
228,2,,,
;0.0,,
228,3,,,
;0.0,,
228,4,,,
;0.0,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,,
229,4,,,
;0.0,,
240,0,,
240,1,,,
240,2,,,
;11.6 l,,
240,3,,,
;160 km,,
240,4,,,
;264.0,,
241,0,,
241,1,,,
;159 ml,,
241,2,,,
;14.1,,
241,3,,,
;5.4,,
241,4,,,
242,0,,
242,1,,,
;0.0,,
242,2,,,
;0 km,,
242,3,,,
;0.0,,
242,4,,,
;0.0,,
243,0,,
243,1,,,
;0.0,,
243,2,,,
243,3,,,
;3.97,,
243,4,,,
;0.0,,
and here is a recent auto-scan.
Monday,21,September,2015,16:16:10:51928
VCDS Version: 15.7.1.0 (x64)
VIN: 3VWPL71K89M272852   License Plate:
Mileage: 243670km-151409mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
          75
VIN: 3VWPL71K89M272852   Mileage: 243670km-151409miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: --H01---    Serial number: VWX7Z0H72491JO
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
   Component: GSG DSG         082 1402
   Revision: 05108020    Serial number: 00001009261684
   Shop #: WSC 04940 001 00001
   VCID: 130B6CE332BF50A6F0-8046
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B600D492900FC881306E9921B0042B100
   VCID: 75CF327BDC0BEE967E-8020
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CD9275F3F21BFDE01-8028
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001014370
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 3245C967ADE5B9AE9B-8066
   Component: Wischer 230808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0382262
   Coding: 0000100
   VCID: 334BCC6352FFB0A690-8066
   Component: 78 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06G1H$
   Coding: 0014136
   VCID: 6CF9171F4F412F5E91-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3B0044340
   Subsystem 3 - Serial number: 6342MSME3E307878M
   Subsystem 4 - Serial number: 6351HSME174A4C71D
   Subsystem 5 - Serial number: 6361HSME175F5826H
   Subsystem 6 - Serial number: 63727SME16701603R
   Subsystem 7 - Serial number: 63827SME16701021M
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010042
   VCID: 032B5CA342DFC02640-8056
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H72491JO
   Coding: 0007203
   VCID: 3957FE4B70934AF65A-806C
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 020708F1000751
   Coding: ED807F072013022002
   VCID: 354FF27B5C8BAE96BE-8060
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T2EKX03
   VCID: 7DDF2A5B243BB6D636-8028
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000532488807
   Coding: 0001205
   VCID: 6FC300137E57D446B4-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A75D1078535F16E23-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 139007885283281B0904058FB0880F0488DC00
   VCID: 04295FBF47D1C71E79-8050
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 187
                    Mileage: 205700 km
                    Time: 13:05:22
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000552988807
   Coding: 0001204
   VCID: 70C1036F6369CBBEAD-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Status: 00101100
                    Reset counter: 59
                    Fault Status: 00111000
                    Reset counter: 59
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2224675
   Coding: 0010400
   VCID: 29772E0B8033FA762A-807C
            000 -  -
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003360131
   Coding: 0001168
   VCID: 76CD3577010DE58E77-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003383939
   Coding: 0001168
   VCID: 77D3387306079C866C-8022
Address 75: Telematics
End-------------------------(Elapsed Time: 01:30)--------------------------
