MMI Intermittent no sound
JoolsP
C?ID=295482
Firstly an apology, this is my first post and its long as I want to tell you my fault finding methedology.
I have been chasing an intermittent fault on my MMI for several months now.
The car is an Audi RS4 B9 (2018) with 86,000 miles on it.
The MMI is a navigation plus (I8H) with Bang & Olufsen which I connect my iPhone to via the USB cable in the front panel.
The fault started out as the radio (DAB) taking several seconds (45 plus) to come on to station, previously
it was as soon as the car started (occasionally it still does).
Several weeks later this morphed into the whole MMI booting up as normal and then after a while switching itself off
(no MMI button controls, volume etc from the central console or steering wheel), only to start rebooting again and again
numerous times until it finally gives up and swithces itself off.
Other times it boots up and works perfectly until you stop the car to fuel up for example and then it will start the
reboot cycle as above and refuse to work.
After scanning the car and tracing the MOST optical loop its as follows:
Information electronics control unit 1 (J794), to Control unit in instrument cluster (J285),
to Digital sound package control unit (J525), back around to Information electronics control unit 1 (J794)
First scan results
Date: 19/03/23
Address 5F: Information Electr. (J794)
6672 - Optical Data Bus for Display in Instruments
U10CF 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in instrument cluster display]
Reset counter: 250
Mileage: 111064 km
Date: 2023.02.19
Time: 14:37:31
Voltage terminal 30: 13.1 V
Temperature of MOST transceiver-max.value: -50 �C
Temperature of MOST transceiver-min.value: -11 �C
Temperature of MOST transceiver-Up-to-date: 31 �C
Before anyone says, yes I have tried the Optical Bus Diagnostic and it reports that it isn't available!
I assume this is because the CAN Gateway doesn't have a MOST optical connector in it.
I hav elso pulled out and looked at all the MOST connectors and there is a red light present on all of them.
I have removed, stripped and checked both the J794 & J285 for dry joints, corrosion etc, with nothing found.
These parts are not cheap to buy, even second hand just to test a theory, plus the CP will kick in I'm sure.
So I opted for the cheapest route and started with the optical cables looking for kinks that might be causing data loss.
One at a time I unplugged the original optical cables and replaced them with run around cables.
This didn't cure the fault, so its not an optical cable fault, its down to a module.
Next I optically looped out the instrument cluster.
It then reported the instrument cluster lost communication, which makes sense and now sporadic open circuit with the digital sound package module.
So the Information control unit now thinks the digital sound package module is faulty.
Next I reconnected the instrument cluster and looped out the digital sound package module.
This then reported sporadic open circuit with the instrument cluster again and lost communication with the digital sound package module.
So depending on which of either instrument or sound modules you have looped in, the optical loop says its sporadic open circuit.
These results leads me to thinking the likelyhood of both instrument and sound modules having the same fault is less likely than the
information electronics control unit actually being faulty.
I would welcome any ideas / comments on your views.
Sunday,17,December,2023,15:08:06:51684
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WUAZZZF44JA902709   License Plate: YY18WCA
Mileage: 134212km-83395mi   Repair Order:
Chassis Type: F4-AU49 (8W7)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 32 36 39 3C 42 44 46 47 52
          5F 65 6C 6D 74 81 82 A5 A9 BB BC CA CF D6 D7
VIN: WUAZZZF44JA902709   Mileage: 134212km-83395miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DECA)       Labels: Redir Fail!
   Part No SW: 8W0 907 551     HW: 06M 907 309 H
   Component: V6 2.9l TFSI  H11 0006
   Revision: B9H11000    CVN: 00FF8E55
   Coding: 122A00322526050B34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM29TFS0118W0907551 001008
   ROD: EV_ECM29TFS0118W0907551.rod
   VCID: 7AAEF8849C53C79A617-802E
   VINID: 9E546AAAA58411A4490021C0245282F441
   Part No SW: 8W0 927 158 K    HW: 0D5 927 156 H
   Component: 0D5  29TSIRdW H05 1002
   Revision: --H05---    CVN: FC930205
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002013
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 4ACE68448C33971AB17-801E
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 AA    HW: 8W0 907 379 AA
   Component: ESP9 Premium  H13 0200
   CVN: ACAD0D7A
   Coding: 50AA6C9930A2AA9811A5489142861292E6A5DA0A360C55881242484967A55B
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 0452867CEE97816A0BB-8050
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 2608080D5544050D02020100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D2467CAE17416A4BB-8010
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002306178
   Humidity sensor: exterior:
   Serial number: 1B70522900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 8W0909514L  0048
   Coding: 07501143C13900CD050D51195BAF8CF9110B31040000000000000000200016810A450222025705
   Shop #: WSC 06325 790 00001
   VCID: 025E8064F4838F5A397-8056
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 180228  043 0813
   Serial number: 89425300301805901562
   Coding: 5BC7F7
   Serial number: 21330288X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 08 12 2017  01207879
   Serial number: GX1CE105021823810510
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 CN    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00549018
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000004091001
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0036
   Serial number: 7008174235B181329852
   Coding: BF0500
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0036
   Serial number: 7008174235B181329265
   Coding: B30500
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 H    HW: 8W0 959 655 H
   Component: Airbag10.44   H04 0107
   Serial number: 003UR000EVT5 Dataset Number: 8W0909602AH 0007
   Coding: AACCF0C000800000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 4EC66454705BBB3AEDF-801A
   Subsystem 1 - Part No SW: -----------    HW: 442 061 004 18
   Serial number: 3577Y00AF26ADCC2F52V
   Subsystem 2 - Part No SW: -----------    HW: 442 061 004 18
   Serial number: 3587Y00B726ADCC173BN
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 004 18
   Serial number: 3517700B52A9BC95432K
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 004 18
   Serial number: 3527700BF2AF57F4041R
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 103 18
   Serial number: 3557500B9295E555427H
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 103 18
   Serial number: 3567500B9295E552946L
   Part No SW: 4M0 907 129 KS    HW: 4M0 907 129 KS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 0B40AD40C3C9CE124A1-805E
Address 17: Instruments
   Part No SW: 8W7 907 468 F    HW: 8W7 907 468 E
   Component: Gateway       H42 0123
   Revision: 7C000001    Serial number: 0187C823318414 Dataset Number: 8W0909515J  0059
   Coding: 03010001000086405407000000590012E8980007900000000175078E10000000
   GVL: 01583C580800020040DC08000002C800110C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180411121146 20913
   Serial number: 6664487304
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout_Node_0x73_DiagAdress_5F_ZR_High]
                    Reset counter: 176
                    Mileage: 133882 km
                    Date: 2023.12.09
                    Time: 12:28:17
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0024
   Dataset Number: 8W0909519B  0010
   VCID: 79ACE7889955CC8268D-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000121309015
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323E10A404A3FFDAE97-8066
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605814521200907
   Coding: 0003
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22_AU49.rod
   Component: MEM-FS        009 0042
   Serial number: 00000312374790 Dataset Number: 8W0909856C  0009
   Coding: 00781B000000B0010000010101010000000000000000000000000000000000
   Dataset Number: 8W0909520B  0010
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 8W0909535C  0020
   Coding: 4C8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 36362CB4E8CBE3FAC5F-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000315859110  Dataset Number: 8W0909872F  0030
   Coding: 005D8A215E010000000110B2
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 43D04560AB194652721-8016
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Dataset Number: 8W0909852R  0041
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DE4064B4034F5A797-8016
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Dataset Number: 8W0909501J  0052
   Coding: 013500002FB100406309A0006E00080233004010804306502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 015C8F68F185944220D-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY180743EV2
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099646613
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: 12005980
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 179
                    Reset counter: 180
                    Mileage: 133550 km
                    Date: 2023.12.02
                    Time: 11:53:11
                    Supply voltages-Terminal 30 power supply: 11.740 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 11.767 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.712 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 �C
                    general_additional_freeze_frame-interior_temperature: -50.0 �C
                    general_additional_freeze_frame-terminal_control_intern_status: 40 00 5B 12 04 98
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAJJA0440S/ Dataset Number: 8W0909510F  0018
   Coding: 0194020800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 76B6ECB4A84BA3FA05F-8022
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000316301370  Dataset Number: 8W0909873F  0030
   Coding: 005D8A215E010000000110B0
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035 C    HW: 8W5 035 035
   Component: MU-P-LND-EU   034 1329
   Serial number: A829D0JB065237 Dataset Number: 8W0909545VM 0004
   Coding: 019462010000000053111102000A00332F000BE701700100DE
   VCID: 372821B0EFC11AF2DE9-8062
   Subsystem 1 - Part No SW: V03 959 802 TL    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00114111700820328
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK121031800040304
   Compact disc data bank:
   Component: Gracenote2  --- 1016
3073 - Cellular Antenna
          B1053 13 [00001000] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 176
                    Voltage terminal 30: 12.4 V
3084 - GSM antenna 2
          B1533 13 [00001000] - Open Circuit
                    Reset counter: 176
2565 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 176
          U10CF 00 [00001000] - Intermittent Disruption
                    Fault Frequency: 20
                    Reset counter: 179
                    Mileage: 133552 km
                    Date: 2023.12.04
                    Time: 12:46:54
                    Voltage terminal 30: 15.2 V
                    Temperature of MOST transceiver-Up-to-date: 8 �C
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 30000000017278 Dataset Number: 8WA909850A  0002
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F3819D01791D232869-807A
   Component: RVC Compact   H12 0250
   Dataset Number: 8W0909460B  0010
   Coding: 0294020102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 333015A0FBB9F6D2E21-8066
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31891577200000 Dataset Number: 8W0909541C  0016
   Coding: 0570
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 Q    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H37 1251
   Serial number: 1104180467  Dataset Number: 8W0909576M  0001
   Coding: 146040415A
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 55F48B38558DC8E22C5-8000
   Part No SW: 8W2 713 041 F    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18030546287297
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
   Component: HeadUpDisplay H18 1640
   Coding: 2A01D0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 48CA524C923F650AA73-801C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Dataset Number: 8W0909466F  0035
   Coding: 0404090200000403024023A2A50000FC00F0C020C280
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 3C223E9CD6E739AA33B-8068
   Part No SW: 8W0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0010
   Serial number: 180208204737
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000315607167  Dataset Number: 8W0909897F  0030
   Coding: 000D882000010000000010A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 45D45B78A52D78625C5-8010
   Component: TSG HBFS      005 0129
   Serial number: 0000315608643  Dataset Number: 8W0909896F  0030
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 8W0909469D  0009
   Coding: 5A8000049202
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A2E3884DCD3079A217-806E
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 4C8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   Part No SW: 7PP 941 571 BC    HW: 7PP 941 571 B
   Dataset Number: 8W0909471C  0008
   VCID: 1768C1308F013AF2FE9-8042
   Dataset Number: 8W0909472C  0008
End----(Elapsed Time: 02:24, VBatt start/end: 12.3V/11.9V. VIgn 11.9V)-----
I think and it sounds like you have done all that you could do ; the Component Protection certainly limits you diagnosis. Any water damage history?
Address 17: Instruments seems to be a Red flag! And this fault in Address 19 as well:
I suppose you could remove and disconnect and inspect (all in sight!) the instrument cluster harness(es) as there may be a loose or corroded connection (???). Other than that, this all may be a mute point as even if you determine a bad component, it would be a dealer visit to correct or adapt it.
Edit: see if you can get a Auto-Scan when the MMI is up and running (when car is running) and see if any of those faults go away; especially the "no coms" .
