Hi. VCDS reports Oil Sensor P0196 & P0198. (Pls ignore the AC codes, 15048 - Coolant Fan Control Circuit 1. The coolant fan is controlled by a signal generator and a manual toggle switch. Also, please ignore 590082 - Control Circuit for A/C Compressor. That's operated by 12v toggle switch).
Question: I assume the oil thermal temp sensor is the device located on the bottom of the oil pan. Car runs great, oil sump is full.
What is the torque spec for the nuts?
The Excel log reports: G439 Loc. IDE04937 Sensor for engine block temperature: raw value °C -48
How can the engine block = -48 C? I'm in the SW USA.
Thank you very much for your assistance.
End----------(Elapsed Time: 01:04, VBatt start/end: 12.1V/12.1V)-----------
[/CODE]
Friday,23,February,2024,13:51:28:37990
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VW217AU3FM073477 License Plate:
Mileage: 159821km-99308mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VW217AU3FM073477 Mileage: 159821km-99308miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 5GM 906 264 HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13--- CVN: C3146E6B
Coding: 091A00122424002F0000
Shop #: WSC 48004 001 1048576
ASAM Dataset: EV_ECM18TFS0205GM906264 001001
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 04519D43AE92594A0BB-8050
VINID: 0E69C20474650D67401C31071CEF54C609
P0480 00 [00101000] - Electrical Malfunction
Fault Frequency: 28
Mileage: 157135 km
Date: 2023.12.06
Time: 10:38:52
Engine RPM: 1638.25 /min
Normed load value: 43.1 %
Vehicle speed: 88 km/h
Coolant temperature: 98 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.632 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 371 s
MAP_MES_SAE: 92 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.085 V
FAC_TPS_1_SAE: 25.781250 %
FUP_H_SAE: 14960.0 kPa
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [00101111] - Signal too High
Mileage: 159811 km
Date: 2024.02.22
Time: 12:23:27
Engine RPM: 1486.75 /min
Normed load value: 43.5 %
Vehicle speed: 64 km/h
Coolant temperature: 91 °C
Intake air temperature: 37 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 13.710 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 60 s
MAP_MES_SAE: 89 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
FAC_TPS_1_SAE: 23.437500 %
FUP_H_SAE: 14930.0 kPa
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [00101111] - Implausible Signal
Mileage: 159810 km
Date: 2024.02.22
Time: 12:22:58
Engine RPM: 922.25 /min
Vehicle speed: 13 km/h
Coolant temperature: 84 °C
Intake air temperature: 46 °C
Voltage terminal 30: 13.867 V
Engine: operating status: PU
STATE_LS_SAE[1]: CL
T_AST_SAE: 30 s
MAP_MES_SAE: 27 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.026 V
FAC_TPS_1_SAE: 12.890625 %
FUP_H_SAE: 3700.0 kPa
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 D HW: 09G 927 749 D
Component: AISIN AG6 G3 129 2866
CVN: A3B683DE
Coding: 010200000C000000000000000000000000000000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW37.rod
VCID: 3A2D23BB9CD6DFBA217-806E
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53634000000964
Coding: 01FA6AA12427096F007B020781CA298056249000408194B400430050C002
Shop #: WSC 01383 790 50316
VCID: 47CB4A4FDF24B252AE9-8012
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 F HW: 5GM 907 426 F
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 01020004200000010004000000101000
Shop #: WSC 09550 758 180955
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4BC3767FC34C56328A1-801E
B10A9 15 [00001001] - Open or Short to Plus
Reset counter: 170
Mileage: 155384 km
Date: 2023.09.28
Time: 12:55:50
Outside temperature: 27.0 °C
Engine RPM: 1300 /min
Compressor shut-off condition: AC button off
Compressor current: specified value: 0.000 A
524545 - AC Compressor First Run-In
B109E F0 [00001001] - Not Performed
Reset counter: 170
Mileage: 155384 km
Date: 2023.09.28
Time: 10:26:40
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 087 Q HW: 5Q0 937 087 Q
Revision: -------- Serial number: 86581601151178 Dataset Number: 5GM063v____ 0050
Coding: 000018424041804169E44000000403001000000000000000000000000000
Shop #: WSC 00066 790 00254
ROD: EV_BCMBOSCH_014.rod
VCID: 49CF4C77C9304422B8D-801C
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141201 043 0581
Serial number: 150213055914
B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 156
Reset counter: 118
Mileage: 155388 km
Date: 2023.09.29
Time: 05:01:27
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.3 V
Outside temperature: 26.5 °C
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01SF1N Dataset Number: 5GM003V____ 0031
VCID: 51FF641721607CE2F0D-8004
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029P720U
Coding: 303138
Subsystem 2 - Part No SW: ----------- HW: 480 000 912 14
Serial number: 35700000000C5B38321H
Subsystem 3 - Part No SW: ----------- HW: 480 000 612 14
Serial number: 358000000001D0650211
Subsystem 4 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 3510002BB188FC11C18E
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 35200029D188FC1291FK
Subsystem 6 - Part No SW: ----------- HW: 480 402 511 14
Serial number: 3550002B9188FC23237A
Subsystem 7 - Part No SW: ----------- HW: 480 402 511 14
Component: FrontSensor_P 001 6149
Serial number: 3560002B9188FC2353AH
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150103500704
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDB52AF87F4FA92169-806A
Part No SW: 5G1 920 840 HW: 5G1 920 840
Component: KOMBI 243 4270
Coding: 0BB4190A2180CF05020868001000000000000000
VCID: 6491BDC34ED2F94AABB-8030
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 21011510000699 Dataset Number: 5G0067v____ 2011
Coding: 0101000820085900EF0000081C0F00000001050000000000000000000000
GVL: 01503C0000000000400C00008000C80000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 71BFC49781205CE2D0D-8024
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 27150000069210055046
Coding: 29FFFF
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 08011506050366 Dataset Number: V03935206HY 0006
Coding: 003003200000040000000000
VCID: 3E252FAB80FEF39A1DF-806A
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000353065
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Dataset Number: 5GM074V____ 0515
Coding: 0102
VCID: 43D35E5FEB1C9E72721-8016
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 240115060509PM Dataset Number: V03935206HZ 0006
VCID: 3D2728A78DF8E882045-8068
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000537640
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00301153198 Dataset Number: V03935238XP 0001
Coding: 02730000FF00000021220001001800001F0100040100010002
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS5016FG
Reset counter: 170
Mileage: 155384 km
Date: 2023.09.28
Time: 10:31:26
Voltage terminal 30: 12.1 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Dataset Number: 561098V____ 0403
Coding: 02730002C2821A017F1E06000000
Shop #: WSC 00066 790 07177
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.2V)-----------
[/CODE]
