Skoda Octavia 1.4 TFSI 2014 Reg - first time VCDS user - some fault codes
suravakonda
C?ID=573487
Hello all,
Having fed up with expensive black box diagnosis by multiple garages who fixed a few problems with no real progress (as the engine light keeps coming back), I finally found the VCDS via social media while searching frantically for a solution...what can I say...last few days of owning the Hex-V2 kit is an entire new world. I now know exactly what faults are bugging my beloved car (car details on the subject line).
I did some research on mapping the faults on my car with previous posts and here's the fault summary. I would be grateful if any of you can suggest what other tests that I could do to drill down further to fix these issues.
My questions / observations in last few days are marked with ****
Wednesday,21,February,2024,13:36:23:09468
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: #### Mileage: 81924km-50905miles
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
4116 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [01101000] - Signal too High (Rich)
Fault Frequency: 1 **** This happened only once. Should I monitor it?
Mileage: 81629 km
Date: 2024.02.10 **** O2 Sensor B1 S1 replaced with a new one in October 2023 by garage. They had claimed that a O2 B1 S1 fault had come up. I didn't know anything then so I just went ahead with their suggestion.
Time: 11:14:30
Engine RPM: 2154.00 /min
Normed load value: 35.7 %
Vehicle speed: 112 km/h
Coolant temperature: 94 C
Intake air temperature: 33 C
Voltage terminal 30: 14.795 V
Oxygen sensor B1: sensor 1: specified value: 1.0000
Oxygen Sensor 1 Bank 1 Quick Offset Adaptation Counter: 82
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
**** Happened only once on 24/10/2023. Any reason why that would be please? Should I monitor? / Ignore? / get it repaired? ****
0297 - Steering angle sensor
B1168 16 [00001000] - Voltage Too Low
Reset counter: 235
Mileage: 80196 km
Date: 2023.10.24
Time: 00:01:31
***** resolved by resetting tyre pressure after re-inflating tyres. I guess I can safely erase this? But I can't erase selective faults as I understood
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 41
Mileage: 81251 km
Date: 2024.01.13
Time: 17:17:12
**** Last occurred on 23/11/2023. I saw from from forums this could be fuel tank flap actuator fault.
**** I see the fault stopped occurring after 11/2023. Could this be due to us not closing the fuel flap correctly after a specific re-fuel and then fixing it unintentionally maybe after a month or so?
**** Probably due to this, I see reset counter is going down continuously and as I understood once it reaches zero, the fault would get erased by itself?
B1263 01 [00001001] - Electrical Failure
Fault Frequency: 38
Reset counter: 9
Mileage: 80500 km
Date: 2023.11.23
Time: 13:25:37
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: g ltiges Funktelegramm
Voltage: 12.2 V
Outside temperature: 13.5 C
***** old error regarding key battery - replaced and good now since Sep 2022. My question is why did garages leave the fault without erasing it?
***** Any idea why reset counter is not coming down? And looking at Sep 2022 date, it seems none of the faults have been cleared by garages since 2022, even though they claimed they fixed them?
***** I was a novice all these days, only now understanding these, hence so many questions. I hope it's okay.
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 95
Mileage: 73568 km
Date: 2022.09.25
Time: 18:03:06
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
Outside temperature: 17.0 C
***** selector / shifter mechanism. Happened once. Should I still replace the selector module for single fault occurence?
617752 - Selector Lever Park Position Lock Switch
B1162 29 [00011000] - Signal Implausible
Reset counter: 58
Mileage: 81858 km
Date: 2024.02.19
Time: 15:36:57
Operating time: 107007 min
Terminal 30 power supply: 14.9 V
Vehicle speed: 18 km/h
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
**** I have no idea why the below fault could happen. Should I run more tests? I see below URL talks about J500 module, but mine is J533? Is the same fault from these two modules different
131602 - Power Steering Control Module
U101D 00 [00001000] - No Communication
[Timeout Knoten 0x12 / 44 - Steuerger t f r Lenkhilfe]
Reset counter: 49
Mileage: 81294 km
Date: 2024.01.19
Time: 12:09:03
Terminal 30 power supply: 12.8 V
Terminal 15: OFF
Bruce
Near Philadelphia, PA, USA
Please post an unedited fault scan.
suravakonda
C?ID=573487
VIN: TMBBC7NE9E02xxxxx   License Plate:
VIN: TMBBC7NE9E02xxxxx   Mileage: 81924km-50905miles
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H09 6185
   Revision: WAH09---    CVN: E0703AA2
   Coding: 01250032232401080000
   Shop #: WSC 73430 031 00133
   ASAM Dataset: EV_ECM14TFS01104E906016G 002009
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 2615E198786542FA75F-8072
   VINID: 91D4924C779525500204404918B497C31A
                    Mileage: 81629 km
                    Date: 2024.02.10
                    Time: 11:14:30
   Part No SW: 0CW 300 047 E    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5260
   Revision: 00043014    Serial number: CU501404035122 CVN: 0000E173
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3D272EF48DF3E122045-8068
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 609940000003B7
   Coding: 1A078A91242111700078060941C9245851248800608224F000210070C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_SK37.rod
   VCID: 4BC3702CC3475F928A1-801E
                    Reset counter: 235
                    Mileage: 80196 km
                    Date: 2023.10.24
                    Time: 00:01:31
                    Reset counter: 41
                    Mileage: 81251 km
                    Date: 2024.01.13
                    Time: 17:17:12
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 01110004000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2809EFA07271548A473-807C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011409700498 Dataset Number: 5E0063t____ 0055
   Coding: 0F001946424702FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00133
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BA3E0ECD3672F127A1-802E
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140407  041 0570
   Serial number:         140411145010
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y14M04D13H05M14S32S7
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY140342BB2
   Serial number: 00000000000059264255
                    Fault Frequency: 38
                    Reset counter: 9
                    Mileage: 80500 km
                    Date: 2023.11.23
                    Time: 13:25:37
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Reset counter: 95
                    Mileage: 73568 km
                    Date: 2022.09.25
                    Time: 18:03:06
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831410103712 Dataset Number: 5E0039t____ 0001
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 38293FE0A2D1C40AD73-806C
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P7R2YXV Dataset Number: 5E0003t____ 0048
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B14FCC77F3332569-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 404 14
   Serial number: 3576U0000004F9855F0Q
   Subsystem 2 - Part No SW: -----------    HW: 454 000 404 14
   Serial number: 3586U000000B8C855F0U
   Subsystem 3 - Part No SW: -----------    HW: 454 800 604 14
   Serial number: 3516R8A605A03000000+
   Subsystem 4 - Part No SW: -----------    HW: 454 800 704 14
   Serial number: 3526R5F096103000000$
   Subsystem 5 - Part No SW: -----------    HW: 454 800 603 14
   Serial number: 3556V30501C03000000V
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15041404401043
   Coding: 1410
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 7DA7EEF4CD732122445-8028
                    Reset counter: 58
                    Mileage: 81858 km
                    Date: 2024.02.19
                    Time: 15:36:57
                    System status: 30
   Part No SW: 5E0 920 971 B    HW: 5E0 920 971 B
   Component: KOMBI         333 2210
   Coding: 27A402082180A60001086A00000000
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001841401 Dataset Number: 5E0067t____ 0015
   Coding: 030100042F085700EF0006481C0F00010001050000000000000000000000
   GVL: 01543C0000000100400C00000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FDB54FC87FFF332169-806A
   Generator:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Serial number: 000000000B0128140414
   Serial number: 6394213103
                    Reset counter: 49
                    Mileage: 81294 km
                    Date: 2024.01.19
                    Time: 12:09:03
                    Terminal 15: OFF
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B0310AC63877F92AA1-807E
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000099582158  Dataset Number: 5E0222t____ 0013
   Coding: 00150020D001040000001100
   VCID: 44D15B10EE1990EA4BB-8010
   Serial number: 00000000000002324404
   Coding: 1D0200
   Component: EPS_MQB_ZFLS  122 1043
   Dataset Number: 5E0074t____ 0012
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF5204F10B85C260D-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000099572338  Dataset Number: 5E0157t____ 0013
   VCID: 43D3580CEB1797D2721-8016
   Serial number: 00000000000002353852
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    040 0435
   Serial number: S7F01304140035 Dataset Number: 5E0CV1t____ 0045
   Coding: 03730101FF0000001111120100A800002F0000860100010046
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H50 0022
   Serial number: SKZ8Z9PK801B8Z
End----(Elapsed Time: 01:20, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Many of those faults are flagged "Intermittent", meaning the fault condition that set the fault code did not exist, or could not be detected at the time the scan was performed. If this car was mine, I'd clear all the fault codes (do it directly at each module that has fault code) and then see what comes back when.
suravakonda
C?ID=573487
Thanks for reviewing my scan log and for your feedback.
As you said, I can see most of the faults are marked Intermittent, but two of the faults are marked as:
"Confirmed - Tested Since Memory Clear"
What does the above statement mean please? Is it confirmed that this is a fault? I couldn't find the meaning that I could understand in the old posts, hence asking.
(one of these faults is resolved in 2022 and other hasn't come back since November 2023).
Likely the fault conditions that set those DTCs are current and still exist.
suravakonda
C?ID=573487
Much appreciated for the reply. Thanks.
