VW Passat CC 09 no crank
DieselMonster
Yorkshire, UK
C?ID=334665
Hi there, so I have a car which drove fine....was parked for a week or two but prior to today, it started fine. Anyway i put in a battery which didn't charger properly which gave me a clue the battery was bad. Anyhow, me thinking it was worth a try with a battery booster attached, I tried to turn the car on and it cranked a little however smoke came from the battery side of the engine compartment. Now I don't know where the smoke came from specifically as I was sat in the car. After this the car stopped cranking.
After this I put in another battery from a working car, it now doesn't crank. Ignition comes on, steering lock is off. Everything has plenty of power. Now bearing in mind it used to start just fine until i put a dodgy battery in causing the car to no longer crank. I am thinking it is an electrical issue. I did a continuity test on all the fuses and listened to the relays for clicks. I then removed the air filter and hooked up a multimeter to see if the starter motor is getting any power. The readings are as followed:
(ignition off) red lead on positive terminal battery, black lead on thick black cable to starter motor or near there: 11.72V
battery with ignition on 12.3V
battery with ignition off 12.45V
(ignition off) red lead on thick starter motor cable that comes from the positive terminal battery, black lead on negative terminal battery: 12.43V
(ignition on) red lead on thick starter motor cable that comes from the positive terminal battery, black lead on negative terminal battery: 12.21V
Terminal 30 on power supply on vcds shows 12.2V with ignition on
How can I further diagnose this problem? I have a working VW with same CR diesel engine, I will compare voltage stats on starter to see if they are the same. Although I have voltage readings, only thing I have noticed is drop in voltage with ignition on. The first reading of 11.72V, I'm unsure of where that black cable is coming from. I gave the starter a few light taps but I'm confident starter is mechanically fine unless it has been electronically damaged. Is the ECU damaged, the power supply that sits next to the battery that has all the terminals going to it? VCDS can't seem to find any major faults that I'm noticing, but perhaps you will.
Friday,23,February,2024,12:26:43:08765
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WVWZZZ3CZ9E510398   License Plate: BV09
Mileage: 432470km-268724mi   Repair Order: 230224
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E510398   Mileage: 432470km-268724miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC 0001SG  6221
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 26214 051 00000
   VCID: 70B92CF996A1305AFFB-8024
   VINID: 9E69EAAAA0D3A895450400C920343BEA34
8 Faults Found:
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - Intermittent
                    Mileage: 418288 km
                    Date: 2018.07.16
                    Time: 16:18:57
                    RPM: 4209 /min
                    Speed: 72.0 km/h
                    Voltage: 13.76 V
                    Lambda: 95.5 %
                    Bin. Bits: 10011111
                    Bin. Bits: 00000000
                    Temperature: 81.0°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 417024 km
                    Date: 2018.07.16
                    Time: 13:23:30
                    Lambda: 11.8 %
                    Lambda: -1.6 %
                    Voltage: 0.380 V
                    Bin. Bits: 10000001
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
                    Mileage: 430469 km
                    RPM: 920 /min
                    Speed: 62.0 km/h
                    Voltage: 7.37 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 270.0 mg/str
                    Mass Air / Rev.: 490.0 mg/str
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
                    RPM: 1817 /min
                    Speed: 67.0 km/h
                    Voltage: 6.38 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 605.0 mg/str
                    Mass Air / Rev.: 450.0 mg/str
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - Intermittent
                    Mileage: 430437 km
                    Date: 2018.07.16
                    Time: 09:22:07
                    Voltage: 5.32 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 705.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
008825 - Leak in Air Intake System
               P2279 - 000 -  - Intermittent
                    Mileage: 430558 km
                    Date: 2018.07.16
                    Time: 17:32:51
                    RPM: 1357 /min
                    Speed: 35.0 km/h
                    Temperature: 24.3°C
                    Absolute Pres.: 989.4 mbar
                    (no units): 204.0
                    (no units): 0.38
                    Temperature: 79.2°C
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 31
                    Mileage: 431597 km
                    Date: 2018.07.16
                    Time: 21:35:27
                    RPM: 207 /min
                    Speed: 5.0 km/h
                    Voltage: 12.08 V
                    Lambda: 77.3 %
                    Lambda: -13.4 %
                    Bin. Bits: 00001110
                    Voltage: 1.900 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Voltage: 12.01 V
                    Voltage: 12.01 V
                    Voltage: 12.01 V
                    Voltage: 12.01 V
Readiness: 1 5 0 0 0
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785785867
   Coding: 0003346
   Shop #: WSC 05311 000 00000
   VCID: 2B03FB957F0713828A9-807E
                    Reset counter: 12
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:28
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 227
                    Hex Value: 0x0000
                    Reset counter: 12
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:28
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 149
                    Hex Value: 0x0000
                    Reset counter: 12
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:28
   Part No SW: 5K0 907 044     HW: 5K0 907 044
   Component: Climatronic   120 0202
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 68894499A2F1F89AA7B-803C
   Revision: 00H54000    Serial number: 00000008533969
   Coding: E0800F8B0004100047970F00170000000008FF475C40017C170000000000
   Shop #: WSC 05124 000 00000
   VCID: 3333E3F5A7374B42C29-8066
   Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 300408 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     250608 054  0402
   Coding: 00209133
   Shop #: WSC 05124
   Component: J234__301 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPBTGKZW
   Coding: 0012337
   VCID: 3B23CBD58F6783021A9-806E
   Subsystem 1 - Serial number: 6333FTS638111258
   Subsystem 2 - Serial number: 6343FTS646901268
   Subsystem 3 - Serial number: 6353ETS63JLLTVNH
   Subsystem 4 - Serial number: 6363ETS6S3FMTVNP
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507BN
   Coding: 0000501
   VCID: 74B120E9E2B90C7A1B3-8020
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H2ÿ 0021
   Coding: 00000226
   Part No SW: 3C8 920 970 A    HW: 3C8 920 970 A
   Component: KOMBI         H19 0023
   Coding: 440F00
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2A0DFE917C7D0A8A71F-807E
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: &_
   Component: J533__Gateway   &_     0142
   Revision:   &_           Serial number: À00P085300F98
   Coding: F9807F060002020000
   VCID: 26150AA164E52EEA557-8072
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 00400 210 83203
   VCID: 392FD1DD855BB112085-806C
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1532
   Revision: 71009005    Serial number: 00000611488607
   Coding: 0000693
   VCID: 40D9BC39E681E0DA4FB-8014
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 207    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0DFE9170FD0A8A71F-807E
            000 - - - MIL ON
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:28
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 7.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763604941570085FCE107C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1532
   Revision: 71009005    Serial number: 00000255488609
   Coding: 0000692
   VCID: 41DFB93DED8BE9D2405-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000047365
   Coding: 0000057
   VCID: 280904996EF1389A67B-807C
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 12
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:28
                    Voltage: 12.30 V
                    Count: 30
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x0110
02442 - Function Lamp in Control Head
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 12
                    Mileage: 432477 km
                    Date: 2018.07.16
                    Time: 00:06:29
                    Voltage: 11.90 V
                    Count: 81
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x0110
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3254141
   Coding: 0500040004
   Shop #: WSC 05314 000 00000
   VCID: 65974DAD5563E5F29CD-8030
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000444284
   Coding: 0000144
   VCID: 313FE9FD5D2B7952B05-8064
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000442392
   Coding: 0000144
   VCID: 323DE6F1582D424AC9F-8066
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.3V)-----------
EuroX
Northern NJ USA
C?ID=208579
I mean this circuit is very simple. Turn and hold the key in the crank position and have someone check if the starter is getting the signal at solenoid. If starter is getting signal at the solenoid then its safe to start starter is fucked unless you don't have a good chassis ground. I would assume smoke was from the shitty aux coolant pump that always pukes coolant into the engine wiring harness.
DieselMonster
Yorkshire, UK
C?ID=334665
Hmm....okay so this car doesn't have a key, it's a fob and so I'd imagine crank position is with fob all the way in which turns ignition on. After doing this how do I check for signal, using multimeter checking for voltage? How much should the signal be? Am I checking the thick red cable that is attached to solenoid or terminal 50 connector?
I have checked a few videos on YouTube testing starter motor. Have become more familiar but not not 100% sure how you're asking me to test it.
Jef
HQ
Quick and easy look.. go to 09-08-015.2. Terminal 50 is the activation for the starter, so you can verify the car is wanting to kick the starter over. If the Terminal 50 is flipping to ON, then a closer look at the starter as per Ziddy's post is a good starting point.
But if Terminal 50 isn't flipping, then then we are missing something and need to back pedal a bit.
EuroX
Northern NJ USA
C?ID=208579
Yes as Jef mentioned terminal 50 at starter. I would make sure you are getting signal at solenoid. If you are not then trace the wire backwards. If you are getting a signal then starter is no good, unless you have poor chassis ground.
DieselMonster
Yorkshire, UK
C?ID=334665
Ok guys, so what i know so terminal 50 is the signal that runs from multiple areas that all connect once ignition is on. From alarm and clutch pedal to the starter motor. I will check if this is working. If this is working I want to hook the cables from battery to starter and then cause starter to turn. If it doesn't turn then starter or solenoid is bad. I will also check for drop in battery voltage to check the connections and leads.
From the outside the starter motor doesn't look promising, the solenoid section is all rusty looking. What I can't understand is starter turned yesterday very briefly. But anyhow I'll check the starter so we can tick this off whether it works or not.
This was a decent guide
siLc
Tallinn, Estonia
C?ID=330192
The factory alarm has no effect on starter engagement. The clutch pedal is indirectly involved - if the ECU recognizes the clutch being pressed, then it is probably not the cause.
This guide might give a good idea on the mechanical side but the electrics are a bit more complicated on the PQ46 platform than the Mk4.
When you press the key in for starter, are there any relay clicks to be heard from underneath the engine bay fusebox? If there are, the two starter relays are operating and you should probably focus on the starter itself being bad.
DieselMonster
Yorkshire, UK
C?ID=334665
Ok guys, so I hooked up positive and negative batteries to the starter motor positive side on the solenoid and negative on the body. Further more I removed the Terminal 50 connector and plugged another lead to positive battery to the connector. The idea was to direct power the starter motor to see if it works, it didn't spin.
09-08-015.2 I checked this as Jef said, terminal 50 is flipping on as I push the fob in beyond ignition position. However you have to hold the fob in for it to remain on so it is a two person job. After this I wanted to see the voltage coming from terminal 50. So I put multimeter on with negative on battery, positive on terminal 50 and someone else pushing key fob in to put the fob in crank position. Checking vcds to see terminal 50 is on, voltage on multimeter was in the m voltage range, very low.
So now I'm baffled, terminal 50 should be pushing out 12v and it isn't. Starter motor won't turn when direct power is applied including to terminal 50. I don't know which one is the issue now. What I can do is check another vw cr car and compare the voltage on that.
As for the relay clicks. When I put key in I checked each individual relay that is under the steering wheel, they all clicked. There is one relay in engine bay marked 100 I swapped that over from another car and didn't make a difference.
I guess what I can do on terminal 50 is a continuity test once terminal 50 is on via fob being pushed in to crank position to see if power is being supplied.
EuroX
Northern NJ USA
C?ID=208579
Well is the start dont spin jumping it then I would say it needs a starter. If you have have signal at the starter that will be a separate but related issue.
siLc
Tallinn, Estonia
C?ID=330192
Please notice the appropriate relays are in the engine bay, in an additional relay carrier underneath the front side of the engine bay fusebox. Not under the dashboard.
DieselMonster
Yorkshire, UK
C?ID=334665
Wow you learn something everyday. I didn't know there were relays inside the fuse box that sits next to the battery in the engine bay. Watching YouTube you have to remove the battery tray and a relay box slides out of the fuse box. I'll check it tomorrow now.
