Steering wheel retrofit fail
Griffs63
Kent, (UK)
C?ID=258650
Hi,
I originally posted on the new member forum, but as I am a fully fledged owner (2 days) of a VCDS Hex-CAN, I can post my problem here in details.
I own a 2012 VW Tiguan 2.0 TDS. As it is the basic S model I decided to fit an multi function steering wheel. After research, I realised that I must upgrade my steering wheel module (clock spring) as well as harness. So, I went from 5K0953569F to 5K0953569T.
However, when I install the new module, nothing happens. The car is completely dead. When I put in the key and turn the ignition on, the dashboard lights are dead and the car will not start. Completely dead. I cannot communicate to the VCDS, the communication link is dead. If I quickly swap back, all is OK again and again, so I know there is nothing wrong with the connectors. I believe the module is DOA but the seller says it is me.
It was suggested that the CANBus is faulty. I have a full scan which is shown below. Hopefully someone can advise if I am doing something wrong, the car modules are wrong/faulty or the new module is indeed dead on arrival.
Grateful for help. The old module is back on, but I left the new steering wheel in place, hence the airbag errors.
I would appreciate some .... steer:)
Friday,25,September,2015,15:28:38:26712
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVGAV7AX6CW566283   License Plate:
Chassis Type: AX (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4C 52 53 56 62 72
          77
VIN: WVGAV7AX6CW566283   Mileage: 74290km-46161miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 M    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2    0396
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 08308 002 1048576
   VCID: 3F8D17676E15E4C664-806A
   Part No SW: 09G 927 750 LR    HW: 09G 927 750 LR
   Component: AQ 250 6F           1971
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0C17F0AB6F230F5E31-8058
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VD74 0005
   Revision: --H07---    Serial number: 00000005254183
   Coding: 0005158
   VCID: 79F9B97F30B10AF61A-802C
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   VCID: 7F0D5767E69524C624-802A
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 0064
   Revision: BG021001
   Coding: 6F180ABB80232EC4008800C11400044448010086524D8960648000000040
   VCID: 3979797FB031CAF65A-806C
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 16011  013 0203
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 47
                    Mileage: 56859 km
                    Date: 2014.10.03
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.60 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 23016000    Serial number: 003GJP0FSDF5
   Coding: 0012340
   VCID: 4A9B36B325D7516EC3-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000005YR6
   Subsystem 3 - Serial number: 0008.12.110000300000630046ÿ†63
   Subsystem 4 - Serial number: 630046ÿ†6332MTS605193521 ÿ†63
   Subsystem 5 - Serial number: 93521 ÿ†6342MTS637160092 ÿ†63
   Subsystem 6 - Serial number: 60092 ÿ†6351HTS62UDF1AKJ ÿ†63
   Subsystem 7 - Serial number: F1AKJ ÿ†6361HTS6GKI21AKJ ÿ†63
   Subsystem 8 - Serial number: 21AKJ ÿ†63727TS66GIRV9KR ÿ†63
   Subsystem 9 - Serial number: RV9KR ÿ†63827TS6FUJI0AKJ ÿ
   Subsystem 10 - Serial number: I0AKJ ÿ
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 70983 km
                    Date: 2015.07.27
                    Time: 00:00:35
   Part No SW: 5K0 953 501 AQ    HW: 5K0 953 569 F
   Revision: FF010040    Serial number: 20120120101657
   Coding: 5980140000
   VCID: 79F9B97FF8B10AF61A-802C
   Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
   Component: KOMBI         H04 0617
   Coding: 211F01
   VCID: 3561754F94292E96BE-8060
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 201211F1002953
   Coding: 356002
   VCID: 3A7B6673B537C1EE53-806E
            000 -  -
                    Mileage: 70996 km
                    Date: 2015.07.27
                    Time: 21:46:14
   Component: IMMO          H04 0617
   VCID: 6ADB96338D17B16EE3-803E
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 A
   Component: RNS-MID       H01 1140
   Revision: AB001001    Serial number: VWZ6Z7J6044063
   Coding: 040500000100000600
   VCID: 2345BB1722BDA02660-8076
02633 - Antenna for Satellite Tuner
                    Reset counter: 116
                    Mileage: 70992 km
03181 - Internal Error SDARS Module
            000 -  -
                    Fault Frequency: 214
                    Reset counter: 116
                    Mileage: 70992 km
                    Fault Status: 00101011
                    Fault Frequency: 28
                    Reset counter: 156
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0004185680
   Coding: 0004B4
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 387F7C7B833BD3FEA5-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D
   Component: J388__TSG-HL  007 1504
   Serial number: 00000006419672
   Coding: 000490
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1002
   Revision: 1AH03836    Serial number: 00120170223101
   Coding: 0000258
   Shop #: WSC 01324 020 00200
   VCID: 3C77606B7F03FFDE41-8068
Address 4C: Tire Pressure II
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0004182937
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3979797FB831CAF65A-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D
   Component: J389__TSG-HR  007 1504
   Serial number: 00000006420478
   Coding: 000490
132866 - Switch for Rear Central Locking
          B122E 29 [008] - Signal Implausible
                    Reset counter: 125
                    Mileage: 73384 km
                    Date: 2015.09.12
                    Time: 19:55:09
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000602813
   Coding: 0026156
   VCID: 3561754F5C292E96BE-8060
                    Reset counter: 116
                    Mileage: 70992 km
            000 -  -
                    Reset counter: 116
                    Mileage: 70992 km
                    Fault Frequency: 28
                    Reset counter: 156
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661729307
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 275DAF075E854C063C-8072
End-------------------------(Elapsed Time: 02:55)--------------------------
Griffs63
Kent, (UK)
C?ID=258650
Looking through some of the site threads I do notice dome things I also need to address but not sure how.
Fuel pump error under #9 and an issue with communication between gateway and navigation module. I am not really sure what I need to do here but think I need to enable something in my gateway. I have replaced my old RCD350 with an RNS510. Straight swap with absolutely no issues with using it. nav works but maps out of date.
Griffs63
Kent, (UK)
C?ID=258650
Lets try again. Removed and re-seated fuel pump relay. Added navigation check in gateway list. Cleared DTC's and rescanned. Hopefully this should be easier to help determine my problem why new clock spring kills my car.
Saturday,26,September,2015,13:57:45:26712
          77
VIN: WVGAV7AX6CW566283   Mileage: 74300km-46167miles
   Coding: 0000840
   Component: J104   C6 450M VD75 0005
   Coding: 0005158
   Revision: 00001016
   Coding: 0000001002
   Revision: BG021001
   Coding: 009795
   Coding: 0012340
   Coding: 5980140000
   Coding: 211F01
   Coding: 356002
                    Reset counter: 117
                    Mileage: 74304 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 117
                    Mileage: 74304 km
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 02:47)--------------------------
Griffs63
Kent, (UK)
C?ID=258650
Flying blind here and I would appreciate some help from others better qualified.
I checked my #19 extended options under adaptions. I can gateway extender is set to 0. If I try to change this to 1 and test, it defaults back to zero.
It was suggested that it needs to be set to 1 to accept my new steering wheel module 5K0953569T. When this is installed, it kills the car.
Eddie-NL
C?ID=41179
a 569T is for a passat which has a different ignition system to your tiguan
The car is dead as it doesn't know you have turned the ignition on
Use a 569H or 569L
Use a 569H or 569L
Yeah Eddie, although I wasn't sure which SWCM the car was born with at the time I came up with something similar:
If 5K0-953-569-F was original the direct replacement of 5K0-953-569-H or the latest variant of 5K0-953-569-AL should be compatible.
On that note, 5K0-953-569-AL is not listed on our Wiki page so any feedback, preferably in conjunction with a Auto-Scan, would be appreciated.​
5K0-953-569-H is an older part number so you may need to go used.
I believe the new 16 module/clock spring is either faulty or incorrect for the vehicle.
I suspect the controller is faulty if it won't even communicate directly but it is entirely possible that the incompatibility issue is the actual problem. So, I can't comment on the possibility that it was DOA but I think we agree that it won't work in this vehicle.
Griffs63
Kent, (UK)
C?ID=258650
Eddie. Dank je wel...
After months this is the first solid advice I have received. I will now try to find a replacement for my new module.
Griffs63
Kent, (UK)
C?ID=258650
Dana, thanks for also confirming. It is definitely has symptoms but for one or two reasons, either of which necessitate the correct version being installed to get it to communicate. What version is AL? I presume H or L will definitely work in a Tiguan as it is basically a Golf??
Griffs63
Kent, (UK)
C?ID=258650
Hmmm. Ok decided to order L version to be safe.
It would be useful if the list of steering wheel modules was updated to show what vehicles are supported. I used this list to order my T version as it was highline and supported MFSW. I was unaware it only supported Passat and that was because of the different ignition systems. There is a lot of people interested in steering wheel upgrades and reading across the forums they usually get there eventually by trial and error like me.
If the list could show model and year it will save time and money.
Anybody want to buy a new 5K0953569T module?
Griffs63
Kent, (UK)
C?ID=258650
The new module was fitted yesterday. Success, but also some issues. Every button on the steering wheel works, which is a massive step from before, but I have a Christmas tree dashboard and the lights will not clear. I have driven the car and performed 360 degree circles many times, but I am left with the following errors.
Stability control error, steering wheel error, tyre pressure error and more importantly, the steering wheel is heavy so I am not getting the assist. The cruise control works but the MFD right stalk doesn't control the MFD.
Two things to note.One, I didn't change the stalk that came with the module. I figured if I already had a stalk with MFD and cruise control, then there is no point; two, I cant get the CANBUS extender to work #17 in gateway module. I couldn't before either, but I still had full steering functionality.
Here is a scan. The scan is after a reset and a drive.
Hopefully someone with more knowledge can help me please.
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4C 52 53 56 62 65
          72 77
VIN: WVGAV7AX6CW566283   Mileage: 75520km-46925miles
65-Tire Pressure -- Status: Cannot be reached 1100
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 75518 km
                    Date: 2015.10.18
                    Time: 20:02:47
                    Temperature: 31.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
Readiness: 0010 0100
   Coding: 0000840
   Component: J104   C6 450M VDB0 0005
   Coding: 0005158
                    Reset counter: 176
                    Mileage: 75522 km
                    Date: 2015.10.18
                    Time: 20:30:23
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.75 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Reset counter: 176
                    Mileage: 75522 km
                    Date: 2015.10.18
                    Time: 20:30:23
   Revision: 00001016
   Coding: 0000001002
Address 09: Cent. Elect.        Labels: None
   VCID: 55A1D5CFBC690E965E-FFFE
No Faults Found
   Coding: 0012340
   Part No SW: 1K5 953 501 S    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20111016200932
   Coding: 110A140000
   Shop #: WSC 09003 957 00200
   VCID: 3B756377B20DF8E648-806E
   Coding: 820000
1140738 - Steering angle sensor
                    Reset counter: 176
                    Mileage: 75518 km
                    Date: 2015.10.18
                    Time: 20:20:58
   Coding: 211F01
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 176
                    Mileage: 75518 km
                    Date: 2015.10.18
                    Time: 20:18:51
   Coding: 356002
                    Reset counter: 176
                    Mileage: 75518 km
                    Date: 2015.10.18
                    Time: 20:18:56
            000 -  -  - Intermittent
                    Mileage: 75518 km
                    Date: 2015.10.18
                    Time: 20:16:15
                    Reset counter: 175
                    Mileage: 75520 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 176
                    Mileage: 75522 km
                    Date: 2015.10.18
                    Time: 20:29:47
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 176
                    Mileage: 75522 km
                    Date: 2015.10.18
                    Time: 20:29:47
                    RPM: 697 /min
                    (no units): 7.0
                    Voltage: 13.90 V
                    Reset counter: 176
                    Mileage: 75522 km
                    Date: 2015.10.18
                    Time: 20:29:47
                    (no units): 7.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 3
Address 46: Central Conv.
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 175
                    Mileage: 75520 km
Address 65: Tire Pressure
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:08)--------------------------
Mrclopec
Nipomo, CA, USA
C?ID=149231
So something you may not have realized....When you order a specific VW/AUDI part, and it is a control module containing software, the part number is listed based on its software and what that software covers. If you look at your latest autoscan you will notice "Part No SW: 1K5 953 501 S HW: 5K0 953 569 L". This means you have the hardware 5K0953569L but the software within it is 1K5953501S. The hardware may support your vehicle, but the software within the control module may not. According to VW's parts catalog, your year had several variants of clockspring covering different features. One variant ended in F. Another variant ended in L. The replacement for either of those was a variant ending in H meaning H is a type of "one covers all" module. The supersession of the H module is the AL module. You actually bought 1K5953501S instead of buying 5k0953569L. It just uses the 569L's hardware. To be safe, I would have purchased the H module or the AL.
Griffs63
Kent, (UK)
C?ID=258650
Mrclopec, I certainly didn't realise that. I just went on advice given to me as I have no understanding on the interoperability of software and modules. I wouldn't have bought the T version either if I had known it was for a Passat. How does one get ythis knowledge or a link to the information?
Saying that, I did some more diagnosis on my problem.Ignore my previous post. Well most of it. I followed the RT WIKI advice on how to reset G85 sensor and the steering lock. And I used the long code helper in the SWCM to activate the computer for wiper stalk. Everything is working as it should but I have 1 dashboard error for tyre pressure and 2 in modules. Software/hardware related maybe. Darned if I am going to spend more money on modules though. I have spent enough and I have more spares than VW.
is there anything I can do regarding updating the software?
Address 01: Engine       Labels: 06J-906-026-CCT.clb
Control Module Part Number: 06J 997 027 M    HW: 06J 907 309 A
  Component and/or Version: MED17.5.2 TFSI 2    0396
           Software Coding: 0423010A19070160
            Work Shop Code: WSC 08308 002 1048576
                    Mileage: 75525 km
                    Date: 2042.14.08
                    Time: 22:56:47
                    RPM: 775 /min
                    Load: 19.6 %
                    Temperature: 99.0°C
                    Temperature: 54.0°C
                    Voltage: 13.716 V
Readiness: 1110 0101
                Address 19: CAN Gateway       Labels: 7N0-907-530-V2.clb
Control Module Part Number: 7N0 907 530 M    HW: 1K0 907 951
  Component and/or Version: J533  Gateway H42 1623
           Software Coding: 356002
            Work Shop Code: WSC 01357 011 00200
                    Reset counter: 177
                    Mileage: 75525 km
                    Date: 2042.14.08
                    Time: 22:55:52
            000 -  -
                    Mileage: 75525 km
                    Date: 2042.14.08
                    Time: 22:55:48
I absolutely agree with Mrclopec. The original controller would supersede to a higher-line part number a majority of the time. This applies to numerous controllers but BCMs and SWCMs are most common when retrofitting in Mk6 based Golf platform vehicles.
It would be nearly impossible for us to keep up with all of the revisions and vehicle applications across 4 brands :( For that reason the top of that Wiki page includes notes regarding the original controller in addition to the parts catalog:
If in doubt check the Parts Catalog and order based on the VIN or based on the Original Part Number. In any case the Catalog should interpret the Part and provide you with a Part Number that superseded the Original Part Number. The final Part Number you will get is normally a Highline Module which you can verify based on the Table below.
Based on the before and after scan data
Original
   Coding: 5980140000
Current
   Coding: 110A140000
.. the current coding is significantly different.
Based on the original configuration of 5980140000 I would code the new controller to 198A140000 which should resolve the Engine controller (Powertrain) conflict resulting in 049682/U0212 - Steering Column Control Module.
Next, this vehicle uses Indirect TPMS but the 19-CAN Gateway is looking for address 65-Tire Pressure (Status: Cannot be reached 1100). Removing that from the 19-CAN Gateway using the [Installation List] function should resolve 01044 - Control Module Incorrectly Coded in addition to the 01325 - Control Module for Tire Pressure Monitoring (J502) - No Signal/Communication issue
Griffs63
Kent, (UK)
C?ID=258650
Well it looks like I am the silly boy for not heeding the advice to get a H or AL. Ignorance thinking that as a L is compatible, then it would suffice, compounded with the fact I could not find a reasonably prices H or AL resulted in an L version.
So, to make the best of a badly executed project, here is the latest status.
Yesterday I re coded the SWCM. My long code helper showed my that my stalk was not active, so I changed from 110A140000 to 510A140000. This removed the fault code from my SWCM and enabled MFD on my stalk.
I just had a quick play with my code helper but I could not find what options would result in 198A140000 so I have left that for the moment. I don't have the other 2 options listed in the options.
I did remove address 65 from my gateway and my TPMS fault disappeared. Thank you!
I still have convenience module 46 and 4C as modules even though they are not selected in the gateway installation.
So this is my latest scan.
Just to be clear, my outstanding task is therefore to code the new controller to 198A140000 which should resolve the Engine controller (Powertrain) conflict resulting in 049682/U0212 - Steering Column Control Module.
          77
VIN: WVGAV7AX6CW566283   Mileage: 75630km-46994miles
46-Central Conv. -- Status: Not registered 0001
4C-Tire Pressure II -- Status: Not registered 0001
                    Mileage: 75636 km
                    Date: 2015.10.19
                    Time: 18:08:43
                    RPM: 777 /min
                    Load: 21.6 %
                    Temperature: 99.0°C
                    Temperature: 52.0°C
                    Voltage: 13.462 V
   Coding: 0000840
   Component: J104   C6 450M VDB7 0005
   Coding: 0005158
   Revision: 00001016
   Coding: 0000001002
   Revision: BG021001
   Coding: 009795
   Coding: 0012340
   Coding: 510A140000
   Coding: 820000
   Coding: 211F01
   Coding: 356002
            000 -  -
                    Mileage: 75636 km
                    Date: 2015.10.19
                    Time: 18:10:09
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
   ROD: EV_UHVNA.rod
Hi Neil - I think this controller is going to work so I wouldn't consider it poorly executed yet :)
These need to be added to the 19-CAN Gateway [Installation List] :
Next, you should add the missing Auto trans ignition lock and traditional ignition switch to the #16 coding.
198A140000 would be the typical configuration for a car with a 12 button MFSW born without a MF stalk.​
You may want to experiment with 598A140000 if the factory MF stalk is still installed... but I don't know if the presence of that stalk and 12 button MFSW will cause a conflict/fault codes.​
Either way - try both, clear codes, cycle the ignition and check functionality with each config.
Griffs63
Kent, (UK)
C?ID=258650
Thanks Dana, you give me some hope :-) I will try this later when I get home from work. The steering wheel and the MFD stalk are working together at the moment.
I did have both the #46 and 4C ticked previous but I was getting errors. I will try again.
Griffs63
Kent, (UK)
C?ID=258650
Dana,
I think I have resolved this. Thank you, thank you :-)
I enabled 46 and 4C. Although I cannot communicate with the modules, the fault codes have been removed.
I did have issues with the SWCM, but I think I have resolved.
598A140000 did not work. Error code 31 - input out of range.
590A140000 did not work. Error code 31.
518A140000 did work. So it didn't like the auto ignition lock.
I still have nav errors, but nothing I can do about that I don't think as it is antenna related.
          77
VIN: WVGAV7AX6CW566283   Mileage: 75700km-47037miles
   Coding: 0000840
   Component: J104   C6 450M VDBA 0005
   Coding: 0005158
   Revision: 00001016
   Coding: 0000001002
   Revision: BG021001
   Coding: 009795
   Coding: 0012340
   Coding: 518A140000
   Coding: 820000
   Coding: 211F01
   Coding: 356002
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 02:52)--------------------------
So would you say all is now 100% OK? Everything in the car works as it should. Steering wheel and stalk.
Ahh, those are virtual so they don't speak directly but need to be in the list for internal communication reasons.
Yep, I would call that finished!
Side note. Now that you mentioned the ign lock coding bit.. we received (retrofitting) email feedback from a RoW market forum user not long ago indicating something similar. golfi_vend tends to take his observations to forum and Eddie-NL and I haven't spoke via email for a long time. So, I don't think that made it here
Ross tech wiki upgrades
.. but that thread is sorta the unofficial bug or feedback reporting area for Mk5/6 #16 controllers on our Wiki page. I'll see if I can locate the conversation details and ping the guys to see if we can add any clarity.
Griffs63
Kent, (UK)
C?ID=258650
Dana,
Thanks very much for your help. I am happy. I did notice though that since I coded the SWCM, although the error codes have gone, the left and right buttons on the right side of the steering wheel no longer work. Not really sure what they do on the MFD, but they 100% did something,now they don't.
OK, I sorta figured there would be a conflict but it may be worth living with it rather than putting a non MFA stalk on the car. I doubt you are missing out on anything, the buttons on the right primarily control the MFA stuff that you can access through the stalk.
Edit, after I clicked save I thought to myself ... you probably want ALL of the fancy new buttons to do something :) That's the point of this right. See if 118A140000 kills the MFA stalk and enables the buttons. Even if you have an incorrectly coded DTC that may be something to live with providing all other basic functions continue to work.
