hi all. new VCDS user here
ive got a 2017 golf r estate and I'm trying to complete haldex pump relearn after haldex service and pump replacement. when I select pump motor in AWD module 22, the pump runs up only once and does its thing for about 25sec, then stops and VCDS displays the message "finished-timed out"
if I pull up the live data for calibration values, it doesn't appear to store any new values, so the the relearn is unsuccessful
ive tried resetting all adaptation values and attempting a fresh relearn with no success, still get the message "finished-timed out"
wondering if anyone has come across this issue with the unit not completing a relearn
> Chassis Type: AU-VW37 (5Q0)
> Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
> 57 5F A5 A9
> VIN: WVWZZZAUZHP507031 Mileage: 98274km-61064miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: OK 0000
> 10-Park/Steer Assist -- Status: OK 0000
> 13-Auto Dist. Reg -- Status: OK 0000
> 14-Susp. Elect. -- Status: OK 0000
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 22-AWD -- Status: OK 0000
> 2B-Steer. Col. Lock -- Status: OK 0000
> 3C-Lane Change -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 52-Door Elect, Pass. -- Status: OK 0000
> 55-Headlight Range -- Status: OK 0000
> 57-TV Tuner -- Status: OK 0000
> 5F-Information Electr. -- Status: OK 0000
> A5-Frt Sens. Drv. Assist -- Status: OK 0000
> A9-Struct. Borne Sound -- Status: OK 0000
> Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
> Part No SW: 5G0 906 259 J HW: 06K 907 425 B
> Component: 2.0l R4 TFSI H13 0002
> Revision: --H13--- CVN: B3414DD3
> Coding: 091D00122466050B3000
> Shop #: WSC 12345 123 61029
> ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
> ROD: EV_ECM20TFS0205G0906259J.rod
> VCID: 3537312D85C24302CC5-8060
> VINID: 9E69EAAAA465A9880500700304CB2300FB
> No fault code found.
> Readiness: 0000 0001
> Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
> Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
> Component: DQ250-6A MQB H53 4935
> Revision: 06253104 Serial number: TFK01604221279 CVN: 0000FD8F
> Coding: 0014
> Shop #: WSC 00028 028 00067
> ASAM Dataset: EV_TCMDQ250021 001001
> ROD: EV_TCMDQ250021.rod
> VCID: 53F36FB52B767D32C21-8006
> Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
> Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
> Component: ESC H62 0736
> Revision: 00000000 Serial number: 61586000000422
> Coding: 04FA93A1542019734777070341C46920C92A98E2E0829677184250B8C2A803
> ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
> ROD: EV_Brake1UDSContiMK100IPB_035.rod
> VCID: 7BA3E715E36655727A1-802E
> Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
> Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
> Component: VWKESSYMQB 021 0710
> Revision: 00021000 Serial number: 0406883435 Dataset Number: 5G2IJ1v____ 0006
> Coding: 032C0C
> ASAM Dataset: EV_KessyHellaMQBAB 002019
> ROD: EV_KessyHellaMQBAB_002.rod
> VCID: 3B232715A3E695723A1-806E
> Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
> Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
> Component: Climatronic H04 1601
> Revision: 00001K08
> Coding: 02120004100100001105004000101422
> ASAM Dataset: EV_ACClimaBHBVW37X 006142
> ROD: EV_ACClimaBHBVW37X_006_VW37.rod
> VCID: 72BDCA31B42C143A297-8026
> Fresh air blower control module (front):
> A/C pressure/coolant temperature sensor:
> Air quality sensor:
> Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
> Part No SW: 5Q0 937 087 AB HW: 5Q0 937 087 AB
> Component: BCM PQ37BOSCH 028 0163
> Revision: -------- Serial number: 865825051602P4 Dataset Number: 5G9063v____ 0001
> Coding: 03011A46C24122F309A44080B10C07281800000000000000000000000000
> ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
> ROD: EV_BCMBOSCH_015.rod
> Wiper motor control module:
> Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
> Component: WWS 160507 042 0551
> Serial number: 160520182708
> Coding: 0E4DDD
> Rain/Light Recognition Sensor:
> Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
> Component: RLHS 042 0105
> Serial number: S3Y16M06D07H21M56S21
> Coding: 37E8DD
> Anti-theft alarm system sensor:
> Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
> Component: Sensor, DWA 005 0316
> Serial number: 000000000ZY1611715NW
> Alarm horn:
> Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
> Component: Sirene, DWA 005 0313
> Serial number: 00000000000066104650
> Humidity sensor: interior:
> Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
> Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
> Component: PARKHILFE 8K H03 0054
> Revision: -------- Serial number: 39331615203420 Dataset Number: V03935236FM 0001
> Coding: 0071155011
> ASAM Dataset: EV_EPHVA18AU3700000 002026
> ROD: EV_EPHVA18AU3700000_002_VW37.rod
> VCID: 43D35FF5DB16EDB2721-8016
> Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
> Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
> Component: ACC BOSCH MQB H10 0571
> Dataset Number: V03935239PQ 0001
> Coding: 350047C151FFC428949C8045000006
> ASAM Dataset: EV_ACCBOSCHVW416 001005
> ROD: EV_ACCBOSCHVW416_001_VW37.rod
> Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
> Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
> Component: DAEMPFUNGS-SG H17 0121
> Serial number: 06051641350345 Dataset Number: 5G0532v____ 0051
> ASAM Dataset: EV_DRCONTITEMIC 001019
> ROD: EV_DRCONTITEMIC_VW37.rod
> VCID: 3829381992D0BE6AD73-806C
> Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
> Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
> Component: AirbagVW20 015 0388
> Serial number: 003MLR1U4M9A Dataset Number: 5G0003V____ 0112
> Coding: 98FCC0C0000000005C5400CF00C800000065
> Shop #: WSC 00028 028 00055
> ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
> ROD: EV_AirbaVW20SMEVW37X_VW37.rod
> VCID: 7F5B1305F77E4952569-802A
> Left seat belt tensioner:
> Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
> Component: BeltPretRevFL H36 0350
> Serial number: 34169677D31051640539
> Coding: 333135
> Right seat belt tensioner:
> Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
> Component: BeltPretRevFR H36 0350
> Serial number: 34169676D01061650553
> Coding: 333135
> Crash sensor for side airbag: driver side:
> Subsystem 3 - Part No SW: ----------- HW: 480 000 406 16
> Component: SideSensor_Df 001 0887
> Serial number: 357670000004A2019B1N
> Coding: 2D2D2D
> Front Passenger's Side Airbag Crash Sensor:
> Subsystem 4 - Part No SW: ----------- HW: 480 000 406 16
> Component: SideSensor_Pf 001 0887
> Serial number: 35867000000CD2019B1Z
> Coding: 2D2D2D
> Rear Side Airbag Crash Sensor (on driver's side):
> Subsystem 5 - Part No SW: ----------- HW: 480 403 105 16
> Component: SideSensor_Dr 001 6149
> Serial number: 35165029B209EA04717A
> Coding: 2D2D2D
> Passenger side rear thorax airbag crash sensor:
> Subsystem 6 - Part No SW: ----------- HW: 480 400 906 16
> Component: SideSensor_Pr 001 6149
> Serial number: 35265029920FC4C2915H
> Coding: 2D2D2D
> Crash sensor for front airbag: driver side:
> Subsystem 7 - Part No SW: ----------- HW: 480 402 805 16
> Component: FrontSensor_D 001 6149
> Serial number: 3556502A32057292C383
> Coding: 2D2D2D
> Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
> Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
> Component: Lenks.Modul 075 0195
> Revision: FF033033 Serial number: 20160530400468
> Coding: 0C10
> ASAM Dataset: EV_SMLSVALEOMQB 001015
> ROD: EV_SMLSVALEOMQB.rod
> VCID: 73B3CF35CB361D32221-8026
> Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
> Part No SW: 5G1 920 658 B HW: 5G1 920 658 B
> Component: KOMBI 323 8311
> Coding: 23AC10187F88000802886F0B4400000000000000
> ASAM Dataset: EV_DashBoardVDDMQBAB 009051
> ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
> VCID: 2D07194D6D920BC2B45-8078
> Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
> Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
> Component: GW MQB High 212 2265
> Revision: -------- Serial number: 02061610520164 Dataset Number: V03935242HR 0001
> Coding: 030100043F085900FB00027E9C0F00010001050000000000000000000000
> GVL: 01D43C100000060040CC90000000CC0000000000000000000000000000000000
> ASAM Dataset: EV_GatewConti 013020
> ROD: EV_GatewConti_013.rod
> VCID: 7CA1E409E668524A73B-8028
> Generator:
> Multifunction steering wheel control module:
> Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
> Component: E221__MFL-DC1 H11 0040
> Serial number: 29160000995150066204
> Coding: 2DFFFF
> Battery Monitoring Control Module:
> Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
> Component: J367-BDMHella H10 9070
> Serial number: 9444100404
> Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
> Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
> Component: Haldex4Motion H52 7083
> Serial number: HA1-00011.05.16 Dataset Number: v1260x015G0 0000
> Coding: 0001
> ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
> ROD: EV_AllWheelContrHA1VW37X_004.rod
> VCID: 4ACD72D1FC3C3CFAB17-801E
> Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
> Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
> Component: ELV-MQBA H01 0120
> Revision: 00000000 Serial number: 16000086290010
> Coding: 5D00000000000000
> ASAM Dataset: EV_ELVMarquMQB 004111
> ROD: EV_ELVMarquMQB_004_VW37.rod
> VCID: 34310C298EB85A0AFBB-8060
> Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
> Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
> Component: HRE_Master H12 0071
> Serial number: 0405300967 Dataset Number: 5G9764V____ 0033
> Coding: 02011203
> ASAM Dataset: EV_HREntryHella 001028
> ROD: EV_HREntryHella_VW37.rod
> VCID: 3C212409A6E8924A33B-8068
> Lane change assistance control module 2:
> Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
> Component: HRE_Slave H12 0071
> Serial number: 0405042096
> Coding: 020112
> Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
> Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
> Component: TSG FS 010 0031
> Serial number: 0000202008598 Dataset Number: V03935240DH 0001
> Coding: 003F1220D001028000001000
> ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
> ROD: EV_DCUDriveSideEWMAXCONT.rod
> VCID: 47CB4BE5EF2EC192AE9-8012
> Rear Driver Side Door Control Module:
> Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
> Component: Fond FHSG DRV 007 0002
> Serial number: 00000000000003699727
> Coding: 0D0000
> Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
> Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
> Component: EPS_MQB_ZFLS 506 5072
> Dataset Number: V03935242LM 0001
> Coding: 9107
> ASAM Dataset: EV_SteerAssisMQB 013144
> ROD: EV_SteerAssisMQB_013.rod
> VCID: 3A2D2211ACDCAC7A217-806E
> Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
> Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
> Component: TSG BFS 010 0031
> Serial number: 0000202841953 Dataset Number: V03935240DV 0001
> Coding: 003F1020DE01028000801000
> ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
> ROD: EV_DCUPasseSideEWMAXCONT.rod
> VCID: 46D546E1E824D89A55F-8012
> Rear Passenger Door Control Module:
> Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
> Component: Fond FHSG PSG 007 0002
> Serial number: 00000000000013097642
> Coding: 050000
> Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
> Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
> Component: AFS-ECU H07 0090
> Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0021
> Coding: 06A603000B010200
> ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
> ROD: EV_HeadlRegulVWAFSMQB.rod
> VCID: 40D950F9CA00F6AA6F3-8014
> Left Headlamp Power Output Stage:
> Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
> Component: LeiMo links H01 0002
> Coding: 2E0000
> Right Headlamp Power Output Stage:
> Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
> Component: LeiMo rechts H01 0002
> Coding: 2E0000
> Address 57: TV Tuner (R78) Labels:| 8V0-919-DTV-V1.clb
> Part No SW: 8V0 919 129 E HW: 8V0 919 129 D
> Component: JP-DTV H12 2070
> Coding: 02041C0000000100000002
> ASAM Dataset: EV_TVMELC 001039
> ROD: EV_TVMELC_VW37.rod
> VCID: 42DD5AF1C40CE4BA797-8016
> Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
> Part No SW: 3G0 035 050 C HW: 3G0 035 050
> Component: MU-H-N-JP 052 0636
> Serial number: K5F AW7L2094LC Dataset Number: V03935241AV 0001
> Coding: 02730206FF00000051110001001038001F0207F601200100F6
> ASAM Dataset: EV_MUHig4CGen2AW7 001081
> ROD: EV_MUHig4CGen2AW7_VW37.rod
> VCID: 1A6DC2910C1C8C7AC17-804E
> Display and control head 1 for information electronics:
> Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
> Component: ABT_High H63 0032
> Serial number: VWZ8Z9SKL024F2
> Data carrier:
> Subsystem 2 - Part No SW: V03 959 802 QM HW: -----------
> Component: JPN 2016/2017 --- 7620
> Serial number: --------------------
> Control module for chip card reader:
> Subsystem 3 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
> Component: DSRC UNIT H09 0002
> Serial number: 502129398650
> Traffic data antenna:
> Subsystem 4 - Part No SW: 8V0 035 504 B HW: 8V0 035 504 B
> Component: VICS Antenna H06 0001
> Serial number: 503400056302
> Compact disc data bank:
> Subsystem 5 - Part No SW: V03 959 800 EG HW: -----------
> Component: Gracenote2--- --- 2010
> Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
> Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
> Component: MQB_B_MFK H04 0220
> Serial number: 31051611K20609 Dataset Number: V03935242BU 0001
> Coding: 0003070200000501000223548040A10084000E100000
> ASAM Dataset: EV_MFKBoschMQBB 001001
> ROD: EV_MFKBoschMQBB_001_VW36.rod
> Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
> Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
> Component: SAS-GEN 2 H07 0001
> Serial number: 160425201495
> ASAM Dataset: EV_SoundActuaGen2AU64X 003010
> ROD: EV_SoundActuaGen2AU64X.rod
> VCID: 2F3B0345679E79D2869-807A
> End----------(Elapsed Time: 01:57, VBatt start/end: 12.3V/12.3V)-----------
> HTTP_USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36
> REMOTE_ADDR: 118.92.254.239
