Audi c7 a6 2013 no horn help!
Chr15
C?ID=207693
Thanks in advance for any help. It's much appreciated.
I have a 2013 C7 AUDI A6 with horn not working problem. Come to me just for diagnostic but think its now become my problem.
Horn can be seen pressed at the steering wheel via data on snap on solus ultra. (Haven't checked this on VCDS)
Horn/sounder can be activated manually from relay and from activations on VCDS and works as it should.
Information I have is it stopped working after having towbar module removed. Unable to fault how its been removed other than for deactivating from can gateway (which ive now done) I'm now starting to think it could be coding that needs looking into but unfortunately the long coding helper has no information for this vehicle.
Any one able to offer coding help??
Thanks again to anyone who can help
Chris
Thursday,24,September,2015,18:08:34:26527
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ4G6EN002741   License Plate: VE13 OVZ
Mileage: 29645km-18420mi   Repair Order: 2
Chassis Type: 4G (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G6EN002741   Mileage: 29645km-18420miles
17-Instruments -- Status: Malfunction 0110
Address 01: Engine (J623-CGLC)       Labels: 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 3113
   Revision: 45H25---
   Coding: 0A034012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003009
   ROD: EV_ECM20TDI01103L906018LB.rod
   VCID: 75E1E5F2D4A6A9967E-8020
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000000877
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381_AU57.rod
   VCID: 397929C2B83E0DF65A-806C
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A19F016085F980CB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 3A7B36CEBD3806EE53-806E
   Part No SW: 4H0 907 064 CG    HW: 4H0 907 064 CG
   Component: BCM2 2.0      H33 0433
   Coding: 01B83046000000000000
   VCID: 70EFD4E6A3C48CBEAD-8024
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
   Component: KLIMA 2 ZONEN H11 0087
   Serial number: 10051300110769
   Coding: 34210008A1
   ASAM Dataset: EV_AirCondiBasisUDS 002045
   ROD: EV_AirCondiBasisUDS.rod
   VCID: 60CFA4A67B243C3E3D-8034
0314 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.24
                    Time: 18:03:22
0315 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.24
                    Time: 18:03:22
   Part No SW: 4H0 907 063 CB    HW: 4H0 907 063 B
   Revision: 13012002    Serial number: 00000001431271
   Coding: 690000108034A7E00105008300005F5F0F9DC20827080201000004406000
   VCID: 6ADBC68E8518766EE3-803E
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 130504  H36 0080
   Coding: 0045F7
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
00576 - Terminal 15
                    Fault Status: 01101000
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.24
                    Time: 18:03:00
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031313703024
   Coding: 08C305
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 71E9D1E2A0CE85B6A2-8024
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00D7BP8
   Coding: 3032343631324E303235554A305234473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 366322FE8920E28EB7-8062
   Serial number: 3575HRB400450G787OR5
   Serial number: 3585HRB401850G08I91H
   Serial number: 3515JRB401A50HHOKA5C
   Serial number: 3525JRB400G50HQ6C1J6
   Serial number: 3554VRB401A50IBQK1EO
   Serial number: 3564VRB401G50IBQIHRF
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130516000171
   Coding: 000034
   VCID: 306F14E66344CCBEED-8064
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H09 0010
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0410
   Revision: 27450257    Serial number: 658070513592001
   Coding: 33A6090003412600010400
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F8D47DAA61A23C664-806A
1048578 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.21
                    Time: 19:25:04
          B2010 00 [009] -  -
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.24
                    Time: 18:03:22
   Part No SW: 4G5 907 468 B    HW: 4G5 907 468 B
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000932085
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS.rod
   VCID: 346718F69F5CF09E89-8060
   Serial number: 2058820503
   Voltage stabilizer:
6151 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.24
                    Time: 18:03:22
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H02 0056
   Revision: --------    Serial number: EJ1BPA7204FTDL
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   VCID: 33651BEA9A52F7A690-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 479D5F3AF6CA6B06DC-8012
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0009477257
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 326B1EEE6548FEAE9B-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0306456048
   Coding: 011B062280B900008320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Component: TSG BF        H03 0507
   VCID: 4683523EF1C0720E27-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000690052
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2C570096476CA85ED1-8078
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H54 0801
   Coding: 0101000001415B47082B060301010000010000
   VCID: 275DFFBA568A8B063C-8072
   Subsystem 1 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
   Component: DU6 Basic  H43 0084
   Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49995902E0DE9D76CA-801C
   Component: TSG HR        H03 0507
End-------------------------(Elapsed Time: 04:02)--------------------------
Gone But Not Forgotten
Do you have a legacy auto-scan saved way before anything was modified or unmodified?
Chr15
C?ID=207693
Unfortunately the I have only seen the car without a working horn. I have an auto scan of it before I cleared any codes and with the trailer module still active in the CAN Gateway.
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 69
          72
69-Trailer -- Status: Cannot be reached 0100
   Revision: 45H25---
0669 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:36
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:37
0687 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:31:35
0478 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:36
0477 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:39
0716 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:56
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 238
                    Mileage: 29635 km
                    Date: 2015.08.25
                    Time: 09:51:56
                    Fault Status: 00101101
                    Fault Frequency: 36
                    Reset counter: 22
                    Mileage: 29635 km
                    Date: 2015.09.02
                    Time: 11:18:12
   Coding: 34210008A1
0242 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:36
0269 - Control Circuit for A/C Compressor
          B10A9 29 [008] - Signal Implausible
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.09
                    Time: 11:39:06
          U1111 00 [009] - -
                    Reset counter: 237
                    Mileage: 29620 km
                    Date: 2015.08.12
                    Time: 16:07:31
          U1111 00 [009] - -
                    Fault Frequency: 46
                    Reset counter: 238
                    Mileage: 29620 km
                    Date: 2015.08.12
                    Time: 16:07:31
0388 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:50:17
   Coding: 0045F7
   Coding: 02006D
00576 - Terminal 15
                    Reset counter: 238
                    Mileage: 29645 km
                    Date: 2015.09.17
                    Time: 16:53:00
   Coding: 08C305
12674064 - Databus
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:37
12664832 - Databus
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
1048576 - Databus
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:37
1048581 - Databus
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:33:23
1049862 - Databus
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:50:17
   Coding: 000034
00457 - Control Module for Network (J519)
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:37
   Coding: 33A6080003412600010000
          B2010 00 [009] -  -
                    Reset counter: 238
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:34:25
16776963 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:50:17
16776977 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
   Coding: 00CD074400
   Voltage stabilizer:
5057 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
5729 - No Communication with Towing System Control Module (J345)
          U1003 00 [009] - -
                    Reset counter: 238
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:34:53
          U1101 00 [008] - Active
                    Fault Frequency: 8
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.09
                    Time: 11:39:05
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:40
   ROD: EV_RCEPS.rod
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 12:45:49
                    Reset counter: 22
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:35:36
                    Reset counter: 22
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:36
                    Fault Frequency: 23
                    Reset counter: 22
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:42:01
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:40
461568 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:56
463104 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
334336 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.08
                    Time: 13:41:35
465152 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 23
                    Mileage: 29635 km
                    Date: 2015.09.02
                    Time: 11:18:06
            000 -  -  - Intermittent
                    Reset counter: 23
                    Mileage: 29645 km
                    Date: 2015.09.17
                    Time: 15:59:19
                    Bin. Bits: 00010010 00000000
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 23
                    Mileage: 29645 km
                    Date: 2015.09.17
                    Time: 15:59:30
                    Bin. Bits: 00000000 00000100
Address 69: Trailer
End-------------------------(Elapsed Time: 04:20)--------------------------
Chr15
C?ID=207693
Any body any suggestions maybe?
