Error 34 and error 37 invalid key
Mills1908
C?ID=353772
Hi, ive fitted a new chassis control module to my audi q7 4m, ive coded eveything in and all i need to do now is do the adaptions but i cant access the module via the security access for some reason, im using code 20103 which worked fine on the old module
has anyone had the same problem or im i being stupid and theres somehing im missing, any advice or help at this point would be very much appreciatied
Westbury, UK
Please post an Auto-Scan of your Q7 with the new module fitted - and preferably with the old one as well (remember VCDS saves all scans in C:\Ross-Tech\VCDS\Scans)
Mills1908
C?ID=353772
Mills1908
C?ID=353772
this is the old module
Tuesday,06,February,2024,14:38:05:45536
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4M0GD026614   License Plate:
Chassis Type: 4M-AU73 (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 42 44 46 47
          50 52 5F 69 6C 6D 74 81 82 8B A5 AC BB BC CA D6 D7
VIN: WAUZZZ4M0GD026614   Mileage: 161196km-100162miles
50-Seat Adj. 3rd row -- Status: OK 0000
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0009
   Revision: 91H45---    CVN: 5D7B42084F8B6DFB92F1EF3C
   Coding: 2A2A4032057E050335080000000000000000000000000000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0114M0907401 001013
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 6694408A08ECD33AB5F-8032
   VINID: 9D196AAAA11D017500086181107E0CD84B
14581 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [01100101] - Electrical Fault
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine RPM: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.240 V
                    Glow-control unit: activation voltage: 10880 mV
                    Glow_period_control_unit_ground_offset_voltage: -260 mV
                    Glow-control unit: calculated glow voltage: 11430 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 127.8 V²s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 9
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 16
                    Co EOM st Op Mode Short-Bits 0-7: 8
14583 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [01100101] - Electrical Fault
                    Date: 2047.15.31
                    Time: 31:63:63
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H03 1008
   Revision: --H03---    CVN: 642B4C69
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 3B22C1FE23EEBED23A1-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Dataset Number: 4M0909504G  0029 CVN: 3BD0D926
   Coding: 249830B230A40A9CD6A45892188152AAE6A6D2240C0C506B1A184A5567654B
   Shop #: WSC 61640 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FDAB5EE37F6A2F2169-806A
   Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
   Component: MEM-BFS       008 0014
   Serial number: 00000169436942 Dataset Number: 4M0909866B  0013
   Coding: 002010000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3A2CC4FA2CD487DA217-806E
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0083
   Coding: 6618083C5549451102620180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678A4D8E0FE6CA328E9-8032
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000353072
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: D0484CC7000000000001
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0215
   Dataset Number: 4M0909514L  0040
   Coding: 07501943C12900CD010D57195B3F08F9130331009000000000000000A00016810A45022B125605
   ASAM Dataset: EV_BCM1BOSCHAU736 014003
   ROD: EV_BCM1BOSCHAU736_014.rod
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 150610  042 0792
   Serial number:         150626213549
   Coding: 1BC7F7
   Serial number: 20706707
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
   Component: E1 - LDS  H05 0007
   Serial number: 22 08 2015  00076410
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE123091511520116
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00045752
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000016127
65568 - Terminal 30-5
          U1415 00 [00001001] - Open circuit
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:18
                    average_Voltage_terminals: 14.60 V
                    Outside air temperature sensor-Resistance: 343.04 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C
                    interior_temperature: 17742.00 °C
                    Vehicle speed: 0.00 km/h
262153 - Lamp 1 for Contour Lighting of Door; Front Right
          U1178 00 [00001001] - No Communications
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:25
                    average_Voltage_terminals: 14.50 V
262179 - Lamp 1 for Ambient Lighting of Door; Front Right
          U1186 00 [00001001] - No Communications
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:25
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 C    HW: 4M0 907 561
   Component: LRR4          H08 0160
   Dataset Number: 4M0909863J  0022
   Coding: 3473FFEA58FFEC08949880A4
   ASAM Dataset: EV_ACCBOSCHAU736 001016
   ROD: EV_ACCBOSCHAU736.rod
   VCID: 3038E6D2FAA84D8A9F3-8064
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0084
   Serial number: 003L1000U7ZB Dataset Number: 4M0909602K  0002
   Coding: AACCF0D80C80000098F650F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 78A81EF2525855CA173-802C
   Subsystem 1 - Part No SW: -----------    HW: 442 062 509 15
   Serial number: 3577Y00AB1A537E14496
   Subsystem 2 - Part No SW: -----------    HW: 442 062 509 15
   Serial number: 3587Y00A91A537D48110
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 009 15
   Serial number: 3517700C11C81BC4844F
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 009 15
   Serial number: 3527700C71C81BC3824J
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 909 15
   Serial number: 3557500A11C5DC25632B
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 909 15
   Serial number: 35675009F1C5DC2151DT
   Subsystem 7 - Part No SW: -----------    HW: 442 0C3 108 15
   Serial number: 2307500C91C4D05322D7
   Subsystem 8 - Part No SW: -----------    HW: 442 420 609 15
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00991A537E213CP
   Subsystem 9 - Part No SW: -----------    HW: 442 420 609 15
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00991A537E160CR
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 308 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800C51A580C2B0F9
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015E73160182140220D-8054
   Part No SW: 4M0 920 790 A    HW: 4M0 920 790 A
   Component: FBenRDW       H12 0280
   Coding: 248501D07C80060001A3E9603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2D06FFA6ED9A2062B45-8078
16777007 - Databus
          [Fahrwerk_Anzeige_01 communication error can_error_timeout]
                    Reset counter: 240
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:37:33
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 4079
   Revision: 3C030052    Serial number: 5243C016C15815 Dataset Number: 4M0909515H  0057
   Coding: 0301000100808F407F07000000590032D8920007180000000100000000000000
   Shop #: WSC 59596 001 1048576
   GVL: 01503C0C08040200C0BCC8000002C80011082000000000000000000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU73.rod
   VCID: 3634D0CA18CC63BAC5F-8062
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20150929020548 00155
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 8750867803
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0080
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0011
   ASAM Dataset: EV_LCMLeftHELLAAU736 001006
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 15000070137009
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323CECDAF4A47F9AE97-8066
   Component: MEM-FS        008 0014
   Serial number: 00000169436803 Dataset Number: 4M0909856B  0013
   Coding: 003813000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   ASAM Dataset: EV_LCMRightHELLAAU736 001006
   Part No SW: 4M0 959 593 G    HW: 4M0 959 593 C
   Component: TSG FS        005 0052
   Serial number: 0000168849713  Dataset Number: 4M0909872F  0027
   Coding: 005D9A015E01000000003082
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 40D8B6124A08DD0A6F3-8014
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H19 0004
   Serial number: 0000249086 Dataset Number: 4M0909852G  0022
   Coding: B0040101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3332E9DE0BBE7692E21-8066
   Part No SW: 8W0 907 064 AD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   015 0307
   Dataset Number: 4M0909501E  0054
   Coding: 01351E002F110040630980006600580203000004004702502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_010_AU73.rod
   VCID: 7EA408EA707C6BFA5DF-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1521611L5
   Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000033519598
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
   Component: J505-FSH  H03 0050
   Serial number: 00000000000000004508
640003 - Bulb for Left Brake Lamp / Tail Lamp
          B133A 12 [00001000] - Short to Plus
                    Fault Frequency: 13
                    Reset counter: 240
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 17:13:46
                    Supply voltages-Terminal 30 power supply: 14.769 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.742 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.701 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 94 02 30
                    general_additional_freeze_frame-Vehicle speed: 0.89 km/h
                    light_freeze_frame: 00000000 00000000 00000000 00000000
65716 - Windshield defogger
          B1473 01 [00001001] - Electrical Failure
                    Fault Frequency: 8
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:21
                    Supply voltages-Terminal 30 power supply: 14.729 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.769 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.715 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 02 00
65717 - Windshield defogger
          B1473 1B [00001001] - Resistance Too High
                    Fault Frequency: 8
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:21
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000007086 Dataset Number: 4M1909510C  0008
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 211E1396A142F40200D-8074
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0014
   Serial number: 00000168963789 Dataset Number: 4M0909467B  0014
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C20C2E226E0B9EA33B-8068
   Part No SW: 4M0 959 592 D    HW: 4M0 959 592 C
   Component: TSG BFS       005 0038
   Serial number: 0000167101583  Dataset Number: 4M0909873E  0023
   Coding: 005D9A015E01000000003080
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 035 L    HW: 4M0 035 035 A
   Component: MU-P-LND-EU   050 1438
   Serial number: A649I0F7501830 Dataset Number: 4M0909545C  0024
   Coding: 013706010000000013111102000A00332F001BE7017001009E
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ400Z7X
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0209
   Serial number: 26091500000000000136
   Compact disc data bank:
   Component: Gracenote2---  --- 1011
          B201A 00 [00001001] - -
                    Reset counter: 200
                    Mileage: 161178 km
                    Date: 2024.02.05
                    Time: 16:33:26
                    Voltage terminal 30: 14.8 V
                    Status_Software_Version_Management-module_name: MDUA303/Front
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0211
   Revision: 9A001003    Serial number: 0378614485 Dataset Number: 4M0909527C  0021
   Coding: 0110000202010000
   Bend angle sensor for trailer:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 16893
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Dataset Number: 4M0909460A  0010
   Coding: 0237060103002025000044
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_004_AU49.rod
   VCID: 72BC2CDA34243F9A297-8026
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30256399400000 Dataset Number: 4M0909541E  0020
   Coding: 0090
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70B826D23A280D8ADF3-8024
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777     HW: 4M0 907 777
   Component: Fahrwerk-SG   H10 0102
   Serial number: 2809150081 Dataset Number: 4M0909576L  0037
   Coding: 98505048F8
   ASAM Dataset: EV_ChassContrContiAU736 002013
   ROD: EV_ChassContrContiAU736.rod
   VCID: 76B410CA584C23BA05F-8022
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130025714
   Coding: 303030
3407883 - Level Control System Position Sensor; Front Right
          C1035 F0 [10001001] - Rebound Stop Detected
                    Reset counter: 200
                    Mileage: 161196 km
                    Date: 2024.02.06
                    Time: 14:26:10
3407885 - Level Control System Position Sensor; Rear Right
          C1037 F0 [10001001] - Rebound Stop Detected
                    Reset counter: 200
                    Mileage: 161182 km
                    Date: 2024.02.05
                    Time: 19:18:47
393238 - Internal Control Module Memory Check Sum Error
          B2000 00 [10001001] - -
          [Control module defective damper power stage front right]
                    Mileage: 161134 km
                    Date: 2024.02.01
                    Time: 15:42:51
   Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H07 0066
   Revision: 0L0D5012    Serial number: 20150831000173
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 270A0D8ECF660A324E9-8072
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 A    HW: 4M0 919 617 A
   Component: HeadUpDisplay H26 1524
   Coding: 4F00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736_AU73.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 C    HW: 4M0 907 541
   Dataset Number: 4M0909885G  0020
   ASAM Dataset: EV_ACC2BOSCHAU736 001016
   ROD: EV_ACC2BOSCHAU49X_001.rod
   VCID: 2E04F8AAE09C5B7A8DF-807A
   Part No SW: 4M0 907 217 C    HW: 4M0 907 217 A
   Component: BVS           H13 0030
   Dataset Number: 4M0909466H  0034
   Coding: 0407030600000402024023A5AD0000B4B0F0C020E280
   Shop #: WSC 32228 003 1048576
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   Dataset Number: 4M0909571F  0013
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E8438AA201C1B7ACDF-803A
   Part No SW: 4M0 959 595 D    HW: 4M0 959 595 C
   Component: TSG HFS       005 0038
   Serial number: 0000167930733  Dataset Number: 4M0909897E  0024
   Coding: 004D98000001000000003080
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   Component: TSG HBFS      005 0038
   Serial number: 0000167930736  Dataset Number: 4M0909896E  0024
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: 4M0909469E  0013
   Coding: 508000053602
   VCID: 73B229DE4B3E3692221-8026
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
   Component: LED1L         H09 2002
   Dataset Number: 4M0909471C  0011
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 196E3B768912ACC2C8D-804C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 2002
   Dataset Number: 4M0909472C  0011
End----------(Elapsed Time: 02:29, VBatt start/end: 14.8V/14.8V)-----------
and this is the new module
Tuesday,20,February,2024,17:13:42:45536
VIN: WAUZZZ4M0GD026614   Mileage: 161241km-100190miles
47-Sound System -- Status: Cannot be reached 0100
          P0672 00 [11101101] - Electrical Fault
                    Mileage: 161217 km
                    Date: 2024.02.08
                    Time: 22:05:02
                    Coolant temperature: 3 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 10.820 V
                    Glow-control unit: activation voltage: 10440 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 118.9 V²s
          P0673 00 [11101101] - Electrical Fault
                    Mileage: 161217 km
                    Date: 2024.02.08
                    Time: 22:05:02
23402 - Ride Level Control Module
          U0132 00 [00101000] - No Communications
                    Fault Frequency: 8
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:03
                    Coolant temperature: 22 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 10.740 V
                    selected gear-Bits 0-7: 0
Readiness: 1 2 0 0 0
   Coding: 100000
7 Faults Found:
13568 - Databus
          U1121 00 [00101000] - Missing Message
          [ComScl:_PDU_Fahrwerk_01-_Timeout_error]
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:03
168192 - Databus
          [ComScl:_PDU_Fahrwerk_03-_Timeout_error]
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:04
482048 - Databus
          [ComScl:_Signal_Group_SG_Daempfer_02-_Timeout_error]
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:03
275456 - Databus
          [ComScl:_Signal_Group_SG_Fahrwerk_06-_Timeout_error]
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 10:46:15
466176 - Control Module for Suspension
          U122B 00 [00101000] - Implausible Message
          [Signal_FA_Hoehenwert_VL_00_error_(255)_or_PDU_Fahrwerk_01_not_received_correctly_(combination_of_Timeout:_CS:_AC:_Error)]
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:03
465920 - Databus
          U1123 00 [00101111] - Received Error Message
          [Signal_FA_Hoehenwert_VL_00_error_(255)]
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:00
200960 - Databus
          [Signal_LWR_Hoehenwert_VL_error_(255)]
                    Fault Frequency: 9
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:03
   Coding: 1BC7F7
   Coding: 0200FF
   Coding: 230000
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:02
                    average_Voltage_terminals: 12.10 V
                    Outside air temperature sensor-Resistance: 540.16 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 9.00 °C
                    interior_temperature: 16846.00 °C
131073 - Databus
                    Fault Frequency: 8
                    Reset counter: 241
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:02
                    Outside air temperature sensor-Resistance: 542.72 kOhm
131337 - Databus
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:03
                    Outside air temperature sensor-Resistance: 414.72 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 14.50 °C
                    interior_temperature: 18254.00 °C
131344 - Databus
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:03
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:09
                    Outside air temperature sensor-Resistance: 545.28 kOhm
                    interior_temperature: 16718.00 °C
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:09
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:01
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 11.9 V
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [10001001] - Open or Short to Plus
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:04
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [10001001] - Open or Short to Plus
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:04
4196608 - FlexRay Databus
          U1032 00 [00001000] - Initialization Failed
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:57:42
16777007 - Databus
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:01
66304 - Databus
          U1124 00 [00001000] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Reset counter: 241
                    Mileage: 161241 km
                    Date: 2024.02.20
                    Time: 15:56:04
131596 - Steering Column Control Module
          U0212 00 [00001000] - No Communications
          [Timeout_Node_0x0C_DiagAdress_16_SLMS]
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:57:45
131712 - Ride Level Control Module
          U0132 00 [00001000] - No Communications
          [Timeout_Node_0x80_DiagAdress_74_EFP]
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:01
          U1101 00 [00001001] - Active
          [KS_Active]
                    Fault Frequency: 11
                    Reset counter: 201
                    Mileage: 161227 km
                    Date: 2024.02.19
                    Time: 17:14:32
8519683 - Energy Management Active
          U140B 00 [00001000] - -
                    Reset counter: 241
                    Mileage: 161227 km
                    Date: 2024.02.19
                    Time: 17:15:53
                    EM_vehicle_state: 02 1C
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
   Coding: 005D9A015E01000200003082
645635 - Bulb for Rear Left Fog Light
          B12C7 12 [00001000] - Short to Plus
                    Fault Frequency: 12
                    Reset counter: 241
                    Mileage: 161231 km
                    Date: 2024.02.19
                    Time: 17:34:48
                    Supply voltages-Terminal 30 power supply: 14.715 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.729 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.674 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 8A 94 02 30
640001 - Bulb for Left Brake Lamp / Tail Lamp
          B133A 13 [00001001] - Open Circuit
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.08
                    Time: 08:33:03
                    Supply voltages-Terminal 30 power supply: 11.740 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 11.794 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.726 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 38
                    Fault Frequency: 24
                    Reset counter: 241
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 14:46:26
                    Supply voltages-Terminal 30 power supply: 13.343 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.356 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.302 V
                    Fault Frequency: 62
                    Reset counter: 201
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:05
                    Supply voltages-Terminal 30 power supply: 12.201 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.229 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.201 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 00
                    Fault Frequency: 62
                    Reset counter: 201
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:05
131123 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 201
                    Mileage: 161227 km
                    Date: 2024.02.19
                    Time: 17:08:47
                    Supply voltages-Terminal 30 power supply: 11.794 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.767 V
                    key_error_freeze_frame: 11110101 11111111 11111111 11111111
                    Reset counter: 201
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:10
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: MFC1P73xE/HRUN
6666 - Optical data bus
          U1049 00 [00001001] - Open circuit
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 14:29:54
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -11 °C
                    Temperature of MOST transceiver-Up-to-date: 14 °C
7174 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Air suspension (0x06) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:06
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
7204 - Function Restricted due to Missing Message(s)
          [Tilt-angle indicator (0x24) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 240
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:06
   Coding: 0090
   Part No SW: 4M0 907 777 P    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H38 1215
   Serial number: 0710230971
   Coding: 98505048F8
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 46D4A00A682CF33A55F-8012
   Coding: 303030
21 Faults Found:
3342343 - Level Control System
          C1046 F6 [10001001] - Axle Load Determination Not Performed
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:54
3146257 - Temp Sensor for Ride-Height Compressor
          C102F 15 [10001001] - Open or Short to Plus
                    Fault Frequency: 18
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:54
5439488 - Inertial Sensor Package
          C115E 54 [10001001] - Missing Calibration / Basic Setting
                    Fault Frequency: 9
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:55
327680 - invalid data record
          B2005 00 [00001001] - -
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
327683 - Data Set Implausible
          B2012 00 [10001001] - -
                    Reset counter: 201
                    Mileage: 161234 km
327684 - Data Set Missing
          U1118 00 [10001001] - -
          [Data_set_missing_vehicle_specific]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
327936 - Data Set Implausible
          [Data_set_implausible_level_controller]
                    Reset counter: 201
                    Mileage: 161234 km
327937 - Data Set Implausible
          [Data_set_implausible_level_component_controller]
                    Reset counter: 201
                    Mileage: 161234 km
327944 - Data Set Implausible
          [Data_set_implausible_damper_controller]
                    Reset counter: 201
                    Mileage: 161234 km
327939 - Data Set Implausible
          [Data_set_implausible_central_signal_processing_horizontal]
                    Reset counter: 201
                    Mileage: 161234 km
327940 - Data Set Implausible
          [Data_set_implausible_central_signal_processing_vertical]
                    Reset counter: 201
                    Mileage: 161234 km
327941 - Data Set Implausible
          B2012 00 [00001001] - -
          [Data_set_implausible_inclination_display]
                    Reset counter: 201
                    Mileage: 161234 km
327808 - Control Module Incorrectly Coded
          U1014 00 [00001000] - -
          [Incorrectly_coded_coding_weight_class_front_axle_valid]
                    Reset counter: 241
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
327809 - Control Module Incorrectly Coded
          [Incorrectly_coded_coding_weight_class_rear_axle_valid]
                    Reset counter: 241
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
196608 - Ride Height Not Learned
          C1044 00 [10001001] - -
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:54
196609 - Basic Setting of Deflected Position not Performed
          C10C5 00 [10001001] - -
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:54
196610 - Quantity of Fuel Added to Tank
          C123D 29 [00001001] - Signal Implausible
          [Function limitation through missing initialization tank volume not correct]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:54
13697024 - Component Protection
          U1100 00 [00001001] - No Basic Setting
          [Component protection Not Configured Or Invalid Initial State/Ajustment]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
13762560 - Component protection
          U1114 00 [00001001] - GFA key
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
13828096 - Component protection
          U1115 00 [00001001] - No basic setting for SHE key
          [Component protection _ SHE-Key _ not configured]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
15361024 - Component Protection
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 21:24:27
   Coding: 4F00C0
8 Faults Found:
1122640 - Databus
          [TIMEOUT_SARA_08]
                    Reset counter: 241
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:01
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 12.10 V
1122596 - Databus
          [Timeout_Fahrwerk_01]
                    Reset counter: 241
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:53:06
                    Voltage terminal 15: 12.20 V
1123714 - Databus
          [Airbag_01_AB_Systemfehler]
                    Reset counter: 200
                    Mileage: 161217 km
                    Date: 2024.02.07
                    Time: 11:51:09
1123601 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Reset counter: 241
                    Mileage: 161218 km
                    Date: 2024.02.09
                    Time: 08:21:45
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 14.90 V
1123944 - Databus
          [FA_Hoehenwert_VL_00]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:01
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.70 V
1123945 - Databus
          [FA_Hoehenwert_VR_00]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:01
1123952 - Databus
          [FA_Hoehenwert_HL_00]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:01
1123953 - Databus
          [FA_Hoehenwert_HR_00]
                    Reset counter: 201
                    Mileage: 161234 km
                    Date: 2024.02.19
                    Time: 19:29:01
End----------(Elapsed Time: 02:31, VBatt start/end: 14.5V/14.6V)-----------
It's got a missing or incorrect dataset. I suggest you book an SVM session with someone who has access to the factory servers.
Mills1908
C?ID=353772
Is there no way I can get this information from the old control module?
I don't think so. Most modules treat datasets as "write only" and don't support reading them.
Mills1908
C?ID=353772
When you say "most" does that mean it's possible? If so how would i go about reading it?
My understanding is that there are a few infotainment systems on which it's possible, but I've never heard of any other module that allows reading of the dataset. Does that conclusively mean it's not possible on your chassis control module? No, it doesn't. But to even begin to try, one would need a dataset file for it, to know at what memory addresses the dataset lives.
In any case, it's not something you can do with VCDS.
