Audi S3 8V sedan s-tronic MY 2016 rear view camera coding
S3 8V SEDAN
Greece
HUC-2H
Hello everyone, I'm Bill from Greece and I'm a new user. I have been reading for a long time about the coding and changes made to your cars. I recently installed an OEM high reversing camera in my car with the help of an electrician friend. Everything was done correctly and a basic adjustment was made with the help of a professional diagnostic tool (odis) that the electrician had. So far so good, after the end of the whole process and after everything was working perfectly, an error remains in the diagnosis of the vag com cable which has to do with some message that the camera does not receive???
I should note that my car is factory stock and the only upgrade that was made is the reversing camera.
The following is a detailed auto scan of my car.
Am i missing something ?
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          6C A5 A9 BB BC
VIN: WAUZZZ8V1G1XXXXXX   Mileage: 57904km-35979miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---    CVN: AD8DD0AA
   Coding: 0A1D00122466010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 43851480CA037F899E-8016
   VINID: 9D196AAAA2260570401032011415C1C9FB
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4912
   Revision: 06253104    Serial number: TFK01508290443 CVN: 00007ACF
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53A524C03A63EF092E-8006
   Revision: 00000000    Serial number: 62425000000291
   Coding: 31F16BA254242A6F017F070141C8698CD62A5480E08296F6184150F48208
   VCID: 7AFBA964FD49FE418D-802E
   Revision: 00021000    Serial number: 0380112412 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A7B6964BDC93E41CD-806E
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000738246
   Coding: 03000004000000011000000000001100
   VCID: 336544409AA3CF090E-8066
   Humidity sensor: exterior:
   Serial number: 111988C7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061526401121 Dataset Number: 8V0909514M  0091
   Coding: 04051D46C24106FD03804004B11807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0919C6A8A8AFE5D994-805C
   Component: WWS371 150803  042 0585
   Serial number:         150904042631
   Coding: 0A47F7
   Serial number: 20641493
   Coding: 00006C
   Serial number: 09 07 2015  00001805
   Serial number: 000000000ZY152170U9L
   Serial number: 00000000000033468396
   Revision: --------    Serial number: 39331526105103 Dataset Number: 8V0909526E  0042
   Coding: 0070150011
   Shop #: WSC 73430 790 00999
   ROD: EV_EPHVA18AU3700000_VW26.rod
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 14091503030494 Dataset Number: 8V0909863D  0016
   Coding: 003E1701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 489F03ACF3255CD14B-801C
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       180915035 Dataset Number: 8V0909554E  0015
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR13SUJQ Dataset Number: 8V0909602D  0009
   Coding: 98CCC0000C0000005C5400CA004800000065
   VCID: 000FDB8C9B95A491C3-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 35767000000644C4D61Z
   Subsystem 2 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 35867000000B34C4D61/
   Subsystem 3 - Part No SW: -----------    HW: 480 401 109 15
   Serial number: 35165029D1D1B5D460CO
   Subsystem 4 - Part No SW: -----------    HW: 480 401 109 15
   Serial number: 3526502A11D1B5D17213
   Subsystem 5 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3556502A51A14CC120FD
   Subsystem 6 - Part No SW: -----------    HW: 480 402 007 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B11B7E8E221CN
   Subsystem 7 - Part No SW: -----------    HW: 480 402 007 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B91C52F23E2BR
   Subsystem 8 - Part No SW: -----------    HW: 480 002 608 15
   Serial number: I0M8000000004D21461-
   Subsystem 9 - Part No SW: -----------    HW: 480 002 608 15
   Serial number: I0N8000000031111461O
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 GR    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 14071508490401
   Coding: E818
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 102FEBCCCBF5D41153-8044
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 872 A    HW: 8V0 920 872 A
   Component: KOMBI         H03 6420
   Coding: 078D181A7F8400080081EA001000000000000000
   VCID: 3B756C60B2F30749D6-806E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 22091510802033 Dataset Number: 8V0909515K  0065
   Coding: 030100043F085A005B0002789C0B00000001010000000000000000000000
   GVL: 01D43C1000000600408C90000002CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75E1BA58D4579139E0-8020
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 03 09 2015  E0008343
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001509232442
   Serial number: HA1-00027.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4A9B39A4ED29AEC15D-801E
   Revision: 00000000    Serial number: 15000208786002
   Coding: 5D00000000000000
   VCID: 3467475C9FADC83117-8060
   Serial number: 020915BHU0009A Dataset Number: 8V0909872G  0035
   Coding: 001C9A204000040000001003
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Dataset Number: 8V0909852K  0022
   Coding: 9103
   VCID: 39797668B8CF3559C4-806C
   Serial number: 040915BI406674 Dataset Number: 8V0909873G  0035
   Coding: 001C92204000040000001003
   VCID: 428B1184D519768195-8016
   Component: AFS-ECU       H01 0110
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0039
   Coding: 01A200002B230200
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F8D1870A6EB1B69FA-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 036 N    HW: 8V0 035 036 B
   Component: MU-H-LND-EU   H45 0397
   Serial number: A300I0F7553230 Dataset Number: 8V2909545H  0046
   Coding: 01730101FF0A000021111101000A00132F000205010001009E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 3D716278ACE70979E8-8068
   Subsystem 1 - Part No SW: V03 959 801 PN    HW: -----------
   Component: ECE 2018  --- 0166
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY203XHM
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000013071500040193
   Compact disc data bank:
   Component: Gracenote  --- 1010
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H19 0231
   Dataset Number: 0005
   Coding: 02730101A2002001400040
13705478 - Databus
                    Reset counter: 161
                    Mileage: 57904 km
                    Date: 2024.02.17
                    Time: 18:46:36
                    passive
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000417522    Dataset Number: 8V0909466L  0040
   Coding: 0101010001010303000500000100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C776F7CB7FD0071DF-8068
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150901201780
   VCID: 7DF1A278EC67C979A8-8028
   Serial number: 050915BI405299 Dataset Number: 8V0909897E  0021
   Coding: 000C92204000040000001002
   VCID: 45810A98C43741B9B0-8010
   Serial number: 050915BI405293 Dataset Number: 8V0909896E  0021
End-------------------------(Elapsed Time: 06:06)--------------------------
MrMeeseeks
LP/SN
Needs a full unedited autoscan. There is information missing
MrMeeseeks
LP/SN
Certainly.
The autoscan that is generated by VCDS, Please post it again, unedited, no amendments, nothing deleted from the scan's text.
Here's a How-2 guide
S3 8V SEDAN
Greece
HUC-2H
Saturday,17,February,2024,19:01:29:38567
VCDS Version: 23.11.0.0 (x64)
Dealer/Shop Name: Local Dealer
Workshop Code: 790 73430 000999
VIN: WAUZZZ8V1G1043815   License Plate:
          6C A5 A9 BB BC
VIN: WAUZZZ8V1G1043815   Mileage: 57904km-35979miles
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0070150011
   Coding: E818
   Generator:
   Coding: 0001
   Coding: 9103
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
13705478 - Databus
                    Reset counter: 161
                    Mileage: 57904 km
                    Date: 2024.02.17
                    Time: 18:46:36
                    passive
S3 8V SEDAN
Greece
HUC-2H
Certainly.
that is better now ?
S3 8V SEDAN
Greece
HUC-2H
I'm wondering if I posted the problem I'm having in the wrong place or if I should post it where retrofits are mentioned
S3 8V SEDAN
Greece
HUC-2H
Since you are not a Verified member, you can't post in the Retrofits section.
Sir can you please tell me what must do, to be a verified member ?
Bruce
Near Philadelphia, PA, USA
Please view this thread found in the "How To" drop down of the blue bar at the top of the page:
Right, if you were using VCDS with a current interface, it would show you something like this:
13705478 - Databus
[message Parkhilfe_01 not received]
S3 8V SEDAN
Greece
HUC-2H
with odis e my electrician found this above , is this helpful ?
S3 8V SEDAN
Greece
HUC-2H
How is that any different that what I told you?
Yes, what I'm asking you is based on the diagnosis that I should look for, what's going on? In pdc ?
If you want, please tell me from your experience what I should pay attention in order to solve the problem
NEtech
Denmark
C?ID=56995
Do you have a problem, besides there is an DTC?
You can try and change [10-Park/Steer Assist] to 0270150011
and [6C-Back-up Cam.] to 0273010122002001400040
I recommend to buy/upgrade to new version VCDS interface!
NEtech
Denmark
C?ID=56995
And most Audi A3 camera retrofit, has that DTC, U1121 [message Parkhilfe_01 not received]
  • Informative
S3 8V SEDAN
Greece
HUC-2H
thank you very much , i will report soon
S3 8V SEDAN
Greece
HUC-2H
Hello to all, the problem was solved by intervention of the manufacturer.
In particular, he forwarded to my email the dataset that he reconfigured in 6C.
The process was done with odis e and after 20-25 seconds, various sounds were heard from the car's units.
Cleared errors except for 6C and 5F, because the camera encoding was zeroed.
After coding magically all the errors disappeared, and the diagnostic protocol took the form below.
Saturday,24,February,2024,12:43:05:38567
Mileage: 57921km-35990mi   Repair Order: coding 6C success
          6C A5 A9 BB BC
VIN: WAUZZZ8V1G1043815   Mileage: 57921km-35990miles
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0070150011
   Coding: E818
   Generator:
   Coding: 0001
   Coding: 9103
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Dataset Number: 8V0909460E  0005
   Coding: 02730101A0002001400040
End-------------------------(Elapsed Time: 05:48)--------------------------
