2003 VW Passat 1.8L Turbo
ruthymimi
California, USA
C?ID=561169
why do I have an error message when i'm doing a throttle relearn?
Monday,19,February,2024,21:49:30:47881
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWMD63B93E371123   License Plate: COLO
Mileage: 227920km-141622mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWMD63B93E371123   Mileage: 227920km-141622miles
Address 01: Engine        Labels: 06B-906-018-AWM.clb
   Part No SW: 4B0 906 018 DQ    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0060
   Revision: 00000000    Serial number: VWZ7Z0C6993469
   Coding: 0016501
   Shop #: WSC 25162 067 57207
   VCID: 73B3CE7DC7AE9802221-5160
   VINID: 9E69DD5060D22435431C10420C4C17B21C
17966 - Throttle Actuator (G186)
            P1558 - 002 - Electrical Malfunction
17987 - Throttle Actuator (J338)
            P1579 - 001 - Adaptation Not Started
17953 - Throttle Valve Controller
            P1545 - 001 - Malfunction
            P1558 - 008 - Electrical Malfunction
            P1545 - 008 - Malfunction - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00022
   Shop #: WSC 05314
   VCID: 53F36EFD22EEF802C21-51F2
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-00 -
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 05311
   VCID: 2411FD2137C04FBA6BB-513C
GetAttachmentThumbnail
1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-920-xx5-17.lbl Part No: 3B0 920 927 B Component: KOMBI+WEGFAHRSP VDO V08 Coding: 07235 Shop #: WSC 00222 VCID: 2411FD2137C04FBA6BB-513C WVWMD63B93E371123 VWZ7Z0C6993469 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.clb Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05311 VCID: 70B9C171B3B8A31ADF3-513C 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 C Component: 08 Komfortgerát HLO 0003 Coding: 00258 Shop #: WSC 05311 VCID: 372B3A6D96563422DE9-4B1E Subsystem 1 - Part No: 1C1959801 Component: 08 Tõrsteuer.FS KLO 0009 Subsystem 2 - Part No: 1C1959802 Component: 08 Tõrsteuer.BF KLO 0009 Subsystem 3 - Part No: 1C0959811 Component: 08 Tõrsteuer.HL KLO 0009 Subsystem 4 - Part No: 1C0959812 Component: 08 Tõrsteuer.HR KLO 0009 3 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 00913 - Window Regulator Switch; Front Right Driver (E81) 27-10 - Implausible Signal - Intermittent 01358 - Internal Central Locking Switch; Driver Side (E150) 27-10 - Implausible Signal - Intermittent End----(Elapsed Time: 04:50, VBatt start/end: 11.7V/12.0V. VIgn 12.0V)-----
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Could be a bad throttle body or wiring.
First remove it and clean it.
Also check O2 sensor wiring known to short out against body and do damage to ECU.
This is a TSB for a wiring issue at connector. It is not for you car but does apply because it's the same connector. Take note there are two different connectors match yours.
How is the idle?
Does it rev up and down with gas pedal?
Good Luck
Jef
HQ
Ah, out in the open here... so as per the email...
With the replacement throttle body, go into 01-08-062, do you get the same results as the original throttle body?
ruthymimi
California, USA
C?ID=561169
How is the idle?
Good Luck
thank you!
EuroX
Northern NJ USA
C?ID=208579
How is the idle?
Good Luck
Won't apply to this vehicle. 03' will be 1.8T not a belt driven 2.0T. I have never seen that TSB fix anything just a waste of time if you ask me. Most common issue's on B5.5 passats were throttle body or throttle pedal. Nothing in between unless rodents got to it. My money is on the throttle body being fucked.
ruthymimi
California, USA
C?ID=561169
How is the idle?
Good Luck
Actually, I haven’t tried to start it since I installed this Throttle Body because this is the third one I’ve installed. I was told by a repair shop that when I attempt to start it with pending codes, I ruin the part because the codes attach to the new one.
ruthymimi
California, USA
C?ID=561169
Yes Jef,
It's the same unfortunately. :(
ruthymimi
California, USA
C?ID=561169
This car drove excellently and was mechanically sound. I just had the timing belt done, all the flushes, everything.
There was a recall on the vehicle, so I took it to a dealership. However, it was driving strangely. I asked them to look further, and they said the throttle body needed replaced. Unfortunately, an OEM throttle body would take up to a year to receive. After six months, I decided to retrieve my vehicle because they wouldn't provide me any updates or return my calls.
I had it towed from the dealership because it would not run. even though I drove it there with a brand new battery. When I brought it home I bought an aftermarket throttle body and installed it. It didn't work. I bought a second one. It didn't work so I took it to the repair shop that is ran by a German young man. He said he had VCDS and he did not. It was a knockoff. So I bought VCDS myself and a used OEM Throttle Body from ebay recently. And this is where I'm at..... sigh
ruthymimi
California, USA
C?ID=561169
   Coding: 0016501
   Coding: 00022
   Shop #: WSC 05314
            P1848 - 35-00 -
   Coding: 12345
   Shop #: WSC 05311
a little more background:
EuroX
Northern NJ USA
C?ID=208579
What recall was the vehicle in for? I would try to find a good known throttle body.
Ignition on or engine running using Basic setting 060 or 098? TB part number 06B 133 062 M
EuroX
Northern NJ USA
C?ID=208579
on this car should be 60 still IIRC.
Jef
HQ
Key on, engine off, remove intake boot from throttle body. Go into 01-08-062. Manually push the throttle body open... does the ECM report data showing the valve is moving?
Wiring harness... unplug the throttle body, unplug the ECM. Ohm test wiring:
  • TB T6a/3 to ECM T121/117
  • TB T6a/5 to ECM T121/118
Make sure those wires are not shorted to each other or to ground.
ruthymimi
California, USA
C?ID=561169
When i press down the accelerator pedal completely the 'accelerator pedal position sensor' only reads 75%.
ruthymimi
California, USA
C?ID=561169
both systems have closed circuits.
ruthymimi
California, USA
C?ID=561169
I'm going to purchase an accelerator pedal.
