I'm trying to code out the factory trailer hitch on this car. I used the `reverse` method for coding a trailer module for this car, but for some reason I see there is more to be altered in codings.
Below is the factory scan, and the scan after the modifications. After looking at scans from cars without factory hitch, I believe there should be something altered in the ABS coding
Tuesday,06,February,2024,16:01:31:36437
VCDS Version: 23.11.0.0 HEX-NET CB: 0.4643.4
VIN: WAUZZZF51JA132102 License Plate:
Mileage: 91025km-56560mi Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 6D 81 A5 AC
BB BC
VIN: WAUZZZF51JA132102 Mileage: 91025km-56560miles
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AD HW: 04L 907 309 L
Component: R4 2.0l TDI H35 9970
Revision: B1H35--- CVN: 6442B106977AA471B866C2AD
Coding: 0A254032232405083418
Shop #: WSC 15598 004 104857
ASAM Dataset: EV_ECM20TDI01104L906026AD 005010
ROD: EV_ECM20TDI01104L906026AD_005.rod
VCID: 6C94CB878705A2F10F-8038
VINID: 9D196AAAA58505A4410C2040082F2BE062
17158 - Implausible Data Received from ESP Control Module
U0416 00 [00100111] - -
Mileage: 91025 km
Date: 2024.02.06
Time: 15:39:51
Engine RPM: 0.00 /min
Coolant temperature: 9 °C
Intake air temperature: 10 °C
Voltage terminal 30: 10.980 V
Acceleration: 0.000 m/s˛
Cruise Control System (CCS): status-Bits 0-7: 2
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 8
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 128
Accelerator pedal travel: raw value: 0.00 %
Drivetrain coordinator: brake function status-Bits 0-7: 32
Drivetrain coordinator: brake function status-Bits 0-7: 1
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 EB HW: 0HK 927 156 B
Component: 0CK 20TDI RdW H01 0002
Revision: --H01--- Serial number: 0000001575 CVN: B6299DAA
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
VCID: 05429E2384AF73B9F0-8050
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190070001538
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 Q HW: 8W0 907 379 J
Component: ESP9 Plus H10 0775
Dataset Number: 8W2909504F 0006 CVN: 140A545A
Coding: 0CAA489A10A50A98519F4891007F5292E5B592301208508A12004A49A7AD49
Shop #: WSC 06334 790 00001
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 53E6707B3A7B1D092E-8006
11776 - Databus
U1121 00 [00101111] - Missing Message
[ComScl:_PDU_Anhaenger_01-_Timeout_error]
Mileage: 91025 km
Date: 2024.02.05
Time: 15:28:37
80 00 00 00 CA 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
494336 - Trailer Control Module
C1255 F0 [00101111] - Brake Light Signal Implausible
Mileage: 91025 km
Date: 2024.02.05
Time: 15:28:37
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 Q HW: 8W0 820 043 Q
Component: Klima Zone 1 H40 0241
Coding: 141800295140000500000100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 41CA4A33D0079F998C-8014
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002588261
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H02 0007
Serial number: 0720D63900PAG0FSA002
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 8W2909514E 0036
Coding: C2501142C11800CD0545001018AC80B9130B1108000000000000000060001A01004100A222B602
Shop #: WSC 00046 123 12345
VCID: 0248853F95814481D5-8056
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 050618 036 0471
Serial number: 00000001805290302653
Coding: 5FC7F7
Serial number: 21578817X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 09 04 2019 01936792
Interior Light Module:
Subsystem 4 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00873098
Subsystem 5 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000067976002
196898 - Databus
[Engine control module: received error value in signal TSK_status_PLA]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 15:24:09
average_Voltage_terminals: 14.80 V
Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C
interior_temperature: 24.50 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00S1A3E Dataset Number: 8W2909602AC 0012
Coding: AACCF0C00C800000585000F3D04C00000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4CD46B07E74542F16F-8018
Subsystem 1 - Part No SW: ----------- HW: 442 060 607 18
Serial number: 3577Y00AF26D2BB33069
Subsystem 2 - Part No SW: ----------- HW: 442 060 107 18
Serial number: 3587Y00B327DBDE2431C
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 906 18
Serial number: 3517700C72A775729117
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 906 18
Serial number: 3527700A52B0ECB1016B
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B92A9BC72029N
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B92A9BC72430K
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 906 18
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B92AD017103C0
Subsystem 8 - Part No SW: ----------- HW: 442 431 406 18
Component: PedPSensor_D2 256 0887
Serial number: I0M9M009D281F403F30F
Subsystem 9 - Part No SW: ----------- HW: 442 431 406 18
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BD281F403F19P
B13BC F2 [00001000] - No function
Reset counter: 28
Mileage: 91025 km
Date: 2024.02.05
Time: 14:32:51
1055488 - Databus
[NWD: 0x661 Anhaenger_01 Timeout]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 15:08:45
Part No SW: 4N0 907 129 MN HW: 4N0 907 129 MN
Component: Lenks.Modul H03 0009
VCID: 095A9213A8B717D994-805C
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0373
Coding: 05A444C6289000080000E9601000400000000000
VCID: 43C6403BCA1B8D899E-8016
Part No SW: 8W5 907 468 H HW: 8W5 907 468 G
Component: Gateway H43 0145
Revision: AS010003 Serial number: 038AS759819621 Dataset Number: 8W2909515F 0050
Coding: 030100010000064041070000005900124C980007100000000175078E10000000
GVL: 01503C0008040000408C08000000C80000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
VCID: 4ED0610F115970E101-801A
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170328152854 21617
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 9386198204
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AA HW: 4M0 907 397 A
Component: LCM_MLBevoH05 0024
Dataset Number: 8W2909519A 0002
VCID: 76A0E9EFC9496821E9-8022
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W2909520B 0003
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0130
Serial number: 0000333724193 Dataset Number: 8W0909872G 0031
Coding: 005F8B224000000000001000
Shop #: WSC 06325 790 00001
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 4FEE7C0B165379E90A-801A
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Dataset Number: 8W0909852R 0042
Coding: 09880300008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42C8453FD501848195-8016
Part No SW: 8W1 907 064 BH HW: 8W1 907 064 H
Component: BCM2 MLBevo 044 0565
Dataset Number: 8W2909501E 0035
Coding: 01340000002000E06309A0000E00080231024000804104502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 018017
ROD: EV_BCM2HellaAU736_018_AU49.rod
VCID: 044483278F954AB1E7-8050
Subsystem 1 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12053527
131072 - Antenna for Access/Start Authorization; Left
B1474 12 [00001001] - Short to Plus
Reset counter: 243
Mileage: 91025 km
Supply voltages-Terminal 30 power supply: 12.405 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.365 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.283 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 02 10 00 80
antenna_freeze_frame: 00010001 00000010 00000000 01011011
Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
Component: TSG BFS 005 0125
Serial number: 0000275205044 Dataset Number: 8W0909873E 0028
Coding: 001F8B234000000000001080
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 036 B HW: 8W5 035 036
Component: MU-P-LN-EU 034 1177
Serial number: A795B0JB082728 Dataset Number: 8W0909545AB 0041
Coding: 01940401FF0A000053110001000A00332F000EE5017001009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 373E24EB8EC3D12932-8062
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Multimedia System 1:
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00119051800820393
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK118031900040597
Compact disc data bank:
Component: Gracenote2 --- 1016
B201A 00 [00001001] - -
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:25
Voltage terminal 30: 15.1 V
Status_Software_Version_Management-module_name: MDUC303/Front
0532 - Loudspeaker Channel 5
B13A4 01 [00001001] - Electrical Failure
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.06
Time: 15:40:15
0537 - Loudspeaker Channel 6
B13A5 01 [00001001] - Electrical Failure
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.06
Time: 15:40:14
Voltage terminal 30: 15.0 V
1637 - Interface for External Media
U11B8 00 [00001001] - No Communications
[USB - communication error]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:20
Interface for external media: status-Status: Open circuit
3077 - Telephone baseplate
B1051 13 [00001001] - Open Circuit
[Bracket for mobile phone holder - open circuit]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:19
Voltage terminal 30: 15.2 V
7191 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:21
BAP-BAP_Function_ID: 02
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 32012031100000 Dataset Number: 8W2909541B 0004
Coding: 0630
VCID: 48DC5717F33DAED14B-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19061853186100
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3E3031CFA1F9E061F1-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H17 0050
Dataset Number: 8W2909466C 0019
Coding: 0404090300000403022023A1C50000FC10F0C010C000
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 40CC4F37DB0D969183-8014
1122565 - Databus
[TIMEOUT_Anhaenger_01]
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:16
Control Module temperature: 37 °C
Voltage terminal 15: 15.00 V
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 28
Mileage: 91025 km
Date: 2024.02.05
Time: 14:54:21
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0006
Dataset Number: 8W2909571D 0004
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 322815FF65A1340105-8066
Part No SW: 8W0 959 395 H HW: 8W0 959 395 F
Component: TSG HFS 005 0130
Serial number: 0000329413321 Dataset Number: 8W2909897D 0026
Coding: 000049220000000000001000
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
Component: TSG HBFS 009 0130
Serial number: 0000362310754 Dataset Number: 8W0909896G 0031
Coding: 000009220000000000001000
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 15.0V/15.0V)-----------
Address 15: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Monday,19,February,2024,15:30:42:36437
BB BC
MTF pump:
11776 - Databus
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:49
96 00 00 00 CA 24 00 00 00 00
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:49
Coding: 5FC7F7
Coding: 02005D
196898 - Databus
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:49
average_Voltage_terminals: 15.20 V
Outside air temperature sensor-Outside air temperature on CAN: 12.00 °C
interior_temperature: 18.00 °C
1055488 - Databus
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:48
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:56
Voltage terminal 30: 15.3 V
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:13:54
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:49
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:52
Coding: 0630
1122565 - Databus
Reset counter: 243
Mileage: 91025 km
Date: 2024.02.19
Time: 15:12:48
Control Module temperature: 22 °C
Voltage terminal 15: 14.90 V
End----------(Elapsed Time: 01:39, VBatt start/end: 15.0V/15.0V)-----------
