Wednesday,21,February,2024,13:44:58:13049
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VV1B7AX9NM062540 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 3C 42 44 52 5F 75 A5 BB BC
VIN: 3VV1B7AX9NM062540 Mileage: 33811km-21009miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DTEA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 G HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0001
Revision: 1DH31000 CVN: 28F3C2CD
Coding: 012A00122464012F34000000000000000000000000000000
Shop #: WSC 00066 790 00449
ASAM Dataset: EV_ECM20TFS01183A907115G 001002
ROD: EV_ECM20TFS01183A907115G.rod
VCID: 2A0D15E83C7C06CA517-807E
VINID: 0E698148746825E74018214400A97773B0
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 GC HW: 09G 927 158
Component: AISIN AQ8 206 3821
CVN: 75CD90AF
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 00066 790 00444
ROD: EV_TCMAQ450031_VW37.rod
VCID: 7AADE5A88C5C764A617-802E
Part No SW: 5Q0 614 517 GB HW: 5Q0 614 517 BP
Component: ESC H35 0114
Revision: 00000000 Serial number: 53381000000885
Coding: 0BFA6BA450261B6EC57C0204A2C349D0D60AD8A34045927018415058D2A24A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049.rod
VCID: 77ABFC9CBF4E6B221E9-8022
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0585956368 Dataset Number: V03935340QJ 0001
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C94F608230D4DAA73-801C
12786210 - Databus
U1122 00 [00001000] - Implausible Message
[Errorvalue Messagecounter Klemmen_Status_01]
Reset counter: 90
Mileage: 31951 km
Date: 2023.12.21
Time: 08:59:11
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
Terminal_50_Kessy_specified_value: On
Terminal_50_Kessy_actual_value: On
ZAT_pressed: On
Request active: Condition met
Enabling Steering Column Lock: Condition met
Enabling immobilizer: Condition not met
Control Module Voltage: 12.104 V
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: GO_Scan_1
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:| 5G0-907-426.clb
Part No SW: 5NN 907 426 G HW: 5NN 907 426 G
Component: AC Manuell el H36 5001
Revision: 20K02000 Serial number: 00000D00771170
Coding: 00020004200110001100000000000016
ASAM Dataset: EV_ACManuePrehVW37X 002028
ROD: EV_ACManuePrehVW37X_002_VW37.rod
VCID: 54F16B104E78603ADBB-8000
Part No SW: 5Q0 937 085 CJ HW: 5Q0 937 085 CJ
Component: BCM MQBAB MNA H44 0511
Serial number: 1352088901ˇˇˇˇ Dataset Number: V03935358PQ 0001
Shop #: WSC 00066 790 00142
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 0353984CFB963782321-8056
Subsystem 1 - Part No SW: 5NN 955 119 B HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 211018 041 0374
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S4Y21M08D02H05M40S14
Coding: 0008DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 KK HW: 5Q1 953 569 H
Component: Lenks.Modul H04 0190
Serial number: 0300061120210C200422
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H07 0383
Dataset Number: V03935348SU 0001
Coding: 3200075118FF8728749C810580409700000000000000000034
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 45D74654B522C9B25C5-8010
2404 - Databus
[FAULT_TSK_SHUTDOWN_ACC_ACTIVE_PLAUS_FAIL]
Reset counter: 73
Mileage: 32309 km
Date: 2024.01.05
Time: 11:03:31
Voltage terminal 15: 14.7 V
Control Module temperature: 24 ∞C
Vehicle speed: 22.27 m/s
Longitudinal acceleration: 0.00 m/s≤
Adaptive distance regulation: status: ACC_StandBy
196740 - Sensor for Automatic Distance Control
C110B F0 [00001000] - Limited Visibility
[FAULT_SENSOR_BLOCKAGE]
Reset counter: 74
Mileage: 32349 km
Date: 2024.01.06
Time: 14:31:11
Voltage terminal 15: 14.9 V
Control Module temperature: 22 ∞C
Vehicle speed: 15.51 m/s
Longitudinal acceleration: 0.25 m/s≤
Part No SW: 5Q0 959 655 CB HW: 5Q0 959 655 CB
Component: AirbagVW21 008 0421
Serial number: 003J4M06KMEO Dataset Number: V03935355MG 0001
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 025D9D48E48C3E8A397-8056
Component: BF-Gewichtss. H16 0022
Serial number: IBH00000000000HBLWJH
Coding: 303552
Subsystem 2 - Part No SW: ----------- HW: 480 000 909 21
Serial number: 357000000005A161575C
Subsystem 3 - Part No SW: ----------- HW: 480 001 009 21
Serial number: 358000000005B6B8385U
Subsystem 4 - Part No SW: ----------- HW: 480 402 508 21
Component: SideSensor_Dr 005 6149
Serial number: 3510001ACC5B5FE5716R
Subsystem 5 - Part No SW: ----------- HW: 480 402 508 21
Component: SideSensor_Pr 005 6149
Serial number: 3520001BAC5B5FE096BY
Subsystem 6 - Part No SW: ----------- HW: 480 400 410 21
Component: FrontSensor_D 005 6149
Serial number: 3550001B0C618EF56B4L
Subsystem 7 - Part No SW: ----------- HW: 480 400 410 21
Component: FrontSensor_P 005 6149
Serial number: 3560001B0C618EF5B90L
Part No SW: 5NA 920 410 A HW: 5NA 920 410 A
Component: KOMBI 040 3092
Coding: 08A400086788CF050288220B1000000020000D02
ASAM Dataset: EV_DashBoardJCIMQBAB 010005
ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
VCID: 35373694E5C25932CC5-8060
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 10122100840784 Dataset Number: V03935348DD 0001
Coding: 030900347F085B00FA000058180F00010001070000000000000000000000
Shop #: WSC 00066 790 00242
GVL: 01403C000000040040CC80008000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 79AFFAA4895A7D5268D-802C
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 3G0 959 442 R HW: 3G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-YLG H07 0110
Serial number: YLG-0700092356212112
Coding: 2C2B00
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 9291698400
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 11230040725267 Dataset Number: V03935352AH 0001
Coding: 5294C640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F3AA4C9DABD5228D-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 11230041044927
Part No SW: 5Q4 959 393 P HW: 5Q4 959 393 P
Component: TSG FS 009 0911
Serial number: 85018135204198 Dataset Number: V03935346AQ 0001
Coding: 003013200000048000000000
Shop #: WSC 01383 790 50316
VCID: 50F967007A601C1AFF3-8004
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000010790741
Coding: 011000
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Dataset Number: V03935333UK 0001
Coding: 111F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 51FF6204716A1512F0D-8004
Part No SW: 5Q4 959 392 P HW: 5Q4 959 392 P
Component: TSG BFS 009 0911
Serial number: 86018135400736 Dataset Number: V03935346AR 0001
VCID: 4FFB647C675E03E2E69-801A
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000010756205
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3CN 035 869 HW: 3CN 035 869
Component: MU-E--ER 720 0920
Serial number: 27092100020355 Dataset Number: V03935345LA 0001
Coding: 02231600BE00000041220001001000009F0000D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW26.rod
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0302
Serial number: 0000000110NVMU2 Dataset Number: V03935357EW 0001
Coding: 02326020196828208005461160100607
ASAM Dataset: EV_OCUGen3Low 002039
ROD: EV_OCUGen3Low_002_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E81904310212880 Dataset Number: V03935357ND 0001
Coding: 00000A88006E4020089F10000020000000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.3V)-----------
