Touareg 7P EPB replacement
dubwerkz
Malaysia
C?ID=200781
Hi there,
Recently after rectifying the water ingress from the panoramic roof,i had to replace the EPB module.After replacement i have found out that all codes has been missing for the module.I would need guided steps help from you guys on this.
I have the previous log scan with me.
dubwerkz
Malaysia
C?ID=200781
before:
Monday,22,January,2024,12:38:08:06704
VCDS Version: 23.11.0.0 (x64)
VIN: WVGZZZ7PZCD007743   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F
          62 6C 6D 72
VIN: WVGZZZ7PZCD007743   Mileage: 140758km-87462miles
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 AC    HW: 03H 907 309
   Component: 3,6l FSI EU4  H15 8035
   Revision: M7H15---    CVN: D5EEA670
   Coding: 002A0012432600000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023AC 002003
   ROD: EV_ECM36FSI01103H906023AA.rod
   VCID: 63C557B76A4F8889BE-8036
   VINID: 9E65EAAAA1E0A935000071C40CFD62F755
12348 - Coolant Pump 2
          P261A 00 [11101000] - Open circuit
                    Mileage: 140682 km
                    Date: 2024.01.21
                    Time: 15:52:07
                    Engine RPM: 1121.50 /min
                    Normed load value: 45.9 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.182 V
                    Relative load value: 33.16 %
12351 - Coolant Pump 2
          P261C 00 [00100000] - Short to GND
                    Mileage: 140675 km
                    Date: 2024.01.21
                    Time: 12:16:20
                    Engine RPM: 1601.50 /min
                    Normed load value: 41.2 %
                    Vehicle speed: 18 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.253 V
                    Relative load value: 25.92 %
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750     HW: 0C8 927 750
   Component: AL1000 AISIN  001 1883
   Serial number:                CVN: 5D0818D0
   Coding: 001168
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 69D9459F8863D2D974-803C
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 416810010EC010 Dataset Number: 7P0012v____ 7P13
   Coding: 5B6B13C30924255ADAFBC89790D5A4407700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 4581A92FC4BBD6B9B0-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0330
   Coding: 0D960000000000000000
   VCID: 73E527F7D2AF1809CE-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000106303011
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000006239872
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 3467E4EB97215F3117-8060
03776 - Motor for Lumbar Support Adjustment
                    Fault Status: 01100101
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:49
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: 46A6200E80
   VCID: 7EF306C3E1ED4561B1-802A
0315 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:54
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001117461
   Coding: 26001011D1345D010021000380005D0C4319470803010241800000020000
   VCID: 6BD53F978A9FC0C906-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    110606  31  0020
   Serial number: 90243401110628030024
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002006110281
   Subsystem 3 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA101510000000298129
   Coding: 010300
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:00
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28291116783340
   Coding: 508501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428BB233D595E18195-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag02P H05 0023
   Revision: --------    Serial number: 003JX00392G% Dataset Number: 7P6003v____ 0869
   Coding: 000000000000000000000000000000003250
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 408FB83BDB99F39183-8014
   Serial number: 3575LRB405T0IODO8GIN
   Serial number: 3585LRB405D0CTC430KA
   Serial number: 3515RRB405F0KSEGM930
   Serial number: 3525RRB405D0KSEGM0H4
   Serial number: 3555NRB404S70PNC7OA8
   Serial number: 3565NRB40536KCRCN0I
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NH20002S
   Coding: 000C35
   Shop #: WSC 00070 000 00000
   VCID: 387FD0DB8B49BB513B-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0082533
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 880 M    HW: 7P6 920 880 M
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658020711592004
   Coding: 333730002A000008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000185045
   Coding: 0021032600
   GVL: FF4F40451D67000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387FD0DB8349BB513B-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650739178
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000006240407
   Coding: 00383B0000004201000001010101202020202121202020
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000117294675
   Coding: 011D1620DE01451205080000
   VCID: 4487B42BC781EFB1A7-8010
   Revision: 00002001    Serial number: 0152409582
   Coding: 01001E2028B9109583300620010000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO1247152$
   Coding: 191100
   Subsystem 2 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO12419472
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000117389629
   VCID: 3B75CFD7BA7F9049D6-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11615001D5    Dataset Number:             A001
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3663DEE3895D4D2129-8062
   Slave 3:
0040 - Motor for Electronic Parking Brake
          C10E3 29 [00001000] - Signal Implausible
                    Voltage: 13.0 V
0022 - Control Module for Electronic Parking Brake
          C10E2 01 [00001001] - Electrical Failure
                    Reset counter: 14
                    Voltage: 13.0 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0008
   Coding: 010E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CF70CCBF7F157719F-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
13705478 - Databus
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:49
   Part No SW: 4G1 035 053 C    HW: 4G1 035 053
   Component: Radio U Basic H41 0079
   Revision: AB001007    Serial number: 049FY0BB006614
   Coding: 070005020100000003
   VCID: 1F4D1B470EA7EC69DA-804A
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:26:00
                    Voltage: 12.30 V
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:59
                    Voltage: 12.30 V
   Part No SW: 7P6 035 764 A    HW: 7P6 035 764 A
   Component: H-BNT-RW      H44 0318
   Revision: --------    Serial number: 479F00B7512574
   Coding: 010801050040C1EF41000B0E00000003F0000101
   VCID: 377DD3E78657B42932-8062
   Subsystem 1 - Part No: 8R0 919 884 Q
   Component: ROW 2010  0206
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H25 0045
   Serial number: VWZ8Z9L780039C
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000117740130
   Coding: 011C16200001251005080000
   VCID: 3A7BCAD3B545A941CD-806E
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Component: TopView       H05 0097
   Revision: 11001001    Serial number: 82331010130125
   Coding: 0100000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3A7BCAD3BD45A941CD-806E
10489856 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 14
                    Mileage: 140668 km
                    Date: 2024.01.21
                    Time: 10:25:50
                    Voltage terminal 30: 12.0 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 166100062 Dataset Number: 7p0771v____ 0009
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000117666666
End-------------------------(Elapsed Time: 05:02)--------------------------
dubwerkz
Malaysia
C?ID=200781
after EPB replaced
Saturday,17,February,2024,22:17:26:06704
          62 6C 6D 72
VIN: WVGZZZ7PZCD007743   Mileage: 140941km-87576miles
Readiness: 0000 0100
   Coding: 001168
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:12
   Coding: 46A6200E80
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10195440
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Coding: 010300
   Coding: 508501
   Coding: 000C35
   Coding: 0021032600
   Coding: 191100
   Coding: 191100
01512 - Control Module for Sliding Roof
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:19
02907 - Control Module for Roof Shade (J394)
                    Fault Status: 00100101
                    Reset counter: 64
                    Mileage: 140869 km
                    Date: 2024.02.17
                    Time: 16:20:55
   Revision: 00000000    Serial number: C1531500591    Dataset Number:             A001
   Coding: 00000000
   Shop #: WSC 00078 790 12345
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:28
                    Voltage: 12.6 V
0024 - No Basic Setting
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:28
                    Voltage: 12.6 V
12652550 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:28
                    Voltage: 12.6 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:36
                    Voltage: 12.80 V
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:36
                    Voltage: 12.80 V
                    Reset counter: 24
                    Mileage: 140862 km
                    Date: 2024.02.17
                    Time: 15:59:30
                    Voltage terminal 30: 12.5 V
   Coding: 0533314002
End-------------------------(Elapsed Time: 05:04)--------------------------
After replacement i have found out that all codes has been missing for the module. I would need guided steps help from you guys on this.
[Select]
[53-Parking Brake]
[Coding]
- Paste in the coding from the old one: 01040100
[Do it!]
dubwerkz
Malaysia
C?ID=200781
Hi Uwe,
Thanks for your assistance on this
After adding the code 01040100 and do it..i got the : Coding rejected Error 33 :Security access required.
How do i go ahead on this?
NEtech
Denmark
C?ID=56995
First go to [Security Access-16] and enter shown code
security access-16 show code will present a code?
Indeed, it should. Pause for a few seconds when you get there and a yellow help/info balloon should appear.
dubwerkz
Malaysia
C?ID=200781
Hi Uwe,
Thanks to you guys im able to code accepted for the replaced EPB module.is there a step after this to calibrate or learn it as the fault persist.Im attaching the last scan.
Monday,19,February,2024,01:37:26:06704
VIN: WVGZZZ7PZCD007743   License Plate: 3
Mileage: 140976km-87598mi   Repair Order:
          62 6C 6D 72
VIN: WVGZZZ7PZCD007743   Mileage: 140976km-87598miles
Readiness: 1010 0100
   Coding: 001168
                    Reset counter: 25
                    Mileage: 140941 km
                    Date: 2024.02.17
                    Time: 22:13:31
   Coding: 46A6200E80
          U1101 00 [00001000] - Active
                    Reset counter: 66
                    Mileage: 140942 km
                    Date: 2024.02.18
                    Time: 10:48:41
0414 - Motor for Fresh Air / Recirculated Air Flap
          B108B 07 [00001000] - Mechanical Failure
                    Reset counter: 67
                    Mileage: 140944 km
                    Date: 2024.02.18
                    Time: 11:17:28
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
   Coding: 508501
   Coding: 000C35
   Coding: 0021032600
   Coding: 191100
   Coding: 191100
                    Reset counter: 25
                    Mileage: 140941 km
                    Date: 2024.02.17
                    Time: 22:13:35
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 30
                    Voltage: 12.2 V
                    Voltage: 12.2 V
                    Voltage: 12.2 V
   Coding: 130000
   Coding: 130000
5276182 - Power Output Module for Right Headlamp
          C1082 16 [00001000] - Voltage Too Low
                    Reset counter: 70
                    Mileage: 140942 km
                    Date: 2024.02.18
                    Time: 10:48:43
                    Reset counter: 25
                    Mileage: 140941 km
                    Date: 2024.02.17
                    Time: 22:13:42
                    Voltage: 12.60 V
                    Reset counter: 25
                    Mileage: 140941 km
                    Date: 2024.02.17
                    Time: 22:13:42
                    Voltage: 12.60 V
                    Reset counter: 25
                    Mileage: 140941 km
                    Date: 2024.02.17
                    Time: 22:13:32
                    Voltage terminal 30: 12.3 V
   Coding: 0533314002
End-------------------------(Elapsed Time: 04:54)--------------------------
dubwerkz
Malaysia
C?ID=200781
Monday,19,February,2024,01:49:34:06704
VIN: WVGZZZ7PZCD007743 License Plate: 4
Address 53: Parking Brake (7P0 907 801 F)
01:49:29
IDE04435-MAS01849 Air gap-Left 2.354 mm
IDE04435-MAS01850 Air gap-Right 2.343 mm
IDE05267-MAS01849 Electro-mechanical parking brake: tensioning force-Left 3815 N
IDE05267-MAS01850 Electro-mechanical parking brake: tensioning force-Right 4737 N
IDE05269-MAS01849 Electro-mech parking brake: current of parking brake motors-Left 0 A
IDE05269-MAS01850 Electro-mech parking brake: current of parking brake motors-Right 0 A
ENG109099-MAS01849 Actuator status-Left Malfunction
ENG109099-MAS01850 Actuator status-Right Malfunction
I do not think you can fix an "Electrical Failure" type fault code with any sort of calibration. I believe the that fault specifically is a failure of one of the H-bridge drivers in the module.
dubwerkz
Malaysia
C?ID=200781
Hi Uwe,
As this is a used unit,it could be faulty..any way to replace the H bridge driver?Thanks
I would imagine there is, if you can identify the component, source the component, and have the skills to R&R it.
This is a pretty long read but if you make it to post #52:
... that was caused by a faulty parking brake motor. Likewise, the guy in #60 indicated that C10E2 was also a faulty motor (but he didn't include scans).
If there is a faulty motor this original DTC does not point directly to the right or left:
0040 - Motor for Electronic Parking Brake​
C10E3 29 [00001000] - Signal Implausible​
Intermittent - Confirmed - Tested Since Memory Clear​
In conclusion, it is entirely possible that the replacement EPB module has a problem of some sort but I would try to actuate the motors to confirm that both work. If they will not run using the switch in the vehicle with your foot on the brake see if they to via Basic Settings after using the Ceramic brake coding trick noted: here
dubwerkz
Malaysia
C?ID=200781
Hi Dana,
As the C10E2 alarm persist after used replacement of J540 EPB,it could be the one or both the actuators as mentioned.You have mentioned to trick by changing the disc type to ceramic.Is there another way to give a force value and viewing other parameters within the VCDS?
You are going to be limited to the operations that 53 supports ... and the fact that it has C10E2 may prevent the motors from working at all. In that case you may have to resort to old-school diagnostics such jumping power and ground with the rotors installed while watching amp readings, checking for voltage drops, resistance tests and similar but I would firstly try:
1) Using the switch in the car to see if both function. Two people would be ideal since you will need to put your foot on the brake pedal and operate the inside switch.
2) Temporarily Code 53 to 02040100 followed by Basic Settings [*IDE04509*] Air gap calibration. Again, two people would be ideal but that test should start without the brake pedal or any interaction with the switch inside the car. Most importantly, make sure to change the coding back to 01040100 after this is diagnosed.
3) Output Tests. There's no harm in trying this but I don't know how many operations will be supported.
You should be OK as the testing is done with the rotors installed so that the motors don't over extend and blow themselves up.
dubwerkz
Malaysia
C?ID=200781
Hi Dana,
I have changed to 02040100 and perform IDE04509 Air gap cal but status turn to not running after do it..am i doing anything wrong?
Normally, you would hear the motors cycle on/off a few times. Roughly 10 seconds later Finished Correctly or Not Running would be shown. If this one is not making any motor noise at all and goes directly to Not Running that's likely due to the fault code. I don't think you are doing anything wrong.
If they are not operating when you use the inside switch I would be tempted to remove the rotors and have a look at the parking brake shoes, motors, backing plates. You may find that they have a bunch of rust from lack of use that way.
Another idea is to focus on the wiring inside where the water leak was and verify that all of the fused power supplies to the controller are OK. In that case I would load test those wires to rule out voltage drops.
dubwerkz
Malaysia
C?ID=200781
Hi Dana,
Thanks for the assistance.. i just want to make sure
Do i need to keep engine running or do i need to hook up a battery charger if i just keep on in acc mode? during the test.. i did read about power supply issue during testing the actuators..
Engine running is not ideal because you won't be able to hear those motors very well. I would use a battery charger however you may need one that can maintain at least 18 amps on this 7P chassis T'reg.
