Oil pressure issue or sensor?
q76767
New Jersey, USA
C?ID=445722
I have a 11 jetta se 2,5 96k miles runs good, but started throwing oil pressure light after driving it down the road. is it more likely a oil pressure sensor and would it be the blue or brown one with this code? motor runs good and sounds healthy. or i was thinking maybe pickup screen is clogged?
Sunday,11,February,2024,23:24:10:58701
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VWDZ7AJ3BM366099   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDZ7AJ3BM366099   Mileage: 154810km-96194miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 G    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9217
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 06414 444 100828
   VCID: 323D13865821354AE97-8066
   VINID: 0E69D4A8745A0D274318600924778CFFD2
005709 - Oil Pressure Switch for reduced Oil Pressure
               P164D - 000 - Malfunction - Intermittent
                    Mileage: 154815 km
                    Date: 2018.07.04
                    Time: 16:21:11
                    RPM: 704 /min
                    Load: 20.4 %
                    Temperature: 64.0°C
                    Temperature: 16.0°C
                    Absolute Pres.: 1000.0 mbar
Readiness: 1110 1101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           1741
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 0059894EA60D57DA2F3-8054
   Revision: 00H31001
   Coding: B14B440C492808008D0B22ED92221061A70000
   VCID: 7BA3FEA2C3EB34027A1-802E
                    Reset counter: 54
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:15
                    Count: 3
                    Count: 13
                    Count: 28672
                    Count: 16390
                    Count: 31744
                    Count: 1536
                    Count: 65024
                    Reset counter: 54
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:28
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 28928
                    Count: 1536
                    Count: 64768
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000274786
   VCID: 2E0507F64C1911AA8DF-807A
03934 - Control Circuit for Seat Heating; Front Left
                    Fault Status: 00101011
                    Reset counter: 48
                    Mileage: 154672 km
                    Date: 2018.07.04
                    Time: 18:56:33
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:18
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:18
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311067110284
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2D0700FA4D1F6AB2B45-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0089710
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
                    Reset counter: 53
                    Fault Frequency: 15
                    Reset counter: 53
01598 - Drive Battery Voltage
                    Reset counter: 53
                    Mileage: 153837 km
                    Date: 2018.07.04
                    Time: 00:01:45
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD09Z8WG   Dataset Number: 160003v____ 0086
   Coding: 00003935
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3431159EAEB53B7AFBB-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y110000394M07
   Coding: 303241
   Serial number: 3572MSME7E4A315AZZZ4
   Serial number: 3582MSME5C40205BZZZX
   Serial number: 3516KSME1F09680EZZZ%
   Serial number: 3526KSME1A41570EZZZW
   Serial number: 3556LSME6B29770DZZZ6
   Serial number: 3566LSME3E095D37ZZZ6
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Powersupply  lower threshold fall short of]
                    Reset counter: 53
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 53
   Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
   Component: KOMBI         H07 0406
   Coding: 270201
   Shop #: WSC 00066 000 00145
   VCID: 2B030EE2738B6482AA1-807E
          [Supply voltage too low]
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2024.02.11
                    Time: 21:58:48
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70B9D98E9AAD475ADF3-8024
   Component: IMMO          H07 0406
   VCID: 6A8DCBE6BCF1BD8A917-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669231782
   VCID: 2809F1EE62FD4F9A473-807C
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:15
                    Reset counter: 53
   Part No SW: 1K0 035 164     HW: 1K0 035 164
   Component: LOW NAR SDARS H14 0043
   Revision: -----06S    Serial number: VWZ4Z6L3097708
   Coding: 0100040002
   VCID: 5F9BAA327733C822769-800A
                    Reset counter: 162
                    Mileage: 138250 km
                    Date: 2016.11.16
                    Time: 15:05:23
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 118
                    Mileage: 138250 km
                    Date: 2016.11.16
                    Time: 15:05:23
                    Reset counter: 162
                    Mileage: 138250 km
                    Date: 2016.11.16
                    Time: 15:05:17
02633 - Antenna for Satellite Tuner
                    Reset counter: 22
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:08
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2018.07.04
                    Time: 21:57:18
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669307876 Dataset Number: 5K0035730   0001
   Coding: 0A00000000010100
   Shop #: WSC 01383 790 50316
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 629DA3C644C1E5CA597-8036
9458195 - Control Module for Cellular Telephone
          B1052 13 [00001001] - Open Circuit
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                    Reset counter: 162
                    Mileage: 138250 km
                    Date: 2022.06.26
                    Time: 15:05:15
          [Terminal 30: lower limit value not reached]
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2024.02.11
                    Time: 21:57:17
          U1400 00 [00001000] - -
                    Reset counter: 53
                    Mileage: 154796 km
                    Date: 2024.02.11
                    Time: 21:57:17
End----------(Elapsed Time: 01:12, VBatt start/end: 13.9V/13.7V)-----------
EuroX
Northern NJ USA
C?ID=208579
This is a 07K engine that will not apply. Please check connector for reduced oil pressure switch. My money is on the fact its pissing oil through the switch like they all do.
davisev5225
C?ID=263265
It can still apply, and is an extremely easy thing to check (and cross off the list). ;)
Also worth checking. :D
q76767
New Jersey, USA
C?ID=445722
I'll take a look in morning. I had a 2.5 in past that had a oil pressure light and cause was clogged pickup screen. That one took awhile for light to come on. This one comes on pretty much soon as I drive it .
q76767
New Jersey, USA
C?ID=445722
Solved: oil filter was completely stuck inside oil filter housing and faling apart. Changed that and vacum pump seal and no more oil pressure light. Surprising because still had a couple hundred more miles before it was due for a change
davisev5225
C?ID=263265
So your filter was effectively operating in "bypass" mode, which is why the pressure sensor complained.
For posterity, what brand filter were you using?
q76767
New Jersey, USA
C?ID=445722
I couldn't tell you, I bought the car from auction like that so no idea and was to far gone to make anything out on it.
