7343 - ROD - Unknown Error Code
davidbp
C?ID=438179
Could someone please explain how I can get a better understand of an ROD Error, how I understand, the version of VCDS I am using has no data for that module. The car was brought to me with a EGR fault, with a couple of error including 7343 - ROD - Unknown Error Code. Upon investigation the vacuum pipe was so contaminated in oil, it had swollen to the point it would no longer stay on the EGR valve. I also noticed that when I removed the vacuum unit to check for debris, the flap was solid with carbon.
I Refitted the vacuum unit, reconnected the pipe, clear all the codes and it seem fine for about a week, no codes. They opted to fit a new EGR unit which I have done but now I am being presented with permeant 7343 - ROD - Unknown Error Code and It won’t clear.
The 7393 - EGR System - P0400 00 [00100111] – Malfunction has now cleared.
I take it 7343 mean EGR, other references point to EGR Sensor 2, but I didn’t this car was fitted with a sensor 2.
Any help would be greatly received
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAW083138 Mileage: 167030km-103787miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 CQ HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 4971
Revision: -------- Serial number: 00000000000000 CVN: 48D6E9F5
Coding: 00114014030500080000
ASAM Dataset: EV_ECM16TDI02103L906023CQ 001004
ROD: EV_ECM16TDI02103L906023CB.rod
VCID: 77ABE151EF4918121E9-8022
VINID: 9E69EAAAA05BA919C0203043209C84C438
- 00 [10101111]
Mileage: 167033 km
Date: 2024.02.12
Time: 19:17:57
Engine RPM: 0.00 /min
Coolant temperature: 22 °C
Intake air temperature: 12 °C
Voltage terminal 30: 12.085 V
Freeze frame conditions-ANG_EGRV_ENVD: 99.9 %
Freeze frame conditions-ANG_SP_EGRV_ENVD: 0.0 %
Freeze frame conditions-EGRV_PWM_COR_ENVD: -0.4 %
Freeze frame conditions-EGRV_PWM_ENVD: 0.0 %
Freeze frame conditions-V_EGRV_ENVD: 4.98 V
Freeze frame conditions-V_EGRV_BOL_ENVD: 0.72 V
Freeze frame conditions-V_EGRV_TOL_ENVD: 3.98 V
Freeze frame conditions-STATE_EGRV: 0
Freeze frame conditions-EGRVPWM_ENVD: 0.000 %
Freeze frame conditions-TCO_MES: 14 °C
7393 - EGR System
P0400 00 [00100111] - Malfunction
Mileage: 167033 km
Date: 2024.02.12
Time: 17:01:44
Engine RPM: 1501.25 /min
Normed load value: 3.5 %
Coolant temperature: 30 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.456 V
Freeze frame conditions-AMP_ENVD: 996.078 hPa
Freeze frame conditions-Battery voltage: 14.5 V
Freeze frame conditions-FRF_RC: 255
Freeze frame conditions-MAP_MES_ENVD: 1193.35 hPa
Freeze frame conditions-MAF_KGH_MES_ENVD: 88.3442 mg/stroke
Freeze frame conditions-FAC_MAF_CYL_KGH_RATIO_FIL_ENVD: 0.99
Freeze frame conditions-ANG_SP_BPA_ENVD: 67.8 %
Freeze frame conditions-ANG_SP_PORT_ENVD: 14.9 %
Freeze frame conditions-ANG_SP_THR_ENVD: 95.7 %
Freeze frame conditions-SF_ENG_STATE: IS
Freeze frame conditions-Ambient temperature: 9.00 °C
Freeze frame conditions-MAF_MMV_ENVD: 490.235 mg/stroke
Readiness: 1010 0000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 133B200D092A00FDC80C04E7902100803000
VCID: 7EA5F475C0F3295A5DF-802A
Part No SW: 3C8 907 336 H HW: 3C8 907 336 H
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 323D104544AB3D3AE97-8066
Part No SW: 1K0 937 085 D HW: 1K0 937 085 D
Component: BCM PQ35 B+ 103 0541
Revision: 00103 AE
Coding: 40180A3A9025189044000080100000E443010088524D8160648000200000
VCID: 30391A4D4A270F2A9F3-8064
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 16070 21 0501
Coding: 009795
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 035 0604
Serial number: 003C2RA1JH49 Dataset Number: 5K0003v____ 0067
Coding: 00003230
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
Component: S.Sens.Fahr.V U01 ----
Serial number: 1F667049ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 4A4E7549ZZZZZZZZZZZZ
Serial number: 28523457ZZZZZZZZZZZZ
Serial number: 264F3465ZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 03538581A71144B2321-8056
Part No SW: 5K0 920 960 J HW: 5K0 920 960 J
Component: KOMBI H06 0206
Coding: 470B00
VCID: 3431165DBEBF330AFBB-8060
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K0972808DC
Coding: E9801F06000202000003
VCID: 6695BC15B463919AB5F-8032
Fault Frequency: 77
Reset counter: 64
Mileage: 166953 km
01304 - Radio
Reset counter: 56
Mileage: 166953 km
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H06 0206
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2110
Coding: 0000564
VCID: 313F1F494D2D062290D-8064
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H17000
VCID: 2F3B19315B1910D2869-807A
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2124
Coding: 0000564
VCID: 3431165DB23F330AFBB-8060
EuroX
Northern NJ USA
C?ID=208579
Are you using a clone dongle? Or something that hasnt been updated? Post complete auto scan.
davidbp
C?ID=438179
No Genuine interface, sorry, I thought I had copied the whole scan across.
I've checked for updates tonight, software and Firmware, all up date. Just reading through some of the other post, I noticed one where Uwe commented about reinstalling the software, due to lots of ROD errors...
Monday,12,February,2024,17:09:59:17866
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: WVWZZZ1KZAW083138   License Plate:
          - 00 [10101111]
                    Mileage: 167033 km
                    Date: 2024.02.12
                    Time: 19:17:57
7393 - EGR System
                    Mileage: 167033 km
                    Date: 2024.02.12
                    Time: 17:01:44
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
   Revision: 00103 AE
   Coding: 009795
   Coding: 00003230
   Coding: 0000004
   Coding: 470B00
                    Fault Frequency: 77
                    Reset counter: 64
                    Mileage: 166953 km
01304 - Radio
                    Reset counter: 56
                    Mileage: 166953 km
   Coding: 0000564
   Revision: 00H17000
   Coding: 0000564
Address 56: Radio
End----------(Elapsed Time: 00:42, VBatt start/end: 14.3V/14.3V)-----------
No, it has data for your ECU, it's just that DTC 7343 is not defined in the data your particular ECU -- EV_ECM16TDI02103L906023CB.rod.
In other ECUs for which it is defined, it translates to:
P0407 00 -- EGR Sensor 2: Signal too Low.
I think it's a safe bet that this should be applicable to this one as well.
If that's the case, then it would explain why the DTC is not defined in the data for this ECU. Is there any chance this ECU has been tuned/mapped?
davidbp
C?ID=438179
Hi Uwe,
As far as they are aware it’s a stock, no remapping. I will start digging, focus around the potentiometer.
Don’t really want to remove the EGR again, nightmare
