MQB - Relay for Headlight Washer System - Short to Ground
iichel
Netherlands, Operation Market Garden
C?ID=284912
787465 - Relay for Headlight Washer System
          B1262 11 [00001001] - Short to Ground
                    Reset counter: 208
                    Mileage: 176838 km
                    Date: 2024.02.12
                    Time: 17:51:53
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 10.5 ∞C
Intersting, my headlight washers stopped working. I know I replaced the BCM some while ago, perhaps I nicked a wire. I didn't have this error before in my scans.
Which makes life more interesting of course. Perhaps the pump froze up during the cold weeks we had?
Full scan.
Monday,12,February,2024,17:55:20:11868
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel   License Plate:
Mileage: 176838km-109882mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42
          44 47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN: WVWZZZ3CZJEiichel   Mileage: 176838km-109882miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---    CVN: B7DB7878
   Coding: 091D003A2476050B3004
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 313FE88591ABBF4290D-8064
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5297
   Revision: 06454104    Serial number: TFK01706160335 CVN: 000099EF
   Shop #: WSC 05311 115 00065
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222AD3B-8048
          P1734 00 [00000010] - -
   Part No SW: 5Q0 614 517 FM    HW: 5Q0 614 517 AH
   Component: ESC           H62 0755
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 015F7845618BEFC220D-8054
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0577965047 Dataset Number: V03935321YJ 0001
   Coding: 1F20200723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C9A56102311E8AA73-801C
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0024
   Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
   Coding: 001000020000050081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C21C9B146E9422A33B-8068
   Part No SW: 3G8 907 044 T    HW: 3G8 907 044 T
   Component: Climatronic   H10 0221
   Coding: 12020024104411011115500D0018592A
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 3E25C3B950F5503A1DF-806A
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
   Part No SW: 5Q1 937 084 B    HW: 5Q1 937 084 B
   Component: BCM MQBAB HO  H44 0512
   Serial number: 02102311001826 Dataset Number: V03935381P  0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 3829D5A172D16E0AD73-806C
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 06A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 14 04 2017  10001690
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL23010051V
   Serial number: 00000000000070188699
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0158736
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0096892
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0145994
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0146336
                    Reset counter: 208
                    Mileage: 176838 km
                    Date: 2024.02.12
                    Time: 17:51:53
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 8A79267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   VCID: 59EF7025A99B970208D-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F2AE9-8012
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 25061741350001 Dataset Number: V03935290WM 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB770228D-806C
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Component: Airbag VW21   006 0721
   Revision: --------    Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   VCID: 0E45537920D580BAADF-805A
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Serial number: 357000000000507D3628
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Serial number: 358000000008D140C62J
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Serial number: 3510091305210000000U
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Serial number: 352002F2F52100000009
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Serial number: 3550040279610000000%
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   Shop #: WSC 00046 000 00000
   VCID: 2A0DFFE9BC7DCC9A517-807E
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5502
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0FC80000006CC0010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFEBD177F9932569-802A
   Generator:
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100161
   Coding: AF0B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
   Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
   Coding: 0601
   VCID: 4CC199711649F2AA83B-8018
   Serial number: 17000160250002
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71BF2885512BFF42D0D-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
   Coding: 001000020000150081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
   Coding: 00359A20D200028200011000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9F691C3DEC9AB17-801E
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Dataset Number: 8V0909852AA 0001
   Coding: 93070000
   Shop #: WSC 00015 115 00319
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
   VCID: 6B833AED73071592EA1-803E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 01071710801233 Dataset Number: V03935339UR 0001
   Coding: 000000060100035207007F010A0000000000000000000000000000000000
   VCID: 72BD2789542DC45A297-8026
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
   Coding: 00359020DE00028200011000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA065193BE782B8D-801C
   Part No SW: 5NA 035 022 B    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   VCID: 323DE78994AD845AE97-8066
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Subsystem 2 - Part No SW: V03 959 809 PC    HW: -----------
   Component: ECE 2023  --- 0310
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   VCID: 42DDB749240D34DA797-8016
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG069231 Dataset Number: ----------
   Coding: 01840200E70F200004314817
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935262CS 0001
   Coding: 02A8
   VCID: 46D5AB59082508FA55F-8012
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
   Serial number: E80320003220200 Dataset Number: V03935411EY 0001
   Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW38.rod
   VCID: 3635DB9978C5987AC5F-8062
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
   Coding: 000490200100028000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   Component: TSG HBFS005 0350
   Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   VCID: 372BD69D7FCF6172DE9-8062
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16753B191805787AE5F-8042
   Component: LED1R         H09 0003
End----(Elapsed Time: 02:47, VBatt start/end: 11.9V/11.7V. VIgn 11.6V)-----
So let's first check the pump with a hot wire to the battery, since we know the wiring:
The pump is wired like this on every MQB car known to man, probably. At least the ones with SRA.
There is no separate fuse, the bcm simply controls the pump itself, probably via one of its common battery feeds.
Mine has an extra coupling station because the washer reservior in the right wheel housing and not in the left side of the engine bay.
This is the way it's buit on cars with the aux heater.
So we hot wire the T46/46 and sure enough, the headlights are washed. That's strange. I checked all the fuses and found none faulty.
Checked all the relays just to be sure and they work as well.
I don't really care if the washers work or not, I rarely use them, and here they are not legally required. They are a good repellant for tailgaters but serve no real other purpose to me.
BUT
I hate a DTC in my car so it must be investigated
I took my old BCM and had a look, if I could trace the PCB to a power or a ground source, but only found T46/19 as a common GND. This makes sense since it's a sensor ground.
That works on the current BCM, so there is no broken ground wire as far as I'm concerned. The power supply gets lost somewhere in the transistor area.
Fine, let's pull out the 5Q1 then, see if it's perhaps hurt somewhere...
So, I noticed, T46/46 is uhm, absent?
I opened it up to check for a relay anyway and sure enough...
THERE IS NOTHING THERE
So VW apparently decided not to put in the relay anymore.
I'll be investigating further, perhaps another pin will power an external relay. But WHAT THE FUCK VW?
Cuzoe
C?ID=279487
Well WTF indeed? What's the plan going forward? I toyed with the idea of retrofitting headlight washers (I know, for nothing) but in the end the Mk7 Golf R bumper is the Mk7 bumper I like the least. It's the only one (to my knowledge) in NAR that "should" have the mounting\molding points for the washer. And I'm only making that assumption because it has the holes/covers. No big surprise that finding pictures of the inside of the bumper is not so easy.
Unsurprisingly... search by actual PN 5G0807221BJGRU and pictures are easy to find... I still don't like the Mk7 R bumper.
iichel
C?ID=284912
Cuzoe
C?ID=279487
So what was VW's plan here... are headlight washers not mandatory on any cars where they would install this BCM? And therefore headlight washers are not offered on said cars?
iichel
C?ID=284912
Certainly looks that way yes, i have two autoscans with chassis numbers. A 2023 Passat with IQ lights and no washers and a 2023 Tiguan 5NA with IQ lights and no washers.
I'm identifying the extra components that drive the relay. It seems pretty straight forward. Some SMD resistances with known values, an SJ diode, some ceramic capacitors with unknown capacity and a triode?
