2014 Touareg Possible door lock while engine running?
x1800MODMY360x
AZ, USA
C?ID=564397
Hello I got a 2014 Touareg TDI that I'm not sure if I have it coded to have the door to lock if the engine is running by the keyfob. I know that I have it on my 2013 VW Passat TDI but every car is different. Thank You!
Friday,09,February,2024,14:44:34:61664
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVGEP9BP6ED004467   License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEP9BP6ED004467   Mileage: 257968km-160293miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    X21 0011
   Revision: 56X21---    CVN: E7FCBDE438D3FF8238D3FF820E1FC39E
   Coding: 292A4012233600050000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 372B3BD73FC28AB2DE9-8062
   VINID: 9E65D58094A01955000041061C331C261D
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
   Component: AL1000 AISIN  002 3376
   Serial number:                CVN: 187C4FCF
   Coding: 001168
   Shop #: WSC 06920 002 104857
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 72BDCAC314202F9A297-8026
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 420330010EC815 Dataset Number: 7P0012v____ 0001
   Coding: 5B7613C349242557DAF8C89992D9A4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD72235C30075AB17-801E
   Part No SW: 4H0 907 064 DK    HW: 4H0 907 064 DK
   Component: BCM2 2.0      H35 0510
   Coding: 0D860016000000000000
   VCID: 75B7F1DF65CE38A20C5-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2313000139496011
                    Fault Status: 00101101
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:05
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B606600A80
   VCID: 0557811F35AE28221C5-8050
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001627391
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6C81D4BB3684F96AE3B-8038
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    130831  031 0021
   Serial number: 90243400130909091218
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20176468
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002908130366
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R75L203
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:00
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag02B H06 0026
   Revision: --------    Serial number: 003L5002H4U$ Dataset Number: 7P6003v____ 1073
   Coding: 000000000000000000000000000000003242
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42DD5A036400DF1A797-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R135020DRYP
   Serial number: 3575LRB400M50LFGB1MO
   Serial number: 3585LRB400A50LFEI915
   Serial number: 3515RRB406925UD0G899
   Serial number: 3525RRB406925UD0LPBY
   Serial number: 3555NRB406122HCS9G6A
   Serial number: 3565NRB405V22HCSAH2
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815MIG00030
   Coding: 000015
   VCID: 363536D3384873BAC5F-8062
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0001840 TAT 20130723
00886 - Turn Signal Switch (E2)
                    Reset counter: 142
                    Mileage: 257152 km
                    Date: 2024.01.08
                    Time: 17:04:04
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 982 L    HW: 7P6 920 982 L
   Component: Kombi         H13 0419
   Revision: 13240114    Serial number: 658230813592049
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CB4B174F22FA32AE9-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001092570 Dataset Number: 7P6067v____ 0032
   Coding: 000103AD00
   GVL: FB0F40451D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FDB53F717F2B2F2169-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 40252K20135701055476
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000073509938
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 34310CDB2E3461AAFBB-8060
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:05
   Part No SW: 4H0 959 793 AA    HW: 4H0 959 793 P
   Component: TSG FA        H02 0305
   Revision: --------    Serial number: 0000075041116
   Coding: 011D17205E00453005080000
   VCID: 78A9F8EB72DC45CA173-802C
   Revision: 00002001    Serial number: 0315093574
   Coding: 01861E3A68BD509580A00620210A08000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 197136285
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO2384310
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO23833733
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93055396
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 9
                    Reset counter: 110
                    Mileage: 253443 km
                    Date: 2023.08.14
                    Time: 08:36:36
02615 - Fuel Tank Cap; Lock
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 255067 km
                    Date: 2023.10.09
                    Time: 20:17:55
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:05
   Part No SW: 4H0 959 792 Q    HW: 4H0 959 792 M
   Component: TSG BF        H02 0305
   Revision: --------    Serial number: 0000075160932
   VCID: 46D5461348A8E33A55F-8012
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1390300170    Dataset Number:             A001
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 363536D338C873BAC5F-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1E4FB466469EA73B-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Revision: AB001007    Serial number: 156I90D7903995
   Coding: 020007020100000001
   VCID: 2411FC9B9ED4F12A6BB-8070
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:09
                    Bin. Bits: 00000000 00001000
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0706
   Revision: --------    Serial number: 273I10D7501849
   Coding: 010200050040E5EE41022F2C00000003F10001030000000000
   VCID: 392F3DEF09569CC228D-806C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9NA300121
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  5298
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:15
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00010000
   Part No SW: 4H0 959 795 M    HW: 4H0 959 795 J
   Component: TSG HL        H03 0303
   Revision: --------    Serial number: 0000075082386
   Coding: 011817200000253005080000
   VCID: 45D7411F75AEE8225C5-8010
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000109133 Dataset Number: 7P6096v____ 0019
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00000194257082
   Coding: 020D000000000000
   VCID: 3B2327E7036AAED23A1-806E
                    Reset counter: 150
                    Mileage: 257949 km
                    Date: 2024.02.02
                    Time: 18:04:05
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H07000    Serial number: 525 PA8J381721
   Coding: 0110001
   VCID: 372B3BD733428AB2DE9-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 247300097 Dataset Number: 7P6959107C  D045
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0303
   Revision: --------    Serial number: 0000075060181
End----(Elapsed Time: 02:16, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
So get out of it after starting it, and try to lock it.
EuroX
Northern NJ USA
C?ID=208579
Should be possible via coding change. However if you roll the window down get out with car running lock the door and hit the window switch same thing will be accomplished.
