Codes
Maddog
Buffalo River, Victoria, Australia
C?ID=408900
New to this, Mechanic for 40 years, managed to dodge electronics todate for the most part, time for a deep dive
Sunday,11,February,2024,08:50:28:16946
VCDS Version: 23.11.0.0 (x64)  HEX-NET CB: 0.4643.4
Dealer/Shop Name: Casamigos
VIN: WVGZZZ7LZ9D028562   License Plate: 1RS5SL
Mileage: 212130km-131811mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 22 28 2E 34 36 37 46
          47 55 56 65 68 6C 6D 76 77
VIN: WVGZZZ7LZ9D028562   Mileage: 212130km-131811miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 1100
   Part No SW: 070 906 016 DP    HW: 070 906 016 DH
   Component: V10 5,0L EDCG000AGMª1250
   Revision: --H07---    Serial number: VWX3Z0H3817680
   Coding: 0010575
   Shop #: WSC 31414 790 00001
   VCID: 618A8951B90B9899AC-5160
   VINID: 9E65EAAAA1DCA89500088146089A6231F4
001025 - EGR System
               P0401 - 000 - Insufficient Flow - MIL ON
                    Fault Status: 11110000
                    Fault Frequency: 89
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:27:41
                    RPM: 1428 /min
                    Load: 14.9 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 95.1 %
                    Mass Air / Rev.: 280.0 mg/str
                    Mass Air / Rev.: 575.0 mg/str
012401 - Reservoir for Additive for Particle Filter
               P3071 - 000 - Empty - Intermittent
                    Fault Status: 00110000
                    Fault Frequency: 86
                    Mileage: 206624 km
                    Date: 2023.10.26
                    Time: 12:26:46
                    RPM: 1407 /min
                    Speed: 84.5 km/h
                    (no units): 672.0
                    (no units): 672.0
                    (no units): 50.0
                    (no units): 9.82
006482 - Turbocharger Control Module 1
               P1952 - 000 - Defective - Intermittent
                    Fault Frequency: 17
                    Mileage: 206905 km
                    Date: 2023.11.02
                    Time: 21:16:20
                    RPM: 3906 /min
                    Speed: 63.1 km/h
                    Load: 83.1 %
                    Bin. Bits: 00000000
                    Bin. Bits: 00100000
                    Absolute Pres.: 2131.8 mbar
                    Absolute Pres.: 2590.8 mbar
005379 - Load Signal from Alternator Term. DF
               P1503 - 000 - Implausible Signal - Intermittent
                    Mileage: 208837 km
                    Date: 2023.12.19
                    Time: 09:11:20
                    RPM: 588 /min
                    Voltage: 13.30 V
                    Bin. Bits: 00001000
                    Bin. Bits: 00100001
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 EL    HW: 09D 927 750 EL
   Component: AL 750 6A           1471
   Revision: 00H61000    Serial number:
   Coding: 0012648
   VCID: 7CB4D8253EA955719F-5160
                    Fault Status: 00101101
                    Reset counter: 179
                    Date: 2006.01.01
                    Time: 00:00:01
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0012674
   VCID: 46C07ACD35E5DFA1B9-8012
                    Reset counter: 112
                    Mileage: 206561 km
                    Date: 2023.10.23
                    Time: 20:09:51
                    Count: 192
                    Count: 4353
                    Count: 294
                    Count: 1
                    Reset counter: 112
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:20:24
                    Count: 6145
                    Count: 128
                    Count: 1
                    Reset counter: 129
                    Mileage: 208837 km
                    Date: 2023.12.19
                    Time: 09:11:23
                    Count: 12289
                    Count: 8196
                    Count: 1
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: 2D Kessy            6850
   Revision: 00H22071    Serial number: VWX3Z0H3817680
   Coding: 0147688
   Shop #: WSC 06259 002 1048576
   VCID: 2A182E7D81BD1BC1BD-807E
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77BEC709028F7629F2-8022
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 AH
   Component: CLIMAtronic 2+2     4334
   Coding: 0021030
   VCID: 7AB8DE3D319D6B418D-802E
   Subsystem 1 - Part No: 7L6 907 049 F
   Component: CLIMAtronic FOND    0503
00711 - Left Footwell Flap Positioning Motor (V108)
02599 - Rear Left Temperature Flap Motor (V313)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AG    HW: 7L6 937 049 AG
   Component: J519                2002
   Revision: -1004---    Serial number: --------------
   Coding: 600004002B2219000000000000000000
   VCID: 014AA9D15C4B3899CC-8054
01494 - Bulb for Parking Lamps; Left (M1)
            007 - Short to Ground
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª1250
   VCID: 618A8951B90B9899AC-5184
No Faults Found
Address 15: Airbags
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0000012
   VCID: 42C866DD19CDE38195-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 890 E    HW: 7L6 920 890 E
   Component: J285 KOMBI-INST.    9533
   Revision: KHH06V36
   Coding: 0007111
   Shop #: WSC 05970 002 1048576
   VCID: 3A381E3D751DAB41CD-806E
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                    Reset counter: 107
                    Mileage: 202059 km
                    Date: 2023.08.11
                    Time: 15:25:09
                    Reset counter: 128
                    Mileage: 206561 km
                    Date: 2023.10.23
                    Time: 20:09:54
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 890 E
   Component: J533  GW-K-CAN TP20 9533
   Coding: 7FF2FFFDCA846003
   VCID: 70ACFC1563E1211133-8024
                    Reset counter: 67
                    Mileage: 201714 km
                    Date: 2023.08.07
                    Time: 10:35:17
                    Reset counter: 107
                    Mileage: 202059 km
                    Date: 2023.08.11
                    Time: 15:25:09
Address 22: AWD
Address 28: HVAC, Rear
Address 2E: Media Player 3
Address 34: Level Control
Address 36: Seat Mem. Drvr        Labels:
   VCID: 55E2AD81AC436439C0-FFFE
   Note: Excessive Comm Errors
   Part No SW: 7L6 035 680 B    HW: 7L6 035 680 B
   Component: RNS-MID       H03 0902
   Revision: AB001001    Serial number: VWZ6Z7H5290071
   Coding: 020500000100002200
   VCID: 312A3911686B68197C-8064
                    Reset counter: 67
                    Mileage: 201740 km
                    Date: 2023.08.10
                    Time: 09:29:16
                    Reset counter: 129
                    Mileage: 202840 km
                    Date: 2023.08.19
                    Time: 10:04:09
                    Reset counter: 112
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:20:29
Address 46: Central Conv.
Address 47: Sound System
Address 55: Headlight Range
Address 56: Radio
Address 65: Tire Pressure
Address 68: Wiper Electr.
Address 6C: Back-up Cam.
Address 6D: Trunk Elect.
Address 76: Park Assist
Address 77: Telephone
End----(Elapsed Time: 06:28, VBatt start/end: 11.2V/11.6V. VIgn 0.0V)------
Any advice?
Westbury, UK
Looks like that scan was done with the ignition off, an Auto-Scan needs to be done with the ignition on.
TTT
C?ID=547002
   Coding: 0010575
001025 - EGR System
                    Fault Frequency: 89
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:27:41
                    RPM: 1428 /min
                    Load: 14.9 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 95.1 %
                    Fault Frequency: 86
                    Mileage: 206624 km
                    Date: 2023.10.26
                    Time: 12:26:46
                    RPM: 1407 /min
                    Speed: 84.5 km/h
                    (no units): 672.0
                    (no units): 672.0
                    (no units): 50.0
                    (no units): 9.82
                    Fault Frequency: 17
                    Mileage: 206905 km
                    Date: 2023.11.02
                    Time: 21:16:20
                    RPM: 3906 /min
                    Speed: 63.1 km/h
                    Load: 83.1 %
                    Bin. Bits: 00000000
                    Bin. Bits: 00100000
                    Mileage: 208837 km
                    Date: 2023.12.19
                    Time: 09:11:20
                    RPM: 588 /min
                    Voltage: 13.30 V
                    Bin. Bits: 00001000
                    Bin. Bits: 00100001
   Coding: 0012648
                    Reset counter: 179
                    Date: 2006.01.01
                    Time: 00:00:01
   Revision: 00H53001
   Coding: 0012674
                    Reset counter: 112
                    Mileage: 206561 km
                    Date: 2023.10.23
                    Time: 20:09:51
                    Count: 192
                    Count: 4353
                    Count: 294
                    Count: 1
                    Reset counter: 112
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:20:24
                    Count: 6145
                    Count: 128
                    Count: 1
                    Reset counter: 129
                    Mileage: 208837 km
                    Date: 2023.12.19
                    Time: 09:11:23
                    Count: 12289
                    Count: 8196
                    Count: 1
   Coding: 0147688
   Coding: 0021030
No Faults Found
Address 15: Airbags
   Coding: 0000012
   Revision: KHH06V36
   Coding: 0007111
                    Reset counter: 107
                    Mileage: 202059 km
                    Date: 2023.08.11
                    Time: 15:25:09
                    Reset counter: 128
                    Mileage: 206561 km
                    Date: 2023.10.23
                    Time: 20:09:54
                    Reset counter: 67
                    Mileage: 201714 km
                    Date: 2023.08.07
                    Time: 10:35:17
                    Reset counter: 107
                    Mileage: 202059 km
                    Date: 2023.08.11
                    Time: 15:25:09
Address 22: AWD
                    Reset counter: 67
                    Mileage: 201740 km
                    Date: 2023.08.10
                    Time: 09:29:16
                    Reset counter: 129
                    Mileage: 202840 km
                    Date: 2023.08.19
                    Time: 10:04:09
                    Reset counter: 112
                    Mileage: 206564 km
                    Date: 2023.10.24
                    Time: 16:20:29
Address 56: Radio
Any advice?
1st advice, battery charger.
I don't recall whether the 7L chassis T'reg had Vign ("terminal 15") on pin 1 of the DLC; it may not have.
Westbury, UK
It was also the number of modules that did not respond which made me wonder about the ignition state...
Yeah, but I'd expect almost none of the ignition wasn't on at all.
