2018 audi s3 coding problem
Eli Gavel
West Springfield, MA, USA
C?ID=575306
I have a 2018 audi s3 and i brought the car to get scanned by a guy to do with some headlight issue. After this guy all the lights turned on and later i found out by a guy that knows more about audi cars that my car was "factory reset" if thats how you say it. i have the hex net vcds but i need to find the correct long code for each saftey system in the car. If i can find them on here would be great. i also found a bunch of data bus codes and loss of communication. There is like 28000 codes when I scanned the car.
Friday,09,February,2024,17:10:54:47766
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WAUB1GFF1J1043667   License Plate: 4LFY84
Mileage: 88808km-55182mi   Repair Order: 25
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 6C A9 BB BC CF D6 D7
VIN: WAUB1GFF1J1043667   Mileage: 88808km-55182miles
03-ABS Brakes -- Status: Cannot be reached 0100
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 785CFCA0
   Coding: 0A2500122426010E3000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: 4DCC049EBD5AB702945-8018
   VINID: 9D195205759605A0401031861C098AEF55
15211 - Oil Pressure Regulating Valve
          P164E 00 [00101111] - Electrical Malfunction
                    Fault Frequency: 26
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:59
                    Engine RPM: 0.00 /min
                    Coolant temperature: 85 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.226 V
                    Engine oil temperature: 108.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 3 min
                    MAP_MES_SAE: 99 kPa
                    Engine: operating status: ES
                    T_AST_SAE: 0 s
                    ECU_STATE: ENG_STOP
17178 - Databus
          U1123 00 [01101101] - Received Error Message
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:13
                    Engine RPM: 1617.25 /min
                    Coolant temperature: 87 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 11.933 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
18876 - Cruise Control Switch (E45)
          P0568 00 [00100000] - Implausible Signal
                    Mileage: 88808 km
                    Date: 2023.12.22
                    Time: 18:05:02
                    Vehicle speed: 255 km/h
                    Coolant temperature: 0 °C
                    Intake air temperature: -1 °C
                    Voltage terminal 30: 11.289 V
                    Unlearning counter according OBD: 36
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: Not operated
                    Cruise control switch actuation-Control component verified: No
                    ACC variants: ACC
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Fault Frequency: 8
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    Voltage terminal 30: 12.187 V
                    ECU_STATE: ENG_STOP
                    T_ES: 3 min
                    Cruise control switch actuation-Main switch hardware: operated
                    T_AST_SAE: 0 s
Readiness: 0010 0101
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07    CVN: DC685125
   ROD: EV_TCMDQ381061.rod
   VCID: 2114882E9142436200D-8074
   No subsystems:
10681 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [00101111] - -
                    Fault Frequency: 84
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:27
                    Engine RPM: 1501.00 /min
                    Vehicle speed: 10 km/h
                    Coolant temperature: 90 °C
                    Clutch: primary stat: Anfahren - Gangwechsel
                    selected gear: GANG_1
                    Driving position: d
                    Engine torque: 48 Nm
                    Control Module temperature: 73 °C
                    Accelerator pedal position: 31.4 %
                    DTC memory status: 68
21221 - No Communications with Parking Brake Control Module
          U0128 00 [00101111] - -
                    Fault Frequency: 90
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -16 Nm
                    Control Module temperature: 76 °C
                    Accelerator pedal position: 15.3 %
                    DTC memory status: 73
Address 03: ABS Brakes
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0462555663 Dataset Number: 8V0909577F  0012
   Coding: 030C1C
   VCID: 3C2A595A16E00E8A33B-8068
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 13 [00001000] - Open Circuit
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:06
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001414908
   Coding: 03000014010000001000000000001400
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D22DAA7A086A6A6F3-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: A240DBD800PAG0MUFU03
459012 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:41:48
459015 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:01
459020 - Databus
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
1048839 - Function limitation due to crash signal
          B1397 00 [00001000] - -
                    Reset counter: 162
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:06
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001733200097 Dataset Number: 8V0909514AA 0012
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065EFBB218AC845A15F-8052
   Component: WWS371 171104  043 0585
   Serial number:         171115031220
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 16 06 2017  00000464
   Serial number: 00000000000099978578
   Sunroof control module:
   Subsystem 4 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001WHFWP00000
   Coding: 101F00
17 Faults Found:
204546 - Remote key 2
          B147A 18 [00001000] - Current Too Low
                    Reset counter: 171
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 11.6 V
                    Outside temperature: 1.0 °C
204549 - Remote key 2
          B147A 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 171
                    Mileage: 88808 km
                    Date: 2023.12.30
                    Time: 07:32:19
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Voltage: 11.8 V
                    Outside temperature: 3.5 °C
          B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.26
                    Time: 22:09:49
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Voltage: 14.1 V
                    Outside temperature: 24.5 °C
528917 - Databus
          [ESP_21 Datenbus fehlende Botschaft]
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
                    Outside temperature: 27.5 °C
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Fault Frequency: 45
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533525 - Databus
          [ESP_07_alt aktiv]
                    Fault Frequency: 36
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533781 - Databus
          [ESP_02 Datenbus fehlende Botschaft]
                    Fault Frequency: 37
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
549141 - Databus
          [TSG_BT_01 Datenbus fehlende Botschaft]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 22.0 °C
550677 - Databus
          [TSG_HBFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
554517 - Databus
          [ESP_05_alt aktiv]
                    Fault Frequency: 220
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
554773 - Databus
          [EPB_01_alt aktiv]
                    Reset counter: 146
                    Mileage: 88798 km
                    Date: 2023.07.14
                    Time: 22:51:22
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.9 V
                    Outside temperature: 25.0 °C
555029 - Databus
          [ESP_21_alt aktiv]
                    Fault Frequency: 35
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Fault Frequency: 196
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.4 V
                    Outside temperature: 25.5 °C
576516 - Databus
          [LCM rechts - LCM_Feh_LM_R_alt aktiv]
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: operated
                    Voltage: 12.0 V
                    Outside temperature: 33.0 °C
722436 - No Communications with Moveable Sunroof Control Module
          U0207 00 [00001000] - -
          [Steuergerät für Schiebedach->kein Signal/ Kommunikation]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 00:10:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 28.0 °C
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [00001001] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
939524 - No Communications with Humidity Sensor
          U10F5 00 [00001001] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617334 Dataset Number: 8V0909526J  0062
   Coding: 0470155011
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 4BC80A86434EB9328A1-801E
16 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [00001001] - Open Circuit
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:33
12656914 - Databus
          [Bremsensteuergerät - ESP_02 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656913 - Databus
          [Bremsensteuergerät - ESP_10 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Fault Frequency: 23
                    Reset counter: 106
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637412 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsVR - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637411 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsVL - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
12656918 - Databus
          [Bremsensteuergerät - ESP_19 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656919 - Databus
          [Bremsensteuergerät - ESP_20 - kein Signal/keine Kommunikation]
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
12656920 - Databus
          [Bremsensteuergerät - ESP_21 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637421 - Databus
          [Bremsensteuergerät - ESP_21.ESP_v_Signal - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637424 - Databus
          [ESP - ESP_19.ESP_VL_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637425 - Databus
          [ESP - ESP_19.ESP_VR_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637426 - Databus
                    Fault Frequency: 22
                    Reset counter: 110
                    Mileage: 88754 km
                    Date: 2023.07.01
                    Time: 07:44:42
12656926 - Databus
          [Bremsensteuergerät - ESP_33 - kein Signal/keine Kommunikation]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Fault Frequency: 23
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:28
12656922 - Databus
          [Bremsensteuergerät - ESP_07 - kein Signal/keine Kommunikation]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: 8V1909863AB 0001
   Coding: B500008119F7842474988055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B285A4613EE09B23A1-806E
10 Faults Found:
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 08:28:24
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 11.7 V
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 110
                    Mileage: 88808 km
                    Date: 2023.07.18
                    Time: 16:53:15
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 10.9 V
                    Status_ACC_System: ACC_Init
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 10:37:53
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.9 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 54
                    Mileage: 88763 km
                    Date: 2023.07.01
                    Time: 20:28:42
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 13.7 V
                    Velocity_vehicle_reference: 18.87 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 54
                    Mileage: 88772 km
                    Date: 2023.07.01
                    Time: 20:44:48
                    Control Module temperature: 42 °C
                    Velocity_vehicle_reference: 9.67 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.31 m/s²
1110 - Databus
          [FAULT_TIMEOUT_ESP_02]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 12.1 V
                    Velocity_vehicle_reference: 0.11 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.42 m/s²
1058 - Databus
          [FAULT_TIMEOUT_ESP_05]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 2.83 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.65 m/s²
1089 - Databus
          [FAULT_TIMEOUT_ESP_10]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
                    Voltage terminal 15: 12.3 V
                    Velocity_vehicle_reference: 0.13 m/s
1092 - Databus
          [FAULT_TIMEOUT_ESP_21]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
2126 - Databus
          [FAULT_TSK_ROAD_SLOPE_FAIL]
                    Reset counter: 117
                    Mileage: 88799 km
                    Date: 2023.07.16
                    Time: 12:32:49
                    Control Module temperature: 32 °C
                    Velocity_vehicle_reference: 0.93 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.48 m/s²
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       161117090 Dataset Number: 8V0909554H  0001
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 45DC3CBE652A4F425C5-8010
8 Faults Found:
10493953 - Databus
          U1121 00 [10001001] - Missing Message
          [ESP_02_Timeout]
                    Fault Frequency: 57
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    COM: 10 57 10 76 00 00 6C BB 00 00
                    Voltage terminal 30: 12.1 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Vehicle speed: Not available
                    Longitudinal acceleration: Not available
                    Lateral Acceleration: Not available
                    Yaw rate: Not available
                    Brake pressure: 0.0 bar
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    ESP status: 0
                    Fall-back level: 00 00 8C 20
10498049 - Databus
          [ESP_05_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    COM: 10 57 10 66 00 00 6E 9B 00 00
                    Brake pressure: Not available
                    AMR state: 6
                    Damping adjustment indicator lamp: On
                    ESP automatic engagement: activated
                    ESP status: 0
                    Fall-back level: 02 01 CC 20
10502145 - Databus
          [ESP_21_TimeOut]
                    Fault Frequency: 65
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    AMR state: 0
                    ESP status: 0
10502148 - Databus
          [failure value vehicle speed]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    COM: 0E 2D 0E 5B 00 29 49 D3 00 00
                    Voltage terminal 30: 14.0 V
                    Brake pressure: -0.3 bar
                    AMR state: 0
                    ESP status: 1
                    Fall-back level: 00 01 C0 20
10551297 - Databus
          [ESP_07_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:12
                    COM: 10 38 10 66 00 00 70 7B 00 00
                    Voltage terminal 30: 12.0 V
                    AMR state: 6
                    ESP status: 0
10522629 - Databus
          U1122 00 [00001000] - Implausible Message
          [init value steer angle]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    COM: 0A B1 0A EF 00 00 06 63 00 00
                    Voltage terminal 30: 11.7 V
                    Steering angle: Not available
                    Steering rate: 0 rad/s
                    AMR state: 0
                    Fall-back level: 00 00 10 20
10522630 - Databus
          [old value steer angle]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    AMR state: 0
10526728 - Databus
          [standing time not available]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:57
                    COM: 0A B1 0A EF 00 00 15 8B 00 00
                    Voltage terminal 30: 12.9 V
                    AMR state: 6
                    Time since terminal 15 off: Not available
                    Outside air temperature via CAN: 31.0 °C
                    Fall-back level: 00 00 10 A0
   Serial number: 003GCR09RSLE Dataset Number: 8V0909602R  0002
   VCID: 47C036B65F265D52AE9-8012
   Left seat belt tensioner:
   Serial number: 34230167A27111741128
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A30111750669
   Coding: 333135
   Serial number: 694000000000001P16LU
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 000 412 17
   Serial number: 35700000000CD6E0292U
   Subsystem 5 - Part No SW: -----------    HW: 480 000 412 17
   Serial number: 35800000000793F8382S
   Subsystem 6 - Part No SW: -----------    HW: 480 402 111 17
   Serial number: 3510001AF27F0824E78G
   Subsystem 7 - Part No SW: -----------    HW: 480 401 411 17
   Serial number: 35200019F2825B26247+
   Subsystem 8 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3550002B71B7E8F3F39X
   Subsystem 9 - Part No SW: -----------    HW: 480 402 410 17
   Serial number: 3560002C725629A5225/
24 Faults Found:
9438993 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 11 [10001000] - Short to Ground
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9438481 - Igniter for Driver head airbag
          B1005 11 [10001000] - Short to Ground
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9440027 - Driver's side; side-airbag igniter
          B100B 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
          B1006 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:33
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [10001000] - Resistance Too High
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
9451029 - Crash sensor side airbag; passenger side
          B1036 15 [10001000] - Open or Short to Plus
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:08
9445890 - Seat occupied recognition control module
          B1022 02 [10001001] - Signal Failure
                    Mileage: 88787 km
                    Date: 2023.07.13
                    Time: 09:03:07
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:29
9482752 - Seat Occupied Recognition
          B10B2 00 [10001001] - Function Restriction due to Missing Message(s)
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2024.01.17
                    Time: 00:01:00
9444885 - Driver's seat position sensor
          B101E 15 [10001000] - Open or Short to Plus
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
9445141 - Passenger's seat position sensor
          B101F 15 [10001000] - Open or Short to Plus
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
          B13BC F2 [10001001] - No function
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 18:47:27
9447936 - Crash data stored; driver side
          B102A 00 [10001001] - -
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:06
9445937 - Seat occupied recognition control module
          B1022 31 [00001000] - No Signal
                    Fault Frequency: 33
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
13679104 - Local Data Bus
          U10BA 00 [00001000] - No Communication
          [PreCrash LIN no communication]
                    Reset counter: 172
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:35
12680960 - No Communication with Control Module for Seat Belt Tensioner; Front Right
          U017F 00 [00001000] - -
          [ECU for Pretensioner right no communication]
                    Reset counter: 163
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:27
9445929 - Seat occupied recognition control module
          B1022 29 [00001000] - Signal Implausible
                    Reset counter: 174
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:43:01
9577755 - Sensor Mat for Seat Occupied Detection
          B1225 1B [00001000] - Resistance Too High
                    Reset counter: 160
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03121704221781
   Coding: 2018
   VCID: 0D4CC49E7DDAF702545-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
   Component: FBenUSA       H16 0066
   Coding: 08ED18533B88CF050281E8001800000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
16776968 - Databus
          [ESP_24 communication error can_error_timeout]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:12
16776973 - Databus
          [RKA_01 communication error can_error_timeout]
                    Fault Frequency: 16
                    Reset counter: 106
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
16776982 - Databus
          [SWA_01 communication error can_error_timeout]
                    Reset counter: 125
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:28
13637376 - Databus
          [ECU for brake control module error value recieved]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
   Component: GW MQB High   518 5323
   Serial number: 25111710522595 Dataset Number: 8V0909515Q  0089
   Coding: 030100043F085A005B00806EB80B00000001010000000000000000000000
   GVL: 01D63C1000000600404C80000002CC0000040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3822454A22D822AAD73-806C
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20171122021939 20325
   Serial number: 758860000017120103A2
131603 - No Communication with ABS Brake Control Module
          U0121 00 [00001001] - -
          [Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
131662 - Lane change assistant control module
          U1045 00 [00001001] - No communication
          [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                    Fault Frequency: 16
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:31
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
131722 - Control Module 2 for Lane Change Assistance
          U10A5 00 [00001001] - No Communications
          [Timeout Knoten 0x8A / CF - Steuergerät 2 für Spurwechselassistent]
                    Fault Frequency: 16
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:31
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [00001000] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 162
                    Mileage: 88808 km
                    Date: 2023.09.13
                    Time: 06:47:16
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [00001001] - Warning Triggered
                    Fault Frequency: 20
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.10.01
                    Time: 14:46:48
                    Terminal 30 power supply: 10.7 V
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [00001001] - Active
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:06
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00004.10.17 Dataset Number: v1260x015G0 0000
   Coding: 0001
10 Faults Found:
16655 - Databus
          [Bremsensteuergerät - TO -- ESP_02]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17468 - Databus
          [Bremsensteuergerät - TO -- ESP_05]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17495 - Databus
          [Bremsensteuergerät - TO -- ESP_07]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17501 - Databus
          [Bremsensteuergerät - TO -- ESP_10]
                    Fault Frequency: 88
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:25
17471 - Databus
          [Bremsensteuergerät - TO -- ESP_14]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17502 - Databus
          [Bremsensteuergerät - TO -- ESP_18]
                    Fault Frequency: 57
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.08.18
                    Time: 18:50:23
17469 - Databus
          [Bremsensteuergerät - TO -- ESP_19]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17470 - Databus
          [Bremsensteuergerät - TO -- ESP_21]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17504 - Databus
          [Bremsensteuergerät - TO -- ESP_29]
                    Fault Frequency: 87
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
17505 - Databus
          [Bremsensteuergerät - TO -- EPB_01]
                    Fault Frequency: 200
                    Reset counter: 135
                    Mileage: 88798 km
                    Date: 2023.07.16
                    Time: 09:34:08
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   Dataset Number: 8V0909519D  0006
   VCID: 42D627A27404787A797-8016
0368 - Hardware coding
          C119E 01 [00001000] - Electrical Failure
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:55:15
0357 - Temperature sensor
          C11C1 01 [00001000] - Electrical Failure
                    Fault Frequency: 170
                    Reset counter: 145
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
   Revision: 00000000    Serial number: 17000355276007
   Coding: 5D00000000000000
   VCID: 343A717A3EB0C6CAFBB-8060
12666370 - Databus
          [Timeout Message ESP_10]
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 655.34 km/h
                    Voltage: 69
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 05
13637376 - Databus
          [Errorvalue ESP_v_Signal]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Vehicle speed: 655.35 km/h
                    Voltage: 7A
                    AD-Value H-bridge: 3C
                    CAN signals: 04
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 7A
                    CAN signals: 04
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 C    HW: 8S0 907 397 C
   Component: LCM_MQB       H07 0022
   VCID: 41D428AE7102636260D-8014
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:02
0257 - Databus
          U1200 00 [00001000] - Defective
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:59:02
0395 - Headlights in Service Position
          C1241 00 [00001001] - -
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
Address 3C: Lane Change
   Serial number: 131017EJC01084 Dataset Number: 8V0909872J  0040
   Coding: 005D1B204000048000000002
   VCID: 43D822A66B1E7172721-8016
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Türelektronik Beifahrer (J387)]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
65573 - Local Data Bus
          [Türelektronik Beifahrerseite hinten (J389)]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
458776 - Databus
          [Gateway_71 Datenbus fehlende Botschaft]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: 8V0909852S  0001
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
8 Faults Found:
16272 - Steering Angle Sensor
          B1168 F2 [00001000] - Not Initialized
                    Reset counter: 139
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 11.75 V
                    Temperature: 5.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 11.92 V
                    uAdSensI_SwitchedKl30_xdu16: 11.89 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
20224 - Databus
          [ESP_19 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    System status: Driving mode
                    Temperature: 30.0 °C
                    KFC: 4F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 12.06 V
                    uAdSensI_SwitchedKl30_xdu16: 12.01 V
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_UNDERVOLT: not activated
19456 - Databus
          [ESP_05 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 00
19200 - Databus
          [ESP_02 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    Supply voltage: 13.75 V
                    Temperature: 36.0 °C
                    KFC: 4B
                    KFA: 00 00
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.03 V
                    RP_CNTERR: not activated
20992 - Databus
          [ESP_24 Botschaft - CAN-Timeout]
                    Fault Frequency: 9
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    Supply voltage: 14.00 V
                    KFC: 52
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.06 V
                    uAdSensI_SwitchedKl30_xdu16: 13.98 V
20736 - Databus
          [ESP_21 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 51
                    KFA: 00 00
19968 - Databus
          [ESP_14 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
                    Motor status: 00
                    KFC: 4E
                    KFA: 00 00
20480 - Databus
          [ESP_20 Botschaft - CAN-Timeout]
                    Reset counter: 128
                    Mileage: 88808 km
                    Date: 2023.12.09
                    Time: 12:30:58
                    Motor status: 02
                    Supply voltage: 14.50 V
                    Temperature: 17.0 °C
                    KFC: 50
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.59 V
                    uAdSensI_SwitchedKl30_xdu16: 14.56 V
Address 47: Sound System
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 30111710520382 Dataset Number: 8V0909583C  0008
   Coding: 000000050100147206112300040000000000000000000000000000000000
   VCID: 72B6B762042488FA297-8026
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 38
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
13705472 - Databus
          [ESP_19 data bus missing message]
                    Fault Frequency: 77
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
0029 - Control Module for Light Activation/Adjustment; Right
          U116F 00 [00001000] - No Communications
          [KN_LCM_R no communication]
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:04
66673 - Control Module for Light Activation/Adjustment; Right
          [LCM_Feh_LM_R no communication]
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:04
13705984 - Databus
          [ESP_VL_Radgeschw received error value]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13705986 - Databus
          [ESP_VR_Radgeschw received error value]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
   Serial number: 141017EJD09096 Dataset Number: 8V0909873J  0040
   Coding: 005D13204000048000000002
458776 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
   VCID: 3924404E19D23BA228D-806C
7 Faults Found:
13705491 - Databus
          [message ESP_10 not received]
                    Fault Frequency: 27
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    passive
13705492 - Databus
          [message ESP_20 not received]
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:20
                    passive
13705476 - Databus
          [Oldbit-monitoring Gateway_71.ESP_21_alt]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:15
                    passive
13705989 - Databus
          [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HL]
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705990 - Databus
          [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HR]
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705984 - Databus
          [Errorvalue-monitoring Gateway_71.ESP_v_Signal]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    passive
13705995 - Databus
          [Undervoltage Gateway_71.ESP_v_Signal]
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 171027201755
   VCID: 3E2E535200FC1C9A1DF-806A
0007 - Actuator for Structural Noise
          P193B 00 [00001000] - Electrical Malfunction
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 09:31:59
0014 - Databus
          [Keine Funktion durch CAN FehlerESPsteuergerätebotschaft fehlt--> keine Klangerzeugung]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 190917EII27703 Dataset Number: 8V0909897H  0028
   Coding: 000C13204000048000000002
   Serial number: 190917EII2757B Dataset Number: 8V0909896H  0028
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 09:18:11
Address CF: Lane Chge Asst 2
   Dataset Number: 8V0909471E  0008
   VCID: 1760A6F64F060DD2FE9-8042
   Dataset Number: 8V0909472E  0008
End----(Elapsed Time: 02:10, VBatt start/end: 11.0V/11.0V. VIgn 11.1V)-----
Address 0x15,5Q0 959 655 J,UDS Basic Settings,IDE01551-Reset rollover bar deployments
                Address 15: Airbags       Labels: 5Q0-959-655.CLB
Control Module Part Number: 5Q0 959 655 J    HW: 5Q0 959 655 J
  Component and/or Version: AirbagVW20    010 0830
           Software Coding: 9DCCFCC0000000005000001AC24800000065
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_AirbaVW20SMEVW37X 002144 (AU37)
24 Faults Found:
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:33
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:08
                    Mileage: 88787 km
                    Date: 2023.07.13
                    Time: 09:03:07
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:29
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2024.01.17
                    Time: 00:01:00
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 18:47:27
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:06
                    Fault Frequency: 33
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
                    Reset counter: 172
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:35
                    Reset counter: 163
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:27
                    Reset counter: 174
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:43:01
                    Reset counter: 160
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
24 Faults Found:
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:12
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:33
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:24
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:08
                    Mileage: 88787 km
                    Date: 2023.07.13
                    Time: 09:03:07
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:29
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2024.01.17
                    Time: 00:01:00
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:25
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 18:47:27
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:06
                    Fault Frequency: 33
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
                    Reset counter: 172
                    Mileage: 88808 km
                    Date: 2023.10.10
                    Time: 00:02:35
                    Reset counter: 163
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:27
                    Reset counter: 174
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:43:01
                    Reset counter: 160
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
Address 15: DTCs cleared
Address 44,3Q0 909 144 L,recoded (Long Coding),from,811F0000,to,811F0000,(06385/790/00016),
UDS Adaptation Channel (8B): IDE04891-IDE02003-Adapting high values-Body height left rear wheel house edge
Stored value 356 mm
VCDS Release 23.11.0:  SRI Reset-SRI2.CLB
Control Module Part Number: 8V0 920 890 A       Labels:  .*5G0-920-XXX-17.clb-SRI2
Component:FBenUSA       H16 0066, Coding:08ED18533B88CF050281E8001800000000000000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  3600 km                                                         ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      268 d                                                           ---
IDE00515-ESI: oil quality        ESI: Oil Quality                                                poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                              0 km                                                            ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               12400 km                                                        ---
IDE01153-SIA: maximum value of distance to service                                                      SIA: Maximum Distance to Service                                16000 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    365 d                                                           ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection                                 FIX: Maximum Distance to Inspection                             32100 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Maximum Time to Inspection                                 730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  26200 km                                                        ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      912 d                                                           ---
IDE00512-ESI: minimum value km-driving distance/inspection                                              ESI: Minimum Distance to Service                                14500 km                                                        ---
IDE00513-ESI: maximum value km-driving distance/inspection                                              ESI: Maximum Distance to Inspection                             14500 km                                                        ---
IDE00514-ESI: maximum value of time between inspections                                                 ESI: Maximum Time to Service                                    730 d                                                           ---
IDE00827-ESI: minimum value of time between inspections                                                 ESI: Minimum Time to Service                                    365 d                                                           ---
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      0
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  26200 km                                                        0
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      912 d                                                           0
Address 17,8V0 920 890 A,channel IDE00342-ESI: Resetting ESI,adapted from,no warning ,to,Resetting ,
Address 17,8V0 920 890 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,26200 km,to,0 km,
Address 17,8V0 920 890 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,912 d,to,0 d,
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    Resetting                                                       ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  0 km                                                            ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      0 d                                                             ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               0 km                                                            ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  0 km                                                            ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      0 d                                                             ---
Address 19: DTCs cleared
Address A9: DTCs cleared
Address 17: DTCs cleared
Address 29: DTCs cleared
Address 0x29,8S0 907 397 D,UDS Basic Settings,IDE00498-Resetting of all adaptation values
Address 02,0GC 300 012 A,recoded (Long Coding),from,0014,to,0014,(00000/000/00000),
Address 05,5Q0 959 435 C,recoded (Long Coding),from,030C1C,to,030C1C,(12345/123/61029),
Address 05: DTCs cleared
Address 08,8V0 820 043 Q,recoded (Long Coding),from,03000014010000001000000000001400,to,03000014010000001000000000001400,(06385/790/00016),
Address 08: DTCs cleared
Address 4B,3Q0 907 338 ,recoded (Long Coding-exp),from,000000050100147206112300040000000000000000000000000000000000,to,000000050100147206112300040000000000000000000000000000000000,(06385/790/00016),
Address 4B: DTCs cleared
Address 19,3Q0 907 530 L,recoded (Long Coding),from,030100043F085A005B00806EB80B00000001010000000000000000000000,to,030100043F085A005B00806EB80B00000001010000000000000000000000,(06385/790/00016),
                    Fault Frequency: 26
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:59
                    T_ES: 3 min
                    MAP_MES_SAE: 99 kPa
                    T_AST_SAE: 0 s
                    ECU_STATE: ENG_STOP
17178 - Databus
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:13
                    Mileage: 88808 km
                    Date: 2023.12.22
                    Time: 18:05:02
                    ACC variants: ACC
                    Fault Frequency: 8
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    ECU_STATE: ENG_STOP
                    T_ES: 3 min
                    T_AST_SAE: 0 s
   No subsystems:
                    Fault Frequency: 84
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:27
                    Driving position: d
                    Fault Frequency: 90
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    Driving position: P
   Coding: 030C1C
459012 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:32:20
459015 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:32:25
   Coding: 0A47F7
   Coding: 101F00
17 Faults Found:
                    Reset counter: 171
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.6 V
                    Reset counter: 171
                    Mileage: 88808 km
                    Date: 2023.12.30
                    Time: 07:32:19
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Voltage: 11.8 V
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.26
                    Time: 22:09:49
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.1 V
528917 - Databus
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533269 - Databus
                    Fault Frequency: 45
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533525 - Databus
          [ESP_07_alt aktiv]
                    Fault Frequency: 36
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533781 - Databus
                    Fault Frequency: 37
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
549141 - Databus
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
550677 - Databus
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
554773 - Databus
          [EPB_01_alt aktiv]
                    Reset counter: 146
                    Mileage: 88798 km
                    Date: 2023.07.14
                    Time: 22:51:22
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.9 V
555029 - Databus
          [ESP_21_alt aktiv]
                    Fault Frequency: 35
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
558100 - Databus
                    Reset counter: 175
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.4 V
576516 - Databus
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.0 V
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 00:10:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
   Coding: 0470155011
16 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:33
12656914 - Databus
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656913 - Databus
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12658704 - Databus
                    Fault Frequency: 23
                    Reset counter: 106
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637412 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637411 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
12656918 - Databus
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656919 - Databus
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
12656920 - Databus
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637421 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637424 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637425 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637426 - Databus
                    Fault Frequency: 22
                    Reset counter: 110
                    Mileage: 88754 km
                    Date: 2023.07.01
                    Time: 07:44:42
12656926 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
13639168 - Databus
                    Fault Frequency: 23
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:28
12656922 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
10 Faults Found:
0828 - Databus
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 08:28:24
0822 - Databus
                    Reset counter: 110
                    Mileage: 88808 km
                    Date: 2023.07.18
                    Time: 16:53:15
2101 - Databus
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 10:37:53
                    Reset counter: 54
                    Mileage: 88763 km
                    Date: 2023.07.01
                    Time: 20:28:42
                    Reset counter: 54
                    Mileage: 88772 km
                    Date: 2023.07.01
                    Time: 20:44:48
1110 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
1058 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
1089 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
1092 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
2126 - Databus
                    Reset counter: 117
                    Mileage: 88799 km
                    Date: 2023.07.16
                    Time: 12:32:49
8 Faults Found:
10493953 - Databus
          [ESP_02_Timeout]
                    Fault Frequency: 57
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    AMR state: 0
                    ESP status: 0
10498049 - Databus
          [ESP_05_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    AMR state: 6
                    ESP status: 0
10502145 - Databus
          [ESP_21_TimeOut]
                    Fault Frequency: 65
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    AMR state: 0
                    ESP status: 0
10502148 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    AMR state: 0
                    ESP status: 1
10551297 - Databus
          [ESP_07_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:12
                    AMR state: 6
                    ESP status: 0
10522629 - Databus
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    AMR state: 0
10522630 - Databus
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    AMR state: 0
10526728 - Databus
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:57
                    AMR state: 6
   Coding: 333135
   Coding: 333135
   Coding: 303337
8 Faults Found:
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:25:06
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1055232 - Databus
          [NWD: 0x11E ESP_08 Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1052928 - Databus
          [NWD: 0x0FD ESP_21 Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1049088 - Databus
          [NWD: 0x101 ESP_02 Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
1052416 - Databus
          [NWD: 0x106 ESP_05 Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
1052672 - Databus
          [NWD: 0x392 ESP_07 Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
   Coding: 2018
16776968 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:36
16776973 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:37
16776982 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:37
   Generator:
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 30 power supply: 11.2 V
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
   Coding: 0001
10 Faults Found:
16655 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17468 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17495 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17501 - Databus
                    Fault Frequency: 88
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:25
17471 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17502 - Databus
                    Fault Frequency: 57
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.08.18
                    Time: 18:50:23
17469 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17470 - Databus
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17504 - Databus
                    Fault Frequency: 87
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
17505 - Databus
                    Reset counter: 135
                    Mileage: 88798 km
                    Date: 2023.07.16
                    Time: 09:34:08
12666370 - Databus
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 06
                    Voltage: 69
                    CAN signals: 05
13637376 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 7A
                    CAN signals: 04
13637378 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 7A
                    CAN signals: 04
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:02
0257 - Databus
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:59:02
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
458776 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
   Coding: 811F0000
8 Faults Found:
                    Reset counter: 139
                    Motor status: 00
                    Temperature: 5.0 °C
                    KFC: 3F
                    KFA: 00 90
20224 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 4F
                    KFA: 00 00
19456 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 00
19200 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    KFC: 4B
                    KFA: 00 00
20992 - Databus
                    Fault Frequency: 9
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    KFC: 52
                    KFA: 00 00
20736 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 51
                    KFA: 00 00
19968 - Databus
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
                    Motor status: 00
                    KFC: 4E
                    KFA: 00 00
20480 - Databus
                    Reset counter: 128
                    Mileage: 88808 km
                    Date: 2023.12.09
                    Time: 12:30:58
                    Motor status: 02
                    KFC: 50
                    KFA: 00 00
13705478 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
13705472 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
0032 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
458776 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
7 Faults Found:
13705491 - Databus
                    Fault Frequency: 27
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    passive
13705492 - Databus
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:20
                    passive
13705476 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:15
                    passive
13705989 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705990 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705984 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    passive
13705995 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
0014 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:16:26
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 09:18:11
End----(Elapsed Time: 02:01, VBatt start/end: 11.2V/11.2V. VIgn 11.1V)-----
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          4B 52 5F 6C A9 BB BC CF D6 D7
VIN: WAUB1GFF1J1043667   Mileage: 88808km-55182miles
03-ABS Brakes -- Status: Cannot be reached 0100
39-Right Light -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 785CFCA0
   Coding: 0A2500122426010E3000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: 4DCC049EBD5AB702945-8018
   VINID: 9D195205759605A0401031861C098AEF55
15211 - Oil Pressure Regulating Valve
          P164E 00 [00101111] - Electrical Malfunction
                    Fault Frequency: 26
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:59
                    Engine RPM: 0.00 /min
                    Coolant temperature: 85 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.226 V
                    Engine oil temperature: 108.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 3 min
                    MAP_MES_SAE: 99 kPa
                    Engine: operating status: ES
                    T_AST_SAE: 0 s
                    ECU_STATE: ENG_STOP
17178 - Databus
          U1123 00 [01101101] - Received Error Message
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:13
                    Engine RPM: 1617.25 /min
                    Coolant temperature: 87 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 11.933 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
18876 - Cruise Control Switch (E45)
          P0568 00 [00100000] - Implausible Signal
                    Mileage: 88808 km
                    Date: 2023.12.22
                    Time: 18:05:02
                    Vehicle speed: 255 km/h
                    Coolant temperature: 0 °C
                    Intake air temperature: -1 °C
                    Voltage terminal 30: 11.289 V
                    Unlearning counter according OBD: 36
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: Not operated
                    Cruise control switch actuation-Control component verified: No
                    ACC variants: ACC
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Fault Frequency: 8
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    Voltage terminal 30: 12.187 V
                    ECU_STATE: ENG_STOP
                    T_ES: 3 min
                    Cruise control switch actuation-Main switch hardware: operated
                    T_AST_SAE: 0 s
Readiness: 0010 0101
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07    CVN: DC685125
   ROD: EV_TCMDQ381061.rod
   VCID: 2114882E9142436200D-8074
   No subsystems:
10681 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [00101111] - -
                    Fault Frequency: 84
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:27
                    Engine RPM: 1501.00 /min
                    Vehicle speed: 10 km/h
                    Coolant temperature: 90 °C
                    Clutch: primary stat: Anfahren - Gangwechsel
                    selected gear: GANG_1
                    Driving position: d
                    Engine torque: 48 Nm
                    Control Module temperature: 73 °C
                    Accelerator pedal position: 31.4 %
                    DTC memory status: 68
21221 - No Communications with Parking Brake Control Module
          U0128 00 [00101111] - -
                    Fault Frequency: 90
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:42:58
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -16 Nm
                    Control Module temperature: 76 °C
                    Accelerator pedal position: 15.3 %
                    DTC memory status: 73
Address 03: ABS Brakes
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0462555663 Dataset Number: 8V0909577F  0012
   Coding: 030C1C
   VCID: 3C2A595A16E00E8A33B-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001414908
   Coding: 03000014010000001000000000001400
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D22DAA7A086A6A6F3-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: A240DBD800PAG0MUFU03
459012 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:32:20
459015 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:32:25
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001733200097 Dataset Number: 8V0909514AA 0012
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065EFBB218AC845A15F-8052
   Component: WWS371 171104  043 0585
   Serial number:         171115031220
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 16 06 2017  00000464
   Serial number: 00000000000099978578
   Sunroof control module:
   Subsystem 4 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001WHFWP00000
   Coding: 101F00
17 Faults Found:
204546 - Remote key 2
          B147A 18 [00001000] - Current Too Low
                    Reset counter: 171
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 11.6 V
                    Outside temperature: 1.0 °C
204549 - Remote key 2
          B147A 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 171
                    Mileage: 88808 km
                    Date: 2023.12.30
                    Time: 07:32:19
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Voltage: 11.8 V
                    Outside temperature: 3.5 °C
          B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.26
                    Time: 22:09:49
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Voltage: 14.1 V
                    Outside temperature: 24.5 °C
528917 - Databus
          [ESP_21 Datenbus fehlende Botschaft]
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
                    Outside temperature: 27.5 °C
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Fault Frequency: 45
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533525 - Databus
          [ESP_07_alt aktiv]
                    Fault Frequency: 36
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
533781 - Databus
          [ESP_02 Datenbus fehlende Botschaft]
                    Fault Frequency: 37
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
549141 - Databus
          [TSG_BT_01 Datenbus fehlende Botschaft]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 22.0 °C
550677 - Databus
          [TSG_HBFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 00:00:03
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
554517 - Databus
          [ESP_05_alt aktiv]
                    Fault Frequency: 220
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
554773 - Databus
          [EPB_01_alt aktiv]
                    Reset counter: 146
                    Mileage: 88798 km
                    Date: 2023.07.14
                    Time: 22:51:22
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.9 V
                    Outside temperature: 25.0 °C
555029 - Databus
          [ESP_21_alt aktiv]
                    Fault Frequency: 35
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.0 V
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Fault Frequency: 196
                    Reset counter: 175
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 19:42:56
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 14.4 V
                    Outside temperature: 25.5 °C
576516 - Databus
          [LCM rechts - LCM_Feh_LM_R_alt aktiv]
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: operated
                    Voltage: 12.0 V
                    Outside temperature: 33.0 °C
722436 - No Communications with Moveable Sunroof Control Module
          U0207 00 [00001000] - -
          [Steuergerät für Schiebedach->kein Signal/ Kommunikation]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 00:10:05
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 28.0 °C
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [00001001] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
939524 - No Communications with Humidity Sensor
          U10F5 00 [00001001] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.1 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617334 Dataset Number: 8V0909526J  0062
   Coding: 0470155011
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 4BC80A86434EB9328A1-801E
16 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [00001001] - Open Circuit
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:33
12656914 - Databus
          [Bremsensteuergerät - ESP_02 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656913 - Databus
          [Bremsensteuergerät - ESP_10 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Fault Frequency: 23
                    Reset counter: 106
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637412 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsVR - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637411 - Databus
          [Bremsensteuergerät - ESP_10.ESP_WegimpulsVL - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
12656918 - Databus
          [Bremsensteuergerät - ESP_19 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
12656919 - Databus
          [Bremsensteuergerät - ESP_20 - kein Signal/keine Kommunikation]
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
12656920 - Databus
          [Bremsensteuergerät - ESP_21 - kein Signal/keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
13637421 - Databus
          [Bremsensteuergerät - ESP_21.ESP_v_Signal - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637424 - Databus
          [ESP - ESP_19.ESP_VL_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637425 - Databus
          [ESP - ESP_19.ESP_VR_Radgeschw_02 - Fehlerspeicher auslesen]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
13637426 - Databus
                    Fault Frequency: 22
                    Reset counter: 110
                    Mileage: 88754 km
                    Date: 2023.07.01
                    Time: 07:44:42
12656926 - Databus
          [Bremsensteuergerät - ESP_33 - kein Signal/keine Kommunikation]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Fault Frequency: 23
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.11.05
                    Time: 17:08:28
12656922 - Databus
          [Bremsensteuergerät - ESP_07 - kein Signal/keine Kommunikation]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: 8V1909863AB 0001
   Coding: B500008119F7842474988055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B285A4613EE09B23A1-806E
10 Faults Found:
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 08:28:24
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 11.7 V
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 110
                    Mileage: 88808 km
                    Date: 2023.07.18
                    Time: 16:53:15
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 10.9 V
                    Status_ACC_System: ACC_Init
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 112
                    Mileage: 88808 km
                    Date: 2023.07.19
                    Time: 10:37:53
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.9 V
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 54
                    Mileage: 88763 km
                    Date: 2023.07.01
                    Time: 20:28:42
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 13.7 V
                    Velocity_vehicle_reference: 18.87 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 54
                    Mileage: 88772 km
                    Date: 2023.07.01
                    Time: 20:44:48
                    Control Module temperature: 42 °C
                    Velocity_vehicle_reference: 9.67 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.31 m/s²
1110 - Databus
          [FAULT_TIMEOUT_ESP_02]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 12.1 V
                    Velocity_vehicle_reference: 0.11 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.42 m/s²
1058 - Databus
          [FAULT_TIMEOUT_ESP_05]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 2.83 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.65 m/s²
1089 - Databus
          [FAULT_TIMEOUT_ESP_10]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
                    Voltage terminal 15: 12.3 V
                    Velocity_vehicle_reference: 0.13 m/s
1092 - Databus
          [FAULT_TIMEOUT_ESP_21]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:39:05
2126 - Databus
          [FAULT_TSK_ROAD_SLOPE_FAIL]
                    Reset counter: 117
                    Mileage: 88799 km
                    Date: 2023.07.16
                    Time: 12:32:49
                    Control Module temperature: 32 °C
                    Velocity_vehicle_reference: 0.93 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.48 m/s²
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       161117090 Dataset Number: 8V0909554H  0001
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 45DC3CBE652A4F425C5-8010
8 Faults Found:
10493953 - Databus
          U1121 00 [10001001] - Missing Message
          [ESP_02_Timeout]
                    Fault Frequency: 57
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    COM: 10 57 10 76 00 00 6C BB 00 00
                    Voltage terminal 30: 12.1 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Vehicle speed: Not available
                    Longitudinal acceleration: Not available
                    Lateral Acceleration: Not available
                    Yaw rate: Not available
                    Brake pressure: 0.0 bar
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    ESP status: 0
                    Fall-back level: 00 00 8C 20
10498049 - Databus
          [ESP_05_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    COM: 10 57 10 66 00 00 6E 9B 00 00
                    Brake pressure: Not available
                    AMR state: 6
                    Damping adjustment indicator lamp: On
                    ESP automatic engagement: activated
                    ESP status: 0
                    Fall-back level: 02 01 CC 20
10502145 - Databus
          [ESP_21_TimeOut]
                    Fault Frequency: 65
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:11
                    AMR state: 0
                    ESP status: 0
10502148 - Databus
          [failure value vehicle speed]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    COM: 0E 2D 0E 5B 00 29 49 D3 00 00
                    Voltage terminal 30: 14.0 V
                    Brake pressure: -0.3 bar
                    AMR state: 0
                    ESP status: 1
                    Fall-back level: 00 01 C0 20
10551297 - Databus
          [ESP_07_Timeout]
                    Fault Frequency: 31
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:12
                    COM: 10 38 10 66 00 00 70 7B 00 00
                    Voltage terminal 30: 12.0 V
                    AMR state: 6
                    ESP status: 0
10522629 - Databus
          U1122 00 [00001000] - Implausible Message
          [init value steer angle]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    COM: 0A B1 0A EF 00 00 06 63 00 00
                    Voltage terminal 30: 11.7 V
                    Steering angle: Not available
                    Steering rate: 0 rad/s
                    AMR state: 0
                    Fall-back level: 00 00 10 20
10522630 - Databus
          [old value steer angle]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:54
                    AMR state: 0
10526728 - Databus
          [standing time not available]
                    Reset counter: 174
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:02:57
                    COM: 0A B1 0A EF 00 00 15 8B 00 00
                    Voltage terminal 30: 12.9 V
                    AMR state: 6
                    Time since terminal 15 off: Not available
                    Outside air temperature via CAN: 31.0 °C
                    Fall-back level: 00 00 10 A0
   Serial number: 003GCR09RSLE Dataset Number: 8V0909602R  0002
   VCID: 47C036B65F265D52AE9-8012
   Left seat belt tensioner:
   Serial number: 34230167A27111741128
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A30111750669
   Coding: 333135
   Serial number: 694000000000001P16LU
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 000 412 17
   Serial number: 35700000000CD6E0292U
   Subsystem 5 - Part No SW: -----------    HW: 480 000 412 17
   Serial number: 35800000000793F8382S
   Subsystem 6 - Part No SW: -----------    HW: 480 402 111 17
   Serial number: 3510001AF27F0824E78G
   Subsystem 7 - Part No SW: -----------    HW: 480 401 411 17
   Serial number: 35200019F2825B26247+
   Subsystem 8 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3550002B71B7E8F3F39X
   Subsystem 9 - Part No SW: -----------    HW: 480 402 410 17
   Serial number: 3560002C725629A5225/
8 Faults Found:
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:25:06
9482752 - Seat Occupied Recognition
          B10B2 00 [10001001] - Function Restriction due to Missing Message(s)
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
          B13BC F2 [10001001] - No function
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1055232 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1052928 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:50
1049088 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
1052416 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
1052672 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 17:24:51
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03121704221781
   Coding: 2018
   VCID: 0D4CC49E7DDAF702545-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
   Component: FBenUSA       H16 0066
   Coding: 08ED18533B88CF050281E8001800000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
16776968 - Databus
          [ESP_24 communication error can_error_timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:36
16776973 - Databus
          [RKA_01 communication error can_error_timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:37
16776982 - Databus
          [SWA_01 communication error can_error_timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:18:37
   Component: GW MQB High   518 5323
   Serial number: 25111710522595 Dataset Number: 8V0909515Q  0089
   Coding: 030100043F085A005B00806EB80B00000001010000000000000000000000
   GVL: 01D63C1000000600404C80000002CC0000040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3822454A22D822AAD73-806C
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20171122021939 20325
   Serial number: 758860000017120103A2
131603 - No Communication with ABS Brake Control Module
          U0121 00 [00001001] - -
          [Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
131662 - Lane change assistant control module
          U1045 00 [00001001] - No communication
          [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
131722 - Control Module 2 for Lane Change Assistance
          U10A5 00 [00001001] - No Communications
          [Timeout Knoten 0x8A / CF - Steuergerät 2 für Spurwechselassistent]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [00001001] - Warning Triggered
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [00001001] - Active
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:52:54
                    Terminal 15: On
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00004.10.17 Dataset Number: v1260x015G0 0000
   Coding: 0001
10 Faults Found:
16655 - Databus
          [Bremsensteuergerät - TO -- ESP_02]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17468 - Databus
          [Bremsensteuergerät - TO -- ESP_05]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17495 - Databus
          [Bremsensteuergerät - TO -- ESP_07]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17501 - Databus
          [Bremsensteuergerät - TO -- ESP_10]
                    Fault Frequency: 88
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:25
17471 - Databus
          [Bremsensteuergerät - TO -- ESP_14]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17502 - Databus
          [Bremsensteuergerät - TO -- ESP_18]
                    Fault Frequency: 57
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.08.18
                    Time: 18:50:23
17469 - Databus
          [Bremsensteuergerät - TO -- ESP_19]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17470 - Databus
          [Bremsensteuergerät - TO -- ESP_21]
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
17504 - Databus
          [Bremsensteuergerät - TO -- ESP_29]
                    Fault Frequency: 87
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 10:54:26
17505 - Databus
          [Bremsensteuergerät - TO -- EPB_01]
                    Fault Frequency: 200
                    Reset counter: 135
                    Mileage: 88798 km
                    Date: 2023.07.16
                    Time: 09:34:08
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   Dataset Number: 8V0909519D  0006
   VCID: 42D627A27404787A797-8016
   Revision: 00000000    Serial number: 17000355276007
   Coding: 5D00000000000000
   VCID: 343A717A3EB0C6CAFBB-8060
12666370 - Databus
          [Timeout Message ESP_10]
                    Fault Frequency: 33
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:13
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 655.34 km/h
                    Voltage: 69
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 05
13637376 - Databus
          [Errorvalue ESP_v_Signal]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:25
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Vehicle speed: 655.35 km/h
                    Voltage: 7A
                    AD-Value H-bridge: 3C
                    CAN signals: 04
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 7A
                    CAN signals: 04
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 C    HW: 8S0 907 397 C
   Component: LCM_MQB       H07 0022
   VCID: 41D428AE7102636260D-8014
0368 - Hardware coding
          C119E 01 [00001000] - Electrical Failure
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:52:02
0257 - Databus
          U1200 00 [00001000] - Defective
                    Reset counter: 145
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 14:59:02
0395 - Headlights in Service Position
          C1241 00 [00001001] - -
                    Reset counter: 135
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:16
Address 3C: Lane Change
   Serial number: 131017EJC01084 Dataset Number: 8V0909872J  0040
   Coding: 005D1B204000048000000002
   VCID: 43D822A66B1E7172721-8016
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Türelektronik Beifahrer (J387)]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
65573 - Local Data Bus
          U10BA 00 [00001000] - No Communication
          [Türelektronik Beifahrerseite hinten (J389)]
                    Reset counter: 161
                    Mileage: 88808 km
                    Date: 2023.08.16
                    Time: 13:56:06
458776 - Databus
          [Gateway_71 Datenbus fehlende Botschaft]
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: 8V0909852S  0001
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
8 Faults Found:
16272 - Steering Angle Sensor
          B1168 F2 [00001000] - Not Initialized
                    Reset counter: 139
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 11.75 V
                    Temperature: 5.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 11.92 V
                    uAdSensI_SwitchedKl30_xdu16: 11.89 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
20224 - Databus
          [ESP_19 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    System status: Driving mode
                    Temperature: 30.0 °C
                    KFC: 4F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 12.06 V
                    uAdSensI_SwitchedKl30_xdu16: 12.01 V
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_UNDERVOLT: not activated
19456 - Databus
          [ESP_05 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 00
19200 - Databus
          [ESP_02 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    Supply voltage: 13.75 V
                    Temperature: 36.0 °C
                    KFC: 4B
                    KFA: 00 00
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.03 V
                    RP_CNTERR: not activated
20992 - Databus
          [ESP_24 Botschaft - CAN-Timeout]
                    Fault Frequency: 9
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.17
                    Time: 18:50:12
                    Motor status: 02
                    Supply voltage: 14.00 V
                    KFC: 52
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.06 V
                    uAdSensI_SwitchedKl30_xdu16: 13.98 V
20736 - Databus
          [ESP_21 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:23
                    Motor status: 00
                    KFC: 51
                    KFA: 00 00
19968 - Databus
          [ESP_14 Botschaft - CAN-Timeout]
                    Reset counter: 120
                    Mileage: 88808 km
                    Date: 2023.07.24
                    Time: 17:11:28
                    Motor status: 00
                    KFC: 4E
                    KFA: 00 00
20480 - Databus
          [ESP_20 Botschaft - CAN-Timeout]
                    Reset counter: 128
                    Mileage: 88808 km
                    Date: 2023.12.09
                    Time: 12:30:58
                    Motor status: 02
                    Supply voltage: 14.50 V
                    Temperature: 17.0 °C
                    KFC: 50
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.59 V
                    uAdSensI_SwitchedKl30_xdu16: 14.56 V
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 30111710520382 Dataset Number: 8V0909583C  0008
   Coding: 000000050100147206112300040000000000000000000000000000000000
   VCID: 72B6B762042488FA297-8026
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
13705472 - Databus
          [ESP_19 data bus missing message]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
0032 - Headlight
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:49:03
458776 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:14
7 Faults Found:
13705491 - Databus
                    Fault Frequency: 27
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:17
                    passive
13705492 - Databus
                    Fault Frequency: 39
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:20
                    passive
13705476 - Databus
                    Fault Frequency: 29
                    Reset counter: 120
                    Mileage: 88754 km
                    Date: 2023.06.26
                    Time: 17:42:15
                    passive
13705989 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705990 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
13705984 - Databus
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 08:40:26
                    passive
13705995 - Databus
                    Reset counter: 141
                    Mileage: 88808 km
                    Date: 2023.07.16
                    Time: 12:51:18
                    passive
0014 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.09
                    Time: 18:16:26
                    Reset counter: 157
                    Mileage: 88808 km
                    Date: 2023.07.21
                    Time: 09:18:11
EuroX
Northern NJ USA
C?ID=208579
Please clear all codes and post updated auto scan. Code wrap please. thanks.
Eli Gavel
West Springfield, MA, USA
C?ID=575306
this is what shows up after clearing codes
Saturday,10,February,2024,08:09:59:47766
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WAUB1GFF1J1043667   License Plate: 4LFY84
Mileage: 88808km-55182mi   Repair Order: 55
Gateway Installation List:  3Q0 907 530 L
ABS Brakes look to be off-line. This causes a tremendous cascade of faults in other modules.
Blown or missing fuse?
Eli Gavel
C?ID=575306
Not sure could it be one of those big fuses that you can't see directly if it blown?
Eli Gavel
C?ID=575306
This is the auto scan after the codes were cleared previously.
Saturday,10,February,2024,23:52:18:47766
          P164E 00 [00100111] - Electrical Malfunction
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:18
                    Coolant temperature: 4 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 11.738 V
                    Engine oil temperature: 3.0 °C
                    T_ES: 2880 min
                    MAP_MES_SAE: 100 kPa
                    T_AST_SAE: 0 s
                    ECU_STATE: ENG_STOP
          U0121 00 [10100111] - -
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:16
                    ECU_STATE: ENG_STOP
                    T_ES: 2880 min
                    T_AST_SAE: 0 s
Readiness: 1110 0101
   No subsystems:
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:16
                    Driving position: P
                    Engine torque: -28 Nm
                    Control Module temperature: 4 °C
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:16
                    Driving position: P
   Coding: 030C1C
459012 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
459015 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:26
   Coding: 0A47F7
   Coding: 101F00
8 Faults Found:
528917 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
                    Outside temperature: 2.0 °C
533269 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:19
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
533525 - Databus
          [ESP_07_alt aktiv]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
533781 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
555029 - Databus
          [ESP_21_alt aktiv]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:18
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.7 V
   Coding: 0470155011
9 Faults Found:
12656914 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12656913 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12658704 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12656918 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12656919 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:18
12656920 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12656926 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
13639168 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
12656922 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
10 Faults Found:
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
                    Control Module temperature: 13 °C
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1110 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1058 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1089 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1103 - Databus
          [FAULT_TIMEOUT_ESP_19]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1091 - Databus
          [FAULT_TIMEOUT_ESP_20]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1092 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1074 - Databus
          [FAULT_TIMEOUT_ESP_33]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
2126 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
10493953 - Databus
          [ESP_02_Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    COM: 00 7D 00 BE 00 06 FA DB 00 00
                    Voltage terminal 30: 11.8 V
                    AMR state: 0
                    ESP status: 0
10498049 - Databus
          [ESP_05_Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    COM: 00 7D 00 BE 00 06 FC BB 00 00
                    AMR state: 6
                    ESP status: 0
10502145 - Databus
          [ESP_21_TimeOut]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    AMR state: 0
                    ESP status: 0
10551297 - Databus
          [ESP_07_Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
                    COM: 00 5D 00 9E 00 06 FE 9B 00 00
                    AMR state: 6
                    ESP status: 0
   Coding: 333135
   Coding: 333135
   Coding: 303337
8 Faults Found:
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:30
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
1055232 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
1052928 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
1049088 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
1052416 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
1052672 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
   Coding: 2018
16776968 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
16776973 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
16776982 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
   Generator:
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Terminal 15: On
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Terminal 15: On
   Coding: 0001
10 Faults Found:
16655 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17468 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17495 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17501 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17471 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17502 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17469 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17470 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
17504 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 23:48:37
17505 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 23:48:37
12666370 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 06
                    Voltage: 65
                    AD-Value H-bridge: 32
                    CAN signals: 05
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
458776 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
   Coding: 811F0000
8 Faults Found:
20480 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
                    Motor status: 00
                    Temperature: 12.0 °C
                    KFC: 50
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.83 V
                    uAdSensI_SwitchedKl30_xdu16: 11.79 V
19200 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 00
19712 - Databus
          [ESP_10 Botschaft - CAN-Timeout]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 4D
                    KFA: 00 00
19456 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.70 V
                    uAdSensI_SwitchedKl30_xdu16: 11.64 V
20736 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 51
                    KFA: 00 00
20224 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 4F
                    KFA: 00 00
20992 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    Motor status: 00
                    KFC: 52
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.86 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
19968 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:17
                    Motor status: 00
                    KFC: 4E
                    KFA: 00 00
13705478 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
13705472 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
0032 - Headlight
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
   Serial number: 141017EJD09096 Dataset Number: 8V0909873J  0040
   Coding: 005D13204000048000000002
458776 - Databus
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:13
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
   VCID: 3924404E19D23BA228D-806C
13705491 - Databus
          [message ESP_10 not received]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:15
                    passive
13705492 - Databus
          [message ESP_20 not received]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:18
                    passive
13705476 - Databus
          [Oldbit-monitoring Gateway_71.ESP_21_alt]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
                    passive
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 171027201755
   VCID: 3E2E535200FC1C9A1DF-806A
0014 - Databus
          [Keine Funktion durch CAN FehlerESPsteuergerätebotschaft fehlt--> keine Klangerzeugung]
                    Reset counter: 135
                    Mileage: 88808 km
                    Date: 2024.02.10
                    Time: 08:09:14
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 190917EII27703 Dataset Number: 8V0909897H  0028
   Coding: 000C13204000048000000002
   Serial number: 190917EII2757B Dataset Number: 8V0909896H  0028
Address CF: Lane Chge Asst 2
   Dataset Number: 8V0909471E  0008
   VCID: 1760A6F64F060DD2FE9-8042
   Dataset Number: 8V0909472E  0008
End----(Elapsed Time: 01:59, VBatt start/end: 11.6V/11.6V. VIgn 11.3V)-----
EuroX
Northern NJ USA
C?ID=208579
Perhaps a story on this vehicle got fucked is in order. Is this a vehicle after an accident?
Eli Gavel
C?ID=575306
This is an auction car but I never had any coding issue after I fixed the car it only happened after the guy scanned the car and he’s saying there is loose wiring which I don’t believe.
EuroX
Northern NJ USA
C?ID=208579
Something tells me whoever touched this vehicle did more bad than good to it honestly. Do you have any older logs prior to him touching it? I will assume he wrote some data to it that it's not supposed to have. Have you driven the car? It looks like ABS is offline. I would check all fuses for ABS module.
Eli Gavel
C?ID=575306
yeah I was told by the guy that scanned my car that it’s my wiring or fuse of some sort. It’s just funny that he’s trying to say what the issue could be after what actually happened was everything lit up after him. I don’t have any logs of the car I just purchased vcds. I will definitely look into grounds and fuses also I was told to replace the abs module which I did and I made sure the new one was the same parts number but the same code came up after scanning the car saying there is no communication it’s the abs module maybe I need to to some sort of programming to the car with the new module.
EuroX
Northern NJ USA
C?ID=208579
No I would assume you have a popped fuse somewhere. Depend on what the person did and what was actually done I would not be surprised please check all fuses under the hood and under the dash.
Eli Gavel
C?ID=575306
Great news the car is fixed I had a guy come out and recode my abs and got rid of all my codes and lights also I found a loose ground on the car which fixed the no communication with the abs module. Thanks for all the help car is all set.
EuroX
Northern NJ USA
C?ID=208579
Well ABS wasn't talking so how could it be recoded? Why wasn't it talking? Lesson learned good help is hard to find. I would get your money back if you paid the first asshat to fuck up your car. Best of luck.
Eli Gavel
C?ID=575306
It wasn’t talking because of the loose ground as soon as I connected it then the abs light on the dash was flashing which means something changed and then the guy can and was able to code it
EuroX
Northern NJ USA
C?ID=208579
Would of been helpful to know that the ground was loose or not connected. Probably could of avoided all this.
Yeah, that would explain a lack of communications too. Not as common as a blown or missing fuse, but still stops the flow of power to the ABS. It would be cool if you'd show where the exactly the loose ground was.
