Resolved 2016 Golf R need help with ABS module coding
Resolved
Zeljo
Edmonton, AB, Canada
C?ID=123505
Original ABS module had no comms dont have original code, replaced with used unit with same part number and options just from 2017 R, tried using code
01FA6BA154280970457B030340C76980D62A90A2C0029637184050D8C2A8430000000012121212B835351919323200
from donor vehicle but get : Coding rejected Error 13: incorrect message length or invalid format.
let me know if can help with different code or procedure
Wednesday,07,February,2024,18:30:12:09301
VCDS Version: 23.11.0.0 (x64)
VIN: WVWLF7AU1GW120743   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
          5F A5 A9
VIN: WVWLF7AU1GW120743   Mileage: 126792km-78784miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---    CVN: C7E73461
   Coding: 091D00122466000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 458BAF33C485B3B9B0-8010
   VINID: 9E69DC5874650579C10801C40C7C490729
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [10100111] - -
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Engine RPM: 0.00 /min
                    Coolant temperature: 20  C
                    Intake air temperature: 22  C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.167 V
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
                    CCS Switch: ACC operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    ACC variants: ACC
                    Engine: operating status: ES
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10100111] - -
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
                    Voltage terminal 30: 12.109 V
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 19.0  C
                    Time since engine start: 0.0 s
                    T_ES: 305 min
                    ECU_STATE: ENG_STOP
21321 - Implausible Data Received from ABS Control Module
          U0415 00 [00100111] - -
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Voltage terminal 30: 12.128 V
                    ECU_STATE: ENG_STOP
                    T_ES: 305 min
                    ECU_STATE: ENG_STOP
23129 - Implausible Data Received from ABS Control Module
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Voltage terminal 30: 12.148 V
                    ECU_STATE: ENG_STOP
                    T_ES: 305 min
                    ECU_STATE: ENG_STOP
Readiness: 1110 0101
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01509020222 CVN: 0000A540
   ROD: EV_TCMDQ250021.rod
   VCID: 53AF816B3AD11D092E-8006
21221 - No Communications with Parking Brake Control Module
          U0128 00 [00001011] - -
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 60107000001771
   Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   VCID: 79F313C3F8FD075984-802C
12 Faults Found:
0056 - Front Right Wheel Speed Sensor
          C101B 01 [10001001] - Electrical Failure
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
0195 - Control module not coded
          U1013 00 [10001001] - -
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
8286 - Databus
          U1123 00 [10001001] - Received Error Message
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
8292 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
8299 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
8306 - Databus
          U1122 00 [10001001] - Implausible Message
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:48
8311 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [10001001] - Switches/Motors Detected
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:43
   Revision: 00021000    Serial number: 0379254649 Dataset Number: V03935197YW 0001
   Coding: 030C0C
   VCID: 3A71CCCFBD7BCC41CD-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08    Dataset Number: 0000
   Coding: 00020004200100010105000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6AD13C8F8D5BBCC17D-803E
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Outside temperature: 20.5  C
                    Engine RPM: 0 /min
                    Temperature downstream of evaporator: 21.3  C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061524600182 Dataset Number: V03935237MC 0001
   Coding: 00051A46C041A2E149E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 01037B23902D5F99CC-8054
   Component: WWS    161220  043 0551
   Serial number:         170110133749
   Component: RLHS  037 0059
   Serial number: S4Y15M09D16H10M37S54
   Coding: 90A8DD
   Revision: --------    Serial number: 39331525704844 Dataset Number: 5G0039v__A_ 0023
   Coding: 0071155011
   VCID: 438FB12BCAB18D899E-8016
12658704 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
13637412 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
13637426 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
13688835 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 05081503210437 Dataset Number: 5g0114v____ 1027
   Coding: 01045700FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
10 Faults Found:
15360768 - Component Protection
          U1101 00 [00001001] - Active
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Control Module temperature: 31  C
                    Voltage terminal 15: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
1071 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Voltage terminal 15: 12.0 V
1067 - Brake Temperature
          C10DF 00 [00001001] - -
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
1058 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:45
1059 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
1078 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
0261 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
1043 - Automatic Distance Control
          B10E7 F0 [00001001] - Disconnected
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
1118 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
1081 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 25081541350223 Dataset Number: 5G0532v____ 0044
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3777D5FB8E69D12932-8062
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01PZJF Dataset Number: 5GM003V____ 0041
   Shop #: WSC 01383 790 50316
   VCID: 51A38B6300CD6F191C-8004
   Serial number: IBH0000J1600069DNX0R
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 15
   Serial number: 35700000000515CC361H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 209 15
   Serial number: 3580000000086CEC261Y
   Subsystem 4 - Part No SW: -----------    HW: 480 400 709 15
   Serial number: 3510002B51D1B5D3030Y
   Subsystem 5 - Part No SW: -----------    HW: 480 402 408 15
   Serial number: 3520002B91CF2D85D30I
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3550002C91CB0C02D3AE
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3560002C71CB0C00617%
          B13BC F2 [10001001] - No function
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 09091504400595
   Coding: 0C10
   Shop #: WSC 31589 004 1048576
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 09136303A81D17D994-805C
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 0BAD081A7F88880902886A0B5400000000000000
   VCID: 2D5BF7937C356BF958-8078
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:45
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:45
16777022 - Function Restricted due to Interrupted Communications
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:45
16776967 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
16776973 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003899254 Dataset Number: V03935223TH 0001
   Coding: 0101000830085900FB00023A9C0F00000001050000000000000000000000
   GVL: 01D43C100000060040CC90000000CC0000000000000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75EB1FF3D4E56339E0-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001780210045373
   Coding: 35FFFF
131699 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
                    Terminal 15: On
   Serial number: HA1-00009.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4A919C0FED9B5CC15D-801E
16656 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:40
   Revision: 00000000    Serial number: 15000191590006
   Coding: 5D00000000000000
   VCID: 346DE2F79F1F3A3117-8060
13637378 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 69
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 04
   Component: HRE_Master    H11 0071
   Serial number: 0378842561 Dataset Number: 5G9764V____ 0027
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C7DCAD7B74FF271DF-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0378933384
   Coding: 020111
337776 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Serial number: 020915BI110068 Dataset Number: 5G0222v____ 0064
   Coding: 003E13208000040000000000
65573 - Local Data Bus
          U10BA 00 [00001001] - No Communication
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
65799 - Door Warning / Entry Lighting
          B1775 01 [00001001] - Electrical Failure
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
589824 - Local Databus
          U1030 00 [00001001] - Electrical Malfunction
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
589825 - Local Data Bus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Dataset Number: V03935249RP 0001
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
19204 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Motor status: 00
                    System status: Driving mode
                    Supply voltage: 12.00 V
                    Temperature: 31.0  C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 12.33 V
                    uAdSensI_SwitchedKl30_xdu16: 12.34 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
20228 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Motor status: 00
                    Temperature: 31.0  C
                    KFC: 4F
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 12.05 V
                    uAdSensI_SwitchedKl30_xdu16: 12.04 V
20740 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Motor status: 00
                    Temperature: 31.0  C
                    KFC: 51
                    KFA: 00 04
15873 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Motor status: 00
                    Temperature: 31.0  C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 12.14 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
19716 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Motor status: 00
                    Temperature: 31.0  C
                    KFC: 4D
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 12.20 V
                    uAdSensI_SwitchedKl30_xdu16: 12.21 V
   Serial number: 200815BHK03573 Dataset Number: 5G0157v____ 0060
   Coding: 003E13208000040000800000
   VCID: 4281B42FD5AB848195-8016
65572 - Local Data Bus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0001
   Coding: 022202010B010400
   VCID: 4085BE27DBA7969183-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
13705986 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
13705992 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:41
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000421702    Dataset Number: 5G0HL1V____ 0053
   Coding: 0100000000020308000400010100000100
   ROD: EV_MFKBoschAU370.rod
6553600 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:42
                    Control Module temperature: 36  C
                    Terminal 15 on: 445.1 s
7536641 - Databus
                    Reset counter: 190
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 05:49:46
                    Terminal 15 on: 449.6 s
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 161120201340
   VCID: 2F67ED9B763919E96A-807A
End-------------------------(Elapsed Time: 05:24)-----------------------
iichel
Netherlands, Operation Market Garden
C?ID=284912
01FA6BA15422096C457E030440C66980D62A90A2C0029637144000D8C0A8420000000012121212B835351919323200
may not be perfect, but check if it takes
EuroX
Northern NJ USA
C?ID=208579
Above coding is incorrect per vin. Here is my second good deed for the year:
Data source:Vehicle
Hardware part number:3Q0907379G
Part number:3Q0907379AB
Hardware version number:H42
Software version number:0723
Production date:30.08.2015
Coding:
Coding:01FA6BA15422096C057E030441C66980D62A90A0C08296B7184050D8C288
Ability to flash:Unknown
System name:ESC
ASAM base version:BV_Brake1UDS
ASAM 2D/ODX data set:EV_Brake1UDSContiMK100IPB
ASAM 2D/ODX data set version:034036
ASAM/ODX control module version being used:EV_Brake1UDSContiMK100IPB_034
Target data container:-----------
Version of the target data container:----
Equipment code:FF FF FF FF FF FF FF FF FF FF FF FF
System abbreviation:J104
Zeljo
C?ID=123505
Didn't take it, any other suggestions ???
Zeljo
C?ID=123505
Data source:Vehicle
Coding:
System name:ESC
Didnt take it, just noticed part bumbers are different, any suggestion ???
Zeljo
C?ID=123505
That coding isn't going to take since that's a 28 byte coding and he swapped in a 47 byte module.
Yes just noticed parts number that i have and what EuroX posted are different, is module i have still doable to code or ????
iichel
C?ID=284912
That's up to you. You didn't fit the correct part. Fitting the correct part would make the coding of eurox work. Or we keep trying with the trial and error stuff.
Zeljo
C?ID=123505
I m open to keep trying other codes if you can suggest, let me know thanx
I realize you have other coding to check and work with, but this fault may ultimately affect your efforts ; I would at least have a
look at it and be sure that sensor and tone wheel as well as wiring is fault free. (???).
0056 - Front Right Wheel Speed Sensor C101B 01 [10001001] - Electrical Failure MIL ON - Confirmed - Tested Since Memory Clear
Zeljo
C?ID=123505
Are you saying that this faulty sensor will possibly prevent me from coding the module ??
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Considering that it is Electrical Failure, need to think, not sure.
I'm just not sure, but those sensors go through the ABS module and could potentially cause a problem ; especially as noted above
"electrical failure". I would definitely keep this fault in mind and check it out as best you can.
Boki Ar
C?ID=57300
I agree, I would first try to turn off that problematic sensor. :thumbs: :cool:
EuroX
Northern NJ USA
C?ID=208579
For the wheel speed sensor fault. I would swap pins at the module with the left front sensor and check if the fault now shows a code for the left front wheel speed sensor. If so we can conclude the used module is fucked or NFG. This would be my approach as it takes the wiring, wheel speed sensor and possible wheel bearing out of the equation.
Zeljo
C?ID=123505
Unplugged left side sensor and got same fault just for left side, swapped sensors left to right and confirmed both sensors are good. Can you share pins location at the module to swap with left sensor or any other way to check wiring ??
EuroX
Northern NJ USA
C?ID=208579
At this time I do not have access to vw wiring diagrams please look at erwin to get that information.
Hi guys,
I'm pretty late to this thread but after looking at the parts catalog, and confirming that 3Q0907379AB is still the current day direct replacement, I was gonna pop in here and recommend installing the correct ABS module so it could be coded easily. However, a quick search of the VIN shows some very extensive damage. If the vehicle history was not disclosed to you please see:
Those listings are usually accurate but there isn't a VIN plate/stickers in this instance. If that search result is correct I'd be highly suspicions of the entire harness near the ABS module/cowl area. If the harness was replaced with used I would verify it was from a Golf R with the identical equipment.
EuroX
Northern NJ USA
C?ID=208579
I would agree. But this is why I suggested swapping pins at the abs module connector that way if the fault now states opposite side and it didnt before then we know we have a abs module issue and not sensor or wiring. Op need to look at wiring and test.
etz2k
C?ID=69430
You can try this coding, i hope it's OK:
01FA6BA15422096C457E030440C66980D62A90A2C0029637184050D8C288430000000012121212B835351919323200
