A6 4F Memory Seat module
krustyx
Canada / Netherlands
C?ID=142005
Hello everybody,
I changed the dash/doors trim in my car for the S6 model without the seat memory option. I removed the module.
Not a big deal since i changed the seats for the S7 seats too. Since the modules are completly different, I just want to disable the option so there's no more code. Here's the codes that i'm getting since i've removed the module.
Where do i need to go to disable the module? Thanks
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
> Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
> Component: Gateway H11 0070
> Revision: 11 Serial number: 1300805A318108
> Coding: ECFE73CC1B7106
> Shop #: WSC 94827 999 85536
> VCID: 2757DEB196AEFB26FAD-8072
> 1 Fault Found:
> 01964 - Control Module for Seat & Steering Column Memory (J136)
> 004 - No Signal/Communication
> Freeze Frame:
> Fault Status: 01100100
> Fault Priority: 2
> Fault Frequency: 1
> Reset counter: 248
> Mileage: 111665 km
> Time Indication: 0
> Date: 2014.03.06
> Time: 05:37:34
> Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
> Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
> Component: TSG FA H12 0080
> Revision: 00000000 Serial number: 0p > Coding: 0052971
> Shop #: WSC 02327 785 00200
> VCID: 2C5D219D8F48D87E17F-8079
> 1 Fault Found:
> Freeze Frame:
> Fault Priority: 4
> Fault Frequency: 1
> Reset counter: 248
> Mileage: 111665 km
> Time Indication: 0
> Date: 2014.03.06
> Time: 05:37:32
> Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
> Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
> Component: TSG BF H12 0080
> Revision: 00000000 Serial number: G‰ > Coding: 0052971
> 1 Fault Found:
> Freeze Frame:
> Fault Priority: 4
> Fault Frequency: 1
> Reset counter: 248
> Mileage: 111665 km
> Time Indication: 0
> Date: 2014.03.06
> Time: 05:37:32
United States
I wasn't able to locate a complete Auto-Scan from you in our email history or in forum. Please post the complete scan so we can see what this vehicle is made of in addition to the current configuration of the GAN Gateway Installation List.
-Dana
krustyx
C?ID=142005
Monday,21,April,2014,15:23:09:17391
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUKH94F56N104951   License Plate:
Mileage: 111660km-69382mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
          55 56 61 62 67 6D 72 76 77
VIN: WAUKH94F56N104951   Mileage: 111660km/69382miles
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 010D0109190F0120
   Shop #: WSC 66565 257 00032
   VCID: 2B5F22818A46DF461E5-807E
               P1653 - 008 -
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:37:51
                    RPM: 1312 /min
                    Mass Air / Rev.: 103.6 mg/str
                    Temperature: 49.5°C
                        Idle
                    Load: 9.0 %
Readiness: 0110 0101
   Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4105914
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2649D3B591A4E22EC1B-8073
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020895
   VCID: 2D5B2C99B452D176001-8078
                    Reset counter: 248
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:38:44
                    Hex Value: 0x0000
                    Hex Value: 0x42A2
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500951070
   Coding: 0000143
   Shop #: WSC 94827 999 72508
   VCID: E3CF0AA12216D706665-80B6
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 KSG   H26 0080
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 C    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 303KJ057510714
   Coding: 0031003
   Shop #: WSC 00000 000 08192
   VCID: 234FCAA1E2961706A65-8076
   Component: Bedienteil MMIC6H08 0050
   Subsystem 2 - Serial number: 00000000266912
   Subsystem 3 - Serial number: 0128.10.050000000100010691ÿ
   Subsystem 4 - Serial number: 010691ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000030069672
   Coding: 0524582
   VCID: DBBF32411A66EFC62E5-808E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014114
   Shop #: WSC 02335 785 00200
   VCID: 2A51278585BCC64EE53-807F
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7253127
   VCID: 1C3DF15DDFE828FE67F-8049
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 65 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A6A9M
   Coding: 0013877
   Shop #: WSC 92602 999 83964
   Subsystem 1 - Serial number: 6332CSME0C6469086
   Subsystem 2 - Serial number: 6342CSME0C643251
   Subsystem 3 - Serial number: 6352QSME06741E31D
   Subsystem 4 - Serial number: 6362QSME06762D0BN
   Subsystem 5 - Serial number: 63734SME042B191F1
   Subsystem 6 - Serial number: 63834SME060D2101P
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0310
   Revision: 00H01000    Serial number: 90026052690226
   Coding: 0002342
   Shop #: WSC 02323 785 00200
   Component: E0221           H01 0100
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 931 E
   Component: KOMBIINSTR. M73 H16 0630
   Revision: 00200000    Serial number: 4PU39TWA5
   Coding: 2113363
   Shop #: WSC 94817 999 96786
   VCID: 2143C0A9F88A0516B49-8074
                    Reset counter: 248
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:37:34
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H45 1100
   Revision: 00000000    Serial number: 355K%057556684
   VCID: 38750DCD4B1064DE637-806D
   Coding: 0052971
                    Reset counter: 248
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:37:32
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H18 0130
   Revision: 01300018    Serial number: 01007806180000
   Coding: 7764669
   VCID: 2953D88980BACD56EC9-807C
01696 - Footwell Lighting; Rear Left (W45)
                    Reset counter: 248
                    Mileage: 107813 km
                    Date: 2005.02.01
                    Time: 13:46:15
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000810786
   Coding: 0000126
   VCID: 254BD4B9ECA2E936C81-8070
02753 - Inside Microphone (R74)
                    Reset counter: 248
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:37:39
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000010638
   Coding: 0002114
   VCID: DEB93B550974FAEE49B-808B
   Coding: 0052971
                    Reset counter: 248
                    Mileage: 111665 km
                    Date: 2014.03.06
                    Time: 05:37:32
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801
   Component: EPB  CDEC0080   H03 0080
   Revision: --H03---
   Coding: 0005022
   Shop #: WSC 93250 999 65003
   VCID: 2045C5ADF3800C1EBB7-8075
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394JV057630435
   Coding: 0000002
   VCID: 2E592B95B954AA6E39B-807B
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000148869
   Shop #: WSC 02335 823 00000
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  1510260045
   Coding: 344630393135313035452056413031353130323630303435
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0052778
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000510190086
   Shop #: WSC 12336 024 394758
   VCID: 346D39FD577880BE4FF-8061
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 B
   Component: ValeoHeckdeckel H18 0280
   Revision: --H18001    Serial number: E5030000B
   Shop #: WSC 23250 431 715754
   VCID: ECDD619DCFC8987ED7F-80B9
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD11.10.05--H18001001A0046ÿ
   Subsystem 4 - Serial number: 1A0046ÿ
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720528704259
   Coding: 0201216
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H11 0950
   Revision: 00000000    Serial number: 00000007521964
   Coding: 0010900
golfi_vend
Tartu, Estonia
C?ID=195131
Remove seat memory from can gateway coding or installation list. Or paste coding: ECFE73C41B7106
Coding for module 42 and 52 is 0052843
