- Mar 30, 2014
- 238
- 10
- Brighton, MI
- C?ID=102239
I already swapped out the trailer module (rear right trunk/side aread), no change. 4E0 907 383 J SW: 0100 HW: H09
Note: right cooling fan kept running for long time after shutting off, locking car (see engine code, NOT the normal 'hot engine afterrun'). Ordered module, but then problem went away (not scanned since).
What and where IS "Terminal 30"?
Prodigy braker controller installed, worked great for a year, now erratic, not working most of the time, only very weak braking.
Code coming back after erase (need to check if right away or when using trailer).
Scan:
Scan:
Saturday,30,December,2023,15:20:35:03761
VCDS Version: Release 23.11.0 (x64) Running on Windows 11 x64
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 4L2 910 401 HW: 4L0 907 401 D
Component and/or Version: 3.0TDI EDC17 X18 0002
Software Coding: 2A2A4012257600050000
Work Shop Code: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114L2910401 001002 (AU56)
ROD: EV_ECM30TDI0114L2910401_001.rod
VCID: 61C8286370471B99AC-8034
4529 - Fan 1 Control Circuit
P0692 00 [00100111] - Short to Plus
Mileage: 230200 km
Date: 2023.12.30
Time: 15:20:53
Engine RPM: 0.00 /min
Coolant temperature: 40 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.300 V
Air mass: specified value: 750.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 8.6 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside temperature: 6.5 °C
Coolant fan 2: activation: 12.36 %
Coolant fan 1: activation: 10.00 %
Fuel temperature: 6.6 °C
Saturday,30,December,2023,15:08:40:03761
VCDS Version: 23.11.0.0 (x64)
VIN: WA1WMAFE1CD005741 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFE1CD005741 Mileage: 230200km-143039miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI EDC17 X18 0002
Revision: 54X18--- Serial number: CVN: B8D3205F5C3E0D04D45710C1
Shop #: WSC 92521 052 00000
VINID: 9D10677515950535000051C4049A9EF5D2
P0692 00 [00101111] - Short to Plus
Fault Frequency: 16
Mileage: 229884 km
Coolant temperature: 5 °C
Intake air temperature: 6 °C
Voltage terminal 30: 10.680 V
Coolant temperature at radiator outlet: actual value: 5.2 °C
Outside temperature: 5.5 °C
Coolant fan 2: activation: 13.08 %
Fuel temperature: 5.3 °C
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Serial number: CVN: 44BD1086
Coding: 001378
Shop #: WSC 39017 003 1048576
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3C76B917B7651671DF-8068
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0623761
Shop #: WSC 31414 790 00001
VCID: 346691375735DE3117-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603501928618
Coding: 0000135
VCID: 25407C73ECEFB7B990-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 94
Mileage: 229434 km
Date: 2023.12.03
Time: 16:19:05
00191 - Passenger's Door Handle Touch Sensor (G416)
Reset counter: 94
Mileage: 229434 km
Date: 2023.12.03
Time: 16:19:05
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 94
Mileage: 229434 km
Date: 2023.12.03
Time: 16:19:05
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000000304939
Coding: 0004A036
VCID: 25407C732CEFB7B990-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0018325487
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 0018325484
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6ED2435F7999B4E121-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031111
VCID: 275C767B96E3A5A9A2-8072
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09Y1CK
Coding: 0014131
VCID: 2B548A4B8A0B81C946-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME2965436CM
Subsystem 3 - Serial number: 6342QSME156515469
Subsystem 4 - Serial number: 6352QSME12654276A
Subsystem 5 - Serial number: 6362QSME29642D54N
Subsystem 6 - Serial number: 63734SME65664A78A
Subsystem 7 - Serial number: 63834SME65665156%
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90055113250127
Coding: 0012152
VCID: 285E75479BFDAAD1AB-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 H HW: 4L0 920 984 H
Component: KOMBIINSTR. H22 0411
Revision: 00000000 Serial number: LP440HHCC
Coding: 8BD664040D00CF05020205
VCID: 387EA5078B5D3A513B-806C
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0057
Revision: MB600036 Serial number: 3600M11B030265
Coding: 00C303
VCID: 3F8CCE1BAE730D69FA-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790125086
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 152
Mileage: 229689 km
Date: 2023.12.14
Time: 16:36:00
Reset counter: 152
Mileage: 229689 km
Date: 2023.12.14
Time: 19:36:00
Bin. Bits: 00000
Voltage: 12.30 V
Count: 18
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000000305265
Coding: 0000006
VCID: 68DE35475B7D6AD16B-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000018305885
Coding: 00581B00000011110000
VCID: 326A972F6D21D00105-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0000001
VCID: 2E52835FB919F4E161-807A
Subsystem 3 - Serial number: 5F29.11.1100H010003C914589ÿ
Subsystem 4 - Serial number: 914589ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000018871590
Coding: 011F57205E40440004
VCID: 489ED5C7FBBD4AD14B-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Fault Frequency: 21
Reset counter: 154
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01596519710000
Coding: 3569693
VCID: 387EA5074B5D3A513B-806C
Fault Status: 01101100
Reset counter: 114
Mileage: 150155 km
Date: 2011.08.17
Time: 02:43:01
Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
Component: BO Q7 H30 0110
Revision: 05S00000 Serial number: 01307110006464
Coding: 0D000001
VCID: 2958704340F793D9B4-807C
Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
Component: BO Q7 SLAVE H41 0780
Serial number: 02810110005221
00869 - Line Output; Rear Right
Fault Status: 00101100
Reset counter: 143
Mileage: 229506 km
Date: 2023.12.07
Time: 10:51:59
Voltage: 14.90 V
Temperature: 11.0°C
Bin. Bits: 00000100
Voltage: 14.50 V
Temperature: 14.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190137749
Coding: 0758477
VCID: 2344626BE2DB4989FE-8076
02214 - Tire Pressure Warning
Reset counter: 146
Mileage: 229821 km
Date: 2023.12.19
Time: 19:26:02
Hex Value: 0x0004
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.70 V
Temperature: -2.0°C
(no units): 49.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000099997
Coding: 0012001
VCID: 5EB2139F8939246191-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000018423146
VCID: 479CD6FBF6A345A942-8012
Fault Status: 01101000
Reset counter: 88
Mileage: 229320 km
Date: 2023.11.22
Time: 15:18:44
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 88
Mileage: 229320 km
Date: 2023.11.22
Time: 14:30:58
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156K80B7578275
Coding: 020007010000000000
VCID: 1F4C6E9B0EB36D69DA-804A
Part No SW: 4L2 035 746 B HW: 4L2 035 746
Component: H-BNT-NA H42 0422
Revision: -------- Serial number: 097K20B7507570
Coding: 180200060004EBEF71000345EF632003140000000100000000
VCID: 2D508453741F8FF958-8078
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130KI0BS065749
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002105748
Component: CD-Database 3371
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000018837337
Coding: 010E57204040230004
VCID: 4682DBFFF1A95CA1B9-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000159164851
Coding: 0200000000000000
VCID: 316898236827EB197C-8064
02539 - Terminal 30 from Control Module
014 - Defective
Fault Status: 01101110
Fault Frequency: 105
Reset counter: 114
Mileage: 227050 km
Date: 2023.11.15
Time: 12:50:39
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J1X41BW
Coding: 1011201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD649574F8546F10F-8038
Subsystem 3 - Serial number: RD28.11.11--H57001001B0301ÿ
Subsystem 4 - Serial number: 1B0301ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H8
Revision: AAH8 Serial number: 122229800-----
Coding: 0003595
VCID: 26427B7F91E9BCA199-8072
Component: J_245_EE16_SKB10H12 0220
Component: J_394_EE16_SKB10H12 0220
Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000018837338
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37361132302733
Coding: 0221266
VCID: 2C5689578F0586F14F-8078
End-------------------------(Elapsed Time: 04:23)--------------------------
