- Jul 8, 2022
- 11
- 0
- Auckland, New Zealand
- C?ID=574564
Can the air bag light be cleared?Friday,02,February,2024,18:54:36:29372
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2EZ86027366 License Plate: ESW415
Mileage: 560334 Repair Order:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 91: LT3 Engine Labels: 074-906-032.clb
Part No SW: 074 906 032 BA HW: 074 906 032
Component: R5 2,5L EDC 0400SG 5176
Revision: --H07--- Serial number: VWZDZ0G1039544
Coding: 0003072
Shop #: WSC 28673 002 1048576
VCID: 52FD6B8D28E86A5AC97-8006
004697 - Coolant Circulation Valve (N214)
P1259 - 001 - Short to Ground
Torque: 219.6 Nm
Voltage: 14.52 V
Bin. Bits: 01000100
Temperature: 22.5°C
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Torque: 231.8 Nm
Voltage: 12.77 V
Bin. Bits: 00000000
Temperature: 17.1°C
(no units): 16.0
P1641 - 000 -
Torque: 231.8 Nm
Voltage: 12.77 V
Bin. Bits: 00000000
Temperature: 17.1°C
(no units): 16.0
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 K HW: 906 545 260 8
Component: IMMO 0628 0639
Revision: 00628000 Serial number: VWZDZ0G1039544
VCID: 33330E09B7324352E21-8066
01176 - Key
Address 94: LT3 Airbag
Part No HW: 9064461142
Shop #: WSC 89476 896 02412
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F7909115867D622C5-8000
9013 - Belt buckle; driver: Open circuit
Test Complete - Stored
9012 - Belt buckle; driver: Short to GND
Test Complete - Active/Stored
9600 - Airbag control module (J234): Internal malfunction
Address 95: LT3 ESP
Part No SW: 9064482253 HW: 9064460153
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 4098
ROD: CRFT_ESP_3_36896.rod (*)
VCID: 0B43B6E983C27B924A1-805E
Address 96: LT3 Instruments
Part No SW: 9064481521 HW: 9064461121
Shop #: WSC 00090 824 59817
ASAM Dataset: 32 774
ROD: CRFT_KOMBI_32_774.rod
VCID: 084989E592B4108A673-805C
Address 99: LT3 Ign. Switch
Part No HW: 9065452608
ASAM Dataset: 67 256
ROD: CRFT_EZS_67_256.rod (*)
9011 - Electronic Steering Column Lock Module (J764): Voltage for locking not present
9001 - Voltage: Lower limit not reached
MIL ON - Test Complete - Stored
9005 - Electronic Steering Column Lock Module (J764): Communication error
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0628 0639
Revision: 00628000 Serial number: 12345678901234
00171 - Key 1 not learned
Address 9B: LT3 Driver Door
Part No HW: 9068204026
ASAM Dataset: 33 259
ROD: CRFT_FTUHR_33_259.rod (*)
Address 9C: LT3 HVAC
Part No SW: 2514450200 HW: 9068300685
ASAM Dataset: 21 1
ROD: CRFT_KLIMA_21_1.rod (*)
VCID: 77ABFA19EF4A6F721E9-8022
9002 - High pressure sensor (G65): Open circuit/Short to Plus
9301 - Temperature Regulator Flap Motor (V68): defective/open circuit/short circuit
9602 - Cooling circ. front compressor regul. valve current too low: or open or Short to B+
Address A0: LT3 Radio
Part No HW: 9068200686
ASAM Dataset: 1 3840
ROD: CRFT2_RAD.rod
D141 - Instrument Cluster Control Module (J285): No communication
D242 - CD drive/disk: Error
D142 - Electronic ignition switch (D9): No communication
D241 - CD/DVD drive eject: Error
D010 - Voltage: Lower limit not reached
D140 - CAN data bus: Internal malfunction
Address A2: LT3 CD Changer
ASAM Dataset: CRFT1_CD 3840
ROD: CRFT_CD.rod
D14100 - ROD - Unknown Error Code
D24200 - ROD - Unknown Error Code
D14200 - ROD - Unknown Error Code
D24100 - ROD - Unknown Error Code
D01000 - ROD - Unknown Error Code
D14000 - ROD - Unknown Error Code
Address B1: LT3 Upper Console
Part No HW: 9065453507
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
Part No SW: 9064420600 HW: 9065450601
ASAM Dataset: 33 771
ROD: CRFT_EZE_33_771.rod (*)
VCID: 7F5B1239C77A5732569-802A
7 Faults Found:
90A6 - Fuel level sensor: Short to Plus
90C1 - Emergency light activated; rotary light switch: implausible condition
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
903E - Left turn signal: Open circuit
9007 - Bulb for left low beam headlamp (M29): Short to Plus
900D - Left High Beam Lamp (L125): Short to Plus
9001 - Bulb for Left Parking Lamp (M1): Short to Plus
Address B5: LT3 Special Function
Part No SW: 9064480146 HW: 9064460046
ASAM Dataset: 9 770
ROD: CRFT_PSM_9_770.rod
VCID: 0A4DB3ED8CB8629A717-805E
9008 - Terminal 30-2; voltage: Lower limit not reached
9007 - Terminal 30-1; voltage: Lower limit not reached
Address B6: LT3 Steering Wheel
Part No SW: 9064640318 HW: 9064640318
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 094F8CE189BE698278D-805C
End----------(Elapsed Time: 01:18, VBatt start/end: 14.3V/14.2V)-----------
Address 94: DTCs cleared
Address 91: DTCs cleared
