APP deactivate?
mikeme
Alexandria/fairfax county VA
C?ID=99408
I have a wiper arm off a bit, and the plastic cowling seems to have come loose. so I need to take off the wiper arms, and then be able to put them back on in the right place.
the alldatadiy page says the blades go 10mm from the bottom of the windshield, but the first step is to deactivate the APP, which moves the blades on parking every other time they are turned off.
the process says the following:
•Connect the (VAS 5051A).
•Select "Guided Fault Finding" on the (VAS 5051A).
•Using the "Go To" button, select "Functions/Component Selection" and the following menu options in sequence:
¤ Body
¤ Electrical Equipment
¤ 01 - On Board Diagnostic (OBD) Capable Systems
¤ Vehicle Electrical System Control Module
¤ Functions of Vehicle Electrical System Control Module
¤ Coding Control Module for Wiper Electronics/Deactivating APP
where would I do this with a VCDS?
Monday,21,September,2015,16:16:10:51928
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 3VWPL71K89M272852   License Plate:
Mileage: 243670km-151409mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
          75
VIN: 3VWPL71K89M272852   Mileage: 243670km-151409miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: --H01---    Serial number: VWX7Z0H72491JO
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 3FA390536EB764C664-806A
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
   Component: GSG DSG         082 1402
   Revision: 05108020    Serial number: 00001009261684
   Shop #: WSC 04940 001 00001
   VCID: 130B6CE332BF50A6F0-8046
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B600D492900FC881306E9921B0042B100
   VCID: 75CF327BDC0BEE967E-8020
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CD9275F3F21BFDE01-8028
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001014370
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 3245C967ADE5B9AE9B-8066
   Component: Wischer 230808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0382262
   Coding: 0000100
   VCID: 334BCC6352FFB0A690-8066
   Component: 78 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06G1H$
   Coding: 0014136
   VCID: 6CF9171F4F412F5E91-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3B0044340
   Subsystem 3 - Serial number: 6342MSME3E307878M
   Subsystem 4 - Serial number: 6351HSME174A4C71D
   Subsystem 5 - Serial number: 6361HSME175F5826H
   Subsystem 6 - Serial number: 63727SME16701603R
   Subsystem 7 - Serial number: 63827SME16701021M
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010042
   VCID: 032B5CA342DFC02640-8056
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H72491JO
   Coding: 0007203
   VCID: 3957FE4B70934AF65A-806C
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 020708F1000751
   Coding: ED807F072013022002
   VCID: 354FF27B5C8BAE96BE-8060
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T2EKX03
   VCID: 7DDF2A5B243BB6D636-8028
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000532488807
   Coding: 0001205
   VCID: 6FC300137E57D446B4-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A75D1078535F16E23-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 139007885283281B0904058FB0880F0488DC00
   VCID: 04295FBF47D1C71E79-8050
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 187
                    Mileage: 205700 km
                    Time: 13:05:22
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000552988807
   Coding: 0001204
   VCID: 70C1036F6369CBBEAD-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Status: 00101100
                    Reset counter: 59
                    Fault Status: 00111000
                    Reset counter: 59
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2224675
   Coding: 0010400
   VCID: 29772E0B8033FA762A-807C
            000 -  -
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003360131
   Coding: 0001168
   VCID: 76CD3577010DE58E77-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003383939
   Coding: 0001168
   VCID: 77D3387306079C866C-8022
Address 75: Telematics
End-------------------------(Elapsed Time: 01:30)--------------------------
Santos
In VCDS click the following:
[Select]
[09-Cent. Elect.]
[Coding-07]
Click the drop down box and select 1K1 955 119 E subsystem
Then click
[Long Coding]
There should be a check box "Alternating Parking Position (APP/APS) active".
NEtech
Denmark
C?ID=56995
It is my understanding, that with your current coding, you just use the current coding and use [Do it].
Procedure, as Santos described it.
Then the next 100 cycles are without APS!
mikeme
C?ID=99408
first time I did not choose the 1k1.....
I deselected the check box for the APP, then do it.
is this correct?
it said coding accepted, and now the wipers just stay at the end.
do I need to re-check the box on APP to have it reactivate, or will it just do so in 100 cycles?
thanks again.
