2005 A6 Quattro BKH.
Car has been having starting issues. No crank, no start. Has been starting since it has been at our shop. However, does have a steering lock message with steering wheel and key symbol in display. Found code 00288 - Steering Column Lock Actuator (N360) 014 - Defective, in Address 5 Acc/start auth module.
Steering lock actuator only appears to be available with complete, steering column. My understanding is column has to be matched with kessy/immo. and this cannot be done with VCDS and must be performed by dealer. Is this true?
Thanks in advance,
Thanks in advance,
Tuesday,22,September,2015,09:26:09:37823
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
VCDS Version 15.7.1.0
Data version: 20150904
VIN: WAUDT74F25N046727 License Plate:
Mileage: 184760km-114804mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 76 77
VIN: WAUDT74F25N046727 Mileage: 184760km-114804miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0020
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 02136 444 84361
VCID: 2B16CD518A968F66D8-807F
006449 - Coolant Fan Control Module (J293)
P1931 - 009 - Malfunction - Intermittent
Reset counter: 26
Mileage: 182497 km
Date: 2015.08.30
Time: 18:41:49
RPM: 1120 /min
Mass Air / Rev.: 130.8 mg/str
Temperature: 97.5∞C
Idle
Load: 20.4 %
Speed: 28.0 km/h
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - Intermittent
Reset counter: 25
Mileage: 182603 km
Date: 2015.09.02
Time: 10:55:17
RPM: 192 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 28.5∞C
Start
Bin. Bits: 00001000
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0050219
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 291A3759806A9D762A-807D
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Coding: 0004511
VCID: 26003C659174B20E07-8073
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 107
Mileage: 182057 km
Date: 2015.08.28
Time: 10:14:08
Hex Value: 0x0240
Hex Value: 0x4026
Hex Value: 0x1202
Hex Value: 0x00A8
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Component: FBSAUDIC6 ELV H30 0130
Revision: 30040401 Serial number: 10600300057465
Coding: 0000011
VCID: 63866571A2C6072620-8037
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H35 0040
00955 - Key 1
Fault Frequency: 23
Reset counter: 144
Mileage: 181919 km
Date: 2015.08.27
Time: 15:59:23
014 - Defective
Fault Status: 01111110
Reset counter: 96
Mileage: 183632 km
Date: 2015.09.07
Time: 10:27:48
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 729 B HW: 4E0 035 729
Component: Interfacebox H43 0750
Revision: 00000000 Serial number: 360IS047503874
Coding: 0000003
VCID: 281C325D9B60A47E35-807D
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000048305
Subsystem 3 - Serial number: 0130.08.040000000100010250ˇ
Subsystem 4 - Serial number: 010250ˇ
Reset counter: 136
Mileage: 182110 km
Date: 2015.08.28
Time: 12:24:50
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000056537
Coding: 0524326
VCID: 5BF65D919AB63FE668-800F
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0013123
VCID: 66807C6551F4720EC7-8033
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7155868
VCID: 1B761D91DA367FE6A8-804F
Address 0F: Digital Radio Labels: None
VCID: 55E24BA9BC92E9965E-8001
No Faults Found
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH28 0310
Revision: 09H28000 Serial number: 00359D0710NI
Coding: 0013622
Shop #: WSC 02136 444 64600
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME040C223B
Subsystem 3 - Serial number: 6342CSME05245F7BB
Subsystem 4 - Serial number: 6351HSME037941786
Subsystem 5 - Serial number: 6361HSME040A4A3ED
Subsystem 6 - Serial number: 6371VSME03734C4EU
Subsystem 7 - Serial number: 6381VSME03754635H
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H07 0230
Revision: 00H07000 Serial number: 90026042480032
Coding: 0002041
Component: Lenkradmodul H05 0080
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H09 0460
Revision: 00100000 Serial number: 4I215W794
Coding: 0065263
Shop #: WSC 03419 067 57207
VCID: 1E701485C9246ACE4F-804B
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008048180113
Coding: ECFE73CC1B3904
Shop #: WSC 02136 444 53521
VCID: 271E3161967EAB063C-8073
Reset counter: 144
Mileage: 184710 km
Date: 2015.09.11
Time: 16:46:25
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 618A6F79B8DA153632-8035
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 378HR047501282
VCID: 3522EB295CD2C996BE-8061
00003 - Control Module
014 - Defective
Fault Status: 01101110
Fault Frequency: 7
Reset counter: 0
Mileage: 157515 km
Date: 2014.06.18
Time: 18:09:42
Bin. Bits: 0100
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: Së
Coding: 0035563
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000795340000
Coding: 0423997
VCID: 2C14CE4D8F98885ED1-8079
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F5 910 223 B HW: 4F5 035 223 C
Component: DSP-High C6 H14 0220
Revision: PROD_01 Serial number: 00000000001708
Coding: 0000016
VCID: 22082075FD5C4E2E6B-8077
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000030243
Coding: 0001114
VCID: 5EF0548589A42ACE0F-800B
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 9i!
Coding: 0035563
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0005022
Shop #: WSC 02136 444 53345
VCID: 210A2F79F85A553672-8075
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Fault Frequency: 175
Reset counter: 29
Mileage: 154672 km
Date: 2014.04.04
Time: 12:16:53
Voltage: 12.32 V
Count: 84
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Coding: 0000016
Shop #: WSC 02327 785 00200
VCID: 2404266DE748401E19-8071
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
Part No SW: 4E0 910 541 C HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 352IP047557321
VCID: 200C2A7DF3505C3E7D-8075
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0400
Revision: 00000000 Serial number: 00000000051816
Shop #: WSC 02136 444 53669
VCID: 23062571E246472660-8077
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 4408310368
Coding: 344630393135313035432056413034343038333130333638
Shop #: WSC 00000 384 00290
02273 - Quiescent Current Stage 2
Fault Frequency: 46
Mileage: 163453 km
Date: 2014.10.09
Time: 09:33:35
02276 - Quiescent Current Stage 5
Fault Frequency: 41
Mileage: 163453 km
Date: 2014.10.09
Time: 09:33:45
02274 - Quiescent Current Stage 3
Fault Frequency: 40
Mileage: 163453 km
Date: 2014.10.09
Time: 09:33:55
02277 - Quiescent Current Stage 6
Fault Frequency: 40
Mileage: 163453 km
Date: 2014.10.09
Time: 09:34:05
02272 - Quiescent Current Stage 1
Fault Frequency: 6
Mileage: 170675 km
Date: 2015.01.08
Time: 01:51:00
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 699A775940EA5D76EA-803D
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0020
Revision: --.--.-- Serial number: 11730424300971
Coding: 0001206
Part No SW: 4F0 910 336 HW: 4E0 862 335
Component: Handyvorb2 H10 0080
Revision: 00000000 Serial number: 00000007501672
Coding: 0010900
VCID: 608C6A7DB3D01C3E3D-8035
End-------------------------(Elapsed Time: 03:36)--------------------------
