2005 A6 Steering column replacement
Tom Mench
C?ID=14220
2005 A6 Quattro BKH.
Car has been having starting issues. No crank, no start. Has been starting since it has been at our shop. However, does have a steering lock message with steering wheel and key symbol in display. Found code 00288 - Steering Column Lock Actuator (N360) 014 - Defective, in Address 5 Acc/start auth module.
Steering lock actuator only appears to be available with complete, steering column. My understanding is column has to be matched with kessy/immo. and this cannot be done with VCDS and must be performed by dealer. Is this true?
Thanks in advance,
Tuesday,22,September,2015,09:26:09:37823
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
VCDS Version 15.7.1.0
Data version: 20150904
VIN: WAUDT74F25N046727   License Plate:
Mileage: 184760km-114804mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 72 76 77
VIN: WAUDT74F25N046727   Mileage: 184760km-114804miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 E
   Component: 3.2l V6 FSI         0020
   Revision: --H21---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 02136 444 84361
   VCID: 2B16CD518A968F66D8-807F
006449 - Coolant Fan Control Module (J293)
               P1931 - 009 - Malfunction - Intermittent
                    Reset counter: 26
                    Mileage: 182497 km
                    Date: 2015.08.30
                    Time: 18:41:49
                    RPM: 1120 /min
                    Mass Air / Rev.: 130.8 mg/str
                    Temperature: 97.5∞C
                        Idle
                    Load: 20.4 %
                    Speed: 28.0 km/h
000838 - Camshaft Position Sensor (G163)
               P0346 - 006 - Implausible Signal - Intermittent
                    Reset counter: 25
                    Mileage: 182603 km
                    Date: 2015.09.02
                    Time: 10:55:17
                    RPM: 192 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 28.5∞C
                        Start
                    Bin. Bits: 00001000
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        0050219
   Coding: 0001002
   Shop #: WSC 02335 785 00200
   VCID: 291A3759806A9D762A-807D
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0004511
   VCID: 26003C659174B20E07-8073
                    Fault Status: 01101000
                    Reset counter: 107
                    Mileage: 182057 km
                    Date: 2015.08.28
                    Time: 10:14:08
                    Hex Value: 0x0240
                    Hex Value: 0x4026
                    Hex Value: 0x1202
                    Hex Value: 0x00A8
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0130
   Revision: 30040401    Serial number: 10600300057465
   Coding: 0000011
   VCID: 63866571A2C6072620-8037
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H43 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H35 0040
00955 - Key 1
                    Fault Frequency: 23
                    Reset counter: 144
                    Mileage: 181919 km
                    Date: 2015.08.27
                    Time: 15:59:23
            014 - Defective
                    Fault Status: 01111110
                    Reset counter: 96
                    Mileage: 183632 km
                    Date: 2015.09.07
                    Time: 10:27:48
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 729 B    HW: 4E0 035 729
   Component: Interfacebox    H43 0750
   Revision: 00000000    Serial number: 360IS047503874
   Coding: 0000003
   VCID: 281C325D9B60A47E35-807D
   Subsystem 1 - Part No: 4F0 910 609
   Component: Bedienteil MMIC6H07 0870
   Subsystem 2 - Serial number: 00000000048305
   Subsystem 3 - Serial number: 0130.08.040000000100010250ˇ
   Subsystem 4 - Serial number: 010250ˇ
                    Reset counter: 136
                    Mileage: 182110 km
                    Date: 2015.08.28
                    Time: 12:24:50
                    Bin. Bits:       10
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000023    Serial number: 00000000056537
   Coding: 0524326
   VCID: 5BF65D919AB63FE668-800F
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   VCID: 66807C6551F4720EC7-8033
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7155868
   VCID: 1B761D91DA367FE6A8-804F
Address 0F: Digital Radio        Labels: None
   VCID: 55E24BA9BC92E9965E-8001
No Faults Found
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH28 0310
   Revision: 09H28000    Serial number: 00359D0710NI
   Coding: 0013622
   Shop #: WSC 02136 444 64600
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME040C223B
   Subsystem 3 - Serial number: 6342CSME05245F7BB
   Subsystem 4 - Serial number: 6351HSME037941786
   Subsystem 5 - Serial number: 6361HSME040A4A3ED
   Subsystem 6 - Serial number: 6371VSME03734C4EU
   Subsystem 7 - Serial number: 6381VSME03754635H
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks‰ulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026042480032
   Coding: 0002041
   Component: Lenkradmodul    H05 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H09 0460
   Revision: 00100000    Serial number: 4I215W794
   Coding: 0065263
   Shop #: WSC 03419 067 57207
   VCID: 1E701485C9246ACE4F-804B
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 08008048180113
   Coding: ECFE73CC1B3904
   Shop #: WSC 02136 444 53521
   VCID: 271E3161967EAB063C-8073
                    Reset counter: 144
                    Mileage: 184710 km
                    Date: 2015.09.11
                    Time: 16:46:25
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 618A6F79B8DA153632-8035
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H43 0570
   Revision: 00000000    Serial number: 378HR047501282
   VCID: 3522EB295CD2C996BE-8061
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Mileage: 157515 km
                    Date: 2014.06.18
                    Time: 18:09:42
                    Bin. Bits:     0100
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: Së
   Coding: 0035563
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01000795340000
   Coding: 0423997
   VCID: 2C14CE4D8F98885ED1-8079
   Component: LIN BACKUP HORN H02 1301
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 B    HW: 4F5 035 223 C
   Component: DSP-High C6     H14 0220
   Revision: PROD_01     Serial number: 00000000001708
   Coding: 0000016
   VCID: 22082075FD5C4E2E6B-8077
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H07 0040
   Revision:             Serial number: 00000000030243
   Coding: 0001114
   VCID: 5EF0548589A42ACE0F-800B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: 9i!
   Coding: 0035563
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0005022
   Shop #: WSC 02136 444 53345
   VCID: 210A2F79F85A553672-8075
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 175
                    Reset counter: 29
                    Mileage: 154672 km
                    Date: 2014.04.04
                    Time: 12:16:53
                    Voltage: 12.32 V
                    Count: 84
   Part No SW: 4F0 910 357 A    HW: 4F0 907 357 A
   Component: AFS 1           H03 0010
   Coding: 0000016
   Shop #: WSC 02327 785 00200
   VCID: 2404266DE748401E19-8071
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 C    HW: 4F0 035 541
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 352IP047557321
   Coding: 0000002
   VCID: 200C2A7DF3505C3E7D-8075
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000051816
   Shop #: WSC 02136 444 53669
   VCID: 23062571E246472660-8077
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  4408310368
   Coding: 344630393135313035432056413034343038333130333638
   Shop #: WSC 00000 384 00290
02273 - Quiescent Current Stage 2
            000 -  -  - Intermittent
                    Fault Frequency: 46
                    Mileage: 163453 km
                    Date: 2014.10.09
                    Time: 09:33:35
02276 - Quiescent Current Stage 5
                    Fault Frequency: 41
                    Mileage: 163453 km
                    Date: 2014.10.09
                    Time: 09:33:45
02274 - Quiescent Current Stage 3
                    Fault Frequency: 40
                    Mileage: 163453 km
                    Date: 2014.10.09
                    Time: 09:33:55
02277 - Quiescent Current Stage 6
                    Fault Frequency: 40
                    Mileage: 163453 km
                    Date: 2014.10.09
                    Time: 09:34:05
02272 - Quiescent Current Stage 1
                    Mileage: 170675 km
                    Date: 2015.01.08
                    Time: 01:51:00
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0035370
   VCID: 699A775940EA5D76EA-803D
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0035370
   Part No SW: 4F0 910 283     HW: 4F0 919 283
   Component: Parkhilfe 4-Kan H09 0020
   Revision: --.--.--    Serial number: 11730424300971
   Coding: 0001206
   Part No SW: 4F0 910 336     HW: 4E0 862 335
   Component: Handyvorb2      H10 0080
   Revision: 00000000    Serial number: 00000007501672
   Coding: 0010900
   VCID: 608C6A7DB3D01C3E3D-8035
End-------------------------(Elapsed Time: 03:36)--------------------------
I don't think we have a way of doing that with VCDS.
The question is whether the steering column lock being defective would prevent the car from starting. I've seen an 05 much like that one that wouldn't start and the problem turned out to be the starter itself. However that car did not have any immo/steering column faults or messages in the cluster.
Diagnosticated
C?ID=72030
If it like passat B6 the ignition will not come on if the steering lock has not moved position from locked > unlocked.
golfi_vend
Tartu, Estonia
C?ID=195131
As for steering column lock....Yes whole column needs to replaced and costs $$$.
I have a friend who works with parts(And yes i get good % ;) ) Customer came in to check price....went backwards when heard it :P
Diagnosticated
C?ID=72030
I don't know the Audi design but on a B6 passat the steering lock is held on by two shear bolts. You can get these off and remove the lock. If the Audi is the same you can open the lock, energize the motor and unlock it. Then the ignition etc will work. Engine may not start though.
bobbik
Poland
C?ID=50728
On B6 Passat the easiest way to replace lock(when u don't have new one) , is to read eeprom and put dump into another (used) lock . But Passat lock is cheap, and i don't know Audi lock solution.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
UWE this is very common problem on 4F Audi A6. And yes whole Steering column needs to be replace bacuse Steering lock module and Immobilizer is part of it.
Look at address 05 for faulty codes.
Gone But Not Forgotten
I disassemble the lock and discard it.......someone wants the car that bad they are gonna tow it anyway......
I have been successful with this..........and bypassing the commands for the security feature.
Laci
Albania
How did you do?
How did you do?
Other_Erik
Northern VA (DC Area)
C?ID=192416
This on a 4F A6? I'd be willing to lose the actuator and/or lock so long as I don't lose the ignition cylinder (since that's, you know... necessary. How else would I be able to use the VCDS?). How do you completely bypass the Immo system, though? We went back and forth a couple months ago about my wife's '05 A6 3.2Q that gives the same stupid "defective actuator" message - as soon as I clear code in module 05, no problem starts right up. No chance in hell I'm paying ~$3k to replace a perfectly working COLUMN on a $5k car just because the column lock should've been recalled...
O_E
