- Jul 8, 2022
- 11
- 0
- Auckland, New Zealand
- C?ID=574564
Hi Guys New to VCDS. We have a swapped out a semi-auto for a 6 speed manual. We had to pin: Clutch Pedal Switch T94/39 all good. Reverse Switch J519 F4 X1/22 ?
I had it coded at a Euro Tuning Company pretty $$ so I have purchased VCDS as we have 2 x Crafters and 1 x Transporter.
For a year I have been driving it with the EPS fault and no reverse lights.
After a code clear: It has "Hill Start Assist" and will hold for ages with RPM over 1K.
I can reverse for weeks as long as I don't touch the accelerator. Once it goes over RPM 1K it throws the Fault.
Where should I look?
Wednesday,31,January,2024,14:44:18:29372
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2EZ86005501 License Plate: ECY101
Mileage: 445583 Repair Order:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 K HW: 906 545 260 8
Component: IMMO 0628 0639
Revision: 00628000 Serial number: VWZDZ0G1012978
Shop #: WSC 51706 002 1048576
VCID: 33330E09B7324352E21-8066
01176 - Key
Address 94: LT3 Airbag
Part No HW: 9064461142
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F7909115867D622C5-8000
9012 - Belt buckle; driver: Short to GND
Test Complete - Stored
Address 95: LT3 ESP
Part No SW: 9064482253 HW: 9064460153
ASAM Dataset: 3 4098
ROD: CRFT_ESP_3_36896.rod (*)
VCID: 0B43B6E983C27B924A1-805E
5106 - CAN: Signal outside temperature invalid
MIL ON - Test Complete - Stored
5238 - Reverse gear monitoring (start assist): compares vehicle motion with reverse signal
MIL ON - Test Complete - Active/Stored
Address 96: LT3 Instruments
Part No SW: 9064481521 HW: 9064461121
ASAM Dataset: 32 774
ROD: CRFT_KOMBI_32_774.rod
VCID: 084989E592B4108A673-805C
Address 99: LT3 Ign. Switch
Part No HW: 9065452608
Shop #: WSC 00000 896 01452
ASAM Dataset: 67 256
ROD: CRFT_EZS_67_256.rod (*)
9001 - Voltage: Lower limit not reached
9011 - Electronic Steering Column Lock Module (J764): Voltage for locking not present
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0628 0639
Revision: 00628000 Serial number: 12345678901234
Shop #: WSC 29227 002 1048576
Address 9B: LT3 Driver Door
Part No HW: 9068204026
ASAM Dataset: 33 259
ROD: CRFT_FTUHR_33_259.rod (*)
Address 9C: LT3 HVAC
Part No SW: 2514450200 HW: 9068300685
ASAM Dataset: 21 1
ROD: CRFT_KLIMA_21_1.rod (*)
VCID: 77ABFA19EF4A6F721E9-8022
Address B1: LT3 Upper Console
Part No HW: 9065453507
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
9036 - Supply voltage: Limit value exceeded
Address B4: LT3 Central Elec.
Part No SW: 9064420600 HW: 9065450601
ASAM Dataset: 33 771
ROD: CRFT_EZE_33_771.rod (*)
VCID: 7F5B1239C77A5732569-802A
902A - Rear Fog Lamp Bulb (L20): Short to GND
902B - Rear Fog Lamp Bulb (L20): Short to Plus
90A6 - Fuel level sensor: Short to Plus
901D - License plate lights/side-marker lights: Open circuit
Address B5: LT3 Special Function
Part No SW: 9064480146 HW: 9064460046
ASAM Dataset: 9 770
ROD: CRFT_PSM_9_770.rod
VCID: 0A4DB3ED8CB8629A717-805E
9008 - Terminal 30-2; voltage: Lower limit not reached
Address B6: LT3 Steering Wheel
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 065587DD98A006FA15F-8052
End----------(Elapsed Time: 01:12, VBatt start/end: 13.5V/13.5V)-----------
