ABS and Anti slipping Light On
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
It so nice to back again to this awesome Forum,
I would like to know how to fix the problem which is :
Usually I have to remove the instrument and reinstall again ,then I notice that the ABS and Anti Slipping light start flashing all the time the car starting ,and refused to be programmed . I have to go to dealer to reprogram it ,.
So can VCDS do that program for it ?
Thank you ;
By the way the vehicle is :
GOLF VI 2011
engine code : CAYC
and here is the auto scan but not full.
Monday,17,Sep,2015
VCDS Version: 15.7.1
Data version: 20150904
VIN: WVWZZZ1KZBM615428   License Plate:
Mileage: 107890km-67039mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72
VIN: WVWZZZ1KZBM615428   Mileage: 107890km-67039miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 H    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 6916
   Revision: --------    Serial number: 00000000000000
   Coding: 00254016032400080000
   Shop #: WSC 00066 000 00084
   ASAM Dataset: EV_ECM16TDI02103L906023H 003003
   ROD: EV_ECM16TDI02103L906023A_VW32.rod
   VCID: 2B5EC9454210F579EBD-807E
6088 - No Communication with Transmission Control Module
          U0101 00 [173] - -
                    Fault Frequency: 12
                    Mileage: 107871 km
                    Date: 2015.09.16
                    Time: 21:39:20
6082 - Steering Column Control Module
          U0212 00 [045] - No Communications
                    Fault Frequency: 15
                    Mileage: 107871 km
                    Date: 2015.09.16
                    Time: 21:39:20
   Revision: 00H31001
   Shop #: WSC 00028 028 00001
   VCID: 7BFE3905FAF0A5F93BD-802E
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 51
                    Mileage: 107891 km
                    Date: 2015.09.17
                    Time: 19:46:19
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 4161
                    Count: 44800
            000 -  -
                    Reset counter: 50
                    Date: 2015.09.17
                    Time: 21:39:17
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 195
                    Count: 44288
                    Count: 64512
                    Fault Status: 01100101
                    Reset counter: 50
                    Date: 2015.09.17
                    Time: 21:39:17
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 279
                    Count: 44288
                    Count: 64512
                    Reset counter: 50
                    Date: 2015.09.16
                    Time: 21:39:17
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 270
                    Count: 44288
                    Count: 64512
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000004002
   Shop #: WSC 00028 028 00020
   VCID: 7F06CD15E6E8B9D9175-802A
   Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 46180A3A80251AC0400000C0140000E44F010288524D8160648000200040
   VCID: 3162DB2D683C9FA9D11-8064
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13041  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RAJCDM+
   Coding: 00004431
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3162DB2D603C9FA9D11-8064
   Serial number: 3572MSME1E59046DZZZ2
   Serial number: 3582MSME6E20056DZZZ/
   Serial number: 3512QSME7242115AZZZN
   Serial number: 3522QSME4218121DZZZO
   Part No SW: 5K0 953 507 AS    HW: 5K0 953 549 C
   Revision: --------    Serial number:  90440LDH000JO
   Coding: 5080040000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 01024BED901CCF29611-8054
   Part No SW: 5K0 920 871 A    HW: 5K0 920 871 A
   Component: KOMBI         H03 0406
   Coding: 170B00
   Shop #: WSC 00066 000 00185
   VCID: 2C5CCA59471EF241E27-8079
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 120412F1000108
   Coding: 350002
   VCID: 3A70FC01B54A5CF160B-806F
   Component: IMMO          H03 0406
   VCID: 6AD00C418D6A2C71D0B-803F
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0000180
   VCID: 3776E535465841999F5-8062
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0000180
   VCID: 3874E6094B464EE196F-806D
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
   VCID: 356AEF3D5C54B3898D9-8060
   Coding: 0000144
   VCID: 3668E8314152B891843-8063
Thank you
Regards
prako
Zagreb Cro
C?ID=116509
Hi! Welcome back!
Yes, problem is in that you remove instrument cluster and probably you switch on ignition, but ESP MK60MC1 is synchronized to VIN number,from IC. And every time when you switch ignition control module check it. When VIN isn't match, ABS control module delete coding to zero...
Now wou must recode to original coding if you have it, if you not have, solution is online coding at VW dealer. Problem is that ABS have unike coding for every car...
