Retrofit cruise control Audi A3 (8P)
LN-TAL
Norway
C?ID=13729
Want to retrofit cruise control on my Audi A3. Anything more I need than the switch for the CC ? (and probably some wires) like new steering module etc ?
Saturday,19,September,2015,14:58:59:62006
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ8P54A165042   License Plate: BR51499
Mileage: 162070km-100705mi   Repair Order: etter radio
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 55 56 76 7D
VIN: WAUZZZ8P54A165042   Mileage: 162070km-100705miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 G    HW: 028 101 136 4
   Component: R4 2,0L EDC 0000SG  5705
   Revision: 12345678    Serial number: AUX7Z0D3FN70K1
   Coding: 0000072
   Shop #: WSC 06435 000 00000
   VCID: 275754BD961F22063C-8072
Readiness: 0 0 0 1 0
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023174
   VCID: 3A719DC975ADAFEE53-806E
   Part No SW: 8P0 820 043 E    HW: 8P0 820 043 E
   Component: KlimavollautomatH12 0150
   Revision: 015231      Serial number: 8P0820043E
   VCID: 2E59A199B9E5734EFF-807A
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H30 0501
   Revision: 00030000    Serial number: 00000000690970
   Coding: 0B8ACF0083141000000000000000000000
   VCID: 3B7F98CD7A9796E648-806E
   Subsystem 1 - Part No: 8P1 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
   Shop #: WSC 12345
02401 - Terminal 75x
            006 - Short to Plus
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
   Component: Airbag 8.4ED    H00 0140
   Coding: 0010602
   VCID: 438FE02D0267EE2600-8016
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenks‰ulenmodul 012 0030
   Coding: 0000012
   VCID: 3065BFE1A3D165BEED-8064
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
   Component: KOMBIINSTR. VDO H25 0140
   Revision: D09         Serial number: 2243DD09053438
   Coding: 0004003
   Shop #: WSC 80093 222 69422
   VCID: 356B8EF55CB34096BE-8060
Address 18: Aux. Heat        Labels: 1K0-815-005.clb
   Part No: 1K0 815 005 EF
   Component: Heizgeraet      H08 0040
   Revision:        A    Serial number: 09011596
   Coding: 0001112
   Shop #: WSC 38059 136 84162
   VCID: 6AD16D89458DDF6EE3-803E
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500104325011F
   Coding: 7D0F1F42070100
   VCID: 285557819B012D7E35-807C
   Revision: D09         Serial number: AUX7Z0D3FN70K1
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 397382C570ABA4F65A-806C
   Part No: 1K1 909 144 F
   Component: EPS_ZFLS Kl.10      1301
            000 -  -
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 B
   Component:    KSG          H02 0040
   Coding: 188800186D288505484A016000
   Shop #: WSC 06435 123 12345
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001119925
   VCID: 70E57FE1635125BEAD-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   Part No: 8P0 907 357 A
   Revision: 00000000    Serial number:
   Coding: 0000001
   VCID: 387587C14BA1BDFEA5-806C
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H53 0060
   Revision:      08S    Serial number: AUZ2Z3D2056623
   Coding: 0001001
   VCID: 6FE77C9D7E6F3A46B4-803A
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283     HW: 8P0 919 283
   Component: Parkhilfe 4-Kan H06 0020
   Coding: 0000003
   VCID: 78F547C10B217DFE65-802C
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C5DAB918FF9015ED1-8078
End-------------------------(Elapsed Time: 01:43)--------------------------
LN-TAL
Norway
C?ID=13729
Not alot of replys here ?
I have now installed the cc stalk lever, and coded up. And MOST of the systems seems to work, but the engine module is complaining about invalid signal from CC (or something). I looked at the wiring diagram, and there should be one wire running from the Steering electronics to the ECU. This wire is missing on this car. Can comeone confirm that all the electronics in this car should support CC, so that I can take the hassle with connecting this missing wire and have things working ? Anyone knows where I can buy the hardware (pins) to put into the plug on e.g. ebay ? Is most of the pins (of the same size) on audi / VW standard pins, or is there many different electrical pins even with the same size ?
LN-TAL
Norway
C?ID=13729
Not alot of help to get here :) after som googling I have found that my steering wheel electronic does NOT support cc and needs to be replaced.
But another, easier, question. Is the immo on this car 3 or 4 ?
A 2004 8P A3 will be Immo 3 or Immo 4a (no real difference as far as VCDS is concerned).
NZDubNurd
New Zealand
C?ID=230482
My 2004 8P A3 3.2 parts car is Immo 4C, but is the V6 version (obviously).
Hmm, I might have jumped the gun...
OTOH, I swear we got a 5-digit PIN for my old 2006 by sniffing a GeKo session at the dealer when the car was nearly new and tested that PIN...
But looking at the scan, the IDs are indeed AUX, not AUZ. So color me confused.
Zenerdiode
Newcastle, England
C?ID=24330
I swear we got a 5-digit PIN for my old 2006 by sniffing a GeKo session at the dealer...
Did you have that bead of sweat trickle down your brow in case they discovered the 'unauthorised equipment'? :)
Nah, the dealer tech doing it was fully aware of what we were doing, which was nothing more than passively listening to (and recording) the session.
NZDubNurd
New Zealand
C?ID=230482
They SAID they installed an immobiliser, but actually didn't....
IMMO-Gate.
LN-TAL
Norway
C?ID=13729
Is there anyone who can please tell me what steering coloum module I need ? I THINK 8P0 953 549 G (or A) should fit. But they are hard to find used. I have one F module on hand, but a guy on the net told me that this module PROBABLY wont fit my car. There is several cars on breakers yard in Norway which has this F module, but all of them is newer than my 2004.
Any inputs please ?
AIB Wolfgang
Hi
Looked for parts and that's what you need
8P0 953 549 G ECU
with 1K0 959 653 slip ring and
8P0 953 512 covering
LN-TAL
Norway
C?ID=13729
Ok, thanks. And that is the only module that will work with my car ? A will not work, and neither will F ?
