Night vision warning system
mitch
England, UK
C?ID=160839 (moved to UK?)
Good afternoon from the UK, I have had VCDS for a good few years now and found it to be a great tool, however there are two things that I haven't been able to find an answer to.
I have an Audi A7 (MY14) with pretty much every option going including the night vision system. I want to change the volume of the warning when it detects a pedastrian as it is currently very quiet and can easily be missed. I have found the option in the settings but it won't let me change it. The options for the volume are Soft (which is the factory preset), medium, loud and off. I want to change it to loud (see the picture below)
But every time i press do it, it gives me the following error:
Does anyone have any idea how to solve this please?
My other question is more technical so will post in due course.
Thanks in advance.
We'd appreciate it if you would post up a full Auto-Scan of the vehicle please. With UDS controllers (which this is) in order to do any meaningful digging, we need the ASAM ID of the module in question, but really like to see that in the full context of the whole car.
mitch
England, UK
No problem, here it is....
The Night vision module is 84.
VCDS Version: Release 12.12.2
Data version: 20140212
Saturday,26,April,2014,17:17:31:30660
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 30 36 3B 3C 42 44
          46 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4GXEN055619
Address 01: Engine (J623-CGQB)       Labels: None
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0002
   Revision: 57H25---
   Coding: 1A2A4032256603020800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
   ROD: EV_ECM30BTD0114G0907589C.rod
   VCID: 346C675F9F4CABBE4FF-8061
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4G0 927 158 K    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1003
   Revision: --H16---
   ROD: EV_TCMAL551211_AU57.rod
   VCID: 36685D578930B9AE71B-8063
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Component: ESP PREMIUM   H09 0450
   Coding: 49A79F0392E5F9C0CB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   ROD: EV_ESPPremiAU57X.rod
   VCID: 3B7E4C63B21264C68E5-806E
   Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
   Component: BCM2 2.0      H35 0510
   Coding: 01BA3046000000000000
   VCID: 78F4936FCBA48FDEA37-802D
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 10091300040076
   Coding: 362300B835
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 62C0D1077538750EED3-8037
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001778226
   Coding: 0D07201149769FE2818100C380001800CF9DC30A2F090201000308456F20
   VCID: 6FE6A833BEEAC86672D-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A
   Component: WWS57X 130803  H36 0080
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AB    HW: 4G0 941 531 AB
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Subsystem 7 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031325400824
   Coding: A8EB04
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 71E2AE4BA0DEDE96649-8024
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 2854832F5384DF5EF37-807D
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00ERD06
   Coding: 3031453032314E303134554A305234473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   Serial number: 3575HRB400K50KU6D0TU
   Serial number: 3585HRB400450L5ICPIG
   Serial number: 3515JRB401C50LAKEPBM
   Serial number: 3525JRB401C50LAKLI0C
   Serial number: 3554VRB400U50MBGEHB1
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB400250MKSHPD8
Address 16: Steering wheel (J527)       Labels: None
   Revision: --------    Serial number: 90372MI9000K8
   Coding: 0000FC
   VCID: 37765053863A40A66AD-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 984 Q    HW: 4G8 920 984 Q
   Component: TDieGb AccNv  H80 0618
   Revision: 30460230    Serial number: 658130713596035
   Coding: 338F01020F132600010100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 448C379FCFEC1B3EFFF-8011
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001085526
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPkoUDS.rod
   VCID: 72E0A147A5D8E58E9D3-8027
   Serial number: 9216371303
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 04028E64747464545425363E00
   VCID: 7CFC8F7FFF9CA3FEC7F-8029
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0088
   Serial number: 06091300041638
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 377650538E3A40A66AD-8062
Address 30: Special Function II (J843)       Labels: None
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000046171
   Coding: 01010101000000000001000202
   VCID: E4CC571FE72CFB3E9FF-80B1
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000072895492
   Coding: 0078130000006001000001010101102030303232203232
   VCID: F7F6105346BA00A62AD-80A2
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8204P381
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0060
   Revision: 00H04000    Serial number: 6PZ 010 287-08
   Coding: 0001107
   VCID: 36685D574130B9AE71B-8063
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H04 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F04.09.1300H04000AMS16842ÿ
   Subsystem 4 - Serial number: S16842ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F56025E21628002080413
   VCID: 458A2A9BCCD62236E81-8010
Address 44: Steering Assist (J500)       Labels: None
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0006833199
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 326061476558A58E5D3-8067
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0314028124
   Coding: 013B0622A0B9B88083200A040C010D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Component: TSG BF        H03 0507
   Coding: 011F56025E21628002080402
   VCID: 46882D97F1D0292EE1B-8013
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000797815
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2C5C7F3F477CF37E17F-8079
Address 55: Xenon Range (J431)       Labels: None
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130912-0002-105
   Coding: 1123A6601000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D5A723B7C66FA76001-8078
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109I$0D7706371
   Coding: 010103020100000001
   VCID: 26488D175190C92EC1B-8073
   Part No SW: 4G0 035 670 K    HW: 4G0 035 670 H
   Component: H-BNT-EU      H51 0732
   Revision: --------    Serial number: 190I+0D7553166
   Coding: 090101040103EDFF7D94CF3E00000003000001000000000000
   VCID: 2B5E7C234A72F4461E5-807E
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Component: CD-Database  5298
   Component: TSG HL        H03 0507
   Coding: 010F14024021628002080002
   VCID: 499226ABE0CEC6560C9-801C
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0105397
   Coding: 0205000001000100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4G8 959 107 Q    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0043
   Revision: 11013001    Serial number: 234301061
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 438E3483CAE21C06C65-8016
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4G8 919 604 L    HW: 4G8 919 604 L
   Component: HeadUpDisplay 004 0201
   Coding: D60000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: 3C7C4F7FB71C63FE87F-8069
Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H10 0042
   Serial number: 0K84AE40099944
   Coding: 1411
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001316800075
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 26488D175990C92EC1B-8073
Address 8B: Adaptive Cruise 2 (J428)       Labels: None
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120209137
   Coding: 03C238181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31626E4B605E9E96249-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Address A9: Struct. Borne Sound (J869)       Labels: 4G0-907-159.clb
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130814201229
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   VCID: 2B5E7C234272F4461E5-807E
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 4G0 907 160 B    HW: 4G0
   Component: SAS-GEN 2 AGA H09 0004
   Serial number: 130828200325
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 244C971F2FAC3B3EDFF-8071
OK, we have access to an A6 with a very similar night vision system:
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0026
   Serial number: 0K84AE40035868
   Coding: 1311
   VCID: 3169A3C760A53B9632B
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001113800576
We'll poke at it a bit next week.
mitch
England, UK
   Coding: 1311
Brilliant, thank you
Did you by chance get a message like this before you got the Request Out of Range message?
'Cause I did, and yes, I tried changing the values, both directly and on the Options screen; neither was effective.
mitch
England, UK
No I've never had that screen / warning. I got straight to the first screen shot I posted, changed the values and pressed do it, at which point I got the second screen shot. I don't think I've ever had a screen like the one above.
Interesting...
mitch
England, UK
Hi guys, did you make any progress with looking into this or are you getting stuck with the warning you posted last week?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Hello Mitch, we double checked on our A6 again and a dealer level tool will not allow you to change that setting (ODIS for example won't do that). Based on what I found my impression is that this is a setting that (for whatever reasons) Audi or the supplier decided shall not be altered with dealer level access.
^ What he said.
