2024 RS7 Rear Spoiler Deactivation
UPE
C?ID=540155
Hello all,
I have a 2024 RS7, so I want to deactivate rear spoiler. Is there any guideline to do it with VCDS? I need help for this.
Regards.
I replied to the Support e-mail regarding the same question, and asked the OP to include a scan from this car here, but the relevant portion of my reply was:
At a glance Address 46-Central Conv. contains this slave:
   Rear spoiler control module:
   Subsystem 6 - Part No SW: 4K8 959 252     HW: 4K8 959 252
   Component: J223 HSP 0204  H02 0200
   Serial number: WA164614000142058112
   Coding: 00FF00
For that reason I would open the hood, connect a battery charger and try
changing the coding position labeled:  spoiler_control_unit - installed
You will find that in Byte 19 of address 46 under the experimental
coding helper.
chillybone
C?ID=200729
Hello! just to add I am working with the OP on this as well.
We were able to get passed the SFD security on this car which allows us to get into the long coding section without crashing.
We now just need a security access code and we will be able to code it off.
UPE
C?ID=540155
Here is the full auto scan summary.
Monday,22,January,2024,09:25:00:41134
VCDS Version: 23.11.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WUAPDBF29RN902267   License Plate: RS7 ABT
Mileage: 267km-165mi   Repair Order:
Chassis Type: F2-AU58 (4KL)
Scan: 01 02 03 09 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 65 6D
          74 75 81 A5 A9 BB BC C4 CA CB CC CF D6 D7 DE
VIN: WUAPDBF29RN902267   Mileage: 267km-165miles
1B-Active Steering -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DYGA)       Labels: None
   Part No SW: 4K0 907 557 Q    HW: 0P2 907 309 A
   Component: V8 4.0l TFSI  H31 0001
   Revision: 72H31000    CVN: 91663BF7
   Coding: 1A2A00122526010E342C6000000000000000000000000000
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_ECM40TFS0114K0907557Q 001001
   ROD: EV_ECM40TFS0114K0907557Q.rod
   VCID: C1CAEFAD5029E4990C-8094
   VINID: 9E54605125822627890020861C15DF7B7E
34207 - Sensor for Exhaust Flap 2
          P04A7 00 [00101111] - Implausible Signal
          [Exhaust flap 2 sensorimplausible signal]
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:23
                    Engine RPM: 0.00 /min
                    Coolant temperature: 102 °C
                    Intake air temperature: 89 °C
                    Voltage terminal 30: 12.140 V
                    Engine status: COENG_READY
34233 - Sensor for Exhaust Flap
          P048C 00 [00101111] - Implausible Signal
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:23
17324 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [00100000] - -
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:18
                    Current speed of electric motor: 0.0 /min
                    E-machine operating mode: spec. state-Bits 0-7: 0
                    Phase angle adaptation request: 0
                    Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage: No
                    Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module: No
                    Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM: No
                    Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC: No
                    Exhaust warning light: triggering contr. module-MIL_request_register_ident: 128
                    Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module: Yes
                    Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2: No
                    Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module: No
                    Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2: No
Readiness: 0110 0101
   Part No SW: 4K0 927 158 BR    HW: 0D6 927 156 H
   Component: 0D6 40FSINAR  H06 0001
   Revision: --H06---    CVN: 5B0812A5D85BE3D8
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 834625A50AB536895E-80D6
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AB    HW: 0D7 321 281 D
   Component: V552 ATFP  H02 0623
   Serial number: 2307141019
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M8 907 379 G    HW: 4M8 907 379 G
   Component: ESP9 Premium  H06 0051
   Dataset Number: 4K8909504DB 0003 CVN: C4AC1D44
   Coding: 34AA6A9731A20B9813A048974A8491D3F43A882C568CD0C8125289CB2F5C11
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: C3C6E5A54A35F6891E-8096
   Part No SW: 4N0 907 063 NE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H11 0775
   Dataset Number: 4K0909514T  0056
   Coding: 07000363C0291CDD070E57891CEF9C28130B37D10406009701051A001B33160108690A028010000000000100004308180802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 020007
   ROD: EV_BCM1BOSCHAU651_020_VW53.rod
   VCID: FEB0545161575B6131-80AA
   Subsystem 1 - Part No SW: 4K1 955 119 B    HW: 4K1 955 119
   Component: J400FRWISCH  065 0760
   Serial number: 00000002309090409588
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 22170675X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H10 0090
   Serial number: 19S13.09.2300690101
   Subsystem 4 - Part No SW: 4N0 907 410 D    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600400Z009K02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR131082323310298
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AH    HW: 4K0 947 135 AH
   Component: Dachmodul  H42 0419
   Serial number: A01495335
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H09 0210
   Serial number: WA164554000141609804
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BP26363776
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BP263A0442
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BP26363774
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BP263A0438
Address 15: Airbags (J234)       Labels:. 80A-959-655.clb
   Part No SW: 4M0 959 655 AJ    HW: 4M0 959 655 AJ
   Component: AirbagVW33    H05 4428
   Serial number: 00387M002XYN Dataset Number: 4K0909602DA 0011
   Coding: BFFCFCC000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 003003
   ROD: EV_AirbaVW31SMEAU65x_003_AU58.rod
   VCID: 834625A50AB536895E-80D6 SFD
   Left seat belt tensioner:
   Serial number: 00AI2023264017400000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2023256651600000
   Coding: 04F001
   Component: BF-Gewichtss.  H15 0022
   Serial number: IBH0000D23000L6C7V0C
   Coding: 303233
   Subsystem 4 - Part No SW: -----------    HW: 480 002 209 23
   Serial number: 35700000000F40411C6F
   Subsystem 5 - Part No SW: -----------    HW: 480 002 209 23
   Serial number: 35800000000B0468BA6T
   Subsystem 6 - Part No SW: -----------    HW: 480 031 710 22
   Serial number: 351003C0CE1C52512BFI
   Subsystem 7 - Part No SW: -----------    HW: 480 031 310 22
   Serial number: 352003C0CE60D990E83R
   Subsystem 8 - Part No SW: -----------    HW: 480 032 009 23
   Serial number: 355004C009EBD5905F1P
   Subsystem 9 - Part No SW: -----------    HW: 480 032 009 23
   Serial number: 356004C009EBD950CC0T
   Part No SW: 4N0 907 129 NT    HW: 4N0 907 129 NT
   Component: Lenks.Modul   H03 0011
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 906C1AE94BC35D11D3-80C4
   Part No SW: 4K0 920 890 G    HW: 4K0 920 890 G
   Component: FBenUSA------ H29 0262
   Coding: 0B6F54F17AA8CF05021067649800831008002000
   Shop #: WSC 32280 005 1048576
   ASAM Dataset: EV_DashBoardAU65X 002039
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: B228B061E58F4F0185-80E6
   Part No SW: 4KL 907 468 M    HW: 4KL 907 468 L
   Component: Gateway       H06 0025
   Serial number: F0979374939781 Dataset Number: 4K0909515Q  0073
   Coding: 02030001000406405496000000590132EC9A008890000000090000CE04030000
   GVL: F1597C500800000002DC08008100C800110C0010000000000000000000006700
   ASAM Dataset: EV_Gatew31xUNECE 005014
   ROD: EV_Gatew31xUNECE_VW53.rod
   VCID: DAF838C1DDBF57416D-808E SFD
   Subsystem 1 - Part No SW: 4K0 951 523 P    HW: 4K0 951 523 P
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 4K0 915 181 D    HW: 4K0 915 181 D
   Component: J367-BDMConti  H05 1076
   Serial number: 78568800002309230098
   Subsystem 3 - Part No SW: 4K0 419 508 E    HW: 4K0 419 508 E
   Component: J1158 KLR  H03 0020
   Serial number: 23129005904S0020H032
4624 - Release / Enable Active
          B184C 00 [00001000] - -
          [ECU unlocked]
                    Fault Frequency: 9
                    Reset counter: 44
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:39:44
262727 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_ConnectionManager]
                    Reset counter: 44
                    Mileage: 267 km
                    Date: 2024.01.20
                    Time: 15:49:37
16712374 - Unknown Error Code
          U17A0 00 [00001000] - -
          [Filter_is_not_active]
                    Reset counter: 44
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 14:29:50
   Part No SW: 4N0 907 144 G    HW: 8W0 907 144 D
   Component: SCU_MLBevo    H04 0810
   Serial number: 30303030303030
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
0256 - Internal Control Module Memory Check Sum Error
          B2000 42 [00001001] - General Memory Failure
          [KFC_DATA_FLASH_READ]
                    Expanded ambient data 10-Malfunction type: 00 40
                    Expanded ambient data 10-Terminal 30 power supply: 10.90 V
                    Expanded ambient data 10-Steering wheel angle: internal value: 0 °
                    Expanded ambient data 10-Engine current: 0.00 A
                    Expanded ambient data 10-System status: Initializing
                    Expanded ambient data 10-Calculated vehicle speed: -140 km/h
                    Expanded ambient data 10-Active_steering_internal_status: Initializing
                    Expanded ambient data 10-position_control_mode: NormalPositionControl
                    Expanded ambient data 10-Steering wheel angle velocity: 0 °/s
                    Expanded ambient data 10-Steering_torque_eps: 0.00 Nm
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 B    HW: 8W0 907 163 B
   Component: QSP QCU Gen2  H08 0080
   Revision: A2C74525    Serial number: 605340412200907
   Coding: 0300
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22_AU58.rod
   VCID: BB369D4532C58E4956-80EE
   Part No SW: 4K0 959 760     HW: 4K0 959 760
   Component: MEM-FS        011 0071
   Serial number: 00000509040825 Dataset Number: 4K8909856F  0021
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   VCID: F3A675655A1506094E-80A6
   Part No SW: 4N0 907 566 AM    HW: 4N0 907 566 A
   Component: MRR_HR H28 0588
   Dataset Number: 4K8909535G  0028
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 814A2FAD10A924994C-80D4
   Part No SW: 4M2 959 793 K    HW: 4M2 959 793 K
   Component: TSG FS        001 0463
   Serial number: YE007WF21395A Dataset Number: 4K8909872D  0048
   Coding: 005DCB4352001280A001A432
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: C8DCF2897313D5D1CB-809C
   Part No SW: 4N0 909 144 H    HW: 4N0 909 144 D
   Component: EPS_MLBEVO2BS H24 0512
   Dataset Number: 4K8909852BB 0003
   Coding: C1002101010000
   ASAM Dataset: EV_SteerAssisUNECEAU651 001003
   ROD: EV_SteerAssisUNECEAU651_AU49.rod
   VCID: B5228B7D14E15839A0-80E0 SFD
   Part No SW: 4N0 907 064 HD    HW: 4N0 907 064 HD
   Component: BCM2 MLBevo H19 0285
   Dataset Number: 4K8909501BA 0004
   Coding: 013463004FB100C0650FA0006C01080203004001810026502F0400040F04823F001E0681001F350200000000000000000000
   ASAM Dataset: EV_BCM2CONTIAU651 014010
   ROD: EV_BCM2CONTIAU651_014.rod
   VCID: F8BC4249437365517B-80AC SFD
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 177 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA  006 0501
   Serial number: 0000000000000Q3A0JFF
   Serial number: 00000000000051972550
   left tail lamp 1:
   Subsystem 4 - Part No SW: 4K8 945 069 C    HW: 4K8 945 069 C
   Component: Slali1AU583  H04 0404
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Subsystem 5 - Part No SW: 80A 962 243     HW: 80A 962 243
   Component: GEB.F.Heckoef  H17 0911
   Serial number: 40280720
   Coding: 00FF00
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4K8 945 217 C    HW: 4K8 945 217 C
   Component: Slali2AU583  H04 0404
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4K8 945 070 C    HW: 4K8 945 070 C
   Component: Slare1AU583  H04 0404
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4K8 945 218 C    HW: 4K8 945 218 C
   Component: Slare2AU583  H04 0404
65655 - Adjustment of Rear Spoiler
          B1341 01 [00001001] - Electrical Failure
                    Reset counter: 4
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:23
                    Supply voltages-Terminal 30 power supply: 12.256 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.283 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.242 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
65673 - Sensor for Rear Lid/Hatch Opening
          B1303 4A [00001001] - Incorrect Component(s) Installed
                    Reset counter: 3
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:23
                    Supply voltages-Terminal 30 power supply: 12.249 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.290 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.235 V
   Part No SW: 4M2 959 792 K    HW: 4M2 959 792 K
   Component: TSG BFS       001 0463
   Serial number: YE007WHG2217A Dataset Number: 4K8909873D  0048
   Coding: 005DCB035E001280A001A430
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: C7DEF1B57E0DDAA9C2-8092
   Part No SW: 4M2 035 092 G    HW: 4M2 035 092 B
   Component: MU-TP-NS-US   045 4014
   Serial number: GRO-63325.08.23 Dataset Number: 4K1909545J  0044
   Coding: 15830000804100000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: AD12A31DFCB110F9D8-80F8 SFD
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4K0 919 605 M    HW: 4K0 919 605 M
   Component: DU AU58x Top   H41 0060
   Serial number: INX00128062300220051
   Subsystem 2 - Part No: V03 959 808 FS
   Component: MIB3_NA_       0936
   Compact disc data bank:
   Component: Gracenote2     3008
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4K0 919 603 M    HW: 4K0 919 603 M
   Component: DU AU58x Bot   H41 0060
   Serial number: INX00114062300241286
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008323000132472036
   Android control module:
   Subsystem 6 - Part No SW: 8W0 919 806     HW: 8W0 919 806
   Component: AED2-EU        H54 0527
   Serial number: YD700226092303191889
   Media socket:
   Subsystem 7 - Part No: 4N1 035 736
007 0007
   Digital Sound System Control Module 2:
   Subsystem 8 - Part No SW: 4M2 035 466 B    HW: 4M2 035 466 B
   Component: B_A_3_A_A_AU   H09 0120
   Serial number: HHA-07322.06.2342960
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 F    HW: 4N0 915 105 F
   Component: BMS_48V_LiIon H09 0211
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0010
   Serial number: 30000000227903 Dataset Number: 4K8909850A  0014
   ROD: EV_RDKHUFAU736_AU38.rod
   VCID: AF2EB915F6BD62E9EA-80FA
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 89A 959 107     HW: 89A 959 107
   Component: HDSG-Modul    H02 0711
   Revision: --------    Serial number: A2-C786-3760-1 Dataset Number: 4K8909541G  0010
   Coding: 1620
   ASAM Dataset: EV_DeckLidCONTIAU536 001008
   ROD: EV_DeckLidCONTIAU536_AU37.rod
   VCID: F1AA7F6D20093419BC-80A4
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4K0 907 777 CB    HW: 4K0 907 777 D
   Component: Fahrwerk-SG   H53 2135
   Serial number: 1609231540  Dataset Number: 4K8909576S  0001
   Coding: 746C704B7A04
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002_AU58.rod
   VCID: F9BA474D78797C5904-80AC
   Part No SW: 4KE 035 283 L    HW: 4KE 035 283 E
   Component: CB_H_NAR      043 0595
   Serial number: A971I0PS390827 Dataset Number: 4K0909612N  0026
   Coding: 01E0E0F8C04080F6F0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: C5C2FBBD4401C8B930-8090 SFD
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K1 713 041 L    HW: 4K1 713 041 H
   Component: GSM-LL H17 0056
   Serial number: 23.251 41213
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: AC14AE19C7AB19F1CF-80F8
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 P    HW: 4K4 907 117 B
   Component: zFAS Var C    H10 0394
   Dataset Number: 4K0909466AN 0066
   Coding: 02018600000000000033D60000F4D54C139D5200000000D8000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000098D0008000B000000000000000000080400000F0
   ASAM Dataset: EV_ZFASAU516 004016
   ROD: EV_ZFASAU516_004_VW53.rod
   VCID: BC349E5937CB89715F-80E8
4158 - Coding invalid
          U10DA 00 [00001000] - -
          [Codierung(en) ungültig]
                    Reset counter: 4
                    Mileage: 237 km
                    Date: 2024.01.19
                    Time: 13:38:20
   Part No SW: 4K0 907 159 J    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 230928290562
   VCID: B83C824903F3A551BB-80EC
   Part No SW: 4M2 959 795 K    HW: 4M2 959 795 K
   Component: TSG HFS       001 0463
   Serial number: YE007WI907035 Dataset Number: 4K8909897F  0050
   Coding: 004DC90300001280E000A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: CAD8C8816D1F27C1DD-809E
   Component: TSG HBFS      001 0463
   Serial number: YE007WI906951 Dataset Number: 4K8909896F  0050
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663 B    HW: 4K0 959 663 B
   Component: DCDC_GEN_2 H26 0501
   Serial number: DC23383000283 Dataset Number: 4K0909475C  0014
   ASAM Dataset: EV_DCDC48VFLEXAU581 005014
   ROD: EV_DCDC48VFLEXAU581_005_AU49.rod
   VCID: B73E81750EEDAA29B2-80E2
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4K8 907 594 AA    HW: 4K0 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: 4K0909469K  0024
   Coding: 268040058301
   VCID: FBB65D4572454E4916-80AE
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 R    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0339
   Revision: --------    Serial number: CCC_039_B_9061_ Dataset Number: 4KF909904L  0002
   Coding: 42244000
   ASAM Dataset: EV_HALUNECEAU536 001004
   ROD: EV_HALUNECEAU536_AU58.rod
   VCID: C0CCEAA95B23ED9103-8094 SFD
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N1 903 028 B    HW: 4N1 903 028 B
   Component: BSG-HP1-65    H20 0562
   Serial number: 28092300030106  Dataset Number: 4K0909490A  0007
   Coding: 30000400000000
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
   VCID: AB16AD05C2A51EC9C6-80FE
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H28 0588
   Dataset Number: 4K8909468G  0028
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
   Part No SW: 4K0 941 592 AG    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H20 0132
   Dataset Number: 4K0909471M  0022
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: F5A24B7D5461183960-80A0
   Dataset Number: 4K0909472M  0022
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: A00C4A29BB63CD9163-80F4
End----(Elapsed Time: 02:26, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
AINils
Germany (AIB)
C?ID=56975
You can't do codings in this car as it is protected by SFD2 (PR-NI8). No codings possible in this car
chillybone
C?ID=200729
Odis was able to unlock SFD for 89 minutes allowing us to enter the module and change the coding without crashing with VCDS. Now it just asks for an access security code like most of the previous models need.
Thanks for the scan and updates! If I'm not mistaken, 20103 was accepted but you still received Coding Rejected correct?
In addition, when SFD was unlocked what were the results when attempting to re-code 46 back to the same value that is already stored? Did the controller produce the same Coding Rejected response?
chillybone
C?ID=200729
20103 did not work when we tried it after the SFD was unlocked. it just rejects it as if you put in the wrong code
So after it was unlocked and tried to do the recoding. the module told us it needs a security access. No biggie usually but the normal codes we tried did not work.
Before the SFD was unlocked it used to crash completely mutiple times and using different methods and never even got a chance to ask for the security access
AINils
Germany (AIB)
C?ID=56975
As I wrote this car is protected by SFD2, so no possibilty to open for coding. Also ODIS isn't possible to open SFD2!
No more codings in SFD secured cars for now
chillybone
C?ID=200729
humor me to try at least this. Is there a security access code for 46 that is not 20103 that could work?
This is what vcds is asking for. Currently it says the cars module is unlocked.
Why would it ask for an access code when trying to save the coding and not just say this car is protected by SFD2 or some other verbiage.
AINils
Germany (AIB)
C?ID=56975
As far as I know there's no "message" for locked SFD / SFD2 controller, so VCDS only "see" it's locked, but not why.
Trust me you can't do as your PR Codes show NI8, which means car is highly secured
chillybone
C?ID=200729
We are planning on delivering the car today. Hopefully we will be able to get in the modules in the near future to complete it.
Thank you all again for the insight.
chillybone
C?ID=200729
@Dana By chance do you have an ETA when VCDS will have SFD2 access?
I do not. The team is still working on regular SFD access. When we get past that hurdle SFD2 testing can begin since they are starting to arrive in the US market.
Bruce
Near Philadelphia, PA, USA
@chillybone, we are not in a position to say when we will have any SFD coverage since VAG is the gate keeper and we must work at their pace despite paying them a whopping load of green. Trust me, if RT personnel could make it all go, it would have been available by now. But we get the privilege of paying a huge sum for glacial action.
No, we cannot give dates. No we cannot set an expectation. Yes, we are working as hard as we are able. Yes, as soon as it is all tested, approved, accepted by the VAG gods, SFD capability will be made available to our user community.
SFD2 is an enhancement to SFD... It will come after SFD is available as @Dana has written.
At the risk of sounding a bit too simplistic, why not just unplug the darn thing?
That's certainly worth trying, but it will for sure set fault codes. The question in a such a modern car is: How far into other systems will they cascade?
Right, I considered that suggestion early on but didn't share it because that would create a pile of DTCs and knowing VW/Audi ... the vehicle may go into limp mode resulting in limited engine RPM, vehicle speed among other things.
If the guys want to revisit this J223 appears to receive power from a 20A fuse in position SH7. I believe that's the Black row (of 12 possible fuses) closest to the left side of the panel at the floor in the boot.
PanEuropean
Toronto, Canada
C?ID=11844
Good point Uwe, I had not thought of that.
But, considering that it is a RS7, wouldn't limited vehicle speed save the owner a fortune in speeding tickets? :D
Michael
Sebastian
Magdeburg, Germany
HN0-nnnnnn
From personal experience with a top speed limited '23 ID.Buzz and '67 Mustang I can attest, that this is not the case. 🤭
