Carbon Fiber R8 upgrade
veedabowlu
C?ID=56963
I have a friend that recently upgraded the front and rear brakes to factory carbon fiber rotors and the applicable calipers. He also changed the Brake booster and master cylinder.
It is my understanding that the car needs to be recoded to function correctly. I believe the ABS and airbag have to be recoded. Attached is a full scan. Any help would be greatly appreciated.
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
Chassis Type: FG (8P0)
Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 2E 37 42 46 47
          52 56 61 65 6C 77 A6
VIN: WUAENAFG5BN002076   Mileage: 47580km-29564miles
A6-Microphone -- Status: Malfunction 0010
Address 01: Engine (BUJ)       Labels: None
   Part No SW: 424 910 552 M    HW: 420 907 552 B
   Component: 5.2L V10HDZ/4V F   ª0010
   Revision: F5H07---    Serial number: AUX7Z0K0FND0G7
   Coding: 011000091B0F0120
   Shop #: WSC 42772 001 1048576
   VCID: 1D3BD635C48E72D656-8048
Address 02: Auto Trans        Labels: 420-910-156-V2.clb
   Part No SW: 420 910 156 M    HW: 420 927 156
   Component: SL600 5.2L FSI HDZ  0030
   Revision: SBH03001    Serial number: 8+4NCW3CK
   Coding: 0000001
   Shop #: WSC 02197 785 00200
   VCID: 1933C225D0A60EF6BA-804C
   Subsystem 1 - Part No: 420 713 041 C
   Component: A11 C02  26.06.12   0A11
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Mileage: 47567 km
                    Torque: 0.0 Nm
                    Temperature: 28.0°C
                        0.00 %
Address 03: ABS Brakes        Labels: None
   Part No SW: 420 907 379     HW: 420 614 517 D
   Component: ESP8 quattro    H01 0200
   Coding: 0000267
   VCID: 59B382259026CEF67A-800C
   Part No SW: 420 820 043 G    HW: 420 820 043 G
   Component: J255  Klima 1 Zone  0090
   Revision: 00H06007    Serial number: 00000001171161
   Coding: 1572906
   VCID: 0E19A1791968D94EDF-805A
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 L
   Component: BCM PQ35  H   106 0667
   Revision: 00106 AD
   Coding: 6E000A00A0933624207444E009200009507068001120C92ADC08061C0045
   Shop #: WSC 25166 444 84618
   VCID: 448D4351C7A4631E39-8010
   Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiR  H23 0040
   Coding: 005912
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 025B32
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101010
                    Reset counter: 129
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:22:29
                    Voltage: 11.80 V
                        Term 50 On
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 129
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:22:29
                    Voltage: 11.80 V
                        Term 50 On
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0595096
   Coding: 0000100
   VCID: 366929994178C18EB7-8062
            000 -  -
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:05:33
Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0140
   Revision: 11001001    Serial number: 12591035647928
   Coding: 30010C
   Shop #: WSC 02391 823 56573
   VCID: 49935265E086BE76CA-801C
Address 11: Engine II        Labels: None
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 420 910 376 A    HW: 420 907 376 A
   Component: J250 Raddaempfung   0170
   Revision: --H16---    Serial number: 190DPH 0350035
   Coding: 0000052
   VCID: 1123BA050856C6B6C2-8044
Address 15: Airbags        Labels: 420-959-655.lbl
   Part No SW: 420 959 655     HW: 420 959 655
   Component: SN Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 003B8000DMS%
   Coding: 0021326
   VCID: 5DBB9635840E32D616-8008
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 05ENK
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB405E8FEEEJÿ†63
   Subsystem 5 - Serial number: 8FEEEJÿ†63428RB405E8FE822ÿ†63
   Subsystem 6 - Serial number: 8FE822ÿ†63747RB405F2AABD6ÿ†63
   Subsystem 7 - Serial number: 2AABD6ÿ†63847RB405F2AAE52ÿ
   Subsystem 8 - Serial number: 2AAE52ÿ
02512 - Pressure Sensor for Seat Occupied Recognition (G452)
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Fault Frequency: 15
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 20:55:54
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Coding: 0004141
   VCID: 41834A4518B6763612-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981 X    HW: 420 920 981 X
   Component: KOMBIINSTR. VDO H01 0591
   Revision: D0H01004    Serial number: 224NL004000014
   Coding: 0081263
   Shop #: WSC 40214 001 1048576
   VCID: 2B5F08ED8A3A8C66D8-807E
   Part No SW: 8P0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H43 0311
   Revision:   H43       Serial number: 081210F1000694
   Coding: 354100
   VCID: 336F108D920AD4A690-8066
   Revision: D0H01004    Serial number: AUX7Z0K0FND0G7
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 420 035 785     HW: 420 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020302
   VCID: 52A175090DD0FDAEBB-8006
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 423 035 192 H    HW: 423 035 192 H
   Component: RNS-E PU US     H06 0200
   Revision: 0000012S    Serial number: AUZBZ7L7200022
   Coding: 0730645
   VCID: 152BCE153CBE2A969E-8040
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 420 959 801 H    HW: 420 959 801 H
   Component: Tuer-SG         H04 0103
   Coding: 0005245
   VCID: 1E39D139C98869CE4F-804A
Address 47: Sound System        Labels: 420-035-223.lbl
   Part No SW: 420 035 223 D    HW: 420 035 223 A
   Component: J525 Amp High   H14 0230
   Revision: 00H14001    Serial number: 34844000925703
   Coding: 0246111
   VCID: 091392656006FE760A-805C
Address 52: Door Elect, Pass.        Labels: None
   Part No SW: 420 959 802 H    HW: 420 959 802 H
   Coding: 0005245
   VCID: 1F47EC3DCE8260C644-804A
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0730645
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 0311
   Coding: F32001FE
   VCID: 74EDD391D784939E49-8020
   Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
   Component: J367-BDM  H07 0140
Address 65: Tire Pressure        Labels: None
   Part No SW: 420 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0040
   Revision: 00050040    Serial number: 00000700006850
   Coding: 0462426
   Shop #: WSC 04272 001 1048576
   VCID: 0D1BA675146EE25626-8058
Address 6C: Back-up Cam.        Labels: 420-910-441.clb
   Part No SW: 420 910 441 A    HW: 7L6 907 441 C
   Component: J772__Rearview      0010
   Revision: --H13---    Serial number: 525PA8-J0Z6042
   Coding: 1020412
   VCID: 0A11AD696500F56E03-805E
   Part No SW: 8P1 862 336     HW: 8P1 862 336
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005044711
   Coding: 0011477
   Shop #: WSC 02556 785 00200
   VCID: 75EBEE951CFE8A967E-8020
Address A6: Microphone (J886)       Labels: 420-907-394.clb
   Part No SW: 420 907 394     HW: 420 907 394
   Component: BELTMICBOX    H09 0060
   Coding: 0100010202
   Shop #: WSC 02197 785 00000
   ASAM Dataset: EV_BeltMicAU715 002011
   ROD: EV_BeltMicAU715.rod
   VCID: 56A989192938E18E57-8002
0032 - Microphone 1 for Passenver Side
          B1206 13 [009] - Open Circuit
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:29:04
0048 - Microphone 2 for Passenver Side
          B1207 13 [009] - Open Circuit
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:29:04
0064 - Microphone 3 for Passenver Side
          B1208 13 [009] - Open Circuit
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:29:04
0080 - Microphone 1 for Drivers Side
          B1203 13 [009] - Open Circuit
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:29:04
0096 - Microphone 2 for Drivers Side
          B1204 13 [009] - Open Circuit
                    Reset counter: 87
                    Mileage: 47536 km
                    Date: 2015.09.16
                    Time: 21:29:04
0112 - Microphone 3 for Drivers Side
          B1205 13 [009] - Open Circuit
                    Reset counter: 87
End
I'm confident the airbag module in this car will not accept any coding except the one it already has. I'm not sure why the airbag module would care what kind of brakes the car has anyway. ;)
As for the ABS, I'd consider that far more likely but haven't come up with a coding chart for that module.
