2006 A6 B6 3.2 runs for about 11 minutes after first start then suddenly stalls. No Codes detected, No Engine Light.
acostae
Wichita Falls, TX, USA
C?ID=546672
After replacing both lower intake manifolds and Cranckcase Breather Hose assembly; along with Low Pressure Fuel Pump, fuel pump control module, fuel pump relay and High Pressure Fuel Pump.
Throttle body assembly also replaced and aligned
Using HEX-V2 H11-079599 properly registered, purchased directly from Ross-Tech, with new laptop.
Performed air intake leak detection, at idle, throughout whole plenum and lower manifold assemblies with unlit propane torch, no change in RPM in any location
Vacuum consistent at 40kp/a, deplets when I pull on any plenum air connection, so apparently good vacuum
Fuel rail pressure was present even after engine stalls
Cats were around 570 deg
Never lost communication with ECM, little stick was still turning.
Will stall at idle or while driving, starts right back up but stalls right away since its warm.
Noticed a "Time to Shutdown" reading and saw the minutes and seconds count down until Zero then stalled
Friday,12,January,2024,14:27:02:35625
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUDH74F76N150374   License Plate: HGL0100
Mileage: 324880km-201871mi   Repair Order: 20240112
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUDH74F76N150374   Mileage: 324880km-201871miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 E    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0070
   Revision: --H15---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2D071A4D11198CF2B45-8078
   VINID: 9D19546071161C67811400C710A52F26AE
Readiness: 0110 0101
   Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        4142956
   Coding: 0000002
   VCID: 2615E56134EFBFAA75F-8072
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H05 0090
   Coding: 0020895
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0180
   Revision: 30070501    Serial number: 10604000346629
   Coding: 0000015
   Shop #: WSC 25169 444 84354
   VCID: 6393BC75075D0A82521-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 KSG   H27 0080
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 00101011
                    Reset counter: 44
                    Mileage: 324882 km
                    Date: 2024.01.11
                    Time: 15:49:27
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 731 B    HW: 4E0 035 729
   Component: Interfacebox    H43 1190
   Revision: 00000000    Serial number: 303BG067516731
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 211FF67D5DC1589200D-8074
   Component: Bedienteil MMIC6H08 0050
   Subsystem 2 - Serial number: 00000000333751
   Subsystem 3 - Serial number: 0106.02.060000000100010931
   Subsystem 4 - Serial number: 010931
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0170
   Revision: 00000030    Serial number: 00000000231756
   Coding: 0532518
   VCID: 5BE384953F2D32421A1-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014123
   VCID: 2A0D115120F79BCA517-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH11 0050
   Coding: 00137492
   Shop #: WSC 02335
02382 - Sensor for Light Detection (G399)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 44
                    Mileage: 262136 km
                    Date: 2024.01.12
                    Time: 14:22:00
01024 - Rain Sensor (G213)
            014 - Defective
                    Reset counter: 44
                    Mileage: 262136 km
                    Date: 2024.01.12
                    Time: 14:22:00
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBF7269465
   VCID: 1B63C4957FAD7242DA1-804E
Address 0F: Digital Radio        Labels: None
   VCID: 55F792AD5D09E4322C5-8000
No Faults Found
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0B3S8.
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0D4A43252
   Subsystem 3 - Serial number: 6342CSME0E7F63209
   Subsystem 4 - Serial number: 6352QSME061A4733B
   Subsystem 5 - Serial number: 6362QSME05333A619
   Subsystem 6 - Serial number: 63734SME08141D0F0
   Subsystem 7 - Serial number: 63834SME08164B07$
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks ulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026060240236
   Coding: 0002041
   Shop #: WSC 02323 785 00200
   VCID: 6695A561F46F7FAAB5F-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H17 0660
   Revision: 00200000    Serial number: 4PY542526
   Coding: 2129263
   Shop #: WSC 05300 067 57207
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300806129824A
   Coding: ECFE73CD1B7904
   Shop #: WSC 02334 785 00200
   VCID: 270BE86533E5A6A24E9-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619FB67D1D41189240D-8034
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
                    Fault Status: 01100101
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2024.01.09
                    Time: 16:46:03
00003 - Control Module
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2006.01.01
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H45 1100
   Revision: 00000000    Serial number: 355BK067562133
   VCID: 38293B19EE5B395AD73-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00-00000
   Coding: 0051947
   Shop #: WSC 02327 785 00200
   VCID: 2C0117492A0385FAA3B-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01010275260000
   Coding: 4619325
   VCID: 2E051D411C1FF7EA8DF-807A
                    Fault Status: 01101100
                    Reset counter: 44
                    Mileage: 131877 km
                    Date: 2014.01.23
                    Time: 16:46:36
01502 - Bulb for Rear Fog; Left (L46)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 183
                    Mileage: 316391 km
                    Date: 2023.09.25
                    Time: 07:20:06
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000204650
   Coding: 0000026
   VCID: 1C61C7897AA3757AD3B-8048
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000015793
   Coding: 0002114
   VCID: 5EE58D812C3F276A7DF-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 A    HW: 4F0 907 801
   Component: EPB  CA3C0040   H03 0040
   Revision: --H03---
   Coding: 0005022
   Shop #: WSC 02324 785 00200
   VCID: 1E65CD816CBF676A3DF-804A
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000016
   VCID: 2809EB593EFBA9DA473-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
02627 - Dynamic Cornering Light Motor; Left (V318)
                    Fault Status: 11101010
                    Fault Frequency: 12
                    Mileage: 324888 km
                    Date: 2024.01.09
                    Time: 16:46:05
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394BU067636093
   Coding: 0000002
   VCID: 2313FC7547DD4A82121-8076
Address 61: Battery Regul.        Labels: 4F0-910-181.clb
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000064924
   Shop #: WSC 25105 444 84543
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2601290585
   Coding: 344630393135313035432056413032363031323930353835
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.09
                    Time: 22:03:47
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0051754
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.clb
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700017601
   Coding: 0062221
   VCID: 221DF97158C7438A197-8076
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100010
                    Fault Frequency: 94
                    Reset counter: 80
                    Mileage: 262901 km
                    Date: 2022.09.21
                    Time: 18:05:57
                    (no units): 44.0
                    Voltage: 13.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 J    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0600
   Revision: 00000000    Serial number: 00000601260176
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0051754
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720603303921
   Coding: 0001206
   Part No SW: 4F0 910 336 B    HW: 4E0 862 335
   Component: Handyvorb2      H11 0440
   Revision: 00000000    Serial number: 00000007529535
   Coding: 0010900
End----(Elapsed Time: 02:58, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
Huh? Where is this?
acostae
C?ID=546672
Will look again tomorrow, sorry been at my part time since 5pm.
I setup one of the Measure Values in 01, I believe.
Will verify tomorrow again and will post.
Thanks for asking
acostae
C?ID=546672
Fresh Auto Scan performed before first start, idled for 7 minutes, then stalled after revving up and letting go of Accelerator pedal.
Saturday,13,January,2024,11:25:43:35625
Mileage: 324880km-201871mi   Repair Order: 2024011311:25AM
   Coding: 0000002
   Coding: 0020895
   Coding: 0000015
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.11
                    Time: 15:49:27
   Coding: 0000003
   Coding: 0532518
   Coding: 0014123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00137492
   Shop #: WSC 02335
            014 - Defective
                    Reset counter: 44
                    Mileage: 262136 km
                    Date: 2024.01.13
                    Time: 11:19:00
            014 - Defective
                    Reset counter: 44
                    Mileage: 262136 km
                    Date: 2024.01.13
                    Time: 11:19:00
No Faults Found
   Coding: 0013878
   Coding: 0002041
   Coding: 2129263
   Coding: 0082954
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2024.01.09
                    Time: 16:46:03
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2006.01.01
   Revision: 00-00000
   Coding: 0051947
   Coding: 4619325
                    Reset counter: 44
                    Mileage: 131877 km
                    Date: 2014.01.23
                    Time: 16:46:36
                    Reset counter: 183
                    Mileage: 316391 km
                    Date: 2023.09.25
                    Time: 07:20:06
   Coding: 0000026
   Coding: 0002114
   Revision: 00-00000
   Coding: 0051947
   Revision: --H03---
   Coding: 0005022
   Coding: 0000016
                    Fault Status: 00111010
                    Fault Frequency: 13
                    Mileage: 324888 km
                    Date: 2024.01.09
                    Time: 16:46:05
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
   Coding: 0000002
                    Fault Status: 00110001
                    Reset counter: 44
                    Mileage: 324882 km
                    Date: 2024.01.09
                    Time: 22:03:47
   Coding: 0051754
   Coding: 0062221
                    Fault Frequency: 94
                    Reset counter: 80
                    Mileage: 262901 km
                    Date: 2022.09.21
                    Time: 18:05:57
                    (no units): 44.0
                    Voltage: 13.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0051754
   Coding: 0001206
   Coding: 0010900
End----(Elapsed Time: 02:58, VBatt start/end: 11.6V/11.7V. VIgn 11.6V)-----
acostae
C?ID=546672
Fuel Pump Shut-Off Time found in 01_Engine, Measuring Blocks, Group 106.
Showed 0.00 s before Engine Start then showed 1.00 s After Engine Start.
Also, Throttle Valve Sensor 1 (G187) read 12.9%
Throttle Valve Sensor 2(G188)read 88.6% BOTH AT IDLE (Throttle Valve Angle 1.6%)
This #2 (G188) shouldn't be close to same as #1(G187)?
Maybe that is my stalling problem.
Idled fine for 9 minutes at 766 RPM, pressed Accelerator pedal and released it gently, Engine stalled suddenly, No Fault codes recorded, Comm was still present.
Need to figure out how to insert an image so you see my VCDS screen shots.
Heading to funeral, will return this afternoon.
Thanks, Ernie
TTT
C?ID=547002
That battery is dying.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Could it be a fuel shut off time limit for something like alarm or wireless key not seen?
@TTT are you saying battery in key?
Or battery in car because of...
This is different for sure???? :confused:
Good Luck
acostae
C?ID=546672
Allrighty, have new 94 Group battery in the garage to install as soon as possible.
May be tomorrow, doing a valve cover job on my son's Explorer Sport today.
Thanks for the input, didn't dawn on me, I've been keeping a cheap battery maintainer in it, will use the good one from my 240Z after replacing the battery.
Which was only a year old, but not the best from O'Reilly's.
Thanks again both for your time and observations
acostae
C?ID=546672
Installed brand new 49 Platinum Series battery from Oreillys, replaced Intake Manifold Tuning Valve (Bank1), Audi Brand.
Cleared DTCs, did battery Coding in 61-Battery Regul, Recode Module using Current coding (40 something numbers)
Copied then Pasted in New Coding, pressed Do it!
Displayed Battery Coded
Ran it for 22 minutes this time while observing Throttle Body angle (12.3%) along with both Lower Intake angles (12.1% on both)
Revved engine and watched all three Throttle angles go up simultaneously and come down to idle simultaneously then shut off again.
Did Auto Scan again and P2070 showed again after it shut off.
Have this fault code also in 01 Engine:
P1653 - 008 -
Car starts right away then shuts off when warm.
Am I performing the battery Adaptation properly?
Going to check alternator performance next.
Getting frustrated, been couple months.
Thursday,18,January,2024,12:31:05:35625
Mileage: 324880km-201871mi   Repair Order: 202401181300
               P1653 - 008 -
                    Fault Status: 01101000
                    Mileage: 324881 km
                    Date: 2005.09.22
                    Time: 06:29:22
                    RPM: 1440 /min
                    Mass Air / Rev.: 207.1 mg/str
                    Temperature: 6.0 C
                        Idle
                    Load: 24.7 %
008304 - Intake Manifold Tuning Valve (Bank 1)
               P2070 - 006 - Stuck Open
                    Fault Status: 01100001
                    Mileage: 324881 km
                    Date: 2005.09.22
                    Time: 06:49:12
                    RPM: 672 /min
                    Mass Air / Rev.: 125.4 mg/str
                    Temperature: 64.5 C
                        Idle
                    Absolute Pres.: 345.8 mbar
   Coding: 0000002
   Coding: 0020895
                    Reset counter: 44
                    Mileage: 324881 km
                    Date: 2005.09.20
                    Time: 12:07:51
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0192
                    Hex Value: 0x00FF
   Coding: 0000015
                    Fault Status: 00111011
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.11
                    Time: 15:49:27
   Coding: 0000003
   Coding: 0532518
   Coding: 0014123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00152621
   Shop #: WSC 02335
                    Fault Status: 00101110
                    Reset counter: 84
                    Mileage: 262136 km
                    Date: 2005.09.22
                    Time: 06:26:00
                    Reset counter: 84
                    Mileage: 262136 km
                    Date: 2005.09.22
                    Time: 06:26:00
No Faults Found
   Coding: 0013878
   Coding: 0002041
   Coding: 2129263
   Coding: 0082954
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2024.01.09
                    Time: 16:46:03
                    Reset counter: 44
                    Mileage: 62736 km
                    Date: 2006.01.01
   Revision: 00-00000
   Coding: 0051947
   Coding: 4619325
                    Reset counter: 44
                    Mileage: 131877 km
                    Date: 2014.01.23
                    Time: 16:46:36
                    Reset counter: 183
                    Mileage: 316391 km
                    Date: 2023.09.25
                    Time: 07:20:06
   Coding: 0000026
02246 - Loudspeaker; Center
                    Fault Frequency: 12
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.13
                    Time: 11:55:42
   Coding: 0002114
   Revision: 00-00000
   Coding: 0051947
   Revision: --H03---
   Coding: 0005022
   Coding: 0000016
                    Fault Frequency: 22
                    Reset counter: 44
                    Mileage: 324888 km
                    Date: 2024.01.09
                    Time: 16:46:05
                    Fault Status: 00100111
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
   Coding: 0000002
                    Fault Frequency: 11
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.09
                    Time: 22:03:47
02273 - Quiescent Current Stage 2
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:25
02276 - Quiescent Current Stage 5
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:35
02274 - Quiescent Current Stage 3
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:46
02277 - Quiescent Current Stage 6
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:56
   Coding: 0051754
   Coding: 0062221
                    Fault Frequency: 94
                    Reset counter: 80
                    Mileage: 262901 km
                    Date: 2022.09.21
                    Time: 18:05:57
                    (no units): 44.0
                    Voltage: 13.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0051754
   Coding: 0001206
   Coding: 0010900
End----------(Elapsed Time: 02:59, VBatt start/end: 12.3V/12.2V)-----------
Jef
HQ
Just touching base...
Suspect the engine speed sensor, G28 could be the reason for the rando death of the engine.
Get a battery from the dealer with the BEM Code sticker on it.
61-Battery Regulation using CAN is the section you want to review and check out the video link at the bottom of that page.
I don't see how that's going to help. We ran an aftermarket battery on our 2005 A6 for many years after the original one got weak. Assuming the replacement battery has the same capacity and is of the same basic type, just change the battery serial number and call it good.
acostae
C?ID=546672
Thanks for the advice Jeff and Uwe. After spending over $2,500 so far, may consider using the Oreilly battery for now.
Searching Audi dealer for the G28 sensor, is it also known as Crankshaft Position Sensor?
Does it have two? Looking in audi.oempartsonline.com they show two, part#06E-906-433(Item 4) and 06E-905-163(Item3) under (Home 2006 Audi A6 Quattro Sensors)
Also created account in erWin, now we have to purchase subscriptions no free rides anymore, so I'll be purchasing it next week, need to get it running reliably again first.
Items replaced in last few weeks:
Low Pressure Fuel Pump, Import Direct brand from Oreilly
Fuel Pump Control Module located next to Low Pressure Fuel Pump under rear seat, Import Direct brand from Oreilly
High Pressure Fuel Pump, Import Direct brand from Oreilly
Fuel Pump Relay, Import Direct brand from Oreilly
Lower Intake Manifolds, Banks 1 and 2, new not used OEM Audi components
Gaskets for above, gaskets for Upper Plenum to Lower Intake Manifolds
Throttle Body Assembly, Ebay, looks OEM, has all the QC stamps, new gasket
Crankcase Breather Hose Assembly, Ebay, looks OEM and has all the Audi markings
Bank 2 Injector Harness Assembly, Ebay, all wires tested for continuity and integrity, determined harness is serviceable
Injector Oring sets
MAP Sensor, Bosch
Coolant temp sensor, Import Direct brand from Oreilly
Both Intake Manifold Tuning Valves, part #037906283C, Audi brand
Part#06H906517G, Item#20 in Vacuum System/Intake System diagram, Canister Purge Valve/Solenoid
Group 49 Platinum Series battery, Oreilly brand, per Production Code J1U
Coolant Crossover pipe assembly, front of engine
Vacuum is great and steady, never lost, when engine stalls, I pull any vacuum hose connection and it hisses (Releases) normally (As I've seen before)
Comm with ECU is never lost when it stalls
Am I not performing proper Battery Adaptation/ Reset?
Is there more than one Fuel pump relay?
Waiting to test alternator, tested it back in October and it was fine. Will retest anyway
EuroX
Northern NJ USA
C?ID=208579
How about pulling front o2 sensors out of the exhaust and letting it run? perhaps you have a clogged cat or cats.
acostae
C?ID=546672
Found the Crank sensor thru dealer in Grapevine, TX, closest to me; needs to be ordered.
No other dealer within 600 miles has it available, according to the young man that helped me.
Will replace the Crankshaft sensor first.
May certainly try removing those Upstream O2 sensors, they are easy to remove in this car.
I thought about that problem being the case, just not common both are clogged.
Also, my mistake, one Crankshaft position sensor not two, got mixed up looking at the diagram.
Thanks for the suggestion EuroX
EuroX
Northern NJ USA
C?ID=208579
Agreed not common but I have seen it where one or both cats were had melted honeycomb inside blocking the exhaust choking the car.
acostae
C?ID=546672
Yes EuroX, I've seen it also, however in my cases, (about a dozen different vehicle brands), only one failed, haven't seen both fail; especially when they're on separate exhaust manifolds all way down to muffler system. Both mine showed 479 degrees when engine stalled.
Also, engines affected by clogged Cat did not suddenly stall, would run sluggishly, ran rough and wouldn't accelerate.
I can hit redline with mine while its running, smooth at idle and while revving.
Will remove both Upstream O2 Sensors tomorrow just to rule this situation out.
Replaced the Crankshaft sensor with one from Oreilly, Import Direct brand, looked like an Uro brand logo on it.
Used one on my son's A4 years ago and it worked fine for years.
My A6 ran flawlessly for 32 minutes, idled smoothly and ran smoothly while driving around our neighborhood.
Stalled suddenly at 32-minute mark.
Fuel Rail Pressure was 3590 Kpa, both Intake Manifolds showed 14.3% when it stalled and afterward.
Getting pissed off and frustrated. Been working on it for 2 and half months now.
Showed Open Loop at Start, then showed Closed Loop Using O2 Sensor when It came down to Normal Idle.
Seems and feels to me like an electronic interruption not a mechanical interruption.
Again, found no Air Intake Assembly leaks, Vacuum was healthy and steady, never lost. only when I pulled any air connection would it release.
How can this be? Both lower Intake Manifolds are new Audi parts along with both Secondary Air Injection Valves, Peirburg 037906283C, new not used.
Besides, I am Live Reading in VCDS both intake manifolds at 14.3%, simultaneously increase and decrease in percentage of opening and closing; while observing them at 14.3% when it stalls.
So frustrated, I have no patience to figure out how to upload images of my pictures of VCDS displays.
Do those Secondary Air Intake valves have their own circuit fuse?
Thanks for replies and suggestions, will continue tomorrow.
Sunday,21,January,2024,14:45:03:35625
Mileage: 324880km-201871mi   Repair Order: 202401211444
                    Mileage: 324884 km
                    Date: 2023.01.21
                    Time: 14:33:21
                    RPM: 800 /min
                    Mass Air / Rev.: 163.5 mg/str
                    Temperature: 40.5 C
                        Idle
                    Absolute Pres.: 409.6 mbar
   Coding: 0000002
   Coding: 0020895
   Coding: 0000015
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.11
                    Time: 15:49:27
   Coding: 0000003
   Coding: 0532518
   Coding: 0014123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00152621
   Shop #: WSC 02335
                    Reset counter: 85
                    Mileage: 262136 km
                    Date: 2023.01.21
                    Time: 13:43:00
                    Reset counter: 85
                    Mileage: 262136 km
                    Date: 2023.01.21
                    Time: 13:43:00
No Faults Found
   Coding: 0013878
   Coding: 0002041
   Coding: 2129263
   Coding: 0082954
                    Reset counter: 45
                    Mileage: 62736 km
                    Date: 2024.01.09
                    Time: 16:46:03
                    Reset counter: 45
                    Mileage: 62736 km
                    Date: 2006.01.01
   Revision: 00-00000
   Coding: 0051947
   Coding: 4619325
                    Reset counter: 45
                    Mileage: 131877 km
                    Date: 2014.01.23
                    Time: 16:46:36
                    Reset counter: 183
                    Mileage: 316391 km
                    Date: 2023.09.25
                    Time: 07:20:06
   Coding: 0000026
                    Fault Frequency: 14
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.13
                    Time: 11:55:42
   Coding: 0002114
   Revision: 00-00000
   Coding: 0051947
   Revision: --H03---
   Coding: 0005022
   Coding: 0000016
                    Fault Frequency: 31
                    Reset counter: 45
                    Mileage: 324888 km
                    Date: 2024.01.09
                    Time: 16:46:05
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
   Coding: 0000002
                    Fault Frequency: 11
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.09
                    Time: 22:03:47
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:25
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:35
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:46
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:56
   Coding: 0051754
   Coding: 0062221
                    Fault Frequency: 94
                    Reset counter: 80
                    Mileage: 262901 km
                    Date: 2022.09.21
                    Time: 18:05:57
                    (no units): 44.0
                    Voltage: 13.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0051754
   Coding: 0001206
   Coding: 0010900
End----------(Elapsed Time: 02:59, VBatt start/end: 12.1V/12.1V)-----------
Address 61-01,4F0 915 105 C,recoded (Long Coding),from,344630393135313035432056413032363031323930353835,to,344630393135313035432056413032363031323930353836,(25105/444/84543),
Selective Output Tests
Sunday,21,January,2024,14:51:09
VCDS Release 23.11.0 (x64):  Generic OBD2
Mode 1:Read Data
03:Fuel system 1/2 status     Engine off  Engine off
23:Fuel Rail Press (rel)     670 kPa rel
3C:B1S1 Cat. Temp.     452.0  C
3D:B2S1 Cat. Temp.     452.0  C
Use the [Save] or [Add to log] button on that screen. This will put a snapshot of the relevant text into a plain-text file in your Logs sub-folder. From that file, you can copy & paste the text here.
EuroX
Northern NJ USA
C?ID=208579
                    Mileage: 324884 km
                    Date: 2023.01.21
                    Time: 14:33:21
                    RPM: 800 /min
                    Temperature: 40.5 C
                        Idle
   Coding: 0000002
   Coding: 0020895
   Coding: 0000015
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.11
                    Time: 15:49:27
   Coding: 0000003
   Coding: 0532518
   Coding: 0014123
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00152621
   Shop #: WSC 02335
                    Reset counter: 85
                    Mileage: 262136 km
                    Date: 2023.01.21
                    Time: 13:43:00
                    Reset counter: 85
                    Mileage: 262136 km
                    Date: 2023.01.21
                    Time: 13:43:00
No Faults Found
   Coding: 0013878
   Coding: 0002041
   Coding: 2129263
   Coding: 0082954
                    Reset counter: 45
                    Mileage: 62736 km
                    Date: 2024.01.09
                    Time: 16:46:03
                    Reset counter: 45
                    Mileage: 62736 km
                    Date: 2006.01.01
   Revision: 00-00000
   Coding: 0051947
   Coding: 4619325
                    Reset counter: 45
                    Mileage: 131877 km
                    Date: 2014.01.23
                    Time: 16:46:36
                    Reset counter: 183
                    Mileage: 316391 km
                    Date: 2023.09.25
                    Time: 07:20:06
   Coding: 0000026
                    Fault Frequency: 14
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.13
                    Time: 11:55:42
   Coding: 0002114
   Revision: 00-00000
   Coding: 0051947
   Revision: --H03---
   Coding: 0005022
   Coding: 0000016
                    Fault Frequency: 31
                    Reset counter: 45
                    Mileage: 324888 km
                    Date: 2024.01.09
                    Time: 16:46:05
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
                    Mileage: 324888 km
                    Date: 2024.01.10
                    Time: 15:51:18
   Coding: 0000002
                    Fault Frequency: 11
                    Reset counter: 84
                    Mileage: 324882 km
                    Date: 2024.01.09
                    Time: 22:03:47
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:25
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:35
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:46
                    Mileage: 324882 km
                    Date: 2024.01.16
                    Time: 00:36:56
   Coding: 0051754
   Coding: 0062221
                    Fault Frequency: 94
                    Reset counter: 80
                    Mileage: 262901 km
                    Date: 2022.09.21
                    Time: 18:05:57
                    (no units): 44.0
                    Voltage: 13.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0051754
   Coding: 0001206
   Coding: 0010900
Mode 1:Read Data
VW and Audi is a totally different animal when it comes to vehicles. I have seen both cats fail in these a6's as well as some other cars, including B5 vw passat with the 2.8 v6 as well as the 1.8T engine. In both cases vehicle would start and run for a short amount of time at idle like there was no issue and would die shortly after. If you drove the car under heavy load it would die faster due to larger amount of exhaust gases building up. If you let it idle it would run for longer. 479 degrees sounds way to low if you ask me. These things normally need to be at 525C or higher in order to perform as they should. If your 479 is in Farenheit I'd say they are about 500 degrees off their mark at the very least.
Was a fuel delivery test done? Also fuel filter in the correct orientation? verified arrow is pointing towards the front of the vehicle? I ask because you said fuel pressure is it 35bar when it stalls. That is low if you ask me, but then again I have seen these engines run without a functioning hpfp at idle. As long as they have 5bar they will run at idle.
