Wednesday,10,January,2024,13:39:47:00297
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3CZGE052749 License Plate: PASSAT
Mileage: 247162km-153579mi Repair Order:
Chassis Type: 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 23 2B 3C 42 44 51 52
55 5F 69 6C 75 82 8C A5 A9 BB BC C6 CA CF
VIN: WVWZZZ3CZGE052749 Mileage: 247162km-153579miles
51-Electric Drive -- Status: Malfunction 0010
8C-HV Battery -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CUKC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AH HW: 04E 907 309 F
Component: R4 1.4l TFS H21 3379
Revision: X3H21--- CVN: 861A8C11
Coding: 011D0012647405083000
Shop #: WSC 37585 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
ROD: EV_ECM14TFS01104E906023AH_006.rod
VCID: 6695B3CEC8E7DFAAB5F-8032
VINID: 9E69EAAAA0D3A975401421C424F97C1830
17158 - Databus
U1123 00 [00100111] - Received Error Message
Fault Frequency: 8
Mileage: 247162 km
Date: 2024.01.10
Time: 13:18:19
Engine RPM: 0.00 /min
Coolant temperature: 3 C
Intake air temperature: 4 C
Voltage terminal 30: 10.520 V
Acceleration: 0.000 m/s
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 4
U0428 00 [00100111] - -
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:25
Voltage terminal 30: 11.320 V
Outside temperature: 4 C
Absolute intake pressure: 102 kPa abs
Engine torque: 0.0 Nm
Fuel level: 38.00 l
Electric drive torque: actual value: 0.0 Nm
Operating mode control expanded electrical driving: False result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
High-volt. battery: charge state: abs. value: 19.04 %
Coolant temperature: -40 C
Intake air temperature: -40 C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
13143 - No Communication with HV Battery Energy Control Module
U0112 00 [00100110] - -
Mileage: 247162 km
Date: 2024.01.10
Time: 13:19:58
Voltage terminal 30: 11.180 V
Readiness: 1110 0001
Part No SW: 0DD 300 045 T HW: 0DD 927 770 B
Component: GSG DQ400E H31 1601
Revision: 00031033 Serial number: TFK01504200116 CVN: F52AF510
Shop #: WSC 00083 211 00000
ROD: EV_TCMDQ400021_VW48.rod
VCID: 38292DB6D2D3995AD73-806C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 3Q0 907 379 S HW: 3Q0 907 379 G
Component: ESC H42 0823
Revision: 00000000 Serial number: 61825000000049 CVN: 03BBAF11
Coding: 0FEC408F3825336E077E060441CC49F0021CCCE0608292F1B8B1F0F8CAA2
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
ROD: EV_Brake1UDSContiMK100OMG_002.rod
VCID: 4ACD677EBC3F1BCAB17-801E
0297 - Steering angle sensor
B1168 16 [10100111] - Voltage Too Low
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:26
16412 - Display for Tire Pressure Monitoring
C1146 02 [10101111] - Signal Failure
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:27
16413 - Display for Tire Pressure Monitoring
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:27
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0906
Revision: 00036000 Serial number: 0374883850 Dataset Number: V03935273SQ 0001
Coding: 0F00000703
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E253BAEF0F7A76A1DF-806A
Part No SW: 5GE 907 044 D HW: 5GE 907 044 D
Component: Climatronic H04 1301
Revision: 00001K07
Coding: 1202102420010001011550000010180A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 3D273CA2FDF1BC72045-8068
Subsystem 3 - Part No SW: 3Q0 963 231 HW: 3Q0 963 231
Component: J848 HV-PTC 200 0201
Serial number: -00102.9S.3A20340017
Air quality sensor:
Humidity sensor: exterior:
A/C compressor sub:
H02
459010 - Databus
[Batterie Steuerger t - kein Signal/Kommunikation]
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 13:20:01
B10CD 00 [00001001] - -
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:23
Voltage terminal 30: 11.2 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Back-up lamp: OFF
459030 - Implausible Data Received from Electric A/C Compressor
U046C 00 [00001001] - -
[EKK - unplausibles Signal]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:23
Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
Compressor status: global-A/C compressor release status: transmitted
Compressor status: global-A/C compressor: target speed: 0.0 /min
Compressor status: global-A/C compressor: actual speed: 0.0 /min
Compressor status: global-A/C compressor: function status: Malfunction of internal inverter
Compressor status: global-A/C compressor error indicator: not active
Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
Compressor status: global-A/C compressor: inverter temperature: -127.0 C
Compressor status: internal-A/C compressor: power limitation: not active
Compressor status: internal-A/C compressor: inverter temperature: OK
Compressor status: internal-A/C compressor: start-up monitor: OK
Compressor status: internal-A/C compressor: internal inverter communication: OK
Compressor status: internal-A/C compressor: Communication internal gateway: OK
Compressor status: internal-A/C compressor: icing protection: not active
Compressor status: internal-Inverter: Status: active
Compressor status: internal-A/C compressor: speed (RPM) protection: not active
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86581607150918 Dataset Number: V03935237HM 0001
Coding: 00971E46C3D10AF72F8C5094B11C07381880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 03538A5ADB950A82321-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150701 042 0607
Serial number: 150703050715
Component: RLHS 037 0059
Serial number: S2Y15M07D23H23M11S48
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 S HW: 3G0 941 633 S
Component: E1 - LDS MQB H01 0032
Serial number: 25 05 2015 00000619
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY151613CTD
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000062915518
Humidity sensor: interior:
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183615187 Dataset Number: V03935253NX 0001
Coding: 1A71267951
ASAM Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D47AC628DD14CF2545-8058
13637426 - Databus
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0195
Dataset Number: V03935243QB 0001
Coding: 520467DB5DFFC728949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 35372482C5C16432CC5-8060
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Control Module temperature: 23 C
Voltage terminal 15: 11.2 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
0795 - Databus
[FAULT_APS_RELEVANT_ERROR]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 12071541350165 Dataset Number: V03935221EK 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372B2E8ADFCD9622DE9-8062
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR011GFE Dataset Number: 3G0003V____ 0039
Coding: 88CCC000002000005C5400CF004800000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 50F975165A63211AFF3-8004
Left seat belt tensioner:
Serial number: 3G1857705G0195P00488
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G1857706G0195P00576
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 207 15
Serial number: 35700000000174918518
Subsystem 4 - Part No SW: ----------- HW: 480 001 207 15
Serial number: 3580000000027491851A
Subsystem 5 - Part No SW: ----------- HW: 480 400 107 15
Serial number: 3510002AF1C52F33035%
Subsystem 6 - Part No SW: ----------- HW: 480 400 107 15
Serial number: 3520002C71B65D5293CC
Subsystem 7 - Part No SW: ----------- HW: 480 400 107 15
Serial number: 3550002AF1C52F33D3FQ
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:23
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150716400358
Coding: 0E10
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDB46AAF7FDAE62169-806A
B1149 13 [00001001] - Open Circuit
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:23
Ubat 30 Voltage: 11.30 V
Ignition State: On
Terminal 15: 10.50 V
A/D #1: 97.65 %
A/D #2: 20.78 %
A/D #3: 0.00 %
Address 17: Instruments
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 D HW: 5QE 907 530 A
Component: GW MQB EV 312 3226
Revision: -------- Serial number: 07071510803121 Dataset Number: 3G0067V____ 2213
Coding: 0A0300172EF21000FB00527EDC1F00000001070100010000000300000000
Shop #: WSC 00046 000 00000
GVL: 01543C1800000608D0CC90008002CC1810040000000000000000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 47CB5E4AAF2DE6A2AE9-8012
Subsystem 1 - Part No SW: 1EA 959 442 F HW: 1EA 959 442 F
Component: MFL H50 0420
Serial number: 17044958021322101219
Coding: 2F0000
Subsystem 2 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 1353037003
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0098894
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
131707 - No Communication with HV Battery Energy Control Module
U0112 00 [00001000] - -
[Timeout Knoten 0x7B / 8C - Steuerger t f r Batterieenergiemanagement Hybrid]
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 13:20:00
Terminal 30 power supply: 11.2 V
Terminal 15: On
Address 23: Brake Booster (J539) Labels:| 5QE-909-059.clb
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010458
Coding: 05720100431900000002060500
Shop #: WSC 05311 115 00106
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003.rod
VCID: 4FFB766A475D3EE2E69-801A
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861070715204358
180736 - Implausible Data Received from Engine Control Module
U0401 00 [10101111] - -
[iBoVAG_DT_GeneratorFailure]
Mileage: 247162 km
Date: 2024.01.05
Time: 15:39:33
239616 - Implausible Data Received from Engine Control Module
U0401 00 [00101111] - -
[iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:30
154624 - Implausible Data Received from Engine Control Module
[iBoVAG_Scl_Motor_EV_02_TS_Istmoment_Error]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:26
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000065482013
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BFD092F1290812D0D-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: -------- Dataset Number: V03935220RD 0001
Coding: 14C002
Shop #: WSC 05311 115 00096
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
ROD: EV_RearRadarS1BoschVW48X_VW37.rod
1188165 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Control Module temperature: 25 C
Voltage terminal 30: Measuring value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measuring value not available
Voltage terminal 15: 11.10 V
1192062 - Databus
[databus error value received - PH_Systemzustand]
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 13:22:57
Control Module temperature: 15 C
Voltage terminal 15: 10.80 V
1192264 - Databus
[databus error value received - PH_Tongeber_H_verfuegbar]
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 13:22:57
267010 - Databus
[FAULT_SLAVE]
Fault Frequency: 9
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Component: TSG FS 020 0041
Serial number: 300615BFS01972 Dataset Number: V03935256EF 0001
Coding: 003F1E208000028000001000
VCID: 43D34A5A9B15CA82721-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000315223 Dataset Number: 3G0074V____ 0137
Coding: 01010011005101
Shop #: WSC 00015 115 00300
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3B2332BAE3E5B2423A1-806E
5262656 - Steering Angle Sensor
B1168 F2 [10001001] - Not Initialized
Fault Frequency: 9
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Write only channel
Address 51: Electric Drive (J841) Labels: None
Part No SW: 3G0 907 080 E HW: 3G0 907 080 B
Component: LE Gen 3.3H07 0072
Revision: 00H07000 CVN: 04828BC0
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530113G0907080E 001017
ROD: EV_DMCM08530113G0907080E.rod
VCID: 270BFECA0F6D06A24E9-8072
31801 - No Communication with Battery Energy Control Module
U0111 00 [00101110] - -
Mileage: 247162 km
Date: 2024.01.10
Time: 13:19:57
Voltage terminal 30: 11.027 V
Drive control condition: DisCharge
Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 13
31805 - No Communication with Battery Energy Control Module
Mileage: 247162 km
Date: 2024.01.10
Time: 13:19:58
Voltage terminal 30: 11.025 V
31809 - No Communication with Battery Energy Control Module
Mileage: 247162 km
Date: 2024.01.10
Time: 13:19:58
31813 - No Communication with Battery Energy Control Module
Mileage: 247162 km
Date: 2024.01.10
Time: 13:20:02
Voltage terminal 30: 10.976 V
Component: TSG BFS 020 0041
Serial number: 030715BG302219 Dataset Number: V03935256ZD 0001
Coding: 003F10208000028000001000
VCID: 42DD4F5E840FC38A797-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 039202004F210200
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0373684848 Dataset Number: 0G0124v____ 0016
Coding: 0100000202000000
Part No SW: 5Q0 907 556 HW: 5Q0 907 556
Component: Areaview 2 H11 0329
Serial number: C854706JG001492 Dataset Number: 3G0525v__B_ 2002
Coding: 01840201E70F200000204814
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
VCID: 76B5E38E98472F2A05F-8022
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Dataset Number: V03935222LG 0001
Coding: 028472011082BA0300F800000000
Shop #: WSC 05311 115 00300
ROD: EV_OCULowMQB.rod
VCID: 44D149469E1BCDBA4BB-8010
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 3G0 919 608 HW: 3G0 919 608
Component: HeadupDisplay 029 0152
Coding: 474060
ASAM Dataset: EV_HeadUpDisplContiVW481 001010
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 6B83C2FAD305E2C2EA1-803E
Address 8C: HV Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 3Q0 915 227 P HW: 3Q0 915 227 K
Component: K8C H05 0520
Serial number: 11061512010079 CVN: 8BE8FA63AB6334CEDC659A657E764ED97E764ED97E764ED97E764ED97E764ED9
ASAM Dataset: EV_BECM09620213Q0915227P 002009
ROD: EV_BECM09620213Q0915227P.rod
Battery interrupt switch:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000022061512010130
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0442
Serial number: 15506ZKK311A01030013
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0442
Serial number: 15510ZKK311A01030171
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0442
Serial number: 15513ZKK311A01030951
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0442
Serial number: 15512ZKK311A01030036
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0442
Serial number: 15511ZKK311A01030073
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0442
Serial number: 15506ZKK311A01030092
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0442
Serial number: 15506ZKK311A01030021
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0442
Serial number: 15510ZKK311A01030049
10 Faults Found:
28810 - High Voltage Service Disconnect
P0B33 00 [00100111] - Malfunction
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:25
Voltage terminal 30C: 0.200 V
Current of H-V / hybrid battery: 0.000 A
30175 - Battery Control Module 1
U01A0 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_01_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30178 - Battery Control Module 2
U01A1 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_02_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30181 - Battery Control Module 3
U01A2 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_03_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30184 - Battery Control Module 4
U01A3 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_04_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30187 - Battery Control Module 5
U01A4 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_05_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30190 - Battery Control Module 6
U01A5 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_06_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30193 - Battery Control Module 7
U01A6 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_07_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
30196 - Battery Control Module 8
U01A7 00 [00100110] - No Communications
[Diag_C_IBUS_CMC_08_UZ_TO_E2E]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
28736 - Battery Control Module 8
[Diag_C_IBUS_CC7_CALID_CVN_TO]
Mileage: 247162 km
Date: 2024.01.10
Time: 12:34:51
Part No SW: 3Q0 980 653 E HW: 3Q0 980 653
Component: MQB_B_MFK H08 0121
Serial number: 060715null0792 Dataset Number: V03935253RM 0001
Coding: 00040802070004010022234FC050A100980084300040
1135140 - Databus
[APS_03_US_Fehler_HS]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
Control Module temperature: 30 C
Outside temperature: 4.5 C
System run time: 1156.9 s
Voltage terminal 15: 11.1 V
mid: 02 65
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 1
Software_Info_3: 2
Software_Info_2: 1
Software_Info_1: 0
1135139 - Databus
[APS_03_US_Fehler_VS]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
mid: 02 64
Software_Info_4: 1
Software_Info_3: 2
Software_Info_2: 1
Software_Info_1: 0
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
System run time: 1156.7 s
mid: 02 E0
Software_Info_4: 1
Software_Info_3: 2
Software_Info_2: 1
Software_Info_1: 0
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 150625200437
VCID: 698FB8F2D9F9F0D298D-803C
Component: TSG HFS 020 0041
Serial number: 250615BFO11996 Dataset Number: V03935256XR 0001
Coding: 000E10200100028000001000
Shop #: WSC 00085 002 1048576
VCID: 45D754429521F4B25C5-8010
Component: TSG HBFS 020 0041
Serial number: 250615BFO13545 Dataset Number: V03935256NT 0001
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 M HW: 5QE 915 682 M
Component: OBC KOSTAL H22 4006
Revision: -------- Serial number: 1707150FN0001Z Dataset Number: 3GEJR1V____ 0006
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
ROD: EV_OBCSinglPhaseKLOMQB11P.rod
VCID: 57EB8E0A7F8D76223E9-8002
13705483 - Databus
[BMS_HYB_02_TimeOut]
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 13:19:58
2097152 - Battery Management
P33EB 00 [00001000] - Read Event Memory
Reset counter: 24
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:26
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: V03935218DJ 0001
Coding: 208040748202
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 B HW: 3Q0 907 590
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
ROD: EV_RearRadarS2BoschVW48X_VW37.rod
VCID: 34311986CEBB7D3AFBB-8060
1188165 - Databus
Reset counter: 239
Mileage: 247162 km
Date: 2024.01.10
Time: 12:33:24
End----(Elapsed Time: 02:56, VBatt start/end: 11.4V/11.1V. VIgn 11.1V)-----
