VW Transporter T5.2/T5GP Mirror Fold on Lock
   #21
claitero
C?ID=240949
How do you enable Needle sweep/staging on a transporter?
   #22
Adam87
C?ID=153293
This is done under indicator celebration in instrument cluster.
Is there no possible way to find out mirror fold on lock, polo coding does not work, they retrofit t5/6 bcm's into polos and it still works so must only be down to door modules and coding?
   #23
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I do have a T6 on order, once it's here I'll do some more testing - depending on the findings the results may be applicable to the T5GP/T5.2
   #24
Adam87
C?ID=153293
any news on this yet sebastian?
regards
   #25
JS3
C?ID=240511
Hi Guys - been away from this for a while. Any progress? Thanks.
   #26
Adam87
C?ID=153293
Byte 2 Bit 1 in each door module, then redo basic settings for windows
Sorted 😉
   #27
JS3
C?ID=240511
Hi Adam - can you elaborate a bit further? What do you change byte 2 bit 1 to? And what do you alter in basic settings? Can you tell me your coding? Thanks.
   #28
rod_vw
C?ID=30904
I'm watching for the answer too.
Rod
   #30
JG A3 8V
Belgium
C?ID=274534
would love to try this on my 2013 Transporter too.
   #31
Danners74
C?ID=273244
Im looking to retro fit folding mirrors on a T5 GP. Has any body done this?
Also any news on this folding mirrors on lock,as im looking to get this working on our T6 Kombi DSG highline.
The needle sweep.....is that where the needles sweep when turning the ignition on.....done via instrument cluster?????
Regards Danners.:thumbs:
   #32
Danners74
C?ID=273244
Bumpety bump
   #33
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Adam, can you elaborate on this? I tested this and can NOT confirm it's working. What model/module did you try this on?
FWIW: With Byte 02 Bit 1 active, the Window Regulators are blocked/off with Ignition OFF (but S-Contact ON). ;) I did manage to find some more time to play and I believe I found the meaning of a few bits and fixed the differentiation between the individual control module variants - won't help with this problem yet, though there's gonna be a more appropriate label file included in the next update.
Danners74
C?ID=273244
Any news on yet Sebastian?
   #36
nickdaw
C?ID=180250
Ive got my T6 mirrors to fold on the key now thanks to Adam and the T6 forum
all I changed was the 1500B1 to 1500B3 and 0400A1 to 0400A3
then you have to reset the one touch window switches, :cool:
you have to hold the lock button on key for a second or so longer for the mirrors to fold, then they unfold when you turn the ignition on
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 334150793
Coding: B9F479384A63349193284F646EEB9EF48DA0718960CC6D603204003F0800
Shop #: WSC 02737 534 134075
VCID: 68DFD5C49B54270141-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 071215 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU017111553216158
Coding: 1500B1
Subsystem 3 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU018111553222604
Coding: 0400A1
nickdaw
C?ID=180250
The folding on lock with the key works now!
   #38
Sebastian
Magdeburg, Germany
HN0-nnnnnn
nickdaw, what position is your mirror switch in when you do this? As I wrote earlier, flipping that bit has a completely different effect on mine.
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 14416XXXX
   Coding: A0AA393A0A69349293280F606CEB8F74C0B4738960CD79703304023F0860
   Shop #: WSC 02737 534 105168
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU01905166140XXXX
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 N    HW: 7E0 959 802 N
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU01105166132XXXX
   Coding: 1400A1
   #39
nickdaw
C?ID=180250
my mirror fold works with button switched to the left or right mirror
I see your modules have the letter N as mine have the letter L, I wonder if that has any thing to do with it?
   #40
Danners74
C?ID=273244
Coding: 0228EE
Coding: 1500B1
Coding: 0400A1
hmmmmmm very interesting i have part numbers with Q's on our T6. Im very intrigued if this will work on ours. How do you get into the separate control units??? I.E. J386 and J387 door control modules?
Regards Danners.
