VW Transporter T5.2/T5GP Mirror Fold on Lock
   #41
Danners74
C?ID=273244
Also Sebastian Nickdaw here is the scan for the T6 Saturday,21,January,2017,08:52:40:44004
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
Dealer/Shop Name: Victoria Volkswagen.
Workshop Code: 210 01843 000002
VIN: WV1ZZZ7HZHH100226 License Plate: T6 KOMBI
Mileage: 290km-180mi Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 55 5F 61 69 0B
VIN: WV1ZZZ7HZHH100226 Mileage: 290km-180miles
Address 01: Engine (2D2D2-CXHA) Labels: 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 00254014433501090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: N/A
VCID: 7CF049BBF74083A1BF-8028
No ASAM data for: "EV_ECM20TDI03004L906056KG" (VN75)
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01
ROD: EV_TCMDQ500021_VW41.rod
VCID: 3D7684BFACDA4AA9C8-8068
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 43466000000738
Coding: 307E40986562847E0C770278A68821D3790000
Shop #: WSC 02739 790 50316
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 3F8AFEB7A6D658B9DA-806A
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Reset counter: 45
Mileage: 209 km
Date: 2017.01.13
Time: 11:41:31
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 29111613470765
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF443B3E15C91B191-802A
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaticT5.rod
VCID: 6BD27AE7822E141926-803E
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 343160625
Coding: A0FC793A0A61341193284F606CEB8FF4C084738960CD79603204003F0860
Shop #: WSC 02737 534 1731640
VCID: 2A5CBFE34554CD119D-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 291116 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 Q Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU023111663284791
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU023111663285865
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 27160003205930026485
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32961631000602
Coding: 118108
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K.rod
VCID: 4382F247CA3E3C59BE-8016
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V30033NS8
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A7C8FA3BDF47D91ED-806E
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Coding: 440F010300
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042307
VCID: 68D805EB9BD83F014B-803C
Component: IMMO H03 1104
VCID: 6ADC7FE38DD40D115D-803E
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Coding: 0FCE020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0359
Serial number: VWZAZ2S5405101
Coding: 065700013C00000011111101008808001F0100C6002001004F
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 234252C72A7E1C59DE-8076
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 75410903001609190982
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 44
Date: 2017.01.11
Time: 17:32:21
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000424409154
Coding: 410D000103000000
VCID: 326CA7836D8485D125-8066
End-------------------------(Elapsed Time: 03:43)--------------------------
Saturday,21,January,2017,08:54:30:44004
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KG HW: 04L 907 445
Component and/or Version: R4 2.0l TDI H02 3771
Software Coding: 00254014433501090000
Work Shop Code: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004 (VN75)
ROD: N/A
Readiness: N/A
   #42
nickdaw
C?ID=180250
Hi Danners I have just tried a mates T6 with the same Modules as yours, sorry to say it didn't work.
Im sure some one will work it out for the newer Q modules keep your eyes on the forum
   #43
Danners74
C?ID=273244
Ok perhaps you could let me know how to get into the door control modules through 09 BCM so i can play myself, please
Regards Danners
   #45
rod_vw
C?ID=30904
I've tried the above changes on my T6 but still do not have the mirrors to fold.
Here's a scan before the changes...
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 064160179
   Coding: A0F4791A0A61349193284F606CAB9FF4C0A0738960CD79603204003F0820
   Shop #: WSC 02737 022 198728
   VCID: 68DB475A9B73BC0141-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 080316 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU024021660551791
   Coding: 1400B1 [COLOR="#0000CD"](Changed to B3)[/COLOR]
   Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU023021660544173
   Coding: 0400A1 [COLOR="#0000CD"](Changed to A3)[/COLOR]
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Serial number: 29160000319760106064
   Coding: A4FFFF
Anyone any more ideas?
Rod
   #46
nickdaw
C?ID=180250
make sure you reset the one touch window switches after the coding, you have to hold the lock on the key for a second or so,
and you have comfort open/closing set on the windows.
Then all should be good,
dont take this the wrong way-you do have power folding mirrors to start with?
Adam87
C?ID=153293
It seems (so far anyway) that only 'L' revision modules con be coded to enable mirror fold via key fob.
Coding is just changing the last digit to a '3' (presuming electric folding mirrors from factory)
Also, 'comfort closing' in the BCM (09-cent. Elec) needs to be enabled.
It seems the different software revisions between the door modules is why it works for some and not others
And as already stated, mirror fold will NOT work unless window limits has been readapted (one touch up/down control)
   #48
sazimam
Czech Republic
C?ID=217645
Just an opinion here : recently I had a few T5s here with a complaint to a poor radio reception. The reason was the mirror antennas for tuner 1 and 2 cables damaged due to folding the mirrors.
Maybe this poor design with antenna wires was the reason to disable the auto-fold feature ... :rolleyes:
Sebastian
Magdeburg, Germany
HN0-nnnnnn
There's been a repair kit (or at least instructions in a TSB/TPI) available for some time and if I remember correctly, the new kit/wires should not have that problem anymore.
   #50
JS3
C?ID=240511
Well done guys! (or more importantly) well done Adam87!
I can confirm that my mirrors now fold on lock (by holding the remote key a little longer for the comfort setting) and unfold by turning on the ignition. I have an 'L' revision module.
iOrange
Czech Republic
C?ID=232915
Hi, I`m little bit confused about folding mirrors. I would like to make it to my friend with LHD T5Gp 2011. Mirrors are already retrofitted but with modules 801A/802A...which doesn`t support folding on lock. BCM is 087F. What modules do you suggest to make it work. I also planning upgrade of BCM to 090D (not sure if 7H0 or 7E0...does it matter?)
Is it possible to make it work with latest modules 801N and 802R or there is some problem that is too new or something else? Thaaank you a lot guys!
   #52
dnoermann
C?ID=358118
7H0 or 7E0, they both work.
But don't upgrade to 090D (7E0) upgrade to 090C (7E0) see my post here: https://forums.ross-tech.com/index.php?threads/24174/post-212462
Folding Mirror workes with my T5.2 which i upgraded to 090C (7E0)
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Subsystem 2 - Part No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8652
Serial number: KU0KU008101300018609
Coding: 0400A1
Subsystem 3 - Part No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8652
Serial number: KU0KU002101300011203
Coding: 1400A1
   #53
iOrange
Czech Republic
C?ID=232915
Okay this configuration you have work as mentioned above...folding on lock and unfold after ignition/terminal 15 is on or somehow else? Do we know what else modules if I have problem to get 801J and 802J is good for me?
