Vcds live data
senna1
C?ID=231631
Hi All.
Using vcds on a 56 plate sdi engine caddy, when viewing in mbv i could not find the group for the egr valve, or Glow plugs, Normally i have seen glow plug information such as voltage etc on other Vw caddy vans maybe later model year,, i could see a few groups showing duty cycle but
no name for the group shown just duty cycle, So you cant see how or where is Egr info to view, also any field box's i looked at to see if any balloon no image of a balloon was shown, is this all down to label files, No advanced mvb this was greyed out.
Also i logged injectors here is the log,, why are two showing -readings. and what does that represent, in mg/str are two of them struggling to get fuel.
Tuesday,15,September,2015,13:24:12:46146
VCDS Version: 15.7.0.2 (x64)
Data version: 20150820
VIN:
Address 01: Engine (03G 906 016 HN)
13:23:46 Group 013
0.28 mg/str Inj. Quantity
-0.49 mg/str Inj. Quantity
-0.12 mg/str Inj. Quantity
0.35 mg/str Inj. Quantity
It would be much easier to try to answer this if we complete ID data from the ECU rather than just its part number and values from a measuring block. ;)
senna1
C?ID=231631
I've posted plenty of full autoscans if you check my posts. just did not think i would need to post this time, anyway just ask and i will supply, here is a auto scan for this vehicle
I know you need autoscans with vehicle of no label files to add to your list help,
Tuesday,15,September,2015,12:11:06:46146
VIN: WV1ZZZ2KZ7X132646   License Plate: HG56 ZCV
Mileage: 163200km-101407mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZ7X132646   Mileage: 163200km-101407miles
   Part No SW: 03G 906 016 HN    HW: 028 101 227 2
   Component: R4 2,0L EDC 0000SG  7361
   Revision: 12345678    Serial number: VWZ7Z0G7089476
   Coding: 0003031
   Shop #: WSC 35110 377 00157
   VCID: 76E3CAE201737F8E7F-8022
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -
                    Torque: 104.9 Nm
                    Voltage: 12.31 V
                    Temperature: 29.7°C
                    Temperature: 31.5°C
                    Temperature: 25.2°C
16787 - EGR Valve (N18)
            P0403 - 000 - Malfunction
                    RPM: 840 /min
                    Torque: 48.8 Nm
                    Duty Cycle: 18.7 %
                    Duty Cycle: 94.8 %
                    Absolute Pres.: 907.8 mbar
                    Temperature: 31.5°C
Readiness: 0 1 0 0 0
   Part No: 1K0 907 379 P
   Coding: 0017106
   VCID: 3F8D6FC66EC9FEC66C-806A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000007059886
   Coding: 00884F030004100047000000000000000008FB075C0001
   Shop #: WSC 35110 377 08192
   VCID: 6BD5EB964A31B26690-803E
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 020507 021  0501
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0E55C2
   Coding: 0012345
   VCID: 7DF1D5CE24452CD63E-8028
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 636 0070
   Coding: 0000002
   VCID: 73E5F3F612016AA658-8026
   Part No SW: 2K0 920 943 C    HW: 2K0 920 943 C
   Component: KOMBIINSTRUMENT VDD 1612
   Revision: V0003000    Serial number: VWZ7Z0G7089476
   Coding: 0016401
   Shop #: WSC 80093 222 69422
   VCID: 2B552B968AB17266D0-807E
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 82
                    Mileage: 153342 km
                    Time: 15:21:13
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 080507F1001794
   Coding: 1D0F014007007401
   VCID: 2F6D3F86BEA90E46FC-807A
   Component: IMMO            VDD 1612
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0930
   Coding: 0000560
   VCID: 387F04DA4BE7C9FEAD-806C
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 808A0C087F2D8405485A030010C0
   VCID: 000FAC3A53B7413E55-8054
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000560
   VCID: 397901DE70EDD0F652-806C
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0020200
   VCID: 2D51258EB4A57C56CE-8078
End-------------------------(Elapsed Time: 01:10)--------------------------
OK, but do you really think I should have to go digging for them? If you have one here somewhere, and you start a new thread to which it applies, management here would sincerely appreciate it if you would link to the post that contains the old Auto-Scan.
Anyway, as far as I can telll, no one has ever made a label file for that specific engine except our Danish distributor, and his is obviously in Danish, which I don't read very well at all.
Still extrapolating what's happening in Group 13 based on other, somewhat similar engines, is the ECU increasing or decreasing fuel on a cylinder-by-cylinder basis to smooth the idle. On cylinders 1 and 4 where the numbers are positive, it's adding a bit. On cylinders 2 and 3, it's taking away a bit.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Anyway, as far as I can telll, no one has ever made a label file for that specific engine except our Danish distributor...
Probably won't happen before the weekend but it's on the todo-list as 2nd in line and should be ready early next week latest.
senna1
C?ID=231631
Yes Uwe that is what i thought as neg on two of the 4, the reason i scanned the vehicle was in the mornings first start of the engine, i'm told it is a bit lumpy like the glow plugs are not all working, Then when scanned, although no mill light on, i had dtc for Egr N18, i changed the valve with another vehicle same pt numbers j0 etc except for the last 4 digits, no change in staring problem but as up to now no dtc for N18,, i checked the injectors, and you know the rest, not much else i could do without field box's info, only had a quick look at the vehicle will check it out when not so busy, any info mean while would be appreciated, also tested the glow plugs in the head all seem good, and took them out, visually look good, also regarding the injectors while at tick over rpm they look like 2 are getting less fuel as neg, also still happens as you hold the rpm higher, i could understand some engine when you lift off the throttle they switch off the injectors.
senna1
C?ID=231631
i assume it will be in English. as you write english. for the ross tech guys.
senna1
C?ID=231631
Hi Seb.
How you getting on regarding the label file,
senna1
C?ID=231631
when the label file is done, do i have a update for vcds.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I'll get back to you via email by the end of the day. :)
senna1
C?ID=231631
Hi Seb
I installed the file, and have emailed you.
senna1
C?ID=231631
Hi all
Here is a scan of the Egr Valve etc information after the update by sebastian, The vcds info i have, there are two lots of Egr duty cycle info, Exhaust Gas Recirc. Duty Cycle group 041. of 95.6 % and group 003 of 5.6 % Exhaust Gas Recirc. Duty Cycle why is this, plus i have 19.1 % Position (Spec.) Intake Flap,, Is this the run on valve anti shudder, or the Egr valve itself opening Level.
Tuesday,29,September,2015,13:37:53:46146
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: License Plate:
13:37:09
185.0 mg/str Exhaust Gas Recirculat. (spec.)
185.0 mg/str Exhaust Gas Recirculat. (actual)
861 /min Engine Speed (G28)
78.3°C Coolant Temperature (G62)
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
195.0 mg/str Mass Air Flow (actual)
95.6 % Exhaust Gas Recirc. Duty Cycle
