A6 C7 Missing Adaptation File 5F
d*n
C?ID=165828
Hi
I have an HEX-USB+CAN iterface and running the latest VCDS (23.11.0).
My car is an Audi A6 C7 Allroad 2016
When I go to make changes to the adaptations in module 5F, I do not get a list of channel numbers. Instead I get the full list of adaptations as per an adaptation map.
Am I missing a mapping file or is my car only partially supported by my interface?
Secondly when I select and attempt to change one of the adptations I get a Workshop Code rejected error (using default vlaues)
Extract from scan below.
Saturday,30,December,2023,10:40:19:15913
VCDS Version: 23.11.0.0
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 34 36 3B 42 44 46 52 53
          55 5F 62 69 6C 6D 72 AC 47
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 F    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   052 0670
   Serial number: A733A0J7530145 Dataset Number: 4G1909545F  0036
   Coding: 01754201FF0A000013111101000A00332F000AE7F1700100DF
   Shop #: WSC 28701 003 1048576
   VCID: 1D37E7EA0C8FE779C8-8048
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0175
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY805KGZ
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349PG5000KF
   Compact disc data bank:
   Component: Gracenote2---  --- 1013
That module uses the UDS protocol. The old numbered (0-255) Adaptation Channels no longer exist in modules like that.
You mean this?
Try [No] first. If that doesn't work, try [Yes]. If it still doesn't work, get back to us.
d*n
C?ID=165828
Thank you
When I attempted to change the adaptations this morning I didnt get the workshop error mesage and the change was accepted.
