VCDS DATA AND TERMINOLOGY
   #21
senna1
C?ID=231631
One more for you Uwe,, can vcds do engine ecu software update on a vw polo beat 2017 1.2 tsi Bosch med 17 .5.25
just been browsing the posts on here, and i see vcds does not do ecu or modules software updates,, at that date, unless things have changed
   #22
senna1
C?ID=231631
MQB ABS modules are usually an MK100 variant. Can they be coded? Yes, but the coding isn't 100% understood. See:
When i source a replacement as the vehicles is a Passat MQB platform i will let you know how i get on,
   #23
senna1
C?ID=231631
uwe, i have added the vin into my software i have for the MQB vw passat mk7 (B8 ) ABS module and i think you are correct it is coming up as a ABS
Teves, MK 100 UDS, RHD, do you know of any other vag vehicles that may share the same ABS module, so i have a wider range to search a for a second hand unit,
   #25
Pretty much every MQB based car has a Teves MK100, but there are a number of variants of this. I can only suggest consulting a proper parts catalog, either at a dealer, or something like PL24.
senna1
C?ID=231631
i will check vin with the main dealer see if any more info,,
senna1
C?ID=231631
The vehicle i managed to get the car started to prove that the original Engine ecu was not corrupted, but on replacing the original items i have a lot of problem with the original modules which did not previously have any , The main one is ABS module no or incorrect basic setting i have on other Vw replaced ABS module and coding etc,, But as this is MQB platform is it the same procedure to do Basic settings & coding as the coding has gone 000000000 lost
i have the original coding so bit of luck
Sunday,11,February,2024,15:05:13:51242
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZ6RZHY140146   License Plate:
Mileage: 133870km-83182mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 47 5F
VIN: WVWZZZ6RZHY140146   Mileage: 133870km-83182miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LH    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 3997
   Revision: R4H23---    CVN: 40819633
   Coding: 01110032232411080000
   Shop #: WSC 35281 006 1048576
   ASAM Dataset: EV_ECM12TFS01104E906027LH 001002
   ROD: EV_ECM12TFS01104E906027LH.rod
   VCID: 75BC8E3EF54DB4020C5-8020
   VINID: 9E69EAAAA1A2A98A4110004418AFAF356E
17158 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:01:49
                    Engine RPM: 0.00 /min
                    Coolant temperature: 39 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.298 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Mean injection time: 0.000 ms
                    Engine operating condition: Idle
18062 - Coolant Pump 2
          P261A 00 [00100000] - Open circuit
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:16:13
                    Engine RPM: 649.50 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 43 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 13.805 V
                    Mass flow through throttle valve: 8.5 kg/h
                    Mean injection time: 0.930 ms
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [00101111] - -
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:01:49
                    Voltage terminal 30: 12.250 V
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [00101111] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:01:51
                    Voltage terminal 30: 12.321 V
          U0428 00 [00101111] - -
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:01:49
                    selected gear-Bits 0-7: 0
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [01100101] - Incorrect Correlation
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:16:12
                    Engine RPM: 675.50 /min
                    Normed load value: 22.0 %
                    Voltage terminal 30: 14.182 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Brake actuated status-Bits 0-7: 0
                    Selector lever position-Bits 0-7: 0
                    Adaptation status of neutral position sensor-Bits 0-7: 4
                    Engine status: COENG_RUNNING
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08502192161111
   Coding: 0000000000000000000000000000000000000000000000000000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3E2E511280FB375A1DF-806A
0943 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
          [IISOEMCalibrationError]
                    Reset counter: 36
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:00:43
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [10001001] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:41
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
          [Scl_LWI_SensorNotCalibrated]
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:42
0887 - Control Module
          C104A F0 [00001000] - Incorrect VIN
                    Reset counter: 76
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:00:43
0883 - Control module not coded
          U1013 00 [10001001] - -
          [VehicleConfigUncoded]
                    Reset counter: 36
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 G    HW: 6C0 820 045 G
   Component: AC Manuell    H03 0204
   Serial number:  1610241B-1507 Dataset Number: 6C0032v____ 0012
   Coding: 200100001100100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 231880660B597AB2121-8076
262914 - Refrigerant Pressure
          B10AB F0 [00001101] - Too Low
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 01:41:48
          B10CD 00 [00001100] - -
          [Funktionseinschränkung durch Energiemangement]
                    Reset counter: 103
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:27:01
                    Voltage terminal 30: 12.0 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                    CAN input signal(s) status-Back-up lamp: OFF
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006308236183 Dataset Number: V03935245PJ 0001
   Coding: 030008404253005B0FA44080B10703C800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 31347A2E41A5D82290D-8064
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU012101662866882
   Coding: 1400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU011101662852825
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY162490RAR
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000067101403
   Subsystem 5 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU028101663024915
   Coding: 1400A0
   Subsystem 6 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU024101662987974
   Coding: 0400A0
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [00001000] - No Release by Immobilizer
                    Reset counter: 76
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:00:44
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 0
                    Voltage: 12.0 V
                    Outside temperature: 10.0 °C
266754 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F5 [00001000] - Supply Voltage too Low
                    Reset counter: 76
                    Mileage: 133869 km
                    Date: 2024.01.16
                    Time: 23:07:59
                    Terminal 15 status: OFF
                    OFF: Not operated
                    Voltage: 13.0 V
                    Outside temperature: 77.5 °C
   Revision: --------    Serial number: 39331631405883 Dataset Number: 6C0039v__A_ 0021
   Coding: 0031051001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 43D820E6EB195AB2721-8016
13637426 - Databus
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:41
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00C 002 VW20Airbag00C 002 03800380
   Revision: --------    Serial number: 003TH00D6ZX7 Dataset Number: 6C0003V____ 0583
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A265D029CD31B7A217-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 822 410 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A321F10F163CK
   Subsystem 2 - Part No: -----------
   Component: SideSensor_Pf
   Subsystem 3 - Part No: -----------
   Component: SideSensor_Dr
   Subsystem 4 - Part No: -----------
   Component: SideSensor_Pr
          B13BC F2 [10001001] - No function
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:01:24
          U1101 00 [10001000] - Active
          [ATP Wrong IKA]
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:42
   Part No SW: 6C0 920 940 G    HW: 6C0 920 940 G
   Component: KOMBI         202 2310
   Coding: 272409002180260001082A001000000000000000
   VCID: 2802974A727F99EA473-807C
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 63
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:03:54
9456433 - Key
          B104B 31 [00001000] - No Signal
                    Reset counter: 76
                    Mileage: 133870 km
                    Date: 2024.01.24
                    Time: 00:00:03
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006308236183 Dataset Number: 6C0067V____ 0046
   Coding: 030100046F0A560071000000000000010001010000000000000000000000
   GVL: 01443C0000000000400000000080480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 261E9972786B8F9A75F-8072
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 3041622222400030AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serial number: 63309522225881858669
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AJ    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  323 3242
   Serial number: CGBA1099 Dataset Number: V03935247PP 0001
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71B4BA2E81259822D0D-8024
1094656 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:41
   Part No SW: 5Q6 035 456     HW: 5Q6 035 456
   Component: KonzernAmp 8K H01 2426
   Revision: --------    Serial number: A1117A00005371 Dataset Number: 6C0050v____ 0003
   Coding: 0202000000AAAA00000000000000
   ASAM Dataset: EV_AMPCAN8C1PASE 001015
   ROD: EV_AMPCAN8C1PASE_VW26.rod
   VCID: 73B8B026FB39AA32221-8026
   Part No SW: 3Q0 035 842 B    HW: 3Q0 035 842 B
   Component: MU-S-D-ER     H30 0359
   Serial number: VWZAZ2S0637441 Dataset Number: V03935250ZU 0001
   Coding: 02620000AA00000051110103008808001F0110C60120010003
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2C0A6B5A6687B5CAA3B-8078
   Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
   Component: ABTm_Std2  H53 1031
   Serial number: VWZ8Z9SKW01UKM
15360768 - Component Protection
          U1101 00 [00001000] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 76
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:41
                    Voltage terminal 30: 11.9 V
          U1111 00 [00001001] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:44
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 63
                    Mileage: 139976 km
                    Date: 2023.02.03
                    Time: 00:26:44
End----(Elapsed Time: 01:23, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
AINils
Germany (AIB)
C?ID=56975
Only MQB-A1 and MQB-A2, but not MQB-A0 ;-)
  • Informative
senna1
C?ID=231631
   #31
AINils
Germany (AIB)
C?ID=56975
MQB-A0 is used for Polo based cars:
Ibiza, Fabia, Arona, Kamiq s.o.
MQB-A1 is for "mid-size" cars like Ateca, bu just difference in base plate of car, not in electrics
MQb-A2 is for "bigger" cars like Tiguan (Allsapce), an use biger base plate, but same electric as A1
senna1
C?ID=231631
OK as long as the electrics remain the same.
