Hi
i have posted on support but some of you guys maybe able to help.
Bottom line is i'm trying to see by the Data if the cam timing is correct
vw polo 1.2 2016/17 with correlation fault p0016 , I am told the cambelt has been replaced when checking this fault,, and the Phaser, & the small gauze filter.
I myself have changed the oil and the oil filter and wired the solenoid that controls the cam timing and i can hear it click, i have not checked The cam and crank sensor or the wiring see logged data first, with this post it looks like the cam sensor is working and i have rpm so i think the crank sensor is working plus the engine runs.
My question to support is some of the Vcds Terminology can you explain it's description starting with the 1st logged data, i can see the camshaft adjustment bank 1 intake says specified & actual which is a fault as not getting specified Degrees & IDE00182 Camshaft adaptation intake bank 1: phase position -15.67 ° ( looks like it is retarded )
& IDE00406 Camshaft RPM 356.5 /min looks like the cam sensor is working. The 2nd log data
I AM TRYING TO FIND OUT IF THE ENGINE CAMSHAFT TIMING IS NOT CORRECT BASED ON THE DATA LOGS DO THEY CONFIRM IT IS NOT CORRECT.
Regards
Thursday,28,December,2023,14:30:16:51242
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: License Plate: CAM SENSOR engine at IDLE
Mileage: 133866km-83180mi Repair Order:
Address 01: Engine (04E 906 027 LH)
14:30:00
IDE00019 Voltage terminal 30 14.583 V
IDE00178 Camshaft adjustment intake bank 1: specified value 38.344 °
IDE00179 Camshaft adjustment intake bank 1: actual value 22.000 °
IDE00187 Coolant temperature at engine start 60.8 °C
Address 0x01,04E 906 027 LH,UDS Basic Settings,IDE00749-Test of camshaft adjustment: intake
Thursday,28,December,2023,15:00:22:51242
This data log below some is as the first log, but can you explain & describe what vcds is saying i can see some of it is degrees but what is its actions
for example Crankshaft signal evaluation status GAPFOUND and the status - test program - channel 140 235.
IDE01665 Result of test of camshaft adjustment intake bank 1 Test off
IDE01665-ENG127298 Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140 235
IDE01928 Close cam shaft angle at quantity control valve 48.3 °
IDE01929 Open cam shaft angle at quantity control valve 63.6 °
IDE04670 Crankshaft signal evaluation: status GAPFOUND
IDE04670-ENG127292 Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE 7
IDE06759 Cam shaft adaptation inlet: counter 3
TEST AT IDLE VCDS
15:00:01
IDE00021 Engine RPM 614 /min
IDE00178 Camshaft adjustment intake bank 1: specified value 38.258 °
IDE00182 Camshaft adaptation intake bank 1: phase position -15.64 °
IDE00406 Camshaft RPM 319.5 /min
AND last data log below what is vcds describing
VIN: License Plate: VCDS FALSE TO CORRECT
14:48:43
IDE00021 Engine RPM 716 /min
IDE09925-ENG188621 Intake camshaft bank 1: adaption error cause-Bits 0-7 0
IDE09927 Intake camshaft bank 1: adaption hardware offset active False result
IDE09927-ENG127289 Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE 0
IDE09929 Intake camshaft bank 1: adaption value hardware offset active 16.297 °
IDE09932 Intake camshaft B1: adaptation value sensor tolerance 2.53 °
IDE10041-ENG188621 Intake camshaft B1 active operating state-Bits 0-7 0
IDE10043 intake camshaft bank 1 status adaption EPMCAS_STFULLADAP
IDE10043-ENG127372 intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE 4
14:49:17
IDE00021 Engine RPM 675 /min
ALSO i tried to do OUTPUT test for the cam intake bank 1 to see if on test it would advance and retard but VCDS says refused by control module message
7F 2F 7F Why is this refused.
Address 01: DTCs cleared
Address 0x01,04E 906 027 LH,UDS Selective Output Tests,IDE00227-Intake camshaft adjustment: bank 1
Regards
