- Jun 10, 2023
- 2,401
- 1,193
- Netherlands
- C?ID=547002
2018 November built, 2019 model
Engine running, on operating temperature. No fault codes nor functional complains with the vehicle. Measuring values:
AutoScan: VSSZZZ5FZK6528195
blockmap-01-05E-906-018-R_VSSZZZ5FZK6528195-20231223-1955.CSV
blockmap-02-0CW-300-041-S_VSSZZZ5FZK6528195-20231223-1956.CSV
blockmap-03-5Q0-614-517-DE_VSSZZZ5FZK6528195-20231223-1957.CSV
blockmap-05-3Q0-959-435-L_VSSZZZ5FZK6528195-20231223-1957.CSV
blockmap-08-5F0-907-044-AL_VSSZZZ5FZK6528195-20231223-1958.CSV
blockmap-09-5Q0-937-084-DD_VSSZZZ5FZK6528195-20231223-1958.CSV
blockmap-10-5QA-919-298-D_VSSZZZ5FZK6528195-20231223-1959.CSV
blockmap-13-2Q0-907-572-M_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-15-3Q0-959-655-BH_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-16-5Q0-953-521-LE_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-17-5F0-920-790-A_VSSZZZ5FZK6528195-20231223-1954.CSV
blockmap-19-3Q0-907-530-Q_VSSZZZ5FZK6528195-20231223-1954.CSV
blockmap-2B-3Q0-905-861-B_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-3C-5Q0-907-686-C_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-42-5Q4-959-593-F_VSSZZZ5FZK6528195-20231223-2000.CSV
blockmap-44-3Q0-909-144-M_VSSZZZ5FZK6528195-20231223-2001.CSV
blockmap-47-5Q0-035-456-A_VSSZZZ5FZK6528195-20231223-2001.CSV
blockmap-4B-3Q0-907-338-C_VSSZZZ5FZK6528195-20231223-2001.CSV
blockmap-52-5Q4-959-592-F_VSSZZZ5FZK6528195-20231223-2001.CSV
blockmap-5F-5F0-035-020-K_VSSZZZ5FZK6528195-20231223-2002.CSV
blockmap-65-5Q0-907-273-B_VSSZZZ5FZK6528195-20231223-2002.CSV
blockmap-69-5Q0-907-383-N_VSSZZZ5FZK6528195-20231223-2002.CSV
blockmap-6C-5Q0-907-556-C_VSSZZZ5FZK6528195-20231223-2003.CSV
blockmap-6D-5Q0-959-107-P_VSSZZZ5FZK6528195-20231223-2003.CSV
blockmap-A5-3QD-980-654_VSSZZZ5FZK6528195-20231223-2003.CSV
blockmap-CA-4K0-907-594-AC_VSSZZZ5FZK6528195-20231223-2004.CSV
blockmap-D6-7P5-941-591-AD_VSSZZZ5FZK6528195-20231223-2004.CSV
blockmap-D7-7P5-941-591-AD_VSSZZZ5FZK6528195-20231223-2004.CSV
blockmap-OBD_VSSZZZ5FZK6528195-20231223-2014.CSV
Saturday,23,December,2023,20:15:14:15566
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
Data version: 20231216 DS351.0
VIN: VSSZZZ5FZK6528195 License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 4B 52 5F
65 69 6C 6D A5 CA D6 D7
VIN: VSSZZZ5FZK6528195 Mileage: 131862km-81935miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 R HW: 05E 907 309
Component: R4 1.5l TFS H22 9832
Revision: 81H22000 CVN: 603F5A41
Coding: 012500322364050830000000000000000000000000000000
Shop #: WSC 00249 211 00000
ASAM Dataset: EV_ECM15TFS01105E906018R 003004
ROD: EV_ECM15TFS01105E906018R.rod
VCID: 343A71DA6EB8A34AFBB-8060
VINID: 9A38EAAAA156A9B1850880491446636279
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 041 S HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1694
Revision: 00005008 Serial number: CU501810238145 CVN: 6EAD7F32
Shop #: WSC 33361 790 00157
ROD: EV_TCMDQ200021_VW26.rod
VCID: 45DC3C1E35222AC25C5-8010
Part No SW: 5Q0 614 517 DE HW: 5Q0 614 517 AD
Component: ESC H25 0524
Revision: 00000000 Serial number: 63048000000247
Coding: 21EE6A92242224748778060962C82484562424E1604624733822F00442A2430B002D641212131A1E35351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 77A086D63F4E88521E9-8022
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0497344733 Dataset Number: V03935282HM 0002
Coding: 132C0C0707
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D822063B1614F2721-8016
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98337217
Part No SW: 5F0 907 044 AL HW: 5F0 907 044 AL
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 06000024200114011105004000101020
Shop #: WSC 33361 790 00113
VCID: 70B2BDCA5A20DF6ADF3-8024
Air quality sensor:
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001830600768 Dataset Number: V03935271LB 0006
ROD: EV_BCMBOSCH_019.rod
VCID: 7DAC94FE1D72A202445-8028
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21987728X81A955555A0
Coding: 80007E
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY182803LQA
Subsystem 3 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223981702090
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318299 Dataset Number: V03935268GQ 0009
Coding: 0A71267151
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_VW41.rod
VCID: 51F4184EF16AF662F0D-8004
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0233
Dataset Number: V03935272DT 0001
Coding: 320067CB5CFF8728749C8145804085
VCID: 3E2E53F250F4791A1DF-806A
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W4PNHFRR1 Dataset Number: V03935277CM 0002
Coding: 98CCC0C0000000005C5400CC000800000065
VCID: 055CFC1E75A2EAC21C5-8050
Subsystem 1 - Part No SW: ----------- HW: 454 001 710 18
Serial number: 3570000000041D205232
Subsystem 2 - Part No SW: ----------- HW: 454 001 610 18
Serial number: 3580000000090568623C
Subsystem 3 - Part No SW: ----------- HW: 454 802 110 18
Serial number: 35100F8C99816000000Y
Subsystem 4 - Part No SW: ----------- HW: 454 801 710 18
Serial number: 3520093739716000000C
Subsystem 5 - Part No SW: ----------- HW: 454 801 510 18
Serial number: 3550028B47316000000C
Part No SW: 5Q0 953 521 LE HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20181102400612
Coding: 6C14
ROD: EV_SMLSVALEOMQB.rod
VCID: 0052ED0A6A80CFEA2F3-8054
Part No SW: 5F0 920 790 A HW: 5F0 920 790 A
Component: KOMBI 609 1701
Coding: 04A45A9A6E8C00080188720F3001000080000000
Shop #: WSC 73430 031 00157
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 27009696AF6ED8D24E9-8072
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 04111810803282 Dataset Number: V03935262FX 0010
Coding: 030500F42F085700E90002D81C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00170
GVL: 015E3C0008000600C0CC80000002C80010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 3D2C54FE5DF26202045-8068
Generator:
Component: 1-00-03-00-04
Subsystem 2 - Part No SW: 5F0 959 537 D HW: 5F0 959 537 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1298180918
Coding: 012000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 758860020018102900EB
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000347353002
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333872C66BB6A472E21-8066
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0497114219 Dataset Number: V03935264SK 0003
Coding: 02012103
Shop #: WSC 57812 002 1048576
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0497687714
Coding: 020121
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000352727992 Dataset Number: V03935260YL 0006
Coding: 00351320D000020000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 48C2352A023037AAA73-801C
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000024912029
Coding: 210000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Dataset Number: V03935284GK 0001
Coding: 931F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C2A59FA46E86B0A33B-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD03EE3F Dataset Number: V03935232RY 0008
Coding: 3300000000A0AF8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001004
ROD: EV_AMPMst11CGen2ALPI_VW41.rod
VCID: 2E0E63B28094899A8DF-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 31101811602922 Dataset Number: V03935269SR 0004
Coding: 000000070900064201000940000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 353C4CDE65C2BA42CC5-8060
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000352588126 Dataset Number: V03935260YK 0007
Coding: 00351120D000020000001000
VCID: 47C036160F2E38D2AE9-8012
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000024873460
Coding: 390000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-HGH2.clb
Part No SW: 5F0 035 020 K HW: 5F0 035 020
Component: MU-H-ND-EU H55 1447
Serial number: A678J0JS010233 Dataset Number: V03935267HW 0010
Coding: 04230601000000001111010200880A232F0101E4012004009E
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 20128D8ACA402FEA0F3-8074
Subsystem 1 - Part No SW: 575 919 606 HW: 575 919 606
Component: ABT_High-2_N H41 1041
Serial number: SEZ8Z9V1S02GU4
Subsystem 2 - Part No SW: V03 959 820 JN HW: -----------
Component: ECE 2023/2024 --- 0330
Compact disc data bank:
Component: Gracenote2 --- 1017
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H06 0009
Serial number: 30000000558955 Dataset Number: v09600047P6 0204
ROD: EV_RDKBERU30_005.rod
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0497197695 Dataset Number: V03935204BM 0004
Coding: 0100000202000000
VCID: 42D62702240C1DFA797-8016
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG040272 Dataset Number: V03935257SF 0003
Coding: 06230601270FA00000606814
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_SK37.rod
VCID: 392440EE49DA5E2228D-806C
Part No SW: 5Q0 959 107 P HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0266
Revision: -------- Serial number: 32179370200000 Dataset Number: V03935245M0003
Coding: 1988
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 1272
Serial number: 29091841P13376 Dataset Number: V03935264HE 0004
Coding: 030307060000040000222355C150A90098000E200020
ROD: EV_MFKBoschMQBB_001_SE37.rod
VCID: 0842F52A42B0F7AA673-805C
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Dataset Number: V03935267LM 0003
Coding: 408040532602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75BC8CDE2542FA420C5-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EAE93F21074B91A5DF-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LEDPLUSRightKEBODVW416.rod
End----------(Elapsed Time: 10:12, VBatt start/end: 14.7V/13.1V)-----------
;SW:05E-906-018-R HW:05E-907-309 --- Engine
;Component:R4 1.5l TFS H22 9832, Coding:012500322364050830000000000000000000000000000000
;EV_ECM15TFS01105E906018R,003004,EV_ECM15TFS01105E906018R.rod
;Saturday,23,December,2023,19:55:52:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 343A71DA6EB8A34AFBB-8060
Group,Description,Actual
IDE00019,Voltage terminal 30,14.660, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,697, /min
IDE00025,Coolant temperature,92, °C
IDE00078,Time since engine start,1270, s
IDE00083,Throttle valve position (absolute),11.0, %
IDE00084,Absolute load value,16, %
IDE00085,Normed load value,24.7, %
IDE00086,Accelerator pedal position,15.3, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,21.4, Nm
IDE00102,Control Module temperature,37.1, °C
IDE00148,Mean injection time,0.6920, ms
IDE00151,Oil fill level,59.380, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,293.2, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-25.00, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.14, °
IDE00178,Camshaft adjustment intake bank 1: specified value,21.39, °
IDE00179,Camshaft adjustment intake bank 1: actual value,20.77, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.40, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.57, °
IDE00187,Coolant temperature at engine start,52.9, °C
IDE00188,Fuel high-pressure: actual value,16.968, MPa
IDE00190,Charge air pressure: specified value,280.70, hPa
IDE00191,Charge air pressure: actual value,1010.16, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,16.0, °C
IDE00194,Coolant temperature at radiator output: specified value,103.5, °C
IDE00196,Engine oil temperature,72.9, °C
IDE00201,High fuel pressure: specified value,16.970, MPa
IDE00202,Low fuel pressure: specified value,429.3, kPa
IDE00304,Fuel level,47.00, l
IDE00348,Intake air temperature,37, °C
IDE00349,Throttle valve position: normed,0.8, %
IDE00350,Air mass: specified value,6.2, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,75.8, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,0.60, l/h
IDE00375,Generator: load signal,51.54, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,763.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,373.4, mV
IDE00394,Camshaft position: start of phase window,38.45, °
IDE00406,Camshaft RPM,352.0, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00434,Particle filter: soot mass calculated,154, mg
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0)
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,6.1, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,19, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.009 Lambda / -0.012 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.095, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,0.8, %
IDE00584,Distance driven since erasing DTC memory,296, km
IDE00588,Fuel tank fill level,93.7, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,3.0, Degrees
IDE00594,Absolute intake pressure,28, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,2.3, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,9,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,23.1, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00003,
IDE00773,Terminal 15 status via CAN,1,
IDE01378,Fuel high pressure: control deviation,0.0020, MPa
IDE01385-ENG188621,Wear index-Bits 0-7,0,
IDE01386-ENG188621,Soot index-Bits 0-7,0,
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.090, V
IDE01650,Throttle valve position 2,11, %
IDE01774,Status misfire recognition,0,
IDE01869,Long-term fuel trim bank 1 at idle,0.23, %
IDE01873,Test of catalytic converter: measured value,7.1655,
IDE01876,Adaptation of loss torque,-0.7, Nm
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.9, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01888,Cold start enrichment: adaptation area 1,1.070,
IDE01889,Cold start enrichment: adaptation area 2,1.070,
IDE01890,Cold start enrichment: adaptation area 3,1.070,
IDE01891,Cold start enrichment: adaptation area 4,1.070,
IDE01892,Cold start enrichment: adaptation area 5,1.070,
IDE01893,Fuel pump: specified value,45.802, %
IDE01899,Load value: corrected specified value,65.09, %
IDE01901,Lost torque adaptation: idle,-0.7, Nm
IDE01902,Lost torque adaptation A/C compressor,-0.9, Nm
IDE01903,Lost torque adaptation driving mode,-4.8, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,-2.2, Nm
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01922,Vehicle distance driven,131862, km
IDE01923,Control module distance driven,131560694, m
IDE01928,Close cam shaft angle at quantity control valve,40.1, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,-0.070, MPa
IDE01932,High pressure pump injection volume,0.69, mm³
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,148,
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,215,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,86,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,97,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,38,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,124,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,71,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,3,
IDE02117,Relative load value,15.05, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,209.3, kPa
IDE02756,Number of manual engine starts,13996,
IDE02757,Number of automatic engine starts,23759,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,2281,
IDE03010-MAS01627,Number of prevented stop processes-Steering,5887,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,1,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,2,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,7199,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,2203,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,5,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,7,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,62,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,1518,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,14,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,12,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,364,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.514, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.475, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG188621,Adaptation status of neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3686.0, mV
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,0,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.255, m/s²
IDE03711,Mass flow through throttle valve,5.3, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,51.953, %
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,420.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.1, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,29.047, %
IDE03932,Charge pressure actuator: specified position,160.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3196.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00867,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge air pressure control,BP_A act:101.0, kPa
IDE04010,Engine torque: normalized,8.0, %
IDE04011,Nominal torque,250, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:16880/--- kPa,
IDE04044,Charge pressure control valve,WG_A cmd/act:---/100 % / WG_B cmd/act:---/--- %,
IDE04045,Exhaust gas pressure,EP1:103.68, kPa
IDE04083,Coolant temperatures,ECT 1:92 °C / ECT 2:94 °C,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,925.4, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,99.78, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-9.56, %
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3192.2, mV
IDE04410,Intake manifold pressure: specified value,280.78, hPa
IDE04604,Accelerator pedal travel,0.00, %
IDE04629,AVS operating condition,1,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04693,Increasing desired torque intervention of ESP,-54424.4, Nm
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04859-ENG112933,Brake booster pump activation condition-Bbkvp,0,
IDE04887,Powertrain target torque,29.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,8.3, Nm
IDE04937,Sensor for engine block temperature: raw value,92.8, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05215,EVAP valve diagnosis result correlation factor,0.00,
IDE05240-ENG188621,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG188621,A/C compressor release status-Bits 0-7,1,
IDE05332-ENG188621,Heat request from heater to thermal management-Bits 0-7,2,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,15.26, %
IDE05449,O2 sensor 2: B1: internal resistance limit,12466, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00073,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.99, °C
IDE05470,Cat converter oxygen storage capacity,428.2, mg
IDE05474,Main cat converter OSC age correction factor,0.75000,
IDE05479,Misfire recognition reference moment,5.324, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG188621,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05761-ENG121419,Nominal operating condition: partial engine operation-Bhmbs,0,
IDE05762-ENG121418,Engine operating status partial engine operation-Bhmb,0,
IDE05928,Fuel consumption since DTC memory last erased,9.346, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05950,Charge pressure control adaptation value 1,87.1875, hPa
IDE05951,Charge pressure control adaptation value 2,75.9375, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,95.625, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,37.8, °C
IDE06021,Intake air temperature before throttle valve: raw value,37.6, °C
IDE06039,Required RPM at idle speed,700.0, /min
IDE06040,High fuel pressure: regulator output value,0.0080, MPa
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,37,
IDE06045-ENG188621,Output diagnostic test status-Bits 0-7,0,
IDE06049,Pressure in brake booster: raw value,289, hPa
IDE06059,Particulate filter: oil ash mass,0.01, g
IDE06112-ENG188621,Test of cylinder deactivation-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0030930, V*ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0065598, V*ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0038109, V*ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0050423, V*ms
IDE06198-ENG188621,Tank vent valve: diagnostic status-Bits 0-7,160,
IDE06255,Vehicle lateral acceleration,-0.01, g
IDE06256,Vehicle lateral acceleration: raw value,-0.01, g
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.250, m/s²
IDE06567,Frequency counter deactivate start/stop function,3057,
IDE06568,Stop prevention by driver frequency counter,35455,
IDE06569,Frequency counter vehicle standstill,12543,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,73.3, °C
IDE06610,Frequency counter vehicle standstill with stop,27103,
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06758,Air mass since engine start,2.4725, kg
IDE06799-ENG188621,A/C compressor status: HW input-Bits 0-7,0,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,79.05, %
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06956-ENG188621,Driver-side belt buckle status-Bits 0-7,2,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,available.,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,available.,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,4.3, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,available.,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,94,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07078,AVS result of last switch-over: intake,10,
IDE07079,AVS result of last switch-over: exhaust,10,
IDE07164,Number injections,30976,
IDE07224-ENG188621,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG188621,Bit string for status of oil level-Bits 0-7,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG188621,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,57.04, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,56.84, %
IDE07550,Engine temp. management actuator: raw value,2756.4, mV
IDE07620-ENG188621,Status momentary default during stability intervention-Bits 0-7,0,
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG188621,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG188621,Cam piece counter position malfunction-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,2,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,1,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,3,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,2,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,1,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,3,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG188621,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG188621,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09925-ENG188621,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG188621,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-0.53, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-0.70, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-0.88, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,-0.31, °
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,63.6, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,131816, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,131816, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,5,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,3,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,76.6, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,130338, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,130277, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,2,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,91.7, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,128860, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,128846, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,2,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,90.5, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,127390, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,127318, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,2,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,90.0, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,125906, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,125826, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,2,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,93.6, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,124426, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,124336, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,2,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,104.4, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,122934, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,122841, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,2,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,113.5, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,121444, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,121345, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,2,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,107.9, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,119958, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,119952, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,2,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,117.0, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,118484, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,118461, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,2,
IDE10302,Time since engine start,1303.3, s
IDE10303,Integrated air masse at first engine start,2.4850, kg
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10580,Engine oil level: test method 1,66.1, %
IDE10581,Engine oil level: test method 2,66.9, %
IDE10582,Engine oil level: test method 3,0.0, %
IDE10633,Clutch protection function: reduced torque,3267.7, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,15.0, kPa
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,50, ml/mm
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,2,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,3,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,3652,
IDE11116,Start/stop driver request: counter internal-motor restart,2380,
IDE11203,Oil pressure setpoint,211.9, kPa
IDE11267,Oil level: max. value: relative,95.6, %
IDE11268,Oil level: min. value: relative,62.8, %
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,7,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,77,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,2,
IDE11330,Oil press. control valve: activation pulse duty factor,52.21, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11541-ENG188621,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11929,I share of PID control of fully variable oil pump,-0.68, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00003,
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12077-ENG188621,Position adapt. of outlet camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,1,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,890.0, mV
IDE12106,Temperature sensor for cylinder block,94.7, °C
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,-17.78, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-12.84, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,10.32, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,19.14, %
IDE12210,Particle filter: water mass,107.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000012,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,8160, mg
IDE13086,Particle filter: maximum soot build-up reached,9600, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2147483648,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13945,Mixture variations without lambda controller interference,0.00000,
IDE14152,Oil level: maximum value: compensated,17.792, mm
IDE14153,Oil level: minimum value: compensated,46.904, mm
IDE14534,Knock control: error status,0,
IDE14753,Particulate filter: loading stage,0,
IDE14755,Particulate filter: blockage ratio calculated: relative,39.2,
IDE14756,Particulate filter: blockage ratio calculated: absolute,0.0,
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,10.6, %
IDE14767,Particulate filter: soot load calculated,1.6, %
IDE80106,Analysis 106,00 03 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 C4 00 09 00 00 00 00 FF FF 64 2D 00 5B 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,47.0, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,258.8, °C
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,Correct result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,Correct result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16299,Heated oxygen sensor 1 probe 1: status dew point end,Correct result,
MAS16299-ENG127289,Heated oxygen sensor 1 probe 1: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16300,Heated oxygen sensor 1 probe 2: status dew point end,Correct result,
MAS16300-ENG127289,Heated oxygen sensor 1 probe 2: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16688,Throttle 1: bank 1: diagnostic value normed: leak detection,-0.0664,
MAS16835,Particle filter rate of blockage calculated,1.0156,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17189,Exhaust pressure sensor 1: raw value,1036.4, hPa
MAS17191,Characteristics cooling module: target position,57.04, %
MAS17192,Characteristics cooling module: upper mechanical stop,4561.4, mV
MAS17193,Characteristics cooling module: lower mechanical stop,463.2, mV
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG188621,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG157506-ENG188621,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG157507-ENG188621,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG157508-ENG188621,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG157509-ENG188621,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG188621,AVS_counter_error_debonce-Bits 0-7,3,
ENG121428-ENG188621,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG188621,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG188621,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG188621,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG168741,DTEV r p In Mnf Mes Estim,0.000, %/s
ENG247045,Engine Exhaust Flow Rate,6.4, kg/h
ENG151174,Engine Friction - Percent Torque,5.0, %
ENG157850,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG157851,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG157852,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG157513-ENG161258,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDay_Stop,23,
ENG157513-ENG161259,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDay_Strt,0,
ENG157513-ENG161260,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDurExtSti,0, s
ENG157513-ENG161261,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiHour_Stop,19,
ENG157513-ENG161262,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiHour_Strt,0,
ENG157513-ENG161263,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMinute_Stop,49,
ENG157513-ENG161264,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMinute_Strt,0,
ENG157513-ENG161265,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMonth_Stop,12,
ENG157513-ENG161266,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMonth_Strt,0,
ENG157513-ENG161267,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiScnd_Stop,30,
ENG157513-ENG161268,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiScnd_Strt,0,
ENG157513-ENG161269,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiYear_Stop,2023,
ENG157513-ENG161270,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiYear_Strt,2000,
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.12, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.12, g/s
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG158050-ENG188621,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG158051-ENG188621,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG158052-ENG188621,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG158155,Rba Io Sig Rtc st Diag Stop Count er,96,
ENG139760,Thr Vlv u Sens1 B1,0.559, V
ENG139761,Thr Vlv u Sens2 B1,4.430, V
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG158334,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG158335,Virtual_SigXSet_TiEngOff_tiDiagRef,104, s
ENG158336,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,1454, s
ENG158337,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8387153, s
ENG158338,Virtual_SigXSet_TiOff_tiStrtEnd_Off,1452, s
Elapsed Time: 00:44
;SW:0CW-300-041-S HW:0AM-927-769-E --- Auto Trans
;Component:GSG DQ200G2_M H05 1694, Coding:0014
;EV_TCMDQ200021,001001,EV_TCMDQ200021_VW26.rod
;Saturday,23,December,2023,19:56:40:15566
;VCID: 45DC3C1E35222AC25C5-8010
IDE00008,Software version,1694,
IDE00018,Voltage terminal 15,14.4, V
IDE00019,Voltage terminal 30,14.8, V
IDE00021,Engine RPM,700, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,683, /min
IDE00023,Transmission output speed,0, /min
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activating,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1042.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,33, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,14.8, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,39, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,40, °C
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,16.00, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,16.05, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,15.20, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,15.19, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,574.0, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,574.0, mA
IDE02784-ENG120853,Sub-transmission 1 Valve Current: actual value AD value-Current_Valve_Transmission_Part_1_Actual_AD_Value,1329,
IDE02785-ENG120854,Pulse duty factor of valve for partial transmission 1-Duty_Factor_Valve_Transmission_Part_1,2.4, %
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,573.1, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,573.0, mA
IDE02788-ENG120855,Sub-transmission 2 Valve Current: actual value AD value-Current_Valve_Transmission_Part_2_Actual_AD_Value,1186,
IDE02789-ENG120856,Pulse duty factor of valve for partial transmission 2-Duty_Factor_Valve_Transmission_Part_2,1.9, %
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-58.25, Nm
IDE02794-ENG120857,Actual position clutch 1 duty cycle factor 1-Clutch_1_Actual_Position_Duty_Factor_1,14.0, %
IDE02795-ENG120858,Actual position clutch 1 duty cycle factor 2-Clutch_1_Actual_Position_Duty_Factor_2,85.3, %
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,314.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,314.0, mA
IDE02798-ENG120859,Clutch 1 Valve Current: actual value AD value-Current_Valve_Clutch_1_Actual_AD_Value,608,
IDE02799-ENG120860,Duty cycle of valve for clutch 1-Duty_Factor_Valve_Clutch_1,0.3, %
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02803-ENG120861,Actual position clutch 2 duty cycle factor 1-Clutch_2_Actual_Position_Duty_Factor_1,14.6, %
IDE02804-ENG120862,Actual position clutch 2 duty cycle factor 2-Clutch_2_Actual_Position_Duty_Factor_2,84.7, %
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,290.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,292.0, mA
IDE02807-ENG120863,Clutch 2 Valve Current: actual value AD value-Current_Valve_Clutch_2_Actual_AD_Value,522,
IDE02808-ENG120864,Duty cycle of valve for clutch 2-Duty_Factor_Valve_Clutch_2,0.0, %
IDE02820,Transmission mileage,131118.1, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,60.00, bar
IDE02822-ENG120865,Pressure supply threshold 2-Pressure_Supply_Threshold_2,42.00, bar
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02826-ENG120866,Basic setting sequence index-Basic_Settings_Flow_Index,0,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02860-ENG120867,Status of basic setting data clutch travel pressure characteristic-State_Of_Basic_Adjustmentdata_Clutch_Controltravel_Pressure_Characteristic,2,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,181101,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,SSP,
IDE02862-ENG99175,Production data transmission-Kassel,H,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,R02,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,1257,
IDE02863-ENG120868,Specified position of gear adjuster A-Gearpositioner_A_Commanded_Position,28.82, mm
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,8.82, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,2659,
IDE02866-ENG120869,AD Value 2 of Actual Position of Gear Actuator A-Gearpositioner_A_Actual_Position_AD_Value_2,3018,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,731.9, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,732.0, mA
IDE02869-ENG120870,AD value of actual current of gear Solen.val. A-Gearpositioner_A_Valve_Actual_Current_AD_Value,1425,
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,52.2, %
IDE02871-ENG120872,Specified position of gear positioner B-Gearpositioner_B_Commanded_Position,-0.18, mm
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.20, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,2721,
IDE02874-ENG120873,AD Value 2 of Actual Position of Gear Actuator B-Gearpositioner_B_Actual_Position_AD_Value_2,1413,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,511.5, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,512.0, mA
IDE02877-ENG120874,AD value of actual current of gear Solen.val. B-Gearpositioner_B_Valve_Actual_Current_AD_Value,996,
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,47.3, %
IDE02879-ENG120876,Specified position of gear positioner C-Gearpositioner_C_Commanded_Position,-0.28, mm
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.30, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2728,
IDE02882-ENG120877,AD Value 2 of Actual Position of Gear Actuator C-Gearpositioner_C_Actual_Position_AD_Value_2,1371,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,521.3, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,520.0, mA
IDE02885-ENG120878,AD value of actual current of gear Solen.val. C-Gearpositioner_C_Valve_Actual_Current_AD_Value,1338,
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,50.3, %
IDE02887-ENG120880,Specified position of gear positioner D-Gearpositioner_D_Commanded_Position,28.66, mm
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,8.62, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,2696,
IDE02890-ENG120881,AD Value 2 of Actual Position of Gear Actuator D-Gearpositioner_D_Actual_Position_AD_Value_2,2781,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,747.8, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,749.0, mA
IDE02893-ENG120882,AD value of actual current of gear Solen.val. D-Gearpositioner_D_Valve_Actual_Current_AD_Value,1792,
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,16.1, %
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG122550,Stop process prevented-GE_StartStopp_Info,Stop release,
IDE03008-ENG122551,Stop process prevented-MO_StartStopp_Status,1,
IDE03008-ENG122546,Stop process prevented-Stopp-Verbot-Grund 1,not active,
IDE03008-ENG122547,Stop process prevented-Stopp-Verbot-Grund 2,not active,
IDE03008-ENG122548,Stop process prevented-Stopp-Verbot-Grund 3,not active,
IDE03008-ENG122549,Stop process prevented-Stopp-Verbot-Grund 4,not active,
IDE03008-ENG122552,Stop process prevented-Stopp-Verbot-Grund 5,not active,
IDE03008-ENG122553,Stop process prevented-Stopp-Verbot-Grund 6,not active,
IDE03008-ENG122554,Stop process prevented-Stopp-Verbot-Grund 8,not active,
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,0,
IDE03154-ENG120884,Set clutch default data: Status-Clutch_Default_Data_Setting_Status,3,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03157-ENG120885,Set clutch movemt. press. charac. curve def. data: status-Clutch_Controltravel_Pressure_Characteristic_Default_Data_Setting_Status,3,
IDE03159-ENG120886,Start clutch fast adaptation: Status-Clutch_Fastadaption_Starting_Status,0,
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03161-ENG120887,Clutch fast adaptation basic characteristics remaining number-Remaining_Numbers_Clutch_Fastadaption_Basic_Characteristic,0,
IDE03162-ENG120888,Clutch fast adaptation basic characteristics remaining mileage-Remaining_Km_Clutch_Fastadaption_Basic_Characteristic,0, km
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03166-ENG120889,Protective function temp. clutch 1 protect. level 2 number-Protective_Function_Temperature_Clutch_1_Protection_2_Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03170-ENG120890,Protective function temp. clutch 2 protect. level 2 number-Protective_Function_Temperature_Clutch_2_Protection_2_Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,129880.7, km
IDE03172-ENG100789,Driving Strategy Percentage Driving in D or S w/Cruise-Q003 Driving Time Ecological,99, %
IDE03173-ENG103567,Driving Strategy Percentage Driving in S w/o cruise-Q004 Driving Time Sporty,0, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,1, %
IDE03180-ENG103176,Number of standard trips-General Denominator,152,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,77,
IDE03189-ENG110524,Number of prevented stop processes (statistics)-Basic setting,not active,
IDE03189-ENG159578,Number of prevented stop processes (statistics)-Demontagestellung,not active,
IDE03189-ENG159577,Number of prevented stop processes (statistics)-Drucksensorausfall,not active,
IDE03189-ENG159579,Number of prevented stop processes (statistics)-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE03189-ENG110508,Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots,0.0, km
IDE03189-ENG159710,Number of prevented stop processes (statistics)-Motorstoppverbote Anzahl Stoppverbote,0,
IDE03189-ENG110525,Number of prevented stop processes (statistics)-Stop prohibition via application,not active,
IDE03189-ENG159576,Number of prevented stop processes (statistics)-Temperaturbedingung,not active,
IDE03189-ENG122385,Number of prevented stop processes (statistics)-unsortierte Gangsteller im Stand,not active,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,30, °C
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-63.80, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,0.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,1, km
IDE06244-ENG120895,Clutch 2: target position (mm)-Clutch_2_Commanded_Position_mm,0.0, mm
IDE06245-ENG120896,Clutch 1: adapt.: basic char.: uneven road surface recog-Clutch_1_adaption_basic_characteristic_active_rough_road_detection,7309,
IDE06246-ENG120897,Clutch 2: adapt.: basic char.: uneven road surface recog-Clutch_2_adaption_basic_characteristic_active_rough_road_detection,11842,
IDE06247-ENG120898,Clutch 1: target position (mm)-Clutch_1_Commanded_Position_mm,0.0, mm
IDE06281-ENG120909,Clutch 1: actual position (mm)-Clutch_1_Actual_Position_mm,1.5, mm
IDE06282-ENG120910,Clutch 2: actual position (mm)-Clutch_2_Actual_Position_mm,1.8, mm
IDE06283-ENG120908,Clutch 2: adaptation: clutch end position closed (mm)-Clutch_2_adaption_upper_stop_closed_mm,24.8, mm
IDE06284-ENG120907,Clutch 2: adaptation: clutch end position open (mm)-Clutch_2_adaption_upper_stop_open_mm,1.8, mm
IDE06285-ENG120911,Clutch 1 adaptation basic characteristics point 0 position (mm)-Clutch_1_adaption_basic_characteristic_point_0_mm,5.8, mm
IDE06286-ENG120912,Clutch 1 adaptation basic characteristics point 1 position (mm)-Clutch_1_adaption_basic_characteristic_point_1_mm,7.3, mm
IDE06287-ENG120906,Clutch 1 adaptation basic characteristics point 3 position (mm)-Clutch_1_adaption_basic_characteristic_point_3_mm,19.0, mm
IDE06288-ENG120899,Clutch 2 adaptation basic characteristics point 0 position (mm)-Clutch_2_adaption_basic_characteristic_point_0_mm,9.3, mm
IDE06289-ENG120900,Clutch 2 adaptation basic characteristics point 1 position (mm)-Clutch_2_adaption_basic_characteristic_point_1_mm,11.6, mm
IDE06290-ENG120902,Clutch 2 adaptation basic characteristics point 2 position (mm)-Clutch_2_adaption_basic_characteristic_point_2_mm,20.0, mm
IDE06291-ENG120901,Clutch 2 adaptation basic characteristics point 3 position (mm)-Clutch_2_adaption_basic_characteristic_point_3_mm,22.7, mm
IDE06292-ENG120903,Clutch 1: adaptation: clutch end position open (mm)-Clutch_1_adaption_upper_stop_open_mm,1.7, mm
IDE06293-ENG120904,Clutch 1: adaptation: clutch end position closed (mm)-Clutch_1_adaption_upper_stop_closed_mm,22.0, mm
IDE06294-ENG120905,Clutch 1 adaptation basic characteristics point 2 position (mm)-Clutch_1_adaption_basic_characteristic_point_2_mm,14.6, mm
IDE06425,Dynamometer mode: functional,not activated,
IDE10730-MAS11247,Clutch valves QPV engagement point current offsets-K1 QPV engagement point current offset low,61.3, mA
IDE10730-MAS11248,Clutch valves QPV engagement point current offsets-K1 QPV engagement point current offset high,42.2, mA
IDE10730-MAS11249,Clutch valves QPV engagement point current offsets-K2 QPV engagement point current offset low,59.0, mA
IDE10730-MAS11250,Clutch valves QPV engagement point current offsets-K2 QPV engagement point current offset high,39.1, mA
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,1,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,0,
IDE11208-ENG127895,Pressure supply: number of activation requests-Pressure supply number of switch on request,487330,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,131118.1, km
IDE13855-MAS17011,Clutch 1: unsteady friction value detector-Clutch 1 quantity of total detections (wet-cold oscillation),829,
IDE13855-MAS17013,Clutch 1: unsteady friction value detector-All driving with intervention on clutch 1,5635, km
IDE13855-MAS17015,Clutch 1: unsteady friction value detector-Clutch 1 maximum slippage,254.6, /min
IDE13855-MAS17017,Clutch 1: unsteady friction value detector-Clutch 1 vehicle-km-status during last active intervention,131850, km
IDE13856-MAS17012,Clutch 2: unsteady friction value detector-Clutch 2 quantity of total detections (wet-cold oscillation),156,
IDE13856-MAS17014,Clutch 2: unsteady friction value detector-All driving with intervention on clutch 2,231, km
IDE13856-MAS17016,Clutch 2: unsteady friction value detector-Clutch 2 vehicle-km-status during last active intervention,131550, km
IDE13856-MAS17018,Clutch 2: unsteady friction value detector-Clutch 2 maximum slippage,150.6, /min
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,13186, km
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1 Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,65535,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2 Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80067-ENG127857,Analysis 67-Snapshot 1 clutch 1 actual position,-41.0, mm
IDE80068-ENG127858,Analysis 68-Snapshot 1 clutch 2 actual position,-41.0, mm
IDE80069-ENG127859,Analysis 69-Snapshot 2 clutch 1 actual position,-41.0, mm
IDE80070-ENG127860,Analysis 70-Snapshot 2 clutch 2 actual position,-41.0, mm
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,3750311.5, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,3784709.8, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,2908751.9, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,398120.3, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,7149.5, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80078-ENG127867,Analysis 78-Temperature hybrid time in range 6,0.0, s
IDE80079-ENG127868,Analysis 79-Temperature hybrid time in range 7,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,91, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,9897999.8, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,939559.1, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,11202.5, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,282.4, s
IDE80085-ENG127874,Analysis 85-Clutch 1 temperature time in range 4,0.0, s
IDE80086-ENG127875,Analysis 86-Clutch 1 temperature time in range 5,0.0, s
IDE80087-ENG127863,Analysis 87-Clutch 1 temperature time in range 6,0.0, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,221, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,9514675.3, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,1309420.9, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,23290.5, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,1478.5, s
IDE80093-ENG127864,Analysis 93-Clutch 2 temperature time in range 4,179.3, s
IDE80094-ENG127865,Analysis 94-Clutch 2 temperature time in range 5,0.0, s
IDE80095-ENG127866,Analysis 95-Clutch 2 temperature time in range 6,0.0, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,279, °C
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,81702,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,192497,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,231714,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,193421,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,119947,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,60066,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,26331,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,22278,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,2796,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,502,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,1554,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,22,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,120,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,717,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,15,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,2109,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,26,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,82,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,3,
IDE80135-ENG163713,Analysis 135-Snapshot 1 freewheeling status,Freilauf inaktiv aber möglich,
IDE80136-ENG163714,Analysis 136-Snapshot 2 freewheeling status,Freilauf inaktiv aber möglich,
IDE80137-ENG167891,Analysis 137-Mode A FID event memory entry 1,FF FF,
IDE80137-ENG167892,Analysis 137-Mode A FID event memory entry 2,FF FF,
IDE80137-ENG167893,Analysis 137-Mode A FID event memory entry 3,FF FF,
IDE80137-ENG167894,Analysis 137-Mode A FID event memory entry 4,FF FF,
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,45.40, bar
IDE80261-ENG127834,Pressure supply: act. press.: AD value-Pressure supply actual pressure AD value,2572,
IDE80262-ENG127829,Pressure supply: spec. RPM-Pressure supply commanded speed,2192, /min
IDE80263-ENG127885,Pressure supply: act. RPM-Pressure supply actual speed,0, /min
IDE80264-ENG127836,Pressure supply: PWM pulse duty cycle-Pressure supply PWM duty factor,0.0, %
IDE80265-ENG127855,Pressure supply: act. current-Pressure supply actual current,0.0, mA
IDE80266-ENG127835,Pressure supply: spec. condition-Pressure supply commanded state,0,
IDE80267-ENG127877,Pressure supply: act. condition-Pressure supply actual state,15,
IDE80268-ENG127886,Pressure supply: number of start requests by E-motor-Pressure supply number of switch on request electrical oil pump,65535,
IDE80269-ENG127893,Pressure supply: last error condition of driver-Pressure supply last driver state,0,
IDE80270-ENG127887,Pressure supply: number of time-out errors-Pressure supply number of timeout errors,0,
IDE80271-ENG127888,Pressure supply: number of synchronization errors-Pressure supply number of synchronisation errors,0,
IDE80272-ENG127889,Pressure supply: number of overcurrent errors-Pressure supply number of overcurrent errors,0,
IDE80273-ENG127890,Pressure supply: number of remaining driver errors-Pressure supply number of remaining driver errors,0,
IDE80274-ENG127837,Pressure supply: max. runtime vs. serv.life-Pressure supply maximum duration over lifetime,17, s
IDE80275-ENG127891,Pressure supply: max. runtime during controlled mode-Pressure supply maximum duration in controlled operating mode,11, s
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,131862, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,0,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80281-ENG98675,Mechatronics identification DQ200-Construction version,A0,
IDE80281-ENG120772,Mechatronics identification DQ200-Endnummer,025,
IDE80281-ENG112382,Mechatronics identification DQ200-Index,K ,
IDE80281-ENG120774,Mechatronics identification DQ200-Lfd. Nr. pro Tag,0317,
IDE80281-ENG120775,Mechatronics identification DQ200-Linienkennung,V,
IDE80281-ENG120773,Mechatronics identification DQ200-production day,181101,
IDE80281-ENG120777,Mechatronics identification DQ200-Prüfzeichen,2,
IDE80281-ENG120776,Mechatronics identification DQ200-Ventilkennung,C,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,18.2, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,148.5, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,250.0, Nm
IDE80286-ENG127831,Clutch 1 Adaption clutch end position closed-Clutch 1 adaption upper stop closed,22.0, mm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,99.9, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,15.3, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,155.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,250.0, Nm
IDE80293-ENG127861,Clutch 2 Adaption clutch end position closed-Clutch 2 adaption upper stop closed,24.8, mm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,99.9, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,36836,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,131860, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,32904,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,131860, km
IDE80300-ENG127852,Friction energy: clutch 1-Clutch 1 frictional energy,000000088870, * 20 kJ
IDE80301-ENG127856,Friction energy: clutch 2-Clutch 2 frictional energy,000000085314, * 20 kJ
IDE80302-ENG122492,Selector lever information-Datenstand,19,
IDE80302-ENG111628,Selector lever information-Part Number,5Q1713023BG ,
IDE80302-ENG98856,Selector lever information-Programmability,0 ,
IDE80302-ENG122491,Selector lever information-Programm-Stand,VL ,
IDE80303-ENG127833,Overall software description-Software full name,U16,
IDE80305-ENG125922,Parameter set description-Data set name,0CW300041S_1694_OJAH,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
IDE80309-ENG127892,Pressure supply: max. error display during start request-Pressure supply maximum number of errors during switch on request,0,
IDE80310-ENG127838,Pressure supply: max. delay until transition to regular oper.-Pressure supply maximum delay until transition into controlled operating mode,0.2, s
IDE80311-ENG127851,Pressure supply: max. switch-on period for applicable range-Pressure supply maximum relative switch on duration over applicational window,0, %
IDE80312-ENG122524,CAN bus installation information-ACC_06,installed,
IDE80312-ENG122528,CAN bus installation information-BEM_05,installed,
IDE80312-ENG113024,CAN bus installation information-Charisma_01,installed,
IDE80312-ENG122522,CAN bus installation information-EPB_01,installed,
IDE80312-ENG122525,CAN bus installation information-GRA_ACC_01,not installed,
IDE80312-ENG122511,CAN bus installation information-TSK_06,installed,
ENG122362,Abbruchcode Grundeinstellung,0,
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,11, °C
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,80 04 2A 5C,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,80 04 27 40,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,80 04 12 F2,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,80 04 10 B4,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 30 00 1E,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,U16,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,13.2, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,13.2, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,26, °C
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Odometer reading,0, km
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,5,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,1,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,BB,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Odometer reading,655350, km
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Odometer reading,655350, km
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Odometer reading,655350, km
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Odometer reading,655350, km
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,A1 E1 28 CD,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,F2 D2 F8 57,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,6E AD 7F 32,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,70 A6 1F D7,
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG103186,Clutch center central plate temperature,40, °C
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,0.0, Nm
ENG100625,Coolant temperature,93, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,0.0, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,0.0, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,0.0, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,0.0, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,0.0, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,0.0, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,0.0, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,0.0, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG98602,Driver intention torque,2.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG122533-ENG122530,Druckversorgung Anlauf Historie 2-Druckversorgung Anlauf Historie Fehler-ID,0,
ENG122533-ENG122531,Druckversorgung Anlauf Historie 2-Druckversorgung Anlauf Historie Index,0,
ENG122533-ENG159829,Druckversorgung Anlauf Historie 2-Fehlertyp vor evtl. Abbruch,kein_Fehler,
ENG122533-ENG159825,Druckversorgung Anlauf Historie 2-Flag Druckniveau bei Motorstart,P <= 20 bar,
ENG122533-ENG159826,Druckversorgung Anlauf Historie 2-Flag minimale Spannung unterschritten,Umin >= 9V,
ENG122533-ENG159827,Druckversorgung Anlauf Historie 2-Max. Spannungseinbruch (indiziert) im Motorlauf,U <= 0.5V,
ENG122533-ENG159830,Druckversorgung Anlauf Historie 2-Relativer zeitlicher Abstand relativ zum Motorlauf,T <= 100ms,
ENG122533-ENG159828,Druckversorgung Anlauf Historie 2-Zustand vor evtl. Abbruch,Do not cancel,
ENG120789,Druckversorgung Anlaufadaption zurücksetzen Status,0,
ENG101251,Empty,Empty,
ENG98756,Engine torque,21.0, Nm
ENG104230,Engine torque loss,20.0, Nm
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG120792,Fahrzeug-km-Stand letzte Veränderung der Anlaufadaption,655350, km
ENG120780,Fehler EEPROM Lesefehler Bits 0...15,00 00,
ENG120781,Fehler EEPROM Lesefehler Bits 16...31,00 00,
ENG120782,Fehler EEPROM Lesefehler Bits 32...47,00 00,
ENG120783,Fehler EEPROM Lesefehler Bits 47...63,00 00,
ENG120799,Gangsteller A Adaption Flags,00 0F,
ENG100414,Gangsteller A Adaption Neutralposition,-0.6, mm
ENG120797,Gangsteller A Ventil adaptierter Mittenstrom,530.0, mA
ENG120798,Gangsteller A Ventil adaptierter Nulllagenoffset,-12.3, mA
ENG120801,Gangsteller Adaption Synchronposition G1 Abbruch ursache,00 B0,
ENG120800,Gangsteller Adaption Synchronposition G1 Abbruch zähler,24,
ENG120810,Gangsteller Adaption Synchronposition G2 Abbruch ursache,00 F4,
ENG120809,Gangsteller Adaption Synchronposition G2 Abbruch zähler,0,
ENG120803,Gangsteller Adaption Synchronposition G3 Abbruch ursache,00 F4,
ENG120802,Gangsteller Adaption Synchronposition G3 Abbruch zähler,0,
ENG120812,Gangsteller Adaption Synchronposition G4 Abbruch ursache,00 00,
ENG120811,Gangsteller Adaption Synchronposition G4 Abbruch zähler,0,
ENG120819,Gangsteller Adaption Synchronposition G5 Abbruch ursache,00 B4,
ENG120818,Gangsteller Adaption Synchronposition G5 Abbruch zähler,47,
ENG120828,Gangsteller Adaption Synchronposition G6 Abbruch ursache,00 F4,
ENG120827,Gangsteller Adaption Synchronposition G6 Abbruch zähler,0,
ENG120821,Gangsteller Adaption Synchronposition G7 Abbruch ursache,00 F4,
ENG120820,Gangsteller Adaption Synchronposition G7 Abbruch zähler,11,
ENG120830,Gangsteller Adaption Synchronposition GR Abbruch ursache,00 B0,
ENG120829,Gangsteller Adaption Synchronposition GR Abbruch zähler,255,
ENG126196-ENG126242,Gangsteller Ausbaulage-Zustand Welle 1 GS 13,1,
ENG126196-ENG126243,Gangsteller Ausbaulage-Zustand Welle 1 GS 57,N,
ENG126196-ENG126244,Gangsteller Ausbaulage-Zustand Welle 2 GS 24,N,
ENG126196-ENG126245,Gangsteller Ausbaulage-Zustand Welle 2 GS 6R,R,
ENG120786,Gangsteller Ausbaulage Status,0,
ENG120787,Gangsteller Ausbaulage Zustand / Abbruchcode,0,
ENG120808,Gangsteller B Adaption Flags,00 0F,
ENG100089,Gangsteller B Adaption Neutralposition,-0.2, mm
ENG120806,Gangsteller B Ventil adaptierter Mittenstrom,530.0, mA
ENG120807,Gangsteller B Ventil adaptierter Nulllagenoffset,-17.0, mA
ENG120817,Gangsteller C Adaption Flags,00 0F,
ENG103055,Gangsteller C Adaption Neutralposition,-0.3, mm
ENG120815,Gangsteller C Ventil adaptierter Mittenstrom,530.0, mA
ENG120816,Gangsteller C Ventil adaptierter Nulllagenoffset,-10.3, mA
ENG120826,Gangsteller D Adaption Flags,00 0F,
ENG101354,Gangsteller D Adaption Neutralposition,0.3, mm
ENG120824,Gangsteller D Ventil adaptierter Mittenstrom,530.0, mA
ENG120825,Gangsteller D Ventil adaptierter Nulllagenoffset,-2.2, mA
ENG120788,Gangsteller Defaultdaten setzten Status,3,
ENG120804,Gangsteller Einlegen Zähler G1,16166,
ENG120813,Gangsteller Einlegen Zähler G2,61425,
ENG120805,Gangsteller Einlegen Zähler G3,35106,
ENG120814,Gangsteller Einlegen Zähler G4,62349,
ENG120822,Gangsteller Einlegen Zähler G5,54411,
ENG120831,Gangsteller Einlegen Zähler G6,60066,
ENG120823,Gangsteller Einlegen Zähler G7,26331,
ENG120832,Gangsteller Einlegen Zähler GR,22278,
ENG126195-ENG126242,Gangsteller Neutral-Zustand Welle 1 GS 13,1,
ENG126195-ENG126243,Gangsteller Neutral-Zustand Welle 1 GS 57,N,
ENG126195-ENG126244,Gangsteller Neutral-Zustand Welle 2 GS 24,N,
ENG126195-ENG126245,Gangsteller Neutral-Zustand Welle 2 GS 6R,R,
ENG120784,Gangsteller Neutral Status,0,
ENG120785,Gangsteller Neutral Zustand / Abbruchcode,0,
ENG110510,Gear actuator adaption engaged position G1,8.8, mm
ENG110511,Gear actuator adaption engaged position G2,9.2, mm
ENG110512,Gear actuator adaption engaged position G3,-8.9, mm
ENG99484,Gear actuator adaption engaged position G4,-8.7, mm
ENG110513,Gear actuator adaption engaged position G5,9.6, mm
ENG110514,Gear actuator adaption engaged position G6,-8.1, mm
ENG110515,Gear actuator adaption engaged position G7,-8.4, mm
ENG110516,Gear actuator adaption engaged position GR,8.7, mm
ENG110517,Gear actuator adaption synchro position G1,2.4, mm
ENG110518,Gear actuator adaption synchro position G2,2.2, mm
ENG110519,Gear actuator adaption synchro position G3,-3.5, mm
ENG99198,Gear actuator adaption synchro position G4,-2.6, mm
ENG110520,Gear actuator adaption synchro position G5,2.6, mm
ENG110521,Gear actuator adaption synchro position G6,-2.2, mm
ENG110522,Gear actuator adaption synchro position G7,-3.2, mm
ENG110523,Gear actuator adaption synchro position GR,2.7, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung i.O.,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,17.128,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,10.000,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,6.455,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,4.483,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,3.340,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,2.667,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,2.239,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,16.408,
ENG99720,Height info,1013, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,21.0, Nm
ENG99582,Intake air temperature,38, °C
ENG122357-ENG122524,Kommunikationsstatus Datenbus 1 MQB-ACC_06,received,
ENG122357-ENG122528,Kommunikationsstatus Datenbus 1 MQB-BEM_05,received,
ENG122357-ENG113024,Kommunikationsstatus Datenbus 1 MQB-Charisma_01,received,
ENG122357-ENG122523,Kommunikationsstatus Datenbus 1 MQB-Diagnose_01,received,
ENG122357-ENG122522,Kommunikationsstatus Datenbus 1 MQB-EPB_01,received,
ENG122357-ENG122513,Kommunikationsstatus Datenbus 1 MQB-ESP_02,received,
ENG122357-ENG122514,Kommunikationsstatus Datenbus 1 MQB-ESP_05,received,
ENG122357-ENG110808,Kommunikationsstatus Datenbus 1 MQB-ESP_07,received,
ENG122357-ENG122515,Kommunikationsstatus Datenbus 1 MQB-ESP_10,received,
ENG122357-ENG122516,Kommunikationsstatus Datenbus 1 MQB-ESP_19,received,
ENG122357-ENG122517,Kommunikationsstatus Datenbus 1 MQB-ESP_20,received,
ENG122357-ENG122518,Kommunikationsstatus Datenbus 1 MQB-ESP_21,received,
ENG122357-ENG122519,Kommunikationsstatus Datenbus 1 MQB-Gateway_72,received,
ENG122357-ENG122520,Kommunikationsstatus Datenbus 1 MQB-Gateway_74,received,
ENG122357-ENG122525,Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01,Unknown,
ENG122357-ENG131312,Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01,Unknown,
ENG122357-ENG110802,Kommunikationsstatus Datenbus 1 MQB-Kombi_01,received,
ENG122357-ENG122521,Kommunikationsstatus Datenbus 1 MQB-Kombi_02,received,
ENG122357-ENG110799,Kommunikationsstatus Datenbus 1 MQB-LWI_01,received,
ENG122357-ENG122512,Kommunikationsstatus Datenbus 1 MQB-Motor_04,received,
ENG122357-ENG122502,Kommunikationsstatus Datenbus 1 MQB-Motor_07,received,
ENG122357-ENG122503,Kommunikationsstatus Datenbus 1 MQB-Motor_11,received,
ENG122357-ENG122504,Kommunikationsstatus Datenbus 1 MQB-Motor_12,received,
ENG122357-ENG122505,Kommunikationsstatus Datenbus 1 MQB-Motor_14,received,
ENG122357-ENG122506,Kommunikationsstatus Datenbus 1 MQB-Motor_16,Unknown,
ENG122357-ENG122507,Kommunikationsstatus Datenbus 1 MQB-Motor_17,received,
ENG122357-ENG122529,Kommunikationsstatus Datenbus 1 MQB-Motor_18,Unknown,
ENG122357-ENG122508,Kommunikationsstatus Datenbus 1 MQB-Motor_20,received,
ENG122357-ENG122509,Kommunikationsstatus Datenbus 1 MQB-Motor_26,received,
ENG122357-ENG137653,Kommunikationsstatus Datenbus 1 MQB-Motor_35,received,
ENG122357-ENG122510,Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01,received,
ENG122357-ENG122526,Kommunikationsstatus Datenbus 1 MQB-OBD_01,received,
ENG122357-ENG122511,Kommunikationsstatus Datenbus 1 MQB-TSK_06,received,
ENG122357-ENG122527,Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03,received,
ENG120833,Kupplung 1 Adaption Grundkennline P1 Abbruch Zähler,0,
ENG100960,Kupplung 1 Adaption Grundkennlinie Bereich 1 Abbruch Ursache,00 00,
ENG99364,Kupplung 1 Adaption Grundkennlinie Bereich 1 Abbruch Zähler,0,
ENG104076,Kupplung 1 Adaption Grundkennlinie Bereich 1 Fahrzeug-km-Stand,131862, km
ENG99297,Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG102029,Kupplung 1 Adaption Grundkennlinie Bereich 2 Abbruch Ursache,00 00,
ENG103907,Kupplung 1 Adaption Grundkennlinie Bereich 2 Abbruch Zähler,0,
ENG99304,Kupplung 1 Adaption Grundkennlinie Bereich 2 Fahrzeug-km-Stand,131862, km
ENG102630,Kupplung 1 Adaption Grundkennlinie Bereich 2 Schnelladaptionen verbleibende Anzahl,0,
ENG103806,Kupplung 1 Adaption Grundkennlinie Bereich 3 Abbruch Ursache,00 00,
ENG100083,Kupplung 1 Adaption Grundkennlinie Bereich 3 Abbruch Zähler,0,
ENG102504,Kupplung 1 Adaption Grundkennlinie Bereich 3 Fahrzeug-km-Stand,131853, km
ENG100314,Kupplung 1 Adaption Grundkennlinie Bereich 3 Schnelladaptionen verbleibende Anzahl,0,
ENG120834,Kupplung 1 Adaption Grundkennlinie P1 Abbruch Ursache,00 00,
ENG99148,Kupplung 1 Adaption Grundkennlinie P1 km-Stand,131861, km
ENG120835,Kupplung 1 Adaption Kisspoint Teil 2 Erfolgszähler,0,
ENG120836,Kupplung 1 Adaption Kisspoint Teil 2 Fahrzeug-km-Stand,655350, km
ENG120839,Kupplung 1 Adaption Kisspoint Teil 2 Fehler ursache,0,
ENG120838,Kupplung 1 Adaption Kisspoint Teil 2 Fehler zähler,0,
ENG120840,Kupplung 1 Adaption Kisspoint Teil 2 Fehlerursache kumuliert,0,
ENG120837,Kupplung 1 Adaption Kisspoint Teil 2 verbleibende Schnelladaptionen,0,
ENG120841,Kupplung 1 Adaption Kupplungsendlage Erfolgszähler,4727,
ENG120842,Kupplung 1 Adaption Kupplungsendlage Fahrzeug-km-Stand,131830, km
ENG120843,Kupplung 1 Adaption Kupplungsendlage Fehlerzähler,19,
ENG120793,Kupplung 1 Ventil adaptierter Mittenstrom,515.0, mA
ENG120794,Kupplung 1 Ventil adaptierter Nulllagenoffset,-17.1, mA
ENG120917,Kupplung 1 Weg des P1 aus der letzten Grundeinmessung,10.60, mm
ENG99330,Kupplung 2 Adaption Grundkennlinie Bereich 1 Abbruch Ursache,00 00,
ENG101409,Kupplung 2 Adaption Grundkennlinie Bereich 1 Abbruch Zähler,0,
ENG103271,Kupplung 2 Adaption Grundkennlinie Bereich 1 Fahrzeug-km-Stand,131862, km
ENG100826,Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG103246,Kupplung 2 Adaption Grundkennlinie Bereich 2 Abbruch Ursache,00 00,
ENG102885,Kupplung 2 Adaption Grundkennlinie Bereich 2 Abbruch Zähler,0,
ENG100753,Kupplung 2 Adaption Grundkennlinie Bereich 2 Fahrzeug-km-Stand,131862, km
ENG102173,Kupplung 2 Adaption Grundkennlinie Bereich 2 Schnelladaptionen verbleibende Anzahl,0,
ENG102648,Kupplung 2 Adaption Grundkennlinie Bereich 3 Abbruch Ursache,00 00,
ENG103978,Kupplung 2 Adaption Grundkennlinie Bereich 3 Abbruch Zähler,0,
ENG102303,Kupplung 2 Adaption Grundkennlinie Bereich 3 Fahrzeug-km-Stand,131859, km
ENG102820,Kupplung 2 Adaption Grundkennlinie Bereich 3 Schnelladaptionen verbleibende Anzahl,0,
ENG103369,Kupplung 2 Adaption Grundkennlinie P1 Abbruch Zähler,0,
ENG100946,Kupplung 2 Adaption Grundkennlinie P1 km-Stand,131862, km
ENG102345,Kupplung 2 Adaption Grundkennlinie P1 Zähler Abbruch Ursache,00 00,
ENG120844,Kupplung 2 Adaption Kisspoint Teil 2 Erfolgszähler,0,
ENG120845,Kupplung 2 Adaption Kisspoint Teil 2 Fahrzeug-km-Stand,655350, km
ENG120848,Kupplung 2 Adaption Kisspoint Teil 2 Fehler ursache,0,
ENG120847,Kupplung 2 Adaption Kisspoint Teil 2 Fehler zähler,0,
ENG120849,Kupplung 2 Adaption Kisspoint Teil 2 Fehlerursache kumuliert,0,
ENG120846,Kupplung 2 Adaption Kisspoint Teil 2 verbleibende Schnelladaptionen,0,
ENG120850,Kupplung 2 Adaption Kupplungsendlage Erfolgszähler,4039,
ENG120851,Kupplung 2 Adaption Kupplungsendlage Fahrzeug-km-Stand,131770, km
ENG120852,Kupplung 2 Adaption Kupplungsendlage Fehlerzähler,26,
ENG120795,Kupplung 2 Ventil adaptierter Mittenstrom,505.0, mA
ENG120796,Kupplung 2 Ventil adaptierter Nulllagenoffset,-24.6, mA
ENG120918,Kupplung 2 Weg des P1 aus der letzten Grundeinmessung,10.30, mm
ENG130280,Kupplung Adaption Kissp. max init. Beschleunigungsmoment Betrag,-0.5560, Nm
ENG120919,Laufzeit des Elektromotors,1259791.9, s
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,84.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,0, km
ENG123020-ENG102793,Rollwiderstand-Road Resistance,2.8, %
ENG102748,Selector lever error flags,00 00,
ENG101057,Specified idle speed,700, /min
ENG100803,Speed: output,0, /min
ENG122358-ENG122550,Start Stopp Statusinformationen aktuell-GE_StartStopp_Info,Stop release,
ENG122358-ENG122551,Start Stopp Statusinformationen aktuell-MO_StartStopp_Status,1,
ENG122358-ENG122500,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1,0,
ENG122358-ENG122501,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2,0,
ENG122358-ENG122546,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 1,not active,
ENG122358-ENG122547,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 2,not active,
ENG122358-ENG122548,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 3,not active,
ENG122358-ENG122549,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 4,not active,
ENG122358-ENG122552,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 5,not active,
ENG122358-ENG122553,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 6,not active,
ENG122358-ENG122554,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 8,not active,
ENG120790,Status Anlaufadaption,00 00,
ENG122360-ENG122542,Status der Sonderfunktionen-Launch Control,Funktion nicht freigegeben,
ENG122360-ENG103585,Status der Sonderfunktionen-Segeln,Funktion freigegeben,
ENG122360-ENG122543,Status der Sonderfunktionen-Speicherdruckabbau,Funktion freigegeben,
ENG122361,Temperatur Hybrid,30, °C
ENG123021-ENG123022,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 0,8300569.0, s
ENG123021-ENG123023,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 1,2451211.0, s
ENG123021-ENG123024,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 2,95696.9, s
ENG123021-ENG123025,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 3,1595.0, s
ENG123021-ENG123026,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 4,0.0, s
ENG123021-ENG123027,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 5,0.0, s
ENG123021-ENG123028,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 6,0.0, s
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG101346,Version info driving strategy,FEJRMRFEF.039,
ENG109005,Voltage Common Highside 1,14.8, V
ENG99955,Voltage Common Highside 2,14.6, V
ENG120913,xNm-Punkte für Welle 1: 1. Gang,6.7, mm
ENG120914,xNm-Punkte für Welle 1: 3. Gang,16.6, mm
ENG120915,xNm-Punkte für Welle 1: 5. Gang,5.7, mm
ENG120916,xNm-Punkte für Welle 1: 7. Gang,15.8, mm
ENG126197,xNm-Punkte für Welle 2: 2. Gang,9.6, mm
ENG126198,xNm-Punkte für Welle 2: 4. Gang,20.6, mm
ENG126199,xNm-Punkte für Welle 2: 6. Gang,9.1, mm
ENG126200,xNm-Punkte für Welle 2: R. Gang,18.6, mm
ENG120791,Zähler Adaptionausblendung,10,
ENG130281,Zähler für erfolgte Umschaltungen auf alte Kisspoint Adaption,0,
ENG122356-ENG122545,Zähler Systemdruckabbau-Zähler Systemdruckabbau erfolgreich,690,
ENG122356-ENG122544,Zähler Systemdruckabbau-Zähler Systemdruckabbau erwartet,699,
Elapsed Time: 00:50
;SW:5Q0-614-517-DE HW:5Q0-614-517-AD --- ABS Brakes
;Component:ESC H25 0524, Coding:21EE6A92242224748778060962C82484562424E1604624733822F00442A2430B002D641212131A1E35351919323200
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW37.rod
;Saturday,23,December,2023,19:57:36:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 77A086D63F4E88521E9-8022
Group,Description,Actual
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,No,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,5F28195,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.25000, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,Not available due to specific system,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,1,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,13,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,2468,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,4,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,977,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,2,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2022,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2021,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,9,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,6,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,8,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,5,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,21,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,16,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,6,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,10,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,15,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,17,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,20,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,18,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,29,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,56,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,11,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,8,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,51,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,12,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,45,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,8,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,6,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,17,
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2022,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2019,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,1,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,10,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,26,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,20,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,22,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,12,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,51,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,59,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,32,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,12,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03128,Requested start processes (ring memory),AUTO HOLD slippage recognition,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,18,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.763, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-723, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,1,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,valid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 34 2018,
IDE04442-IDE00010,Vacuum sensor-Serial number,00 04 B9 0F 72,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,available.,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,5,
IDE04442,Vacuum sensor,-722, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,0,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.01962, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.20601, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.09810, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.28125, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.172, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-0.481, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-0.481, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not available due to specific system,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,131521, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MYERAD00038,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,29, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-723, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.00, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,720, mbar
IDE04644-IDE02955,Roll-over protection-System status,available.,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04645-IDE02657,Electromechanical parking brake-Cut-off current: left: reached,0.00, A
IDE04645-IDE02658,Electromechanical parking brake-Cut-off current: right: reached,0.00, A
IDE04645-IDE04496,Electromechanical parking brake-Left parking brake motor: status,closed,
IDE04645-IDE04497,Electromechanical parking brake-Right parking brake motor: status,closed,
IDE04645-IDE04506,Electromechanical parking brake-Calculated left rear brake temperature,11.5, °C
IDE04645-IDE04507,Electromechanical parking brake-Calculated right rear brake temperature,11.5, °C
IDE04645-IDE04647,Electromechanical parking brake-Left parking brake motor: current,0.00, A
IDE04645-IDE04648,Electromechanical parking brake-Right parking brake motor: current,0.00, A
IDE04645-IDE05048,Electromechanical parking brake-Left parking brake motor: actuation counter,13863,
IDE04645-IDE05049,Electromechanical parking brake-Right parking brake motor: actuation counter,13863,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,129986, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,available.,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,2, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),2, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,Not available due to specific system,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,64,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,0,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,30,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,80,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,0, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,64,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,0,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,30,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,80,
IDE05712-IDE02955,AUTO HOLD-System status,available.,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,Condition met,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,On,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,311510,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,1285312,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,20102,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,43184,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2126,
IDE07280-MAS00107,Multiple collision brake-Month,14,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,30,
IDE07280-MAS00110,Multiple collision brake-Minutes,62,
IDE07280-MAS00111,Multiple collision brake-Seconds,62,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 37 38 38 34 32 33 30 30 30 30 36 31 38 41 33 31 30 30 30 46 37 2F 02 2C 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,100.384, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,111.712, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,101.947, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,11913,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.603, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,15644,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,109.368, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,3171,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,108.196, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,6751,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,11.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,11.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,11.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,11.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,131861, km
MAS00210-IDE80009,Parking Brake-Analysis 9,131841, km
MAS00210-IDE80010,Parking Brake-Analysis 10,21496, km
MAS00210-IDE80011,Parking Brake-Analysis 11,131862, km
MAS00210-IDE80012,Parking Brake-Analysis 12,00 00 00 00 00 00,
MAS00210-ENG167752,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG167753,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG167754,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG167755,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG167756,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG167757,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Not available due to specific system,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG157353-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
;SW:3Q0-959-435-L HW:3Q0-959-435-L --- Acc/Start Auth.
;Component:VWKESSYMQB 037 1204, Coding:132C0C0707
;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB.rod
;Saturday,23,December,2023,19:57:55:15566
;VCID: 43D822063B1614F2721-8016
IDE00019,Voltage terminal 30,14.783, V
IDE00021,Engine RPM,698.5, /min
IDE00021-MAS02248,Engine RPM-Signal state,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Up-to-date,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,closed,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,113,
IDE02419,Proximity sensor frt.pass. door: number of triggers,116,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,31,
IDE02422-MAS01483,Driver door handle: version information-Software version,17,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,AA,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,31,
IDE02423-MAS01483,ass. door handle: version information-Software version,17,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,AA,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,00,
IDE02424-MAS01483,Left rear door handle: version information-Software version,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,00,
IDE02425-MAS01483,Right rear door handle: version information-Software version,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,Yes,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72h-Signaling counter left rear door,0,
IDE02485,72h-Signaling counter right rear door,0,
IDE02495,Service-Key: Number of activations,136,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,to,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,7,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,56,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,78,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2023,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,11,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,12,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,25,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,22,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,9,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,26,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,10,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,11,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,26,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,13,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,40,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,26,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,37,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,31,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,43,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,7,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,ID sensor not found,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,ID sensor not found,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Missing from ECM,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,CAN Signal: read coil operation is set,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,ID sensor not found,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_SERVICE_KEY,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,SERVICE_KEY,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,00,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_SERVICE_KEY,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,SERVICE_KEY,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,00,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,UID_MONITORING,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,UID_SEARCH,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,A2,
IDE05204,Manufacturer production data door handle drivers door,1F 07 21 9A 51,
IDE05205,Manufacturer production data door handle front pass.door,1F 07 21 9A 51,
IDE05206,Manufacturer production data door handle left rear,00 00 00 00 00,
IDE05207,Manufacturer production data door handle right rear,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,10,
IDE08440,Recommendation energy management,no restriction,
IDE09840-MAS06517,CU for tailgate opener: counter readings-Rear spoiler counter,9,
IDE09840-MAS12705,CU for tailgate opener: counter readings-Number of detected proximities,3734,
IDE09840-MAS12706,CU for tailgate opener: counter readings-Number of detected kick movements,3734,
IDE09840-MAS12707,CU for tailgate opener: counter readings-Number of transmitter activations,65535,
IDE09841-MAS04394,CU for tailgate opener: sensor status-Connection status,Yes,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,0,
IDE80258-MAS00110,Immobilizer status-Minutes,8,
IDE80258-MAS00111,Immobilizer status-Seconds,0,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2023,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,58,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,53,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,131862, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop active in Start/Stop mode,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG160891,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG160890,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG160889,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG160888,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,14.765, V
ENG139762,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG245551,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2023,
ENG125220-MAS00107,History last automatic terminal switch off-Month,8,
ENG125220-MAS00107,History last automatic terminal switch off-Month,7,
ENG125220-MAS00108,History last automatic terminal switch off-Day,31,
ENG125220-MAS00108,History last automatic terminal switch off-Day,29,
ENG125220-MAS00108,History last automatic terminal switch off-Day,13,
ENG125220-MAS00108,History last automatic terminal switch off-Day,2,
ENG125220-MAS00108,History last automatic terminal switch off-Day,1,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,16,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,10,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,18,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,19,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,56,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,51,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,55,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,38,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,31,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,12,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,50,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,26,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,25,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,129349, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,129719, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,129781, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,128734, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,129349, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,SBC_WATCHDOG_RESET,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_WATCHDOG_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_WATCHDOG_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_WATCHDOG_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,SBC_WATCHDOG_RESET,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 28 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 80 FF FF FF,
ENG157998-MAS00106,lf_shutdowns-Year,2021,
ENG157998-MAS00106,lf_shutdowns-Year,2023,
ENG157998-MAS00107,lf_shutdowns-Month,6,
ENG157998-MAS00107,lf_shutdowns-Month,9,
ENG157998-MAS00108,lf_shutdowns-Day,24,
ENG157998-MAS00108,lf_shutdowns-Day,23,
ENG157998-MAS00108,lf_shutdowns-Day,6,
ENG157998-MAS00109,lf_shutdowns-Hours,19,
ENG157998-MAS00109,lf_shutdowns-Hours,10,
ENG157998-MAS00109,lf_shutdowns-Hours,22,
ENG157998-MAS00110,lf_shutdowns-Minutes,22,
ENG157998-MAS00110,lf_shutdowns-Minutes,3,
ENG157998-MAS00110,lf_shutdowns-Minutes,16,
ENG157998-MAS00111,lf_shutdowns-Seconds,55,
ENG157998-MAS00111,lf_shutdowns-Seconds,23,
ENG157998-MAS00111,lf_shutdowns-Seconds,39,
ENG157998-MAS00111,lf_shutdowns-Seconds,48,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,130197, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,75045, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,75045, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,75035, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,01,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,00,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,00,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,00,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,00,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,00,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,00,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,00,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,00,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,00,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,00,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,00,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,00,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,00,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,00,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,00,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,00,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,00,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,00,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,00,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,2320,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,20,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,131847, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,131844, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,131562, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,131562, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,131423, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,131292, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,131292, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,131000, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,131000, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,131000, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,130713, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,130713, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,131804, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,131804, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,131625, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,131625, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,131565, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,131565, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,131565, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,131565, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,12,
ENG157420-ENG161149,Scan_cycle_data-Retry_count_n -6,23,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,15,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,51,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,9,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,9,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,10,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,9,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,11,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,9,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,7,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,11,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,9,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,20,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,9,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,11,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,9,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,9,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,10,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,9,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,rear_right_door,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,trunk,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,Driver_door,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,trunk,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,rear_right_door,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,rear_left_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,trunk,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,Driver_door,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,Driver_door,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,Driver_door,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Reset_stop_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Reset_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Reset_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Reset_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Reset_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Reset_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Reset_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Reset_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Reset_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2023,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,12,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,23,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00109,service_key_internal_status-Hours,19,
ENG129035-MAS00110,service_key_internal_status-Minutes,53,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,34,
ENG129035-MAS00111,service_key_internal_status-Seconds,35,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK.,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG139702-ENG140253,WFS_key_signature-clap_15_activateing_signature,02,
ENG139702-ENG140248,WFS_key_signature-signature_key_1,01 23,
ENG139702-ENG140249,WFS_key_signature-signature_key_2,03 C5,
ENG139702-ENG140250,WFS_key_signature-signature_key_3,00 00,
ENG139702-ENG140251,WFS_key_signature-signature_key_4,00 00,
ENG139702-ENG140252,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:20
;SW:5F0-907-044-AL HW:5F0-907-044-AL --- Auto HVAC
;Component:Climatronic H05 1801, Coding:06000024200114011105004000101020
;EV_ACClimaBHBVW37X,006145,EV_ACClimaBHBVW37X_006_VW37.rod
;Saturday,23,December,2023,19:58:39:15566
;VCID: 70B2BDCA5A20DF6ADF3-8024
IDE00019,Voltage terminal 30,14.2, V
IDE00021,Engine RPM,700, /min
IDE00025,Coolant temperature,94, °C
IDE00198,Refrigerant pressure,7.8, bar
IDE00767,No. of unscheduled ECU resets,21,
IDE00965,Compressor shut-off condition,Compressor switch-on reduction,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,800, /min
IDE00969,Compressor load,0.5, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,19.0, °C
IDE00974,Outside air temperature internally calculated,11.5, °C
IDE00976,Left front vent temperature,26.3, °C
IDE00977,Right front vent temperature,25.7, °C
IDE00981,Footwell vent temperature,40.7, °C
IDE00982,Temperature downstream of evaporator,16.7, °C
IDE00983,Inside temperature,24.5, °C
IDE00984,Sun intensity left,0, W/m²
IDE00985,Sun intensity right,0, W/m²
IDE00987,Blower voltage: specified value,4.5, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,93,
IDE00994,Actual value for fresh air/recirculation air flow flap,31.5, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,94,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,208,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,40,
IDE00998,Left temperature flap - actual value,81,
IDE00998,Left temperature flap - actual value,25.0, %
IDE00999,Temperature door left - Specified value,82,
IDE01040,Left Temperature Control Door - cold stop,31,
IDE01041,Left temperature flap: warm stop,231,
IDE01042,Right temperature flap: actual value,23.5, %
IDE01042,Right temperature flap: actual value,78,
IDE01043,Temperature door right - Specified value,80,
IDE01044,Right temperature flap: cold stop,31,
IDE01045,Right temperature flap: warm stop,230,
IDE01050,Front air distribution flap: actual value,101,
IDE01050,Front air distribution flap: actual value,35.0, %
IDE01051,Air distribution door front - Specified value,100,
IDE01052,Front air distribution flap: air outlet stop,236,
IDE01053,Front air distribution flap: footwell air outlet stop,27,
IDE01054,Defroster flap: actual value,74.5, %
IDE01054,Defroster flap: actual value,181,
IDE01055,Defrost door - Specified value,182,
IDE01056,Defroster flap: stop open,236,
IDE01057,Defroster flap: stop closed,20,
IDE01063,Status of recirculation air,recirc. due to back pressure portion,
IDE01066,Convertible top status,to,
IDE01076,Time since ignition off,24, min
IDE01088,Rear temperature flap: actual value,20,
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01089,Rear temperature flap: specified value,20,
IDE01090,Rear temperature flap: cold stop,0,
IDE01091,Rear temperature flap: warm stop,0,
IDE01217-MAS01447,Left heated seat stage-Act.val.,2,
IDE01217-MAS01448,Left heated seat stage-Target value,2,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Target value,0,
IDE01226,Blower voltage: actual value,4.4, V
IDE01227,Blower current,2.00, A
IDE01232,Supply voltage for external components,25.5, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,35780,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,13,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE03008-MAS01564,Stop process prevented-Front windshield heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Front windshield heater,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Blowout temperature difference to specifications,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,52,
IDE03010-MAS01564,Number of prevented stop processes-Front windshield heater,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,1415,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,927,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),31,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),268,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,29,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Front windshield heater,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,1,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,563,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),12,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),98,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,17,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,4,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,55,
IDE03127,Prevented stop processes (ring memory),Blowout temperature difference to specifications,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2023,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,12,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,18,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,13,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,8,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,57,
IDE03128,Requested start processes (ring memory),Blowout temperature difference to specifications,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,100,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,17.8, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,17.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,55.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,8.5, °C
IDE06235,Potentiometer for rear vent temperature,255,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measuring value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measuring value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,51,
Elapsed Time: 00:13
;SW:5Q0-937-084-DD HW:5Q0-937-084-CG --- Cent. Elect.
;Component:BCM MQBAB H H38 0273, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,019001,EV_BCMBOSCH_019.rod
;Saturday,23,December,2023,19:58:58:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 7DAC94FE1D72A202445-8028
Group,Description,Actual
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,not coded/not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,not coded/not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,not coded/not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,not coded/not installed,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00550-IDE00047,Identification of parameterization-Parameter set version,30 A1,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measuring value not available,
IDE00973,Outside temperature,19.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Front windshield heater-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Front windshield heater-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Front windshield heater-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,to,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,to,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02515,Low beam,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear wiper,not active,
IDE02743,High Beam,|Connector number,Connector terminal number
IDE02744-MAS01632,Steering wheel heating-Status,not coded/not installed,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,not coded/not installed,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,254,
IDE02857-IDE03111,Activation current-Interior lighting,32, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,132, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,No malfunction,
IDE02857-ENG128455,Activation current-Cockpittaster_2,No malfunction,
IDE02857-ENG128456,Activation current-Cockpittaster_3,No malfunction,
IDE02857-ENG128457,Activation current-Cockpittaster_4,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,336, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,18.7, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,14.7, V
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,Stage 2,
IDE03388-MAS02201,Left front heated seat: status-Temperature,26.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,16.00, °C
IDE03504,Personalized settings,|profile,Comfort opening
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded freeze frame conditions-DTC,03 04 0C,
IDE04347-IDE07836,Expanded freeze frame conditions-Log data,00 00 00 02 0D 00 0D 00 66 01 AD 15 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 03 00 04 0A EC 00 00 0C 13 00 00 00 03 00 00 07 15 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0C 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 01 00 00 01 00 54 64 08 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 04 81 3E 2F 00 00 00 00 04 4C 20 34 00 20 00 00 40 08 00 02 EB 1F 00 00 00 98 E8 5D 00 3B 00 00 00 00 00 00 00 00 00 00 09 00 02 01 00 00 00 00 02 00 00 00 98 0A 00 00 00 8F 00 00 00 00 00 00,
IDE04925,Daytime running lights,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Duty cycle,22.00, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,271200,
IDE05045-MAS05878,Front wiper module-Stage,Stage 1,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05533,Heater for nozzles,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,Not operated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,Not operated,
IDE05742-MAS03835,Light switch position-Position lamps,operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-19.40, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,-2.30, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.00, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.00, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,26,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,27,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,0, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,terminal
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.8, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,18.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,55.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.9, °C
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,88.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,88.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,88.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lamps,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-ENG247157,Wireless transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG247187,Wireless transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lamps,|Connector number,Connector terminal number
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,76.40, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,797.4, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Not operated,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,to,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,closed,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG140257,Central locking system-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,8,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,D9 B4 64 9D,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,672, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,656, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,222, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,282, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,126, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,222, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,192, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,66, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,13, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,14, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,20, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,20, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,not installed / not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,not installed / not active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,not installed / not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lamps,not installed / not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,not installed / not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,not coded/not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,NOT-DEFINED,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,NOT-DEFINED,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,NOT-DEFINED,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,not coded/not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
IDE12940,Lever functions of the steering column electronics,not coded/not installed,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,Not operated,
IDE14110-MAS17843,Digital Key-Bluetooth control section,Not operated,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.65, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.65, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.65, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.65, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,14.65, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,14.75, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2023,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,59,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,24,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,53,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,131862, km
MAS00829-MAS00244,Access/start authorization-Prompt wire,operated,
MAS00829-MAS01763,Access/start authorization-Signal Strength,-41,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Front windshield heater,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,76,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Front seat heating,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,126, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),00 00 00 02 0D 00 0D 00 66 01 AD 15 61 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 06 15 C4 00 00 0C 13 00 00 00 03 00 00 07 15 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0C 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 02 00 01 00 00 00 00 54 64 08 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 04 81 14 4F 00 00 10 00 04 4C 20 34 00 20 00 00 40 08 00 02 EB 1F 00 00 00 98 ED EA 00 3B 00 00 00 00 00 00 00 00 00 00 09 00 02 01 00 00 00 00 02 00 00 00 98 0A 00 00 00 8F 00 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,1750,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,2712,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG247080-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG247080-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,active,
ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
ENG128380,Parametermonitor_0,84 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 64 64 64 7E 7F 64 64 7E 64 64 64 7F 64 64 64 64 64 00 64 7E 7F 64 64 7E 64 64 64 7F 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 04 04 00 00 FF FF 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 00 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 32 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 00 32 07 00 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0F 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Account,Key number
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Konto,Perso_Steuerung
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|10|0|10|0|,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,109845, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.2, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.7, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.7, V
ENG116791,Temperatures,19.50, °C
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,Radio telegram: valid,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,19.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,Not operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.7, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,Not operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 00:42
;SW:5QA-919-298-D HW:5QA-919-298-A --- Park/Steer Assist
;Component:PLA 3.0 12KH07 0050, Coding:0A71267151
;EV_EPHVA2CAU3700000,009041,EV_EPHVA2CAU3700000_VW41.rod
;Saturday,23,December,2023,19:59:43:15566
;VCID: 51F4184EF16AF662F0D-8004
IDE00018,Voltage terminal 15,14.1, V
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,83, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,78, cm
IDE00974,Outside air temperature internally calculated,11.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,No,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,85, cm
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,84, cm
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,1.008, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,1.056, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,1.104, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.976, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,1.040, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,1.136, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,1.072, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,1.088, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 4,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 6,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Parking aid button,Not operated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,14.0, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio lowering request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,79, cm
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.992, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.912, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.976, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,1.008, ms
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 5,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 5,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 5,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Driving direction,forward,
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,No shut-off requirement,
IDE01943,Turn signal lamp,Not operated,
IDE01965,Parallel parking assistance button,Not operated,
IDE01966,Cause of parallel park assist switching off,No shut-off requirement,
IDE01967,Parking side,Right,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,33,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2022,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2023,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,9,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,8,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,10,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,26,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,12,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,20,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,28,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,25,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,58,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,47,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,22,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,32,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,26,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,10,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Parallel Parking Assistance,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Parallel Parking Assistance,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Parallel Parking Assistance,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Parallel Parking Assistance,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Parallel Parking Assistance,
IDE03212,Start/stop conditions,Stop release,
IDE03683,Request power steering boost,No,
IDE03684,Vehicle stopped,Yes,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03783,Switch-on speed for parallel parking assist,37, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,88, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,48, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,94, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,87, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,23, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,1, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,19, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,0,
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,1,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2013,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2064,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2023,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2073,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2102,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,4,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,12,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,5,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,30,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,19,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,27,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,3,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,6,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,16,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,12,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,0,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,16,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,28,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,4,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,12,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,1,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,13,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,5,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,24,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,29.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-1.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-20.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,19.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-5.0, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-1.1, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,6.3, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.2, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,4.3, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,6.5, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.4, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-0.7, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,4.3, m
MAS00464-MAS00111,Standard - ambient data 1-Seconds,54,
MAS01426,Rear parking aid buzzer: volume,Stage 5,
MAS01427,Speaker frequency for rear park assist,Stage 6,
MAS01428,Front parking aid buzzer: volume,Stage 5,
MAS01429,Speaker frequency for front park assist,Stage 5,
MAS10122,ARA operating condition,Initialization,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,10, %
ENG113996-ENG113979,Function_PLA-BS_alignement_BF,No,
ENG113996-ENG113982,Function_PLA-BS_alignement_driver,No,
ENG113996-ENG113978,Function_PLA-BS_identified_BF,Yes,
ENG113996-ENG113980,Function_PLA-BS_identified_BF_old,No,
ENG113996-ENG113981,Function_PLA-BS_identified_Driver,No,
ENG113996-ENG113983,Function_PLA-BS_identified_Driver_old,No,
ENG113996-ENG106720,Function_PLA-Fzgx_Max,4.0, cm
ENG113996-ENG106721,Function_PLA-Fzgy_Max,1254.4, cm
ENG113996-ENG113974,Function_PLA-L_Rangier_Min,999.1, cm
ENG113996-ENG107571,Function_PLA-Manual_Steering_Moment,0.0, Nm
ENG113996-ENG108155,Function_PLA-Parking_Aid_Senders_Cutoff_Time,0, s
ENG113996-ENG113977,Function_PLA-PL_Depth_BF,1363.8, cm
ENG113996-ENG113986,Function_PLA-PL_depth_BF_old,87, cm
ENG113996-ENG113988,Function_PLA-PL_Depth_Driver,2430.5, cm
ENG113996-ENG113990,Function_PLA-PL_Depth_Driver_Old,0.0, cm
ENG113996-ENG113976,Function_PLA-PL_Length_BF,6225.2, cm
ENG113996-ENG113985,Function_PLA-PL_Length_BF_old,614.4, cm
ENG113996-ENG113987,Function_PLA-PL_Length_Driver,1305.6, cm
ENG113996-ENG113989,Function_PLA-PL_Length_Driver_Old,1106.3, cm
ENG113996-ENG108329,Function_PLA-Psi0_BF,54.84, °
ENG113996-ENG108330,Function_PLA-Psi0_BF_Alt,18.53, °
ENG113996-ENG108331,Function_PLA-Psi0_Fahrer,85.45, °
ENG113996-ENG108332,Function_PLA-Psi0_Fahrer_Alt,55.11, °
ENG113996-ENG109009,Function_PLA-Speed_Limit_Power_Steering,93, km/h
ENG113996-ENG109117,Function_PLA-Steering_Angle_Actual_Value,0.0, °
ENG113996-ENG109118,Function_PLA-Steering_Angle_Nominal_Value,0.0, °
ENG113996-ENG113975,Function_PLA-T_Rangier_Min,27.5, cm
ENG113996-ENG113984,Function_PLA-Visual_Indication,No,
ENG113996-ENG110295,Function_PLA-X0_BF,256.2, cm
ENG113996-ENG110296,Function_PLA-X0_BF_Alt,2436.7, cm
ENG113996-ENG110297,Function_PLA-X0_Fahrer,1331.2, cm
ENG113996-ENG110298,Function_PLA-X0_Fahrer_Alt,128.1, cm
ENG113996-ENG110299,Function_PLA-Xa_BF_Alt,27.9, cm
ENG113996-ENG110300,Function_PLA-Xa_Fahrer_Alt,9.3, cm
ENG113996-ENG110301,Function_PLA-Y0_BF,79.0, cm
ENG113996-ENG110302,Function_PLA-Y0_BF_Alt,1611.8, cm
ENG113996-ENG110303,Function_PLA-Y0_Fahrer,2396.1, cm
ENG113996-ENG110304,Function_PLA-Y0_Fahrer_Alt,488.7, cm
ENG113996-ENG113973,Function_PLA-Ya_Alt,8.8, cm
ENG113996-ENG110306,Function_PLA-Ya_Fahrer_Alt,-328.9, cm
Elapsed Time: 00:14
;SW:2Q0-907-572-M HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H03 0233, Coding:320067CB5CFF8728749C8145804085
;EV_ACCMRRCONTIVW376,002012,EV_ACCMRRCONTIVW376_002.rod
;Saturday,23,December,2023,20:00:01:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 3E2E53F250F4791A1DF-806A
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.7, V
IDE00102,Control Module temperature,61, °C
IDE01985-MAS06855,FAZIT identification test sum-Test sum,08 B5 21 3F,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,84,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,11243,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,983,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,67,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,1639,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,220,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,83 D8 A9 C6 A2 5F 95 2F 9A C7 07 19 CE 81 32 39 60 7F 0F D0 B2 94 86 3E 82 8C 6E 19 B5 2D 10 04 55 7F E1 1D 37 CC AA 45 46 81 1C 27 FC 2B F2 07 70 6D DB 7B B4 F2 A4 92 00 FF C0 96 82 48 8D E2 81 FD 83 D6 B5 E3 F7 E4 67 2E D3 F9 9D 81 9C E5 C9 71 C8 76 21 BE 13 C4 26 06 D9 15 EE 1A 8D A0 DF 31 66 C3 AA 82 99 AD 2B 38 92 4F BD C5 D6 3C C2 2A 6C 5C AB 63 ED 39 D2 0E B5 FA 98 58 37 EF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE05228,Operating hour counter,122104, min
IDE05814,Individualization characteristic,E7 B3 63 0C 3F,
IDE06307-MAS00106,Stop prevention history data-Year,2023,
IDE06307-MAS00107,Stop prevention history data-Month,12,
IDE06307-MAS00108,Stop prevention history data-Day,23,
IDE06307-MAS00109,Stop prevention history data-Hours,18,
IDE06307-MAS00110,Stop prevention history data-Minutes,35,
IDE06307-MAS00111,Stop prevention history data-Seconds,46,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Vehicle ahead starts driving: ACC off,
IDE06308-MAS00106,Start request history data-Year,2023,
IDE06308-MAS00107,Start request history data-Month,12,
IDE06308-MAS00108,Start request history data-Day,20,
IDE06308-MAS00109,Start request history data-Hours,16,
IDE06308-MAS00110,Start request history data-Minutes,3,
IDE06308-MAS00111,Start request history data-Seconds,13,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC passive,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,0.184, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,12,
IDE09380-MAS00107,Performed adjustment-Month,0B,
IDE09380-MAS00108,Performed adjustment-Day,0D,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.34, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.45, °
IDE09906,Vertical deadjustment,-1.172, °
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.180, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-1.170, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,0.330, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,0.450, °
IDE12062,Counter for terminal 15 reset,13713,
ENG157277-ENG161032,ACC operating lever signal-ACC_main_switch,Not operated,
ENG157277-ENG98480,ACC operating lever signal-Cancel,Not operated,
ENG157277-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
ENG157277-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
ENG157277-ENG161056,ACC operating lever signal-distance_control_minus,Not operated,
ENG157277-ENG161057,ACC operating lever signal-distance_control_plus,Not operated,
ENG157277-ENG161132,ACC operating lever signal-part_control_lever,control_lever_6_positions,
ENG157277-ENG159615,ACC operating lever signal-Resume,Not operated,
ENG157277-ENG98911,ACC operating lever signal-Set,Not operated,
ENG157277-ENG161234,ACC operating lever signal-tip_down_in_step_1,Not operated,
ENG157277-ENG161235,ACC operating lever signal-tip_down_in_step_2,Not operated,
ENG157277-ENG161236,ACC operating lever signal-tip_up_in_step_1,Not operated,
ENG157277-ENG161237,ACC operating lever signal-tip_up_in_step_2,Not operated,
ENG107409,Longitudinal_acceleration_vehicle_reference,0.28, m/s²
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,18664, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,16697, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,108, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,1859, min
ENG131993,Operating_time_ACC_active_timegap_1,16196, min
ENG131994,Operating_time_ACC_active_timegap_2,206, min
ENG131995,Operating_time_ACC_active_timegap_3,2192, min
ENG131996,Operating_time_ACC_active_timegap_4,4, min
ENG131997,Operating_time_ACC_active_timegap_5,15, min
ENG132001,Operating_time_ACC_active_v-delta_0,0, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,18664, min
ENG132007,Status_ACC_System,ACC_Off_MainSwitch_Off,
ENG109878,Velocity_vehicle_reference,0.00, m/s
Elapsed Time: 00:10
;SW:3Q0-959-655-BH HW:3Q0-959-655-BH --- Airbags
;Component:Airbag VW21 006 0712, Coding:98CCC0C0000000005C5400CC000800000065
;EV_AirbaVW21TS6VW48X,001014,EV_AirbaVW21TS6VW48X_VW37.rod
;Saturday,23,December,2023,20:00:17:15566
;VCID: 055CFC1E75A2EAC21C5-8050
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.8, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.1, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,no measured value present,
IDE01102,Driver thorax airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.2, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,1.9, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.1, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,no measured value present,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,no measured value present,
IDE01114,Driver side belt force limiter igniter ohm value,no measured value present,
IDE01115,side belt force limiter igniter ohm value,no measured value present,
IDE01116,driver side rear belt tensioner igniter ohm value,2.1, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.0, Ohm
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,396.0, Ohm
IDE01197,Key switch contact 1 ohm value,680.0, Ohm
IDE01198,Key switch contact 2 ohm value,1660.0, Ohm
IDE01200,Driver seat position sensor current value,no measured value present,
IDE01201,Frt.pass. seat position sensor current value,no measured value present,
IDE01205,Safety belt switch 2nd row driver side ohm value,Too Small,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,Too Small,
IDE01207,Safety belt switch center 2nd row ohm value,Too Small,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,not installed,
IDE01358,Right pedestrian protection igniter,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,no measured value present,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,no measured value present,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03730,Driver airbag release valve igniter ohm value,no measured value present,
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,no measured value present,
IDE03800,Driver airbag release valve igniter,not installed,
IDE03801,Frt.pass. airbag release valve igniter,not installed,
IDE06034,Rollover protection trigger: driver side,not installed,
IDE06035,Rollover protection trigger: front passenger side,not installed,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE10187,Supply voltage {V},14.7, V
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,not installed,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,not installed,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver's Safety Belt Tensioner Igniter 2,not installed,
MAS00016,Front passenger seat belt tensioner igniter 2,not installed,
MAS00017,Driver's Belt Force Limiter,not installed,
MAS00018,Front passenger side belt force limiter igniter,not installed,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00022,Battery Interrupt Igniter,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,On,
MAS00033,Key switch terminal 2,On,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:14
;SW:5Q0-953-521-LE HW:5Q0-953-569-A --- Steering wheel
;Component:Lenks.Modul 075 0235, Coding:6C14
;EV_SMLSVALEOMQB,001015,EV_SMLSVALEOMQB.rod
;Saturday,23,December,2023,20:00:33:15566
;VCID: 0052ED0A6A80CFEA2F3-8054
IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,not coded/not installed,
IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,not coded/not installed,
IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,not coded/not installed,
IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,not coded/not installed,
IDE00329-MAS00688,Buttons for multi-function display-Multi-function display,not coded/not installed,
IDE00333,Driver assistance systems button,Not operated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Distance Regulation,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,6 Position operating unit,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,On,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02694-MAS01288,Horn operation-Horn,Not operated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 2,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,Not operated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,Not operated,
IDE02743,High Beam,Not operated,
IDE02745-MAS08202,Ignition Switch Key Lock Solenoid-CAN p locked,Engaged and locked,
IDE02745-MAS08203,Ignition Switch Key Lock Solenoid-CAN p locked: qualified,Not qualified,
IDE02745-MAS08204,Ignition Switch Key Lock Solenoid-Hardware input: p_verriegelt,Open,
MAS09606-MAS09607,SMLS p locked-Switch p locked,Engaged and locked,
MAS09606-MAS09608,SMLS p locked-SMLS p locked plausibility,Implausible,
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,14.1, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,14.9, V
ENG127111-ENG103188,Valeo_Entwickler_MWB-GRA Hebel axial (Set),ACC+,
ENG127111-ENG127155,Valeo_Entwickler_MWB-GRA Hebel axial (Set+ACC),ACC+,
ENG127111-ENG103953,Valeo_Entwickler_MWB-GRA Hebel horizontal (On/Off),Blinker GRA Aus,
ENG127111-ENG102675,Valeo_Entwickler_MWB-GRA Hebel vertikal (Plus/Minus),GRA Neutral,
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,01,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG103457,Valeo_Entwickler_MWB-Linker Hebel axial 1 (FAS),FAS unbetätigt,
ENG127111-ENG101659,Valeo_Entwickler_MWB-Linker Hebel axial 2 (GRA Set/Rest),Blinker GRA neutral mit Limiterverbau (weder beschleunigen noch verzoegern),
ENG127111-ENG99692,Valeo_Entwickler_MWB-Linker Hebel axial 3 (ON/CANCEL/OFF),Blinker GRA Aus,
ENG127111-ENG127151,Valeo_Entwickler_MWB-Linker Hebel horizintal (Licht),Neutral position,
ENG127111-ENG127150,Valeo_Entwickler_MWB-Linker Hebel vertikal 1 (Blinker rechts),Blinker in Neutralstellung,
ENG127111-ENG127152,Valeo_Entwickler_MWB-Linker Hebel vertikal 2 (Blinker Links),Blinker in Neutralstellung,
ENG127111-ENG126631,Valeo_Entwickler_MWB-p_verriegelt,EC,
ENG127111-ENG127153,Valeo_Entwickler_MWB-Rechter Hebel axial 1/2 (MFA Wippe),Stecker nicht gesteckt oder Short to UBat,
ENG127111-ENG127154,Valeo_Entwickler_MWB-Rechter Hebel axial 3 (Intervalstufen),Intervall Raendel 2,
ENG127111-ENG100192,Valeo_Entwickler_MWB-Rechter Hebel horizontal (Heckwischer),Heckwaschen neutral,
ENG127111-ENG100503,Valeo_Entwickler_MWB-Rechter Hebel vertikal (Frontwischer),Front wischen neutral,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,25.5, V
ENG127111-ENG127157,Valeo_Entwickler_MWB-WeakUp2,OFF,
Elapsed Time: 00:02
;SW:5F0-920-790-A HW:5F0-920-790-A --- Instruments
;Component:KOMBI 609 1701, Coding:04A45A9A6E8C00080188720F3001000080000000
;EV_DashBoardVDDMQBA0,001026,EV_DashBoardVDDMQBA0_001_VW37.rod
;Saturday,23,December,2023,19:54:20:15566
;VCID: 27009696AF6ED8D24E9-8072
IDE00019,Voltage terminal 30,14.7, V
IDE00021,Engine RPM,699.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00191,Charge air pressure: actual value,8.00, %
IDE00196,Engine oil temperature,71, °C
IDE00301,Mileage,131862, km
IDE00310,Outside temperature,19.0, °C
IDE00316-IDE00500,Time-Hour,19, H
IDE00316-IDE00501,Time-Minute,54, min
IDE00316-MAS00111,Time-Seconds,21, s
IDE00317-IDE00502,Date-Year,2023, yr
IDE00317-IDE00503,Date-Month,12, Months
IDE00317-IDE00504,Date-Day,23, d
IDE00323,Security Access: Number of invalid keys,2,
IDE00510,ESI: distance driven from inspection,4220, km
IDE00511,ESI: time from inspection,219, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,7900, km
IDE00520,Photo transistor,0,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,22250, km
IDE00698,ESI: remaining running time,425, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,1866, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2048, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2130, mm
IDE00935,ESI: Theoretical service interval,26500, km
IDE01076,Time since ignition off,1462, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,7B 98 36 AD,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,11.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,64,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,64,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,4095,
IDE03349,FIX:Max. distance driven until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,365, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,4200, km
IDE03352,FIX: Time since last time-dependent inspection,219, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,35.6, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,47.5, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,50.7, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,35.7, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,22.2, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,47.5, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,50.7, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,22.7, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,22.4, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,47.5, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,50.7, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,23.1, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,20.3, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,47.5, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,50.7, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,21.2, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,131800,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,131600,
IDE03472-MAS06155,Volume after refueling-Third to last distance,131300,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,130900,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,52, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-2, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,868,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2440,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,47.5, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,50, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,50.7, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-51.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,50.7, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,50.5, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,50.7, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.25000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.01,
IDE03474-ENG101623,Calculated volume-reference_volume,50.7, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,113,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0033331,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,19, H
IDE03477-IDE00501,GPS time-Minute,54, min
IDE03477-IDE00501,GPS time-Minute,34, min
IDE03477-IDE00502,GPS time-Year,2023, yr
IDE03477-IDE00503,GPS time-Month,12, Months
IDE03477-IDE00504,GPS time-Day,23, d
IDE03477-MAS00111,GPS time-Seconds,27, s
IDE03477-MAS00111,GPS time-Seconds,46, s
IDE03477-MAS03493,GPS time-last synchronization year,2023, yr
IDE03506,Distance: high resolution,07 DC 10 93,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 02,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 0D,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 08,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 08,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 0D,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,BF F0 75 38,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,3F F0 75 38,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 77 99,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 01 2F,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,0F F0 77 99,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,4F F0 01 2F,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,8F F0 DB 08,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,CF F0 02 68,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,4F F0 02 68,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,0F F0 DB 08,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,8F F1 2B 01,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,CF F0 03 CC,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,3F F1 4D 8A,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,0F F1 59 9E,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,4F F0 04 7C,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF F0 05 4B,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,8F F1 97 2D,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,CF F0 05 9C,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,3F F1 CE CE,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,8F F1 F2 9B,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,CF F0 06 6E,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,0F F1 F2 9B,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,4F F0 06 6E,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08239,Transponder ID Key 1,0A 74 93 57,
IDE08240,Transponder ID Key 2,0A 74 99 B1,
IDE08252-MAS06854,Test sum of adapted transponder-Version,01,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,DD A4 D2 0E,
IDE08343,Immobilizer Challenge,37 2F 69 6D,
MAS00077-ENG99298,Immobilizer-State,02 01 03 73 02 00 00 00 01 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,8, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,28, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,22, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,5, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,19, km
ENG99439,Instrument_recorder,06 17 02 00 4D 51 42 41 30 56 57 31 38 53 31 46 41 43 35 41 30 32 65 37 38 64 31 5F 00 05 00 28 00 09 00 00 02 E2 00 00 00 00 00 00 00 08 00 06 0C F1 15 AA 06 E0 00 BD 00 1D 00 00 01 7F 00 00 00 00 00 00 00 03 00 06 0A 2B B7 07 1C 80 00 C1 00 1D 00 00 02 86 00 00 00 02 00 00 00 01 00 06 0C F5 78 26 03 B0 00 AF 00 1E 00 00 02 8F 00 00 00 01 00 00 00 01 00 06 0C F5 78 26 03 B0 00 AB 00 1E 00 00 01 E5 00 00 00 00 80 00 00 00 00 06 0D 08 AF BA E3 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3B 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 FF FF FF FF FF FF FF 00 00 1E 00 AB 00 E5 01 00 00 00 00 00 00 08 0D 06 00 00 E3 BA AF 1E 00 AF 00 8F 02 00 00 01 00 00 00 F5 0C 06 00 B0 03 26 78 1D 00 C1 00 86 02 00 00 02 00 00 00 F5 0C 06 00 B0 03 26 78 09 00 28 00 E2 02 00 00 00 00 00 00 F1 0C 06 00 E0 06 AA 15 1D 00 BD 00 7F 01 00 00 00 00 00 00 2B 0A 06 00 80 1C 07 B7 1E 00 AF 00 8F 02 00 00 01 00 00 00 E5 06 06 00 A8 9C 12 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 03 00 03 00 03 00 01 00 01 00 01 00 2B 00 0E 00 18 00 37 00 67 00 0F 00 18 00 07 00 27 00 90 00 4A 00 87 00 03 00 06 00 06 00 04 00 06 00 04 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 17 02 00 4D 51 42 41 30 56 57 31 38 53 31 46 47 43 5F 53 45 00 00 00 67 00 06 00 0F 00 FC 00 00 00 00 00 00 00 06 0D 32 6F B4 F8 3F 00 00 01 E4 00 4D 00 00 01 4F 00 00 00 00 00 03 00 06 0D 32 3C 5F C5 3B 00 00 03 AF 00 75 00 00 00 FC 00 00 00 00 00 00 00 06 03 C9 A3 7E 15 EF 00 00 03 AF 00 75 00 00 01 18 00 00 00 00 00 00 00 06 03 C9 A3 7E 16 46 00 00 01 E4 00 4D 00 00 05 8A 00 00 00 00 00 00 00 06 0D 28 03 41 56 D2 00 00 02 07 00 53 00 00 00 50 00 00 00 00 00 04 00 06 05 75 B6 B6 FC 63 00 00 02 76 00 5C 00 00 02 5B 00 00 00 00 00 02 00 06 09 27 E4 A8 F6 00 00 00 02 C6 00 60 00 00 04 43 00 00 00 00 00 01 00 06 0C B2 5E 9A B8 5B 00,
ENG107920-ENG98868,onboard_computer-Range,601, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,7.4, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.4, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,7.1, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,601, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,123,
ENG103405,read_out_measured_value_block,131,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,78 28 02 63 E9 80 17 0C 17 13 35 23 16 03 02 00 DF 10 A9 11 02 11 92 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 FF FF 00 00 40 05,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,13576,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,2,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_Trigger,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:21
;SW:3Q0-907-530-Q HW:3Q0-907-530-C --- CAN Gateway
;Component:GW MQB High 518 5344, Coding:030500F42F085700E90002D81C0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF_VW37.rod
;Saturday,23,December,2023,19:54:58:15566
;VCID: 3D2C54FE5DF26202045-8068
IDE00019,Voltage terminal 30,14.6, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2023-12-23-19:34*00.0*01*03191***
2023-12-23-19:05*00.0*01**
2023-12-23-13:20*00.0*01**
IDE00057,History data 2,|Life Cycle Data String|-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058,History data 3,|Life Cycle Data String|2018-11-26-12:12*T*0*081*061*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-26-09:01*T*0*084*066*0-0-0-1-0-0-0*0*0*00.0*00.0**
2018-11-23-16:34*T*0*085*067*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-19-10:29*T*0*086*071*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-19-10:12*T*0*087*073*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-16-16:23*T*0*084*075*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-15-09:16*T*0*090*055*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-15-09:15*T*0*090*055*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-14-08:36*T*0*090*061*0-0-0-0-0-0-0*0*0*00.0*00.0**
2018-11-14-08:34*T*0*090*060*0-0-0-0-0-0-0*1*0*00.0*00.0**|,
IDE00059,History data 4,|Life Cycle Data String| 0000000km*01*069*JCB*1111111111*10010*06502*019.1*000.0*000.0**
IDE00060,History data 5,|Life Cycle Data String|-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061,History data 6,|Life Cycle Data String|2023-12-23-19:06*035*+17*+000.3*00.00*0.00*001**
2023-12-23-18:31*036*+16*+000.2*00.00*0.00*000**
2023-12-23-13:20*041*+16*+000.5*00.10*0.00*000**
2023-12-23-08:53*040*+16*+000.1*00.00*0.00*000**
2023-12-23-08:22*041*+15*+000.3*00.10*0.00*001**
2023-12-23-08:13*040*+15*+000.2*00.10*0.00*000**
2023-12-22-20:29*049*+25*+000.8*00.30*0.00*000**
2023-12-22-19:29*046*+22*+001.0*00.40*0.00*000**
2023-12-22-18:14*041*+18*+000.9*00.10*0.00*000**
2023-12-22-17:54*041*+17*+001.0*00.20*0.00*000**|,
IDE00062,History data 7,|Life Cycle Data String|2023-12-23-19:10*033*+000.2*000.3*00.0*00.0**
2023-12-23-18:36*035*+000.3*000.4*00.0*00.0**
2023-12-23-13:30*036*+000.5*005.0*00.0*00.0**
2023-12-23-08:54*039*+000.4*004.3*00.0*00.0**
2023-12-23-08:29*040*+000.3*000.3*00.0*00.0**
2023-12-23-08:20*040*+000.2*000.0*00.0*00.0**
2023-12-22-20:53*040*+000.6*011.3*00.0*00.0**
2023-12-22-19:53*044*+000.3*000.5*00.0*00.0**
2023-12-22-18:26*041*+000.4*001.0*00.0*00.0**
2023-12-22-18:11*040*+000.7*000.0*00.0*00.0**|,
IDE00063,History data 8,|Life Cycle Data String| 0131797km*1*54*00*00*03*-------------:--*01**
0129680km*1*53*00*00*03*-------------:--*01**
0129680km*1*52*00*00*03*-------------:--*01**|,
IDE00064,History data 9,|Life Cycle Data String| 0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
2023-12-13-18:34*059*076*065*034*06502*12.30*+25*06*01*03.55*65535*16831**
2023-11-15-17:16*063*076*073*038*06502*12.40*+13*06*01*03.45*65535*16823**
2023-10-18-16:14*066*080*067*036*06502*12.30*+11*06*01*03.40*65535*16802**
2023-09-19-16:33*070*088*071*046*06502*12.40*+24*05*01*03.25*65535*16703**
2023-08-22-16:27*072*083*069*046*06502*12.40*+24*05*01*03.35*65535*16648**
2023-07-24-16:32*072*083*071*048*06502*12.40*+24*05*01*03.35*65535*16556**
2023-06-26-16:12*071*085*067*043*06502*12.30*+28*06*01*03.35*65535*16457**
2023-05-29-15:56*072*084*072*047*06502*12.40*+34*06*01*03.45*65535*16353**
2023-05-01-15:17*077*087*076*055*06502*12.50*+20*05*01*03.45*65535*16230**
2023-04-23-07:16*079*089*072*054*06502*12.40*+17*05*01*03.30*65535*16058**
2023-04-18-14:03*074*087*075*048*06502*12.50*+15*05*01*03.35*65535*15883**|,
IDE00065,History data 10,|Life Cycle Data String|-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066,History data 11,|Life Cycle Data String|2023-12-15-14:59*000*000*000*007*0093*011*00.0*00.3*071*037*072*037*01*01565*01801*00828*06350*17710**
2023-12-15-10:10*000*000*000*007*0060*013*00.0*00.5*074*037*074*037*05**
2023-11-26-13:14*000*000*000*000*0000*036*00.0*00.1*075*040*090*051*02**
2023-11-23-16:50*000*000*000*000*0000*005*00.0*00.0*072*036*072*036*01**
2023-11-22-16:27*000*000*000*012*0106*031*00.0*00.2*077*041*078*041*01**|,
IDE00067,History data 12,|Life Cycle Data String|2023-12-20-19:16*0-0-0-0-0-0-1-0**
2023-12-20-19:07*0-0-0-1-0-0-1-0**
2023-12-10-16:24*0-0-0-1-0-0-0-0**
2023-12-10-16:05*0-0-0-0-0-0-1-0**
2023-12-06-18:00*0-0-0-0-0-0-1-0**
00010*00000*00000*00015*00013*00000*00256*00000**
2023-09-18-14:28*0-0-1-0-0-0-0-0**
2023-08-04-13:54*0-0-1-0-0-0-0-0**
2023-08-04-13:44*0-0-1-0-0-0-0-0**
2023-04-29-11:55*0-0-0-1-0-0-0-0**
2023-04-28-19:55*0-0-0-1-0-0-0-0**
00000*00000*00004*00065*00000*00000*00000*00000**
2023-12-10-16:22*1*063*027*+14*06*090*-32.65*11.7*1**
2023-12-03-15:36*2*060*022*+04*06*025*+13.02*14.0*1**
2023-09-18-14:28*2*059*031*+23*05*020*-26.09*11.7*1**
2023-08-12-08:47*2*060*037*+29*05*025*+27.31*11.7*1**
2023-08-07-12:42*2*059*033*+18*05*025*-16.12*11.8*0**
00006*00012*00000**|,
IDE00068,History data 13,|Life Cycle Data String|-------------:--*---------*---.-*-----**
IDE00069,History data 14,|Life Cycle Data String|2023-12-23-19:34*3*00000*0000*0008*00.30*020004*+19*0040.1*0000.0*0000.0**
2023-12-23-19:09*1*00006*0000*0000*00.00*020004*+17**
2023-12-23-19:09*1*00012*0000*0000*00.00*020004*+17**
2023-12-23-19:08*1*00003*0000*0000*00.00*020004*+17**
65535*01132*00834*00000*00000**
IDE00071,History data 16,|Life Cycle Data String| 0131862km**
00064*00883*12681*00071*00000**
28930*01499*00028*00006**
47431*04311*00102*00004**
01675*07073*01930*02744**
08336*03640*01446**
13567*00092*00002**
00081*00010*00002**
00089*00014*00003**
06923*03001*01977*01408*01068*00789*01167*00740*00424*01196*00000**|,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,14,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805,History data 19,|Life Cycle Data String|2023-12-20-19:15*00320*062*032*+17**
2023-12-20-19:14*00320*061*032*+17**
00142*00288*00000*00000**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,1.0, H
IDE01807-MAS00106,History data 21-Year,2023,
IDE01807-MAS00107,History data 21-Month,5,
IDE01807-MAS00108,History data 21-Day,29,
IDE01807-MAS00109,History data 21-Hours,15, H
IDE01807-MAS00110,History data 21-Minutes,53, min
IDE01807-MAS14375,History data 21-Cycle counter,12888,
IDE01807-MAS14376,History data 21-ECU 1,Brake electronics,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,1.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Multifunction module on the second bus connection,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,1.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Driver's door electronics,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.5, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2023,
IDE01809-MAS00107,History data 23-Month,5,
IDE01809-MAS00108,History data 23-Day,29,
IDE01809-MAS00109,History data 23-Hours,15, H
IDE01809-MAS00110,History data 23-Minutes,56, min
IDE01809-MAS14375,History data 23-Cycle counter,12890,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Comfort data bus,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,6,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Electronic central electric,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,38,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,1,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Passenger's door electronics,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,28,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,1,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.9, H
IDE01810-MAS00106,History data 24-Year,2023,
IDE01810-MAS00107,History data 24-Month,10,
IDE01810-MAS00108,History data 24-Day,28,
IDE01810-MAS00109,History data 24-Hours,11, H
IDE01810-MAS00110,History data 24-Minutes,43, min
IDE01810-MAS14375,History data 24-Cycle counter,13551,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,48,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,1B 00 00 0E,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,1,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Comfort data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,1B 00 00 4B,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,17 F0 00 09,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Extended data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,1B 00 00 09,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,1,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Extended data bus,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,13716,
IDE01812-MAS03173,History data 26-Powertrain data bus,14,
IDE01812-MAS03174,History data 26-Comfort data bus,39361,
IDE01812-MAS03175,History data 26-Extended data bus,36434,
IDE01812-MAS03177,History data 26-Infotainment data bus,0,
IDE01812-MAS03178,History data 26-Suspension data bus,255,
IDE01812-MAS03180,History data 26-Local data bus,7,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,65535,
IDE01813-MAS03173,History data 27-Powertrain data bus,16071,
IDE01813-MAS03174,History data 27-Comfort data bus,65535,
IDE01813-MAS03175,History data 27-Extended data bus,10630,
IDE01813-MAS03177,History data 27-Infotainment data bus,0,
IDE01813-MAS03178,History data 27-Suspension data bus,15129,
IDE01813-MAS14374,History data 27-Totals,65535,
IDE01814-MAS03173,History data 28-Powertrain data bus,1,
IDE01814-MAS03174,History data 28-Comfort data bus,65535,
IDE01814-MAS03175,History data 28-Extended data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,146,
IDE01814-MAS14374,History data 28-Totals,65535,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,1.0, H
IDE01816-MAS00106,History data 30-Year,2023,
IDE01816-MAS00107,History data 30-Month,5,
IDE01816-MAS00108,History data 30-Day,29,
IDE01816-MAS00109,History data 30-Hours,15, H
IDE01816-MAS00110,History data 30-Minutes,53, min
IDE01816-MAS14375,History data 30-Cycle counter,12888,
IDE01816-ENG151642,History data 30-Bus_1,Suspension data bus,
IDE01816-ENG151644,History data 30-Bus_2,Extended data bus,
IDE01816-ENG151646,History data 30-Bus_3,Comfort data bus,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,1.0, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,1.0, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.5, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,1.0, H
IDE01817-MAS00106,History data 31-Year,2023,
IDE01817-MAS00107,History data 31-Month,5,
IDE01817-MAS00108,History data 31-Day,29,
IDE01817-MAS00109,History data 31-Hours,15, H
IDE01817-MAS00110,History data 31-Minutes,53, min
IDE01817-MAS14375,History data 31-Cycle counter,12888,
IDE01817-MAS14376,History data 31-ECU 1,Brake electronics,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,1.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Multifunction module on the second bus connection,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,1.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Driver's door electronics,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.5, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2023,
IDE01818-MAS00107,History data 32-Month,5,
IDE01818-MAS00108,History data 32-Day,29,
IDE01818-MAS00109,History data 32-Hours,15, H
IDE01818-MAS00110,History data 32-Minutes,56, min
IDE01818-MAS14375,History data 32-Cycle counter,12890,
IDE01818-MAS14391,History data 32-Alerting ECU,Electronic central electric,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,1,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.9, H
IDE01819-MAS00106,History data 33-Year,2023,
IDE01819-MAS00107,History data 33-Month,10,
IDE01819-MAS00108,History data 33-Day,28,
IDE01819-MAS00109,History data 33-Hours,11, H
IDE01819-MAS00110,History data 33-Minutes,43, min
IDE01819-MAS14375,History data 33-Cycle counter,13551,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 0E,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.4, H
IDE01820-MAS00106,History data 34-Year,2023,
IDE01820-MAS00107,History data 34-Month,12,
IDE01820-MAS00108,History data 34-Day,23,
IDE01820-MAS00109,History data 34-Hours,19, H
IDE01820-MAS00110,History data 34-Minutes,34, min
IDE01820-MAS14375,History data 34-Cycle counter,13718,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,12, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,13719,
IDE01823-MAS14429,History data 37-Time in current cycle,0.3, H
IDE01827,Specified generator voltage,14.8, V
IDE01828,Generator DF Signal,48.400, %
IDE01829,Generator exciter current,3.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,Generator recognition 75-140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.762, V
IDE01836,Battery current,1.580, A
IDE01837,Temperature of battery sensor,26, °C
IDE01838,Battery temperature,19, °C
IDE01839,Battery charge level,69, %
IDE01841,Battery internal resistance,6.2, mOhm
IDE01842,Usable battery charge,39, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.9, Ah
IDE01849,Previous journey duration,0.3, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,19.3, A
IDE01948,Battery internal resistance not normed,6.2, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,BC C7 FA B0,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG137113,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG137115,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG137116,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG137117,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG137118,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG137119,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG137120,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG137121,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG137114,Play protection status-function_calls_counter_1,0,
IDE02578-ENG137122,Play protection status-function_calls_counter_2,0,
IDE02578-ENG137123,Play protection status-function_calls_counter_3,0,
IDE02578-ENG137124,Play protection status-function_calls_counter_4,0,
IDE02578-ENG137125,Play protection status-function_calls_counter_5,0,
IDE02578-ENG137126,Play protection status-function_calls_counter_6,0,
IDE02578-ENG137127,Play protection status-function_calls_counter_7,0,
IDE02578-ENG137128,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,10,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,259,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,15,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,4,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,65,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2023,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,12,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,10,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,20,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,28,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,12,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,7,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,9,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,36,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,57,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,49,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,3,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Battery state of charge too low,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Battery state of charge too low,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Battery state of charge too low,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Battery state of charge too low,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible standing time too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2023,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,9,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,4,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,8,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,6,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,4,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,18,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,18,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,13,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,14,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,54,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,28,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,4,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,6,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,28,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,26,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,Charge contingency,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,Battery state of charge too low,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,Battery state of charge too low,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,69, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,No malfunction,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,34 03 D8 02 22,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,Wrong switch-over,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,3,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module,
IDE06010-MAS00106,Driving profile history data 4-Year,2019,
IDE06010-MAS00107,Driving profile history data 4-Month,12,
IDE06010-MAS00108,Driving profile history data 4-Day,20,
IDE06010-MAS00109,Driving profile history data 4-Hours,15,
IDE06010-MAS00110,Driving profile history data 4-Minutes,24,
IDE06010-MAS00111,Driving profile history data 4-Seconds,44,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,42811, km
IDE06010-MAS03095,Driving profile history data 4-Function status,asynchronous,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,AUTO,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,141011,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,1838,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,22688,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,51,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2023,
IDE06230-MAS00107,Break recommend.: last message-Month,4,
IDE06230-MAS00108,Break recommend.: last message-Day,4,
IDE06230-MAS00109,Break recommend.: last message-Hours,19,
IDE06230-MAS00110,Break recommend.: last message-Minutes,47,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 1,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,10,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,76,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.7, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07637,Current charge contingent for feedback,3240.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.60,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.55, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.50, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,712, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,696, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,13619.4, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,13131.6, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,Not Used,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Not Used,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,E8 54 A2 13,
IDE08346-MAS06117,Generator Analysis-Specified voltage,14.8, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.7, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,1714, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,52, °C
IDE08347,adapted battery capacity,111, Ah
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,01 2F,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,01 3E,
IDE08685-SFT271901,Status LIN user-Generator,active,
IDE08685-SFT271921,Status LIN user-Multifunction steering wheel control module,active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Static current last LIN sleep phase,-0.068, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,5,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT271913,48V activation restriction-Auxiliary Air Heater Control Module/PTC,not active,
IDE11911-SFT272141,48V activation restriction-Electrical compressor,not active,
IDE12084,Component protection participant status,00 14 19 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 11 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Freewheel engine off block,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.80, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.60, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,10.6, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14)
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initialization,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2023,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,55,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,36,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,53,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,131862, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Seat,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,12,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT271901,Generator,-,
SFT271901-ENG250861,Generator-alternator_family,31,
SFT271901-ENG245985,Generator-asic_manufacturer,30 30,
SFT271901-ENG250451,Generator-asic_variant,30 34,
SFT271901-ENG171470,Generator-Manufacturer,30 30,
SFT271901-ENG99001,Generator-Variant,30 33,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,1,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,1,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG137076-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG137076-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG137076-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG137076-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG137076-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG137076-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG151180,EM_electrical_system_current,17.573, A
ENG118437,EM_IAlternatorReserve,55.6, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,450, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,78, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,64, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG246261,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG167301,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG167323,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG252593,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG167381,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG167382,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1005,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,2204,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9060,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG163716,Gateway app. software identification-software_version_mv-em,0300,
ENG118782-ENG163717,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7190,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG151185-ENG140447,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140444,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG151185-ENG140445,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG151185-ENG140443,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initialization,
ENG151187-ENG140428,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG151187-ENG140427,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG151187-ENG140429,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG151187-ENG140426,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG151187-ENG140425,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG151187-ENG140430,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initialization,
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,-204.0, A
ENG151192,MV-EM_dc_power_desired,-6325, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,-511, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
Elapsed Time: 00:48
;SW:3Q0-905-861-B HW:3Q0-905-861-B --- Steer. Col. Lock
;Component:ELV-MQBB H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW37.rod
;Saturday,23,December,2023,20:00:38:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 333872C66BB6A472E21-8066
Group,Description,Actual
IDE00019,Voltage terminal 30,14.7,
IDE00021,Engine RPM,699.00, /min
IDE00021-MAS00058,Engine RPM-Implausible,No,
IDE00021-MAS00103,Engine RPM-invalid,No,
IDE00021-MAS02239,Engine RPM-outdated,No,
IDE00021-MAS02246,Engine RPM-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,2,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,2,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,12894,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,to,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Not adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,39,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,255,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Not confirmed,
Elapsed Time: 00:04
;SW:5Q0-907-686-C HW:5Q0-907-686-C --- Lane Change
;Component:HRE_Master H12 0081, Coding:02012103
;EV_HREntryHella,001028,EV_HREntryHella_VW37.rod
;Saturday,23,December,2023,20:00:46:15566
;VCID: 3D2C54FE5DF26202045-8068
IDE00018,Voltage terminal 15,14.40, V
IDE00102,Control Module temperature,37.0, °C
IDE00925,Yaw rate,-0.01, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,2,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,2,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,15000.00, km
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057-MAS10065,Dynamic calibration: status-Distance of object 4,100, %
IDE02057,Dynamic calibration: status,is running,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,0.00,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,14.68, V
IDE05065,lane change assist. 2: temperature,35.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Rear Cross Traffic Alert,On,
IDE05070,Curve radius,14976, m
IDE05072,Status of lane change assist. indicator lamp,active,
IDE05077-IDE02389,Rain/light recognition sensor via data bus-Ambient brightness,0,
IDE05077,Rain/light recognition sensor via data bus,not defined,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,-120.00, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,0.00, m
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,0.00, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,-120.00, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,0.00, m
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,0.00, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,-120.00, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,0.00, m
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,0.00, m/s
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05086,Closest object lane used,No object recognized,
IDE05087,Dynamic angle offset lane change assist. 1,-0.54, °
IDE05088,Dynamic angle offset lane change assist. 2,-3.94, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,20.32, °
IDE05093,Measured angle lane change assist. 2,20.32, °
IDE05094,Static angle offset lane change assist. 1,0.00, °
IDE05095,Static angle offset lane change assist. 2,0.00, °
IDE05100,Spray counter,0,
IDE10101,Dimming value of left warning light,0, %
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10105,Dimming value of right warning light,0, %
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,0,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,0,
IDE10235-IDE10233,Status night design-Night design,activated,
IDE10235-IDE10234,Status night design-Day design,not activated,
IDE10235,Status night design,On,
IDE10236-MAS01487,Lane keeping warning system-LED,yellow,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,1.25, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Right,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System condition,System off,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,-120.00, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,0.00, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,-120.00, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,0.00, m
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,0.00, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,0.00, m/s
Elapsed Time: 00:08
;SW:5Q4-959-593-F HW:5Q4-959-593-F --- Door Elect, Driver
;Component:TSG FS 006 0246, Coding:00351320D000020000001000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW41.rod
;Saturday,23,December,2023,20:00:59:15566
;VCID: 48C2352A023037AAA73-801C
IDE00310,Outside temperature,20.00, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.60, V
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.80, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,15, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,9401,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,20.00, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,23.00, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,24.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,26.00, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,20.00, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,0.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,21, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote control lock switch,not installed,
MAS02101,Child safety lock,not active,
MAS06010,Ambient light,Not available,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
;SW:3Q0-909-144-M HW:3Q0-909-144-L --- Steering Assist
;Component:EPS_MQB_ZFLS 507 5082, Coding:931F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Saturday,23,December,2023,20:01:11:15566
;VCID: 3C2A59FA46E86B0A33B-8068
IDE00018,Voltage terminal 15,14.72, V
IDE00019,Voltage terminal 30,14.61, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,707, /min
IDE00102,Control Module temperature,27.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,05,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,N6,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,71,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,11,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assist-System status,operational,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assist-Function status,activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,19.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,-789.4, °
IDE03682-MAS03083,motor position sensor-Cosine signal,1.288, V
IDE03682-MAS03211,motor position sensor-Sine signal,2.695, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,Unknown (3)
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,operational,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-0.6, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,activated,
IDE03735,Steering torque,0.000, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,0.000, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.7, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.7, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,-0.001, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,14.66, V
IDE04187,Steering torque: raw value 1,53.809, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-68.066, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,53.809, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-68.066, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.40, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,-0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.4, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,-0.3, A
IDE04194,Steering assistance: electromotor power,-0.92, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-0.5, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.1, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,161.08, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical middle,0.16, mm
IDE04460,Steering angle sensor: offset straight line running,1.3, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine RPM,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.70, mm
IDE05162-MAS01850,Software end stop-Right,-80.38, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,953677,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,949489,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,43150,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,43150,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,10524239,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,980,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,913,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,962,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,89066,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,2,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,17,
MAS00976-IDE80003,Counter-Analysis 3,1374736261,
MAS00976-IDE80004,Counter-Analysis 4,1273875,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG168891-ENG169036,Strain_detection-Calculated_worm_gear_temperature,30.0, °C
ENG168891-ENG169118,Strain_detection-High_count_worm_gear_alt,1273875,
ENG168891-ENG169133,Strain_detection-KlimaSensor02_alt,1,
ENG168891-ENG169169,Strain_detection-Low_count_worm_gear_alt,1400437632,
ENG168891-ENG169177,Strain_detection-Mileage_counter,0, km
ENG168891-ENG169189,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG168891-ENG102605,Strain_detection-outside_temperature,20.0, °C
ENG168891-ENG168990,Strain_detection-revolutions_per_minute_electric_motor,-5, /min
ENG168891-ENG157280,Strain_detection-Steering_angle,-0.5, °
ENG168891-ENG168991,Strain_detection-steering_moment,0.000, Nm
ENG168891-ENG168992,Strain_detection-Steering_Support_Engine_Commanded_Torque,0.006, Nm
ENG168891-ENG169223,Strain_detection-Strain_detection_per_cent,0.0000095676, %
Elapsed Time: 00:08
;SW:5Q0-035-456-A HW:5Q0-035-456-A --- Sound System
;Component:MIB2_lite_amp H40 0200, Coding:3300000000A0AF8A000000000000
;EV_AMPMst11CGen2ALPI,001004,EV_AMPMst11CGen2ALPI_VW41.rod
;Saturday,23,December,2023,20:01:22:15566
;VCID: 2E0E63B28094899A8DF-807A
IDE00019,Voltage terminal 30,14.7, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,702.50, /min
IDE00767,No. of unscheduled ECU resets,1, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,26, min
IDE04317-MAS00108,Total system run time-Day,121, d
IDE04317-MAS00109,Total system run time-Hours,20, H
IDE04317-MAS00110,Total system run time-Minutes,19, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),5F,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,57, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-10, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,33, °C
IDE10545-MAS01188,Speaker status-Left front bass speaker,Condition not met,
IDE10545-MAS01190,Speaker status-Left front treble speaker,Condition not met,
IDE10545-MAS01191,Speaker status-Right front bass speaker,Condition not met,
IDE10545-MAS01193,Speaker status-Right front treble speaker,Condition not met,
IDE10545-MAS01194,Speaker status-Left rear bass speaker,Condition not met,
IDE10545-MAS01195,Speaker status-Left rear treble speaker,Measuring value not available,
IDE10545-MAS01196,Speaker status-Right rear bass speaker,Condition not met,
IDE10545-MAS01197,Speaker status-Right rear treble speaker,Measuring value not available,
IDE10545-MAS01198,Speaker status-Center speaker,Condition not met,
IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,Condition not met,
IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,Condition not met,
IDE10545,Speaker status,Measuring value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,205, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,205, °C
IDE10657-MAS02238,Temperature switching power supply-Up-to-date,205, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,57, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,-4, °C
IDE10659-MAS02238,Temperature switching power supply 2-Up-to-date,36, °C
MAS00464-MAS00111,Standard - ambient data 1-Seconds,27,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,4, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,23, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,12, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,23, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,19, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,34, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,42, s
Elapsed Time: 00:08
;SW:3Q0-907-338-C HW:3Q0-907-338-C --- Multifunc. Module
;Component:FCM MQB Low 002 0345, Coding:000000070900064201000940000000000000000000000000000000000000
;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW41.rod
;Saturday,23,December,2023,20:01:33:15566
;VCID: 353C4CDE65C2BA42CC5-8060
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,-0.50, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG161283,Processor load-Software_component_AFS_MXB,9, %
IDE01717-ENG161295,Processor load-Total_system_FCM,22, %
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,0, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,76.40, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-20.8, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,-43.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-43.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,102.0, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,102.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),81.20, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lamps,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08706-MAS17333,Actual angle of ref. segments-Vertical angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17334,Actual angle of ref. segments-Vertical angle reference segment right: as a percentage,-15.00, %
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of 1st WARNING,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of 2nd WARNING,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of 3rd WARNING,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,128,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,128,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,128,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2023,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,9,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,27,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,19,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,40,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,34,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,72,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,9.000000, °
ENG157518-ENG161284,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0162,
ENG157518-ENG161297,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7190,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,Malfunction,
Elapsed Time: 00:09
;SW:5Q4-959-592-F HW:5Q4-959-592-F --- Door Elect, Pass.
;Component:TSG BFS 006 0246, Coding:00351120D000020000001000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_AU49.rod
;Saturday,23,December,2023,20:01:47:15566
;VCID: 47C036160F2E38D2AE9-8012
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Passenger Door Control Module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.60, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.80, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,9401,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,14.00, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,13.00, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,22.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,30.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,23.00, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,21, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:08
;SW:5F0-035-020-K HW:5F0-035-020 --- Information Electr.
;Component:MU-H-ND-EU H55 1447, Coding:04230601000000001111010200880A232F0101E4012004009E
;EV_MUHig4CGen2HBAS,001001,EV_MUHig4CGen2HBAS_AU37.rod
;Saturday,23,December,2023,20:02:01:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 20128D8ACA402FEA0F3-8074
Group,Description,Actual
IDE00019,Voltage terminal 30,14.9, V
IDE00021,Engine RPM,694.50, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,69, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-7, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,50, °C
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,4.80, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,2, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Measuring value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measuring value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measuring value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measuring value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measuring value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measuring value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measuring value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measuring value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measuring value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measuring value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measuring value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measuring value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measuring value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measuring value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measuring value not available,
IDE01442-MAS06123,Pressing a button-Eject button,Not operated,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,0, dBµV
IDE01700-MAS01765,Status of tuner for digital radio (DAB)-Audio Signal,available.,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not activated,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,194064, kHz
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,DMB_Audio_HE_AAC_v2,
IDE01700-ENG117350,Status of tuner for digital radio (DAB)-Audio_Mode,00,
IDE01700-ENG117354,Status of tuner for digital radio (DAB)-Audio_Quality,99,
IDE01700-ENG117330,Status of tuner for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE01700-ENG117329,Status of tuner for digital radio (DAB)-availability_traffic_data_TP,Not available,
IDE01700-ENG117348,Status of tuner for digital radio (DAB)-Bit_Rate,0, kbps
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG117327,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,0.000540,
IDE01700-ENG117326,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,16.777215,
IDE01700-ENG117328,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET,16.777215,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label, ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117331,Status of tuner for digital radio (DAB)-Ensemble_ID,00 00 81 81,
IDE01700-ENG117332,Status of tuner for digital radio (DAB)-Ensemble_Label,MTVNL ,
IDE01700-ENG117333,Status of tuner for digital radio (DAB)-Ensemble_Label_Mask,00 00,
IDE01700-ENG117334,Status of tuner for digital radio (DAB)-Extended_Country_Code,E3,
IDE01700-ENG117342,Status of tuner for digital radio (DAB)-Label_Masks,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,00 00 81 20,
IDE01700-ENG117351,Status of tuner for digital radio (DAB)-Protection_Level,1_A_equal_protection_level,
IDE01700-ENG117349,Status of tuner for digital radio (DAB)-Sample_Rate,0, kHz
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,00,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,TOMRRWLND OWR NL,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117325,Status of tuner for digital radio (DAB)-signal_quality,82,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,00,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label, ,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01700-ENG117353,Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock,activated,
IDE01700-ENG117352,Status of tuner for digital radio (DAB)-Transmission_Mode,0,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,14,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,10,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,81, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,46, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,44, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,41, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,electrically OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,57, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01771-ENG117327,Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC,0.000140,
IDE01771-ENG117326,Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC,16.777215,
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,Not available,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG147302,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG151629,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG176482,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG151628,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG152005,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG152004,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG152003,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG152002,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG152001,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG152022,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG176468,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG151627,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG176474,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG151626,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG176502,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG151625,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG176449,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG151624,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG152746,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG151991,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG147289,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG151990,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG152007,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG152006,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,25,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,18,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,20,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,29,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,37, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,37, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,31, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,28, dBµV
IDE02384-ENG147282,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG151635,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG176424,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG151634,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG151996,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG151995,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG151994,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG151993,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG151992,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG152021,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG176458,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG151633,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG176476,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG151632,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG176459,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG151631,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG176512,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG151630,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG152743,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG152017,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG147299,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG152016,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG151998,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG151997,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Signal Strength,0, dBµV
IDE02505-MAS01765,Status of tuner 2 for digital radio (DAB)-Audio Signal,Not available,
IDE02505-MAS02572,Status of tuner 2 for digital radio (DAB)-Mute,not activated,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,180064, kHz
IDE02505-MAS03786,Status of tuner 2 for digital radio (DAB)-Audio Codec,Not available,
IDE02505-ENG117350,Status of tuner 2 for digital radio (DAB)-Audio_Mode,00,
IDE02505-ENG117354,Status of tuner 2 for digital radio (DAB)-Audio_Quality,0,
IDE02505-ENG117330,Status of tuner 2 for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE02505-ENG117329,Status of tuner 2 for digital radio (DAB)-availability_traffic_data_TP,Not available,
IDE02505-ENG117348,Status of tuner 2 for digital radio (DAB)-Bit_Rate,0, kbps
IDE02505-ENG117346,Status of tuner 2 for digital radio (DAB)-Charset,00,
IDE02505-ENG117327,Status of tuner 2 for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,1.000000,
IDE02505-ENG117326,Status of tuner 2 for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,16.777215,
IDE02505-ENG117328,Status of tuner 2 for digital radio (DAB)-DAB_Bit_Error_Rate_NET,16.777215,
IDE02505-ENG117340,Status of tuner 2 for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE02505-ENG117341,Status of tuner 2 for digital radio (DAB)-Data_Service_Label, ,
IDE02505-ENG117345,Status of tuner 2 for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE02505-ENG117331,Status of tuner 2 for digital radio (DAB)-Ensemble_ID,00 00 00 00,
IDE02505-ENG117332,Status of tuner 2 for digital radio (DAB)-Ensemble_Label, ,
IDE02505-ENG117333,Status of tuner 2 for digital radio (DAB)-Ensemble_Label_Mask,00 00,
IDE02505-ENG117334,Status of tuner 2 for digital radio (DAB)-Extended_Country_Code,00,
IDE02505-ENG117342,Status of tuner 2 for digital radio (DAB)-Label_Masks,00 00,
IDE02505-ENG117335,Status of tuner 2 for digital radio (DAB)-Program_Service_Identifier,00 00 00 00,
IDE02505-ENG117351,Status of tuner 2 for digital radio (DAB)-Protection_Level,1_A_equal_protection_level,
IDE02505-ENG117349,Status of tuner 2 for digital radio (DAB)-Sample_Rate,0, kHz
IDE02505-ENG117336,Status of tuner 2 for digital radio (DAB)-Service_Component_Identifier,00,
IDE02505-ENG117338,Status of tuner 2 for digital radio (DAB)-Service_Label, ,
IDE02505-ENG117343,Status of tuner 2 for digital radio (DAB)-Service_Label_Mask,00 00,
IDE02505-ENG117325,Status of tuner 2 for digital radio (DAB)-signal_quality,0,
IDE02505-ENG117337,Status of tuner 2 for digital radio (DAB)-Sub_Channel_Identifier,00,
IDE02505-ENG117339,Status of tuner 2 for digital radio (DAB)-Sub_Service_Label, ,
IDE02505-ENG117344,Status of tuner 2 for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE02505-ENG117353,Status of tuner 2 for digital radio (DAB)-SYNC/OFDM_Lock,not activated,
IDE02505-ENG117352,Status of tuner 2 for digital radio (DAB)-Transmission_Mode,0,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE03150-ENG147328,Readiness for bus sleep mode-Sleep Bit 0,Bus sleep mode,
IDE03150-ENG151641,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG176564,Readiness for bus sleep mode-Sleep Bit 1,Bus sleep mode,
IDE03150-ENG151640,Readiness for bus sleep mode-Sleep Bit 1 reserved,Bus sleep mode,
IDE03150-ENG152013,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Bus sleep mode,
IDE03150-ENG152012,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Bus sleep mode,
IDE03150-ENG152011,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Bus sleep mode,
IDE03150-ENG152010,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Bus sleep mode,
IDE03150-ENG152009,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Bus sleep mode,
IDE03150-ENG152008,Readiness for bus sleep mode-Sleep Bit 15,Bus sleep mode,
IDE03150-ENG176563,Readiness for bus sleep mode-Sleep Bit 2,Bus sleep mode,
IDE03150-ENG151639,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG176562,Readiness for bus sleep mode-Sleep Bit 3,Bus sleep mode,
IDE03150-ENG151638,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Bus sleep mode,
IDE03150-ENG176561,Readiness for bus sleep mode-Sleep Bit 4,Bus sleep mode,
IDE03150-ENG151637,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Bus sleep mode,
IDE03150-ENG176560,Readiness for bus sleep mode-Sleep Bit 5,Bus sleep mode,
IDE03150-ENG151636,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Bus sleep mode,
IDE03150-ENG152747,Readiness for bus sleep mode-Sleep Bit 6,Bus sleep mode,
IDE03150-ENG152000,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG147327,Readiness for bus sleep mode-Sleep Bit 7,Bus sleep mode,
IDE03150-ENG151999,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Bus sleep mode,
IDE03150-ENG152015,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Bus sleep mode,
IDE03150-ENG152014,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Bus sleep mode,
IDE03477-MAS00106,GPS time-Year,2023,
IDE03477-MAS00107,GPS time-Month,12,
IDE03477-MAS00108,GPS time-Day,23,
IDE03477-MAS00109,GPS time-Hours,19,
IDE03477-MAS00110,GPS time-Minutes,2,
IDE03477-MAS00111,GPS time-Seconds,9,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00110,System run time-Minutes,27, min
IDE04317-MAS00108,Total system run time-Day,133, d
IDE04317-MAS00109,Total system run time-Hours,9, H
IDE04317-MAS00110,Total system run time-Minutes,49, min
IDE04329,Status of all SWaP functions,|ID number,Release code for a SWaP function
IDE04334-MAS02643,Public key for SWaP function-Key,E5 C1 EB 0C 09 A6 EE 4E 6E 01 58 43 01 F2 7A C6 62 1C 3B 01 B5 16 8C 76 E9 39 3F 0C 5C AF 2C AD 54 4D 5D 96 5A 00 E2 B2 B9 D4 46 F0 66 E2 37 DF B0 C6 AF A4 D2 55 63 BA B5 7F 72 48 81 FF E0 8E 53 9B 37 E3 4E B2 08 3C EC 0F 90 BD 94 EC D1 A3 9B F2 B3 D3 2D 58 40 79 4D C0 44 3E B0 9E 2F 08 E2 60 00 DE 2D 67 69 67 52 1F B8 AD D7 A1 B9 5B B2 EB F6 D8 E9 FB D9 45 01 C2 6E B3 AD 5C 1F E3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG117822,Bus identification-BusIdentifier,|Bus Identifier|Busmaster|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MIB data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|,
IDE04484,Regional codes,FE FF,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04542-MAS03621,Status of active media source at output 2-Video codec,--------------------,
IDE04542-MAS03622,Status of active media source at output 2-Horizontal video resolution,65535,
IDE04542-MAS03623,Status of active media source at output 2-Vertical video resolution,65535,
IDE04542-MAS03778,Status of active media source at output 2-Active media source,Not available,
IDE04542-MAS03783,Status of active media source at output 2-Video Bitrate,65535, kbps
IDE04542-MAS03784,Status of active media source at output 2-Audio Bitrate,Not available,
IDE04542-MAS03785,Status of active media source at output 2-Digital rights management (DRM),Not available,
IDE04542-MAS03786,Status of active media source at output 2-Audio Codec,--------------------,
IDE04542-MAS03787,Status of active media source at output 2-Image format,--------------------,
IDE04542-MAS03788,Status of active media source at output 2-Horizontal image resolution,65535,
IDE04542-MAS03789,Status of active media source at output 2-Vertical image resolution,65535,
IDE04542-MAS03793,Status of active media source at output 2-Color depth,65535, bit
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,255,
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle status-Driving direction,Measuring value not available,
IDE04545-IDE01714,Vehicle status-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle status-Distance impulses,0,
IDE04545-IDE03684,Vehicle status-Vehicle stopped,Yes,
IDE04546-IDE00301,Calibration of navigation-Mileage,0.000, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,004°36'29,6"E
IDE04605-MAS01780,Navigation: Corrected position-Width,051°56'06,2"N
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.0, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,2C DC AD F3 38 F4,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,5,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,5,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,2,
IDE05277-MAS04286,Available changes in regional codes-Blue-ray regional codes,2,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
IDE05596-MAS00106,Last time GPS position outside map-Year,2023,
IDE05596-MAS00107,Last time GPS position outside map-Month,5,
IDE05596-MAS00108,Last time GPS position outside map-Day,3,
IDE05596-MAS00109,Last time GPS position outside map-Hours,14,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,39,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,52,
IDE05597-IDE03615,Bluetooth: Paired device 1-Variant,£=R;~iPhone"Apple Inc."
iPhone10,5Version 16.7.4 (Builÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth: device address,D4 A3 3D 52 3B 7E,
IDE05597-MAS01483,Bluetooth: Paired device 1-Software version,£=R;~iPhone"Apple Inc."
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),D4 A3,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),D4 A3,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,£=R;~iPhone"Apple Inc."
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,iPhone
"Apple Inc."
iPhone10,5
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,D4 A3,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,D4 A3,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,D4 A3,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,D4 A3,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,D4 A3,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,D4 A3,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,D4 A3,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,D4 A3,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,D4 A3,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,D4 A3,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,D4 A3,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,D4 A3,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,D4 A3,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,D4 A3,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,D4 A3,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,D4 A3,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,D4 A3,
IDE05598-IDE03615,Bluetooth: Paired device 2-Variant,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Software version,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Variant,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Software version,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Variant,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Software version,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Variant,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Software version,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,39.50, %
IDE05814,Individualization characteristic,0D 0F AE 55 87,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,56, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,-13, °C
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,35, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,71, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-8, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,34, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,63, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-13, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,44, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,70, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,0, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,50, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,205, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,205, °C
IDE06522-MAS02238,Temperature of phone unit-Up-to-date,205, °C
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2023.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,12, Months
IDE08530-MAS00108,Connection status online basic services-Day,23, d
IDE08530-MAS00109,Connection status online basic services-Hours,18, H
IDE08530-MAS00110,Connection status online basic services-Minutes,35, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,40,
IDE08530-ENG151979,Connection status online basic services-Server_HTTP_Status_Code_Textual,Backend request running,
IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
IDE08531-MAS00107,Connection status online license services-Month,0, Months
IDE08531-MAS00108,Connection status online license services-Day,0, d
IDE08531-MAS00109,Connection status online license services-Hours,0, H
IDE08531-MAS00110,Connection status online license services-Minutes,0, min
IDE08531-MAS07132,Connection status online license services-Code status,0,
IDE08531-MAS07134,Connection status online license services-ID services,31,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,0, Months
IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
IDE08531-ENG151979,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10412,Media status in optical drive,Empty,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardware version,---,
IDE10479-MAS01483,Interface for external media: identification-Software version,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG126194,Status of the navigation database-nav_db_module,|Country Code,Region Code
IDE10843-ENG126986,Function module: identification-Function_module_identification,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,available.,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,Yes,
IDE10926-ENG126987,Function module: status-Function_module_status,|Module Name,installed
IDE13417-MAS02646,Key (DTCP): MMX-Key type,none,
IDE13516-MAS01159,Device certificate (DTCP): MMX-Version number,0,
IDE13516-MAS01779,Device certificate (DTCP): MMX-Length,0,
IDE13516-MAS06742,Device certificate (DTCP): MMX-Certificate type,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2023,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,20,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,25,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,53,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,131862, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,2924, H
MAS00778-MAS00110,Multimedia System 1-Minutes,20, min
MAS00778-MAS00362,Multimedia System 1-Battery voltage,14.7, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,67, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,30, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,11, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,104.6, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,47, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,42, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,0,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,38, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, Months
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, Months
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,010.173.189.001 ,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.000 ,
MAS03782-ENG117421,WLAN-MAC_Address,2C DC AD F3 38 F6,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,100, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,89, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,2,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,11,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,4, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,23, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,12, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,23, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,19, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,6, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,45, s
ENG127486-ENG117422,mac_adress_wlan_tethering-IP_Address,---------------------------------------,
ENG127486-ENG117423,mac_adress_wlan_tethering-IP_Subnetmask,---------------------------------------,
ENG127486-ENG117421,mac_adress_wlan_tethering-MAC_Address,2C DC AD F3 38 F5,
ENG129160,MMX mNAND Flash Version,Product = mmx2
Branch = rel/CLU8_SEAT
Up to CL = 43700266
FirstTierSupplier = HARMAN
Project = project_mmx2_seat_er_g11.cfg
OEM = SE
Region = ER
Variant = G11
Media-Stack = EVO
Framework = 5.49.12.SR3 MIB2MAIN I199 CI68
JavaVM = j9_1.16+ObjectSwapper_1.02+XIPLoader_1.10+MCFObjectReader_1.01C+JavaCrypto_1.05+Socks5Support_1.00
DSI = 2_67.1
GraphicsServices = MIB2CLU8 199.1
Splashscreens = 65.0 MIB2MAIN
rdiserver = 122
Navigation = CLU8_16291MIB2MAIN_B17.11.1.80227
NavigationMapStyles:
- ASIA = 10.0.784
- AUS = 10.0.784
- EU = 10.0.784
- IL = 10.0.784
- INDIA = 10.0.784
- MEAST = 10.0.784
- MSA = 10.0.787
- MSA2 = 10.0.784
- NEAST = 10.0.784
- ZA = 10.0.784
LocationAccessor = 0.9.15
Speech = 129.1650.1-MIB2MAIN
SpeechResources = 129.1706.1
sseProc = 1.4.3
HMI = H29.344.66
Product = mmx2
Up to CL = 43700266
OEM = SE
Region = ER
Variant = G11
Media-Stack = EVO
JavaVM = j9_1.16+ObjectSwapper_,
ENG129161,MMX NOR Flash Version,Product = mmx2
Up to CL = 43700266
OEM = SE
Region = ER
Variant = G11
Media-Stack = EVO
DSI = 2_67.1
rdiserver = 122
- ASIA = 10.0.784
- AUS = 10.0.784
- EU = 10.0.784
- IL = 10.0.784
- INDIA = 10.0.784
- MEAST = 10.0.784
- MSA = 10.0.787
- MSA2 = 10.0.784
- NEAST = 10.0.784
- ZA = 10.0.784
sseProc = 1.4.3
HMI = H29.344.66
Product = mmx2
Up to CL = 43700266
OEM = SE
Region = ER
Variant = G11
Media-Stack = EVO
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,282, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,65535,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,65535,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
Elapsed Time: 00:32
;SW:5Q0-907-273-B HW:5Q0-907-273 --- Tire Pressure
;Component:RDKBERU30 H06 0009, Coding:
;EV_RDKBERU30,006001,EV_RDKBERU30_005.rod
;Saturday,23,December,2023,20:02:36:15566
;VCID: 343A71DA6EB8A34AFBB-8060
IDE00019,Voltage terminal 30,14.5, V
IDE00310,Outside temperature,11.5, °C
IDE03529-IDE03525,Last received tire pressure sensor in reception range-Sensor identification number (sensor ID),0,
IDE03529-IDE06104,Last received tire pressure sensor in reception range-Wheel position,Unknown,
IDE03529-MAS02818,Last received tire pressure sensor in reception range-CURRENT pressure,5.4, bar
IDE03529-MAS02819,Last received tire pressure sensor in reception range-CURRENT temperature,127, °C
IDE03529-MAS03159,Last received tire pressure sensor in reception range-Manufacturer,Unknown,
IDE03530-IDE03531,Monitoring status-Wheel/tire description,Seat Ateca TPMS ,
IDE03530-IDE03532,Monitoring status-Load status selected,Comfort,
IDE03530-IDE03533,Monitoring status-Front-axle SPECIFIED pressure,2.2, bar
IDE03530-IDE03534,Monitoring status-Rear-axle SPECIFIED pressure,2.2, bar
IDE03530-MAS05745,Monitoring status-Wheel / tire set,1,
IDE03535-IDE02955,System information-System status,active,
IDE03535-IDE03526,System information-Radio interference,not active,
IDE03535-MAS00080,System information-Coding information,22 00,
IDE03535-MAS00084,System information-Terminal 15 on,On,
IDE03535-MAS01561,System information-Unit,bar,
IDE03535-MAS01745,System information-Vehicle speed is not zero,OFF,
IDE03535-MAS02356,System information-Type of calibration,Menu,
IDE03535-MAS04188,System information-Transport mode,not active,
IDE03535-MAS05644,System information-Partial monitoring,not active,
IDE06105-IDE03525,Tire pressure sensor 01-Sensor identification number (sensor ID),651356874,
IDE06105-IDE06104,Tire pressure sensor 01-Wheel position,Left rear,
IDE06105-MAS02818,Tire pressure sensor 01-CURRENT pressure,2.2, bar
IDE06105-MAS02819,Tire pressure sensor 01-CURRENT temperature,127, °C
IDE06105-MAS02820,Tire pressure sensor 01-SPECIFIED pressure,2.2, bar
IDE06105-MAS03159,Tire pressure sensor 01-Manufacturer,HuF,
IDE06105-MAS05317,Tire pressure sensor 01-Warning pressure,2.6, bar
IDE06106-IDE03525,Tire pressure sensor 02-Sensor identification number (sensor ID),651311113,
IDE06106-IDE06104,Tire pressure sensor 02-Wheel position,Right front,
IDE06106-MAS02818,Tire pressure sensor 02-CURRENT pressure,2.4, bar
IDE06106-MAS02819,Tire pressure sensor 02-CURRENT temperature,127, °C
IDE06106-MAS02820,Tire pressure sensor 02-SPECIFIED pressure,2.2, bar
IDE06106-MAS03159,Tire pressure sensor 02-Manufacturer,HuF,
IDE06106-MAS05317,Tire pressure sensor 02-Warning pressure,2.6, bar
IDE06107-IDE03525,Tire pressure sensor 03-Sensor identification number (sensor ID),651357091,
IDE06107-IDE06104,Tire pressure sensor 03-Wheel position,Left front,
IDE06107-MAS02818,Tire pressure sensor 03-CURRENT pressure,2.3, bar
IDE06107-MAS02819,Tire pressure sensor 03-CURRENT temperature,127, °C
IDE06107-MAS02820,Tire pressure sensor 03-SPECIFIED pressure,2.2, bar
IDE06107-MAS03159,Tire pressure sensor 03-Manufacturer,HuF,
IDE06107-MAS05317,Tire pressure sensor 03-Warning pressure,2.6, bar
IDE06108-IDE03525,Tire pressure sensor 04-Sensor identification number (sensor ID),651352937,
IDE06108-IDE06104,Tire pressure sensor 04-Wheel position,Right rear,
IDE06108-MAS02818,Tire pressure sensor 04-CURRENT pressure,2.3, bar
IDE06108-MAS02819,Tire pressure sensor 04-CURRENT temperature,127, °C
IDE06108-MAS02820,Tire pressure sensor 04-SPECIFIED pressure,2.2, bar
IDE06108-MAS03159,Tire pressure sensor 04-Manufacturer,HuF,
IDE06108-MAS05317,Tire pressure sensor 04-Warning pressure,2.6, bar
IDE80001,Analysis 1,OFF,
IDE80002-IDE00056,Analysis 2-History data 1,05 02 01 3E 17 0B 17 84 80 84 00 26 D2 EA CA 02,
IDE80002-IDE00057,Analysis 2-History data 2,08 02 01 3E 17 0B 17 01 01 02 03 00 00 00 00 00,
IDE80002-IDE00058,Analysis 2-History data 3,05 02 01 33 16 0B 17 88 8C 94 00 26 D2 DB 69 03,
IDE80002-IDE00059,Analysis 2-History data 4,04 02 01 23 16 0B 17 80 8C 94 30 26 D2 DB 69 03,
IDE80002-IDE00060,Analysis 2-History data 5,04 02 01 23 16 0B 17 80 8C 94 2E 26 D2 EA CA 02,
IDE80002-IDE00061,Analysis 2-History data 6,05 02 01 1D 16 0B 17 88 8C 90 00 26 D2 EA CA 02,
IDE80002-IDE00062,Analysis 2-History data 7,05 02 01 0E 16 0B 17 88 8C 90 00 26 D2 DB 69 03,
IDE80002-IDE00063,Analysis 2-History data 8,05 02 01 0B 16 0B 17 88 8C 90 00 26 D2 EB A3 00,
IDE80002-IDE00064,Analysis 2-History data 9,04 02 01 04 16 0B 17 80 8C 90 2D 26 D2 DB 69 03,
IDE80002-IDE00065,Analysis 2-History data 10,04 02 01 04 16 0B 17 80 8C 90 2C 26 D2 EB A3 00,
IDE80002-MAS03991,Analysis 2-Reception level antenna 1,430, mV
IDE80002-MAS04488,Analysis 2-Offset level antenna 1,210, mV
MAS00464-MAS00111,Standard - ambient data 1-Seconds,38,
MAS02821-MAS01853,Check tire pressure-Left front,no warning,
MAS02821-MAS01854,Check tire pressure-Right front,no warning,
MAS02821-MAS01855,Check tire pressure-Left rear,no warning,
MAS02821-MAS01856,Check tire pressure-Right rear,no warning,
MAS02821-MAS05636,Check tire pressure-Unknown position,no warning,
MAS02822-MAS01853,Flat tire-Left front,no warning,
MAS02822-MAS01854,Flat tire-Right front,no warning,
MAS02822-MAS01855,Flat tire-Left rear,no warning,
MAS02822-MAS01856,Flat tire-Right rear,no warning,
MAS02822-MAS05636,Flat tire-Unknown position,no warning,
MAS02823-MAS01853,Tire pressure too low-Left front,no warning,
MAS02823-MAS01854,Tire pressure too low-Right front,no warning,
MAS02823-MAS01855,Tire pressure too low-Left rear,no warning,
MAS02823-MAS01856,Tire pressure too low-Right rear,no warning,
MAS02823-MAS05636,Tire pressure too low-Unknown position,no warning,
MAS05645-IDE03511,Wheel / tire set 1-Front-axle SPECIFIED pressure fully loaded,2.5, bar
MAS05645-IDE03512,Wheel / tire set 1-Rear-axle SPECIFIED pressure fully loaded,2.5, bar
MAS05645-IDE03531,Wheel / tire set 1-Wheel/tire description,Seat Ateca TPMS ,
MAS05645-IDE08521,Wheel / tire set 1-Front-axle SPECIFIED pressure comfort,2.2, bar
MAS05645-IDE08522,Wheel / tire set 1-Rear-axle SPECIFIED pressure comfort,2.2, bar
MAS05645-IDE08523,Wheel / tire set 1-Front-axle SPECIFIED pressure standard,2.5, bar
MAS05645-IDE08524,Wheel / tire set 1-Rear-axle SPECIFIED pressure standard,2.7, bar
MAS05646-IDE03511,Wheel / tire set 2-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05646-IDE03512,Wheel / tire set 2-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05646-IDE03531,Wheel / tire set 2-Wheel/tire description, ,
MAS05646-IDE08521,Wheel / tire set 2-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05646-IDE08522,Wheel / tire set 2-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05646-IDE08523,Wheel / tire set 2-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05646-IDE08524,Wheel / tire set 2-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05647-IDE03511,Wheel / tire set 3-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05647-IDE03512,Wheel / tire set 3-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05647-IDE03531,Wheel / tire set 3-Wheel/tire description, ,
MAS05647-IDE08521,Wheel / tire set 3-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05647-IDE08522,Wheel / tire set 3-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05647-IDE08523,Wheel / tire set 3-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05647-IDE08524,Wheel / tire set 3-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05648-IDE03511,Wheel / tire set 4-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05648-IDE03512,Wheel / tire set 4-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05648-IDE03531,Wheel / tire set 4-Wheel/tire description, ,
MAS05648-IDE08521,Wheel / tire set 4-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05648-IDE08522,Wheel / tire set 4-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05648-IDE08523,Wheel / tire set 4-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05648-IDE08524,Wheel / tire set 4-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05649-IDE03511,Wheel / tire set 5-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05649-IDE03512,Wheel / tire set 5-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05649-IDE03531,Wheel / tire set 5-Wheel/tire description, ,
MAS05649-IDE08521,Wheel / tire set 5-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05649-IDE08522,Wheel / tire set 5-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05649-IDE08523,Wheel / tire set 5-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05649-IDE08524,Wheel / tire set 5-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05650-IDE03511,Wheel / tire set 6-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05650-IDE03512,Wheel / tire set 6-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05650-IDE03531,Wheel / tire set 6-Wheel/tire description, ,
MAS05650-IDE08521,Wheel / tire set 6-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05650-IDE08522,Wheel / tire set 6-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05650-IDE08523,Wheel / tire set 6-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05650-IDE08524,Wheel / tire set 6-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05651-IDE03511,Wheel / tire set 7-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05651-IDE03512,Wheel / tire set 7-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05651-IDE03531,Wheel / tire set 7-Wheel/tire description, ,
MAS05651-IDE08521,Wheel / tire set 7-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05651-IDE08522,Wheel / tire set 7-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05651-IDE08523,Wheel / tire set 7-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05651-IDE08524,Wheel / tire set 7-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05652-IDE03511,Wheel / tire set 8-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05652-IDE03512,Wheel / tire set 8-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05652-IDE03531,Wheel / tire set 8-Wheel/tire description, ,
MAS05652-IDE08521,Wheel / tire set 8-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05652-IDE08522,Wheel / tire set 8-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05652-IDE08523,Wheel / tire set 8-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05652-IDE08524,Wheel / tire set 8-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05653-IDE03511,Wheel / tire set 9-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05653-IDE03512,Wheel / tire set 9-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05653-IDE03531,Wheel / tire set 9-Wheel/tire description, ,
MAS05653-IDE08521,Wheel / tire set 9-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05653-IDE08522,Wheel / tire set 9-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05653-IDE08523,Wheel / tire set 9-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05653-IDE08524,Wheel / tire set 9-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05654-IDE03511,Wheel / tire set 10-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05654-IDE03512,Wheel / tire set 10-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05654-IDE03531,Wheel / tire set 10-Wheel/tire description, ,
MAS05654-IDE08521,Wheel / tire set 10-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05654-IDE08522,Wheel / tire set 10-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05654-IDE08523,Wheel / tire set 10-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05654-IDE08524,Wheel / tire set 10-Rear-axle SPECIFIED pressure standard,25.5, bar
MAS05655-IDE03511,Wheel / tire set 11-Front-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05655-IDE03512,Wheel / tire set 11-Rear-axle SPECIFIED pressure fully loaded,25.5, bar
MAS05655-IDE03531,Wheel / tire set 11-Wheel/tire description, ,
MAS05655-IDE08521,Wheel / tire set 11-Front-axle SPECIFIED pressure comfort,25.5, bar
MAS05655-IDE08522,Wheel / tire set 11-Rear-axle SPECIFIED pressure comfort,25.5, bar
MAS05655-IDE08523,Wheel / tire set 11-Front-axle SPECIFIED pressure standard,25.5, bar
MAS05655-IDE08524,Wheel / tire set 11-Rear-axle SPECIFIED pressure standard,25.5, bar
Elapsed Time: 00:05
;SW:5Q0-907-383-N HW:5Q0-907-383-N --- Trailer
;Component:Anhaenger H27 0264, Coding:0100000202000000
;EV_TrailFunctGener2Hella,001008,EV_TrailFunctGener2Hella_VW26.rod
;Saturday,23,December,2023,20:02:46:15566
;VCDS Version: Release 23.11.0 (x64) Data version: 20231216 DS351.0
;VCID: 42D62702240C1DFA797-8016
Group,Description,Actual
IDE01441-IDE02270,Back-up lamp-CAN input signal(s) status,OFF,
IDE01441-IDE04759,Back-up lamp-Hardware output,OFF,
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE01943-IDE05405,Turn signal lamp-Hardware output for left,OFF,
IDE01943-IDE05406,Turn signal lamp-Hardware output for right,OFF,
IDE01943-IDE05407,Turn signal lamp-Light source detection for left,Measuring value not available,
IDE01943-IDE05408,Turn signal lamp-Light source detection for right,Measuring value not available,
IDE01943-MAS00525,Turn signal lamp-Trailer turn signal indicator lamp,OFF,
IDE01943-MAS04425,Turn signal lamp-Left turn signal via CAN,OFF,
IDE01943-MAS04426,Turn signal lamp-Right turn signal via CAN,OFF,
IDE01943-MAS04427,Turn signal lamp-Emergency flasher signal via CAN,Measuring value not available,
IDE02486-MAS01632,Data logger triggering-Status,not activated,
IDE03310-IDE02271,Brake lamp-CAN output signal(s) status,OFF,
IDE03310-IDE04751,Brake lamp-Hardware input,OFF,
IDE03310-IDE04759,Brake lamp-Hardware output,OFF,
IDE03310-IDE04803,Brake lamp-Light source detection,Measuring value not available,
IDE03310-MAS04422,Brake lamp-Brake light signal via CAN,OFF,
IDE03310-MAS04423,Brake lamp-Automatic braking signal via CAN,OFF,
IDE03310-MAS04424,Brake lamp-Driver brakes signal via CAN,OFF,
IDE03310-MAS09719,Brake lamp-Status of output signal 2 via CAN,OFF,
IDE03310-MAS09720,Brake lamp-Signal 2 automatic braking via CAN,OFF,
IDE03527-IDE00075,CAN signals-Vehicle speed,0.00, km/h
IDE03527-IDE01211,CAN signals-Static current measuring mode,not active,
IDE03527-IDE02049,CAN signals-Trailer detected,not detected,
IDE03527-MAS00217,CAN signals-Rear window,OFF,
IDE03527-MAS02290,CAN signals-Rear lid,OFF,
IDE03680-IDE00020,Supply voltages-Terminal 15 status,On,
IDE03680-IDE00773,Supply voltages-Terminal 15 status via CAN,On,
IDE03680-IDE04760,Supply voltages-Terminal 30 status output (pin 9 power outlet),OFF,
IDE03680-IDE04761,Supply voltages-Terminal 30 status output controlled (pin 10 power outlet),OFF,
IDE03680-IDE05404,Supply voltages-Terminal 75x status via CAN,On,
IDE03680-IDE05967,Supply voltages-Voltage terminal 30 left,14.7, V
IDE03680-IDE05968,Supply voltages-Voltage terminal 30 right,14.6, V
IDE03680-IDE05969,Supply voltages-Voltage terminal 30 trailer supply,14.7, V
IDE03680-IDE05970,Supply voltages-Voltage terminal 30 engine supply,14.7, V
IDE03680-IDE10782,Supply voltages-Voltage terminal 30 charging output,14.9, V
IDE05413-IDE05405,Tail lamp-Hardware output for left,OFF,
IDE05413-IDE05406,Tail lamp-Hardware output for right,OFF,
IDE05413-IDE05407,Tail lamp-Light source detection for left,Measuring value not available,
IDE05413-IDE05408,Tail lamp-Light source detection for right,Measuring value not available,
IDE05413-MAS04428,Tail lamp-Tail light signal via CAN,On,
IDE05413-MAS04429,Tail lamp-Left parking light signal via CAN,OFF,
IDE05413-MAS04430,Tail lamp-Right parking light signal via CAN,OFF,
IDE05594-IDE04762,Trailer hitch motor management-Fully electrical trailer hitch,retracted,
IDE05594-IDE04802,Trailer hitch motor management-Trailer swing warning,no warning,
IDE05594-MAS02002,Trailer hitch motor management-Pivoting trailer hitch,OFF,
IDE05594-MAS04336,Trailer hitch motor management-Pivoting: status,locked,
IDE05594-MAS04337,Trailer hitch motor management-Engine current,0.0, A
IDE05594-MAS04338,Trailer hitch motor management-Hall sensor,7,
IDE05594-MAS04339,Trailer hitch motor management-Contact switch 1 on lock pin,For,
IDE05594-MAS04340,Trailer hitch motor management-Contact switch 2 on lock pin,to,
IDE05594-MAS04495,Trailer hitch motor management-Connector A diagnosis,not detected,
IDE09591-ENG125418,Trailer hitch indicator light-Trailor_hitch_indicator_lamp,OFF,
IDE09592-ENG125418,Trailer hitch indicator light 2-Trailor_hitch_indicator_lamp,OFF,
IDE09593,Trailer brake activation,OFF,
IDE09594,Trailer brake activation: diagnosis,Measuring value not available,
IDE12009-IDE09554,Trailer load and trailer nose recognition: values-Power supply,14.6, V
IDE12009-MAS01561,Trailer load and trailer nose recognition: values-Unit,not coded/not installed,
IDE12009-MAS13747,Trailer load and trailer nose recognition: values-Trailer nose,not coded/not installed,
IDE12009-MAS13748,Trailer load and trailer nose recognition: values-Trailer load,65534,
IDE12009-ENG98504,Trailer load and trailer nose recognition: values-Day,FF,
IDE12009-ENG98748,Trailer load and trailer nose recognition: values-Month,FF,
IDE12009-ENG99063,Trailer load and trailer nose recognition: values-Year,FF,
MAS03836-IDE02270,Rear fog lamp-CAN input signal(s) status,OFF,
MAS03836-IDE02271,Rear fog lamp-CAN output signal(s) status,not active,
MAS03836-IDE04759,Rear fog lamp-Hardware output,OFF,
MAS03836-IDE04803,Rear fog lamp-Light source detection,Measuring value not available,
MAS04102-IDE04756,Controls-Button for trailer hitch: extend,not coded/not installed,
MAS04102-IDE04757,Controls-Button for trailer hitch: retract,not coded/not installed,
MAS04102-IDE04758,Controls-Button for trailer hitch: unlock,Not operated,
MAS04102-IDE05792,Controls-Contact switch on hand wheel,not coded/not installed,
MAS04102-MAS04341,Controls-Function illumination supply voltage: status,OFF,
MAS04606-IDE03615,Parameter set-Variant,Version L,
MAS04606-MAS01159,Parameter set-Version number,1,
Elapsed Time: 00:14
;SW:5Q0-907-556-C HW:5Q0-907-556 --- Back-up Cam.
;Component:Areaview 2 H13 0608, Coding:06230601270FA00000606814
;EV_CamSysRVAV2ARCE2MQBAB,006017,EV_CamSysRVAV2ARCE2MQBAB_006_SK37.rod
;Saturday,23,December,2023,20:03:04:15566
;VCID: 392440EE49DA5E2228D-806C
IDE00019,Voltage terminal 30,14.48258, V
IDE00303-MAS00218,Status: doors/lids 1-Driver door,closed,
IDE00303-MAS00219,Status: doors/lids 1-Front Passenger Door,closed,
IDE00303-MAS00220,Status: doors/lids 1-Left rear door,closed,
IDE00303-MAS00221,Status: doors/lids 1-Right rear door,closed,
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status: doors/lids 1-Hood,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,not detected,
IDE00924-IDE08941,Steering angle-Rack position,163.78, mm
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,0.5, °
IDE00924,Steering angle,0.0375, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,81.89, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01164,Parking aid button,Not operated,
IDE01632,System status of parking aid,not active,
IDE01714,Status reverse gear,not selected,
IDE02322,Parking aid indicator light,not active,
IDE04515-MAS10857,Supply voltage for camera-Front camera,12.0, V
IDE04515-MAS10858,Supply voltage for camera-Rear camera,12.0, V
IDE04515-MAS10859,Supply voltage for camera-Camera left,12.0, V
IDE04515-MAS10860,Supply voltage for camera-Camera right,12.0, V
IDE05418-MAS02209,Image adjustment-Image contrast,51, %
IDE05418-MAS02851,Image adjustment-Brightness,57, %
IDE05418-MAS04278,Image adjustment-Color intensity,51, %
IDE07159-MAS01155,Control module switch-off: counter-Control module,57,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,51,
IDE07402,External activation,not active,
IDE10548-MAS11001,Reasons for poor image quality-Reason,Freeze frame conditions,
IDE10548-MAS11002,Reasons for poor image quality-current likeliness,0.0000000,
IDE10589-MAS10857,Temperature of the camera-Front camera,53, °C
IDE10589-MAS10858,Temperature of the camera-Rear camera,46, °C
IDE10589-MAS10859,Temperature of the camera-Camera left,46, °C
IDE10589-MAS10860,Temperature of the camera-Camera right,47, °C
IDE10605-IDE00010,Camera front: version information-Serial number,
IDE10605-MAS01482,Camera front: version information-Hardware version,013,
IDE10605-MAS01483,Camera front: version information-Software version,0107,
IDE10605-MAS04970,Camera front: version information-Part Number,5Q0980546A.,
IDE10606-IDE00010,Camera rear: version information-Serial number,
IDE10606-MAS01482,Camera rear: version information-Hardware version,013,
IDE10606-MAS01483,Camera rear: version information-Software version,0107,
IDE10606-MAS04970,Camera rear: version information-Part Number,5Q0980546A.,
IDE10607-IDE00010,Camera left: version information-Serial number,
IDE10607-MAS01482,Camera left: version information-Hardware version,013,
IDE10607-MAS01483,Camera left: version information-Software version,0107,
IDE10607-MAS04970,Camera left: version information-Part Number,5Q0980546A.,
IDE10608-IDE00010,Camera right: version information-Serial number,
IDE10608-MAS01482,Camera right: version information-Hardware version,013,
IDE10608-MAS01483,Camera right: version information-Software version,0107,
IDE10608-MAS04970,Camera right: version information-Part Number,5Q0980546A.,
IDE10648,Operation time of the ARA function,0.000, s
IDE10649,ARA Status of camera,Initialization,
IDE10650,ARA camera function: activation,not active,
IDE10666-MAS10857,Connection status camera-Front camera,Normal operating mode,
IDE10666-MAS10858,Connection status camera-Rear camera,Normal operating mode,
IDE10666-MAS10859,Connection status camera-Camera left,Normal operating mode,
IDE10666-MAS10860,Connection status camera-Camera right,Normal operating mode,
IDE10740-IDE01453,System state area view-MMI display request,not requested,
IDE10740-IDE01454,System state area view-MMI display feedback,No display,
IDE10740-IDE03619,System state area view-System condition,System active,
IDE10740-MAS02224,System state area view-Display request,passive,
IDE11014-MAS10857,Calibration table status-Front camera,not installed,
IDE11014-MAS10858,Calibration table status-Rear camera,not installed,
IDE11014-MAS10859,Calibration table status-Camera left,not installed,
IDE11014-MAS10860,Calibration table status-Camera right,not installed,
IDE11016-MAS11931,Rear camera: quality-Connection quality,Good,
IDE11016-MAS11932,Rear camera: quality-Counter open circuit,0,
IDE11016-MAS11933,Rear camera: quality-Counter CRC error,0,
IDE11017-MAS11931,Front camera: quality-Connection quality,Good,
IDE11017-MAS11932,Front camera: quality-Counter open circuit,0,
IDE11017-MAS11933,Front camera: quality-Counter CRC error,0,
IDE11018-MAS11931,Left camera: quality-Connection quality,Good,
IDE11018-MAS11932,Left camera: quality-Counter open circuit,0,
IDE11018-MAS11933,Left camera: quality-Counter CRC error,0,
IDE11019-MAS11931,Right camera: quality-Connection quality,Good,
IDE11019-MAS11932,Right camera: quality-Counter open circuit,0,
IDE11019-MAS11933,Right camera: quality-Counter CRC error,0,
IDE11129-ENG132725,Line calibration status-Line_calibration_max_deviation_exceeded,not_set,
IDE11129-ENG132728,Line calibration status-Line_calibration_max_final_error_exceeded,not_set,
IDE11129-ENG132723,Line calibration status-Line_calibration_not_successful,not_set,
IDE11129-ENG132722,Line calibration status-Line_calibration_running,Not_running,
IDE11129-ENG132724,Line calibration status-Line_calibration_solver_error,not_set,
IDE11129-ENG132726,Line calibration status-Line_calibration_solver_max_iterations_reached,Not_reached,
IDE11129-ENG132721,Line calibration status-Line_calibration_successful,Set,
IDE11129-ENG132727,Line calibration status-Line_detection_failure,not_set,
IDE11130-MAS12219,Line calibration error-Left front Range,detected,
IDE11130-MAS12220,Line calibration error-Right front Range,detected,
IDE11130-MAS12221,Line calibration error-Left rear range,detected,
IDE11130-MAS12222,Line calibration error-Right rear range,detected,
IDE11130-MAS12223,Line calibration error-Left horizontal range,detected,
IDE11130-MAS12224,Line calibration error-Left vertical range,detected,
IDE11130-MAS12225,Line calibration error-Right horizontal range,detected,
IDE11130-MAS12226,Line calibration error-Right vertical range,detected,
IDE11137,Line calibration phases,Calibration ended,
MAS00464-MAS00107,Standard - ambient data 1-Month,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,34,
ENG157318-ENG161081,Camera_calibration_values-Front_camera_H_position_deviation,-9.0,
ENG157318-ENG161082,Camera_calibration_values-Front_camera_X_rotation_deviation,-0.1,
ENG157318-ENG161083,Camera_calibration_values-Front_camera_Y_rotation_deviation,0.4,
ENG157318-ENG161084,Camera_calibration_values-Front_camera_Z_rotation_deviation,0.5,
ENG157318-ENG161095,Camera_calibration_values-Left_camera_H_position_deviation,7.6,
ENG157318-ENG161096,Camera_calibration_values-Left_camera_X_rotation_deviation,-0.9,
ENG157318-ENG161097,Camera_calibration_values-Left_camera_Y_rotation_deviation,0.6,
ENG157318-ENG161098,Camera_calibration_values-Left_camera_Z_rotation_deviation,0.7,
ENG157318-ENG161143,Camera_calibration_values-Rear_camera_H_position_deviation,35.3,
ENG157318-ENG161144,Camera_calibration_values-Rear_camera_X_rotation_deviation,-0.3,
ENG157318-ENG161145,Camera_calibration_values-Rear_camera_Y_rotation_deviation,0.8,
ENG157318-ENG161146,Camera_calibration_values-Rear_camera_Z_rotation_deviation,-0.4,
ENG157318-ENG161168,Camera_calibration_values-Right_camera_H_position_deviation,8.0,
ENG157318-ENG161169,Camera_calibration_values-Right_camera_X_rotation_deviation,0.3,
ENG157318-ENG161170,Camera_calibration_values-Right_camera_Y_rotation_deviation,0.8,
ENG157318-ENG161171,Camera_calibration_values-Right_camera_Z_rotation_deviation,-1.3,
Elapsed Time: 00:24
;SW:5Q0-959-107-P HW:5Q0-959-107-J --- Trunk Elect.
;Component:HDSG-Modul H13 0266, Coding:1988
;EV_DeckLidCONTIAU736,001016,EV_DeckLidCONTIAU736_VW37.rod
;Saturday,23,December,2023,20:03:31:15566
;VCID: 45DC3C1E35222AC25C5-8010
IDE00019,Voltage terminal 30,14.75, V
IDE00542,Excessive temperature protection,not active,
IDE02010,Motor 1 for rear lid: activation,0, %
IDE02011,Motor 1 for tailgate: current,0.00, A
IDE02013,Motor 2 for rear lid: activation,0, %
IDE02014,Motor 2 for tailgate: current,0.00, A
IDE02017,Rear lid position: relative,0, %
IDE02018,Rear lid position: absolute,0,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,99, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,1737,
IDE02049,Trailer detected,not detected,
IDE02093-MAS09014,Status of rear lid lock-pre-latch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main latch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,Not operated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,Not operated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,Not operated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,Not operated,
IDE02171-MAS01913,Terminals for closing assist-Closing assistance,not locked,
IDE02171-MAS01943,Terminals for closing assist-Terminal 1,Open,
IDE02171-MAS01944,Terminals for closing assist-Terminal 2,Open,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,1749,
IDE03615-MAS02672,Variant-Start-stop,2,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,OFF,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
IDE05584,Rear lid basic setting status,Unknown (7)
IDE09491-IDE03434,Lock-in area-Detection area lower,176,
IDE09491-IDE03435,Lock-in area-Detection area upper,20,
IDE09492-MAS06165,Temperatures-Processor,32.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,11.00, °C
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,0.00, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,28.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,12.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,12.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,28.00, °C
IDE09492-MAS09053,Temperatures-Output stage for closing assist: calculated,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,0.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,28.00, °C
IDE09493,Status of basic tailgate setting,Basic setting not active,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Cancel,
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Cancel,
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,was cancelled due to safety reasons,
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Cancel,
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Cancel,
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Position error sensor 1,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Reset,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Position underrun,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Position underrun,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,Not operated,
IDE09498-MAS01872,Status of control points-Rear lid remote control lock switch,Not operated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,Not operated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,Not operated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,Not operated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,Malfunction,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,Malfunction,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,Malfunction,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.57, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,3446,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,2571,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,256,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,131,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,3191,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,2630,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,792,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,1,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,770,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,0,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,794,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,10,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,1355,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,296,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,26557,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,599,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,6,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,7,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09506,Rear lid anti-play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000000 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000000 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000000 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000000 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,0,
IDE10697-MAS02282,Luggage compartment cover: position-Position,0,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initialization,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,not active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,6,
Elapsed Time: 00:06
;SW:3QD-980-654 HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H09 1272, Coding:030307060000040000222355C150A90098000E200020
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_SE37.rod
;Saturday,23,December,2023,20:03:42:15566
;VCID: 0842F52A42B0F7AA673-805C
IDE00018,Voltage terminal 15,14.4, V
IDE00102,Control Module temperature,33, °C
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,0.5, °
IDE00767,No. of unscheduled ECU resets,0,
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.14, °/s
IDE00973,Outside temperature,11.5, °C
IDE01968,Dynamic calibration: yaw angle offset,2.552, °
IDE01969,Dynamic calibration: pitch angle offset,-0.141, °
IDE01970,Dynamic calibration: roll angle offset,-0.115, °
IDE01971,Lowest recorded control module temperature,-7, °C
IDE01972,Highest recorded control module temperature,85, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Fuzziness/Diffusion,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,3940, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,4,
IDE04125,Visibility,Not assigned,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration KD OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,-0.011, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.086, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-2.648, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1449, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2022,
IDE10664-MAS00107,Current initial calibration: details-Month,11,
IDE10664-MAS00108,Current initial calibration: details-Day,17,
IDE10664-MAS00109,Current initial calibration: details-Hours,11,
IDE10664-MAS00110,Current initial calibration: details-Minutes,28,
IDE10664-MAS00111,Current initial calibration: details-Seconds,47,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,106451,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00101111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,VSSZZZ5FZK6528195,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1383,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,632,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,357,
IDE10664,Current initial calibration: details,00110011 ,
IDE10664,Current initial calibration: details,00101110 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,48,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,No malfunction,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:27
;SW:4K0-907-594-AC HW:4K0-907-594 --- Sunroof
;Component:SAD_STG_1 005 0002, Coding:408040532602
;EV_SunRoofCONTIAU736,009011,EV_SunRoofCONTIAU736_009_VW37.rod
;Saturday,23,December,2023,20:04:13:15566
;VCID: 75BC8CDE2542FA420C5-8020
IDE03114-MAS02447,Comfort function-Release,not installed,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,not active,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,not active,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,Not operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,Not operated,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,Not operated,
IDE09422-MAS02282,Roof shade-Position,0, %
IDE09422-MAS05370,Roof shade-Direction of movement,Not moving,
IDE09422-MAS05563,Roof shade-Norming,standardized,
IDE09422-MAS08536,Roof shade-Excessive temperature protection,not active,
IDE09422-MAS08862,Roof shade-Reversing,not active,
IDE09422-MAS08866,Roof shade-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,standardized,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,not installed,
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,14,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,8,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,3,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,12,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,232,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,258,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,469,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,2,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,0,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,1,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,162,
IDE09430,History data sunroof reversing,|Year,Month
IDE09431,History data sunroof shade reversing,|Year,Month
IDE09492-MAS01155,Temperatures-Control module,20.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,11.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,20.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,20.00, °C
IDE09515-MAS08884,Controls-Sunroof button,Not operated,
IDE09515-MAS08932,Controls-Sunroof shade button,Not operated,
IDE09515-MAS08992,Controls-Button for sliding roof,Not operated,
IDE09515-MAS12701,Controls-Background lighting,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Front passenger side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Search illumination for control elements,89, %
IDE09517-MAS11499,Control module-Indicator lamp for rear sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,14.60, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE09844,History data sunroof standardization,|Year,Month
IDE09845,History data roof blind standardization,|Year,Month
IDE09846,History data sunroof control point,|Year,Month
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Unknown (255)
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Unknown (255)
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255)
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Unknown (255)
IDE12985-MAS15419,Operating signals: rear door control modules-Operating signal: rear: driver side sliding/tilting sunroof,Not operated,
IDE12985-MAS15420,Operating signals: rear door control modules-Operating signal: rear: passenger side sliding/tilting sunroof,Not operated,
IDE12985-MAS15421,Operating signals: rear door control modules-Operating signal: rear: driver side roof shade,Not operated,
IDE12985-MAS15422,Operating signals: rear door control modules-Operating signal: rear: passenger side roof shade,Not operated,
IDE14139-MAS01161,Wind deflector control module: status-Communication malfunction,not installed,
IDE14139-MAS02282,Wind deflector control module: status-Position,not installed,
IDE14139-MAS04183,Wind deflector control module: status-Position error,not installed,
IDE14139-MAS08536,Wind deflector control module: status-Excessive temperature protection,not installed,
IDE14139-MAS17855,Wind deflector control module: status-Wagon message,Not available,
IDE14139-MAS17856,Wind deflector control module: status-Forced connection requirement,Not available,
IDE14139-MAS17857,Wind deflector control module: status-Position,not installed,
IDE14139-MAS17858,Wind deflector control module: status-Drive initializing,not installed,
IDE14139-MAS17859,Wind deflector control module: status-Adaptation run successful,not installed,
IDE14139-MAS17860,Wind deflector control module: status-Function canceled,not installed,
IDE14140-IDE02021,Wind deflector control module: reception signal-Comfort closing,Not available,
IDE14140-IDE02022,Wind deflector control module: reception signal-Comfort opening,Not available,
IDE14140-IDE14099,Wind deflector control module: reception signal-Wind deflector: denormalization,Not available,
IDE14140-MAS00370,Wind deflector control module: reception signal-Vehicle speed,Not available,
IDE14140-MAS01468,Wind deflector control module: reception signal-Terminal 15,Not available,
IDE14140-MAS02447,Wind deflector control module: reception signal-Release,Not available,
IDE14140-MAS05563,Wind deflector control module: reception signal-Norming,Not available,
IDE14140-MAS05737,Wind deflector control module: reception signal-Position,Not available,
IDE14140-MAS17871,Wind deflector control module: reception signal-Teaching-in run,Not available,
IDE14231-IDE09422,Power sunroof control module: absolute position values-Roof shade,4.2500,
IDE14231-IDE09423,Power sunroof control module: absolute position values-Sunroof,4.8125,
Elapsed Time: 00:04
;SW:7P5-941-591-AD HW:7P5-941-591-A --- Light Ctrl Left 2
;Component:LED1L H06 0005, Coding:
;EV_LED_PLUS_L_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416.rod
;Saturday,23,December,2023,20:04:20:15566
;VCID: 7EAE93F21074B91A5DF-802A
IDE00030-FSS01408,Status of actuator test-Status,not active,
IDE00325,Diagnostic mode,Extended Session,
IDE00767-ENG145196,No. of unscheduled ECU resets-Test_Program_Watchdog_reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,14.6, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.1, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,0.0, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,0.0, V
IDE03680-MAS10129,Supply voltages-Daytime driving light supply,0.0, V
IDE03680-MAS12194,Supply voltages-Supply for logic,14.6, V
IDE03680-ENG166115,Supply voltages-Terminal_30g,14.6, V
IDE06926-ENG159697,History memory: reset counter-reset_reason,Watchdog Reset,
IDE06926-ENG139695,History memory: reset counter-Timestamp,17 0C 17 14 04,
IDE08742-IDE09773,Operating time-Side marker lamps,222.50, H
IDE08742-MAS02923,Operating time-Highway light,0.00, H
IDE08742-MAS09325,Operating time-Daytime running lamps,174.33, H
IDE08742-MAS13654,Operating time-Auxiliary high beam,0.00, H
IDE08742-ENG159696,Operating time-all_weather_light,0.00, H
IDE08742-ENG167223,Operating time-City_light 4,0.00, H
IDE08742-ENG159688,Operating time-Control_module,520.00, H
IDE08742-ENG251669,Operating time-High_beam,1.92, H
IDE08742-ENG251668,Operating time-Low_beam,215.33, H
IDE08742-ENG166111,Operating time-Position_light,217.33, H
IDE08742-ENG251667,Operating time-Static_Cornering_Light,0.00, H
IDE08742-ENG159751,Operating time-Tourist_light,0.00, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.17, H
IDE09770-MAS02526,High side channel 1-Activation,Channel not used,
IDE09770-MAS04136,High side channel 1-Current,Channel not used,
IDE09770-MAS09022,High side channel 1-PWM value,0.0, %
IDE09771-MAS02526,High side channel 2-Activation,Channel not used,
IDE09771-MAS04136,High side channel 2-Current,Channel not used,
IDE09771-MAS09022,High side channel 2-PWM value,0.0, %
IDE09772-MAS01340,High side channel 3-Functions,no function,
IDE09772-MAS09022,High side channel 3-PWM value,0.0, %
IDE09774-IDE09773,Number of activations-Side marker lamps,54694,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS09325,Number of activations-Daytime running lamps,5759,
IDE09774-MAS13654,Number of activations-Auxiliary high beam,0,
IDE09774-ENG159696,Number of activations-all_weather_light,0,
IDE09774-ENG167208,Number of activations-city_light,0,
IDE09774-ENG251669,Number of activations-High_beam,212,
IDE09774-ENG159986,Number of activations-High_beam_excess_temperature,0,
IDE09774-ENG159984,Number of activations-High_beam_excess_temperature_protection,0,
IDE09774-ENG251668,Number of activations-Low_beam,1505,
IDE09774-ENG159985,Number of activations-Low_beam_excess_temperature,0,
IDE09774-ENG159983,Number of activations-Low_beam_excess_temperature_protection,0,
IDE09774-ENG166111,Number of activations-Position_light,7232,
IDE09774-ENG251667,Number of activations-Static_Cornering_Light,0,
IDE09774-ENG159751,Number of activations-Tourist_light,0,
IDE09774-ENG166116,Number of activations-Turn_indicator,101385,
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, H
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,394.00, H
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,12.33, H
IDE09828-MAS00890,Head lamp variant-via CAN,E0 60,
IDE09828-ENG159688,Head lamp variant-Control_module,E0 60,
IDE10048-IDE09768,Supply information-LED channel 1,Not Used,
IDE10048-IDE09769,Supply information-LED channel 2,Terminal_30g,
IDE10048-IDE09771,Supply information-High side channel 2,Terminal_30g,
IDE10048-IDE09772,Supply information-High side channel 3,Terminal 15,
IDE10048-IDE11123,Supply information-High side channel 4,Terminal 15,
IDE10048-MAS01968,Supply information-Fan,Not Used,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal_30g,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-MAS16122,Supply information-LED channel 4,Terminal_30g,
IDE10048-ENG161277,Supply information-Highside_channel 1,Terminal_30g,
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,24, °C
IDE10165-MAS01340,LED channel 1: Master 1-Functions,Low_beam,
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,100.0, %
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,2,
IDE10167-FSS01570,LED channel 1: Slave-Temperature,42, °C
IDE10167-MAS01340,LED channel 1: Slave-Functions,no function,
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,100.0, %
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,3,
IDE10168-FSS01570,LED channel 2: Master-Temperature,21, °C
IDE10168-MAS01340,LED channel 2: Master-Functions,High_beam,
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,2,
IDE10169-FSS01570,LED channel 2: Slave-Temperature,99, °C
IDE10169-MAS01340,LED channel 2: Slave-Functions,no function,
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS09022,LED channel 2: Slave-PWM value,100.0, %
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,4,
IDE10170-FSS01570,LED channel 3: Master-Temperature,49, °C
IDE10170-MAS01340,LED channel 3: Master-Functions,Position_light / Daytime_running_light,
IDE10170-MAS04136,LED channel 3: Master-Current,648, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,3,
IDE10173-MAS09336,Operating times in temperature ranges-between 95°C and 105°C,0.00, H
IDE10173-MAS09337,Operating times in temperature ranges-between 105°C and 115°C,0.00, H
IDE10173-MAS09338,Operating times in temperature ranges-over 115°C,0.00, H
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,404.33, H
IDE10205,Control module version,plus,
IDE10206-MAS09945,Headlamp fan-Fan 1: current,not installed,
IDE10206-MAS09946,Headlamp fan-Fan 2: current,not installed,
IDE10206-MAS11628,Headlamp fan-Fan 1: activation,not installed,
IDE10206-MAS11629,Headlamp fan-Fan 2: activation,not installed,
IDE10282-IDE10165,LED channels: voltages-LED channel 1: Master 1,0.00, V
IDE10282-IDE10168,LED channels: voltages-LED channel 2: Master,0.00, V
IDE10282-IDE10170,LED channels: voltages-LED channel 3: Master,14.00, V
IDE10282-IDE13678,LED channels: voltages-LED channel 4: Master,0.00, V
IDE10282-ENG167217,LED channels: voltages-Channel _1_Slave,0.00, V
IDE10282-ENG167218,LED channels: voltages-Channel _2_Slave,0.00, V
IDE10864-MAS11561,Control mod. temperatures-Power supply for the LED headlamp,31, °C
IDE10864-MAS11562,Control mod. temperatures-Power output module for matrix headlamp,0, °C
IDE11123-MAS02526,High side channel 4-Activation,Channel not used,
IDE11123-MAS04136,High side channel 4-Current,Channel not used,
IDE11123-MAS09022,High side channel 4-PWM value,0.0, %
IDE11124-IDE10205,Headlamp Range Control Motor-Control module version,plus,
IDE11124-ENG145201,Headlamp Range Control Motor-Test_Program_Inclination_of_low_beam,-44.00, mm
IDE11124-ENG145200,Headlamp Range Control Motor-Test_Program_Motor_position_percentage_of_maximum_adjustment_travel,54.80, %
IDE13678-FSS01570,LED channel 4: Master-Temperature,49, °C
IDE13678-MAS01340,LED channel 4: Master-Functions,Turn_indicator,
IDE13678-MAS04136,LED channel 4: Master-Current,0, mA
IDE13678-MAS09022,LED channel 4: Master-PWM value,0.0, %
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,1,
MAS00468,Unlearning counter,53,
Elapsed Time: 00:04
;SW:7P5-941-591-AD HW:7P5-941-591-A --- Light Ctrl Right 2
;Component:LED1R H06 0005, Coding:
;EV_LED_PLUS_R_KEBODAVW416,001003,EV_LEDPLUSRightKEBODVW416.rod
;Saturday,23,December,2023,20:04:27:15566
IDE03680-MAS01468,Supply voltages-Terminal 15,14.5, V
IDE03680-MAS12194,Supply voltages-Supply for logic,14.5, V
IDE03680-ENG166115,Supply voltages-Terminal_30g,14.7, V
IDE08742-IDE09773,Operating time-Side marker lamps,61.33, H
IDE08742-MAS09325,Operating time-Daytime running lamps,109.50, H
IDE08742-ENG159688,Operating time-Control_module,234.83, H
IDE08742-ENG251669,Operating time-High_beam,0.00, H
IDE08742-ENG251668,Operating time-Low_beam,58.50, H
IDE08742-ENG166111,Operating time-Position_light,58.75, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.08, H
IDE09770-IDE10205,High side channel 1-Control module version,not defined,
IDE09772-MAS02526,High side channel 3-Activation,Channel not used,
IDE09772-MAS04136,High side channel 3-Current,Channel not used,
IDE09774-IDE09773,Number of activations-Side marker lamps,17674,
IDE09774-MAS09325,Number of activations-Daytime running lamps,4254,
IDE09774-ENG251669,Number of activations-High_beam,93,
IDE09774-ENG251668,Number of activations-Low_beam,797,
IDE09774-ENG166111,Number of activations-Position_light,2848,
IDE09774-ENG166116,Number of activations-Turn_indicator,46517,
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,160.17, H
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,9.67, H
IDE10048-ENG161278,Supply information-Highside_channel 2,Terminal_30g,
IDE10048-ENG161279,Supply information-Highside_channel 3,Terminal 15,
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,25, °C
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,4,
IDE10170-FSS01570,LED channel 3: Master-Temperature,53, °C
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,170.67, H
IDE10206-MAS02526,Headlamp fan-Activation,Highbeam_shutter,
IDE10206-MAS04136,Headlamp fan-Current,in correct range,
IDE10282-ENG167222,LED channels: voltages-Channel_4_Master,0.00, V
IDE10864-MAS11561,Control mod. temperatures-Power supply for the LED headlamp,30, °C
IDE11124-MAS12195,Headlamp Range Control Motor-Reference run status,will be performed.,
IDE11124-MAS12196,Headlamp Range Control Motor-Fault position,not approached,
IDE11124-MAS12199,Headlamp Range Control Motor-Adjustment speed,normal,
IDE13678-FSS01570,LED channel 4: Master-Temperature,51, °C
Elapsed Time: 00:04
;33-OBD2
;Saturday,23,December,2023,20:14:57:15566
03,Fuel system 1/2 status,Closed loop
04,Calculated load value,25.1 %,25.5 %
05,Engine coolant temperature,104 °C,104 °C
06,Short Term Trim - Bank 1,-0.8 %
07,Long Term Trim - Bank 1,2.3 %
0B,Intake Manifold Absolute Pressure,28 kPa abs
0C,Engine RPM,701 /min,703 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,0.5 Degrees
0F,Intake air temperature,51 °C
11,Absolute Throttle Position,11.0 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.175 V
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,2418 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,23.1 %
2F,Fuel Level Input,93.7 %
30,Warm-ups since DTC cleared,9
31,Distance since DTC cleared,296 km
33,Barometric pressure,100 kPa abs
34,Bank 1 Sensor 1 Status,1.009 Lambda,-0.008 mA
3C,B1S1 Cat. Temp.,294.4 °C
42,Control module voltage,13.080 V,12.800 V
43,Absolute Load Value,16 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,0.8 %
46,Ambient Air Temp,22 °C
47,Absolute Throttle Position B,11 %
49,Accelerator Pedal Position D,15.3 %,15.3 %
4A,Accelerator Pedal Position E,14.9 %
4C,Commanded Throttle Actuator Control,0.8 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
62,Torque actual,8.0 %
63,Torque Reference,250 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
67,Engine Coolant Temp,ECT 1:104 °C,ECT 2:105 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:16780/--- kPa
70,Boost Press Ctrl A/B,BP_A act:100.9 kPa
72,Wastegate Ctrl A/B,WG_A cmd/act:---/100 %,WG_B cmd/act:---/--- %
73,Exhaust Press 1/2,EP1:103.42 kPa
8B,Aftertreatment status,PF_Regen:Status:N,PF_Load: 4.3 %
8E,Eng. friction %torque,6.0 %
9D,Fuel rate,Engine: 0.12 g/s,Vehicle: 0.12 g/s
9E,Exhaust flow rate,6.4 kg/h
A4,Transm gear,N
Type 02 - VIN : VSSZZZ5FZK6528195 (Address E8)
Type 04 - Calibration ID : 05E018R 9832BEAJ (Address E8)
Type 04 - Calibration ID : 0CW300041S 1694 (Address E9)
Type 06 - Calibration Verification Number : 603F5A41 (Address E8)
Type 06 - Calibration Verification Number : 6EAD7F32 (Address E9)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 1775
Ignition cycle count : 9885
Catalyst monitor bank 1 : 1444 / 1775
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 1320 / 1775
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 6756 / 1775
AIR monitor : 0 / 0
EVAP monitor : 0 / 0
Secondary O2 Sensor monitor bank 1 : 1243 / 1775
Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
