lans
- Jun 30, 2015
- 16
- 4
- Macedonia
- HC438952 (2nd hand?)
Saturday,22,August,2015,02:45:43:25280
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WVWZZZ3CZFE445322 License Plate:
Mileage: 10370km-6443mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZ3CZFE445322 Mileage: 10370km-6443miles
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 AS HW: 04L 907 309 R
Component: R4 2,0L TDI H21 0887
Revision: B5H21---
Coding: 0119003203441D083000
Shop #: WSC 05311 115 00300
ASAM Dataset: EV_ECM20TDI01104L906026AS 001005
ROD: EV_ECM20TDI01104L906026AS.rod
VCID: 7BFFC647F287A0E603-802E
20359 - Internal Control Module
P0606 00 [101] - Processor Fault
Mileage: 9511 km
Date: 2015.08.13
Time: 13:16:51
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 63514000002738
Coding: 0EEC6A8F34240B71077A060241C54970562CD0E0608292F13460F078C002
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 3D7B085FAC136ED67D-8068
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0356005419
Coding: 000F1F0603
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 77F7DA77CEAF848667-8022
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AH HW: 5G0 907 044 AH
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 11020104202100012015504000101802
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6DDBF81FBCF33E568D-8038
Slave 1:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 BD HW: 5Q0 937 086 BD
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580501150888
Coding: 00010A46C24102FF03A04084B11007081880000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7DFBC85FEC93AED63D-8028
Slave 1:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141123 042 0607
Serial number: 141201031904
Slave 2:
Component: RLHS 037 0059
Serial number: S5Y15M01D08H10M04S24
Coding: 06A8DD
Slave 3:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 16 11 2014 00000603
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143210NWY
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000061016863
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 C HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0013
Serial number: ATW-00111.01.15
Coding: 0071061041
Shop #: WSC 05311 115 00093
ASAM Dataset: EV_EPHVA2CAU3700000 008017
ROD: EV_EPHVA2CAU3700000_VW48.rod
VCID: 3F877257A61F7CC66F-806A
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 3Q0 907 572 A HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0126
Coding: 2A40600310FFC428949C804C
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X.rod
VCID: 336F2E679A57A8A69B-8066
0862 - Databus
Reset counter: 175
Mileage: 8432 km
Date: 2015.08.06
Time: 14:06:57
Part No SW: 3Q0 959 655 AF HW: 3Q0 959 655 AF
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R2PSHT9S$
Coding: 88CCC000000000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X_VW48.rod
VCID: 0201BBA3956DD12E40-8056
Subsystem 1 - Part No SW: ----------- HW: 454 001 912 14
Serial number: 3576U00000079944E11E
Subsystem 2 - Part No SW: ----------- HW: 454 002 112 14
Serial number: 3586U00000040330021M
Subsystem 3 - Part No SW: ----------- HW: 454 801 712 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R7CB566050000008
Subsystem 4 - Part No SW: ----------- HW: 454 801 712 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RFA546B05000000D
Subsystem 5 - Part No SW: ----------- HW: 454 801 512 14
Component: FrontSensor_D 114 0149
Serial number: 3556V0C5748050000005
B13BC F2 [008] - No function
Mileage: 9021 km
Date: 2015.08.10
Time: 16:29:24
Address 16: Steering wheel (J524) Labels: None
Part No SW: 3Q0 953 521 HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150107400025
Coding: 0000
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 741 HW: 3G0 920 741
Component: KOMBI 209 4311
Coding: 07A401102F80000800883A001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 61C3942F702B6A3639-8034
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 13121410803090
Coding: 030300044F087300EF000258080F00010001070000000000000000000000
ROD: EV_GatewConti.rod
VCID: 72E1EB63A5CDE1AE50-8026
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 27140003140050104513
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2833385303
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
8531970 - Quiescent Current
U1406 00 [009] - Too High
Fault Frequency: 12
Reset counter: 159
Mileage: 9017 km
Date: 2015.08.10
Time: 03:18:01
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000315541013
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E3E46FA0CBDAB6A9-8024
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 111214BLA0672A
Coding: 00350A20DC00020000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 42817BA3D5ED112E00-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000643701
Address 44: Steering Assist (J500) Labels: None
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial number: 0000115696
Coding: 01010010005000
Shop #: WSC 00015 115 00300
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3B7F0647B20760E643-806E
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 171214BLG19605
Coding: 00350020DC00020000001000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 418374AFD0EB0A3619-8014
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000639417
Coding: 090000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 03DA000009000000
Shop #: WSC 05311 000 00001
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75EBD07FD4A3F69675-8020
Part No SW: 3Q0 035 819 HW: 3Q0 035 819
Component: MU-S--ER H11 0135
Serial number: VWZAZ2P4672212
Coding: 02840100FF00000011110001000808001F0100840120010001
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6ED9FF13B1F5C54EB4-803A
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 HW: 3G0 919 605
Component: ABT_Std-2 H42 1015
Serial number: VWZ8Z9PD500879
B201A 00 [009] - -
Reset counter: 107
Mileage: 8378 km
Date: 2015.08.05
Time: 22:25:36
7203 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 163
Mileage: 9351 km
Date: 2015.08.12
Time: 17:47:24
End-------------------------(Elapsed Time: 04:16)--------------------------
