Airbag igniter which is it?
headliner
Chicago, IL, USA
C?ID=18119
check harness connector, and rocket connector. low resistance and high resistance might be little confusing. low resistance means that connection is easier than expected for example something giving additional flow for current. there used to be safety mechanism grounding- or closing loop to prevent accidental high electrical discharge like from clothing for example . It could cause such reading - and must say that often get confused with resistance myself:)
q76767
New Jersey, USA
C?ID=445722
Ok I'll pull the plug off the airbag module and test for continuity between that and plug that goes into airbag. Sorry I'm not the greatest with electrical
   #43
headliner
Chicago, IL, USA
C?ID=18119
some modules have all wires yellow. without diagram is blind walking, get diagram , alldata sells that info for 20bucks, get a good magnifier, to find pin numbers on connectors and run the test. it has nothing to do with electricity it just tool use, diagram will show you which pin , what wire iif colored and where it goes, then you will see if connects to anything, or splits. part of a job.')
   #44
q76767
New Jersey, USA
C?ID=445722
Just got the wiring diagram color's look different than mine tho? Going to double check in morning. 3 wire connector on diagram shows Grey, red and brown my 3 wire connector is black, yellow and brown. The 2 wire connector on diagram shows yellow and black while mine is brown and red. Crappy pic of plugs just what I had on my phone for now
   #45
headliner
Chicago, IL, USA
C?ID=18119
hello
please read instructions, training with airbags prior work.
disconected connectors , be ware that Multimeter in some cases CAN DEPLOY AIRBAG!!! do not measure harness or bag connected to airbags,
C(controller)16 - I(igniter)4 = ? continuity , and then same wire either side to ground and between wires to connector I 1,2,5,- can not have continuity
C16 - I 4 cross 2.1.5 to see if not connected by some mechanical pinch or something
C 17- I 5 continuity and then I5 to ground no continuity and between I 1 2 4
C 24 - I 1 etc between 5 4 2 and ground NO to 3 it goes somewhere I do not see
C25 - I2 and I 1 5 4 as previous
these connectors have names I called em C - controller I - igniter
see what brown 3 is doing I do not see on diagram, might go to other airbag and back to C it could be some diagnostic wire.
If continuity and cross continuity
if continuity of wires is good , no cross continuity, airbag ignter connector inspected and no melt, no visual inperfections.
airbag either was tried to be launched or faulty - no good-
   #46
q76767
New Jersey, USA
C?ID=445722
I tested for continuity between 16 on connector of module to harness side of airbag red and got 000. Tested pin 17 on harness to Grey on harness side to airbag got 000. So looks like wires going to igniter 2 are good. Trying to do the other cross ones now. Brown wire goes to a side igniter
   #47
headliner
Chicago, IL, USA
C?ID=18119
very nice!
“one small step for a man, one giant leap for mankind”
CHECK igniter connector if no visual MELT , you need new rocket motor with igniter
ps
how to put media? imaages , videos , links NEED HELP
   #48
headliner
Chicago, IL, USA
C?ID=18119
check if 16 &17 are not connecter together -conti nui ti -italian vesrion
q76767
New Jersey, USA
C?ID=445722
You have to download a app called imugur upload the pics to there and then copy the permalink and past it into the spot on here that is for pictures. I just pulled the bag down it may have gotten wet at one point
   #50
q76767
New Jersey, USA
C?ID=445722
Paste the permalink from imugur into spot I have circled
   #51
headliner
Chicago, IL, USA
C?ID=18119
ok
q76767
, here is your dinner !
it is very sensitive device ROCKETS ,
if wires checked , your igniter airbag is no good. what year is it ?
   #53
headliner
Chicago, IL, USA
C?ID=18119
I tried to do that and no work for me, do I need to be logged into IMGUR ? let me see my YT
   #56
headliner
Chicago, IL, USA
C?ID=18119
Just replaced the bag and still getting same code! Not sure even what else it could be at this point? Something inside airbag module?
too many dynamics.
-wires traced - OK
-connector inspected ? - ( )
-igniter used ?
   #59
q76767
New Jersey, USA
C?ID=445722
https://www.vweosclub.com/attachments/remove-pins-png.24247/
can you see that connecting metal on 2 pins on the right ?
Ok I just tried it again from probing the connection looks like I bent the pin. I straightened it with a small pick and light is gone!! Sorry that was my fault! Thank you so much for all the help.
So for anyone in future with this problem connectors definitely go bad if bag is tried to deploy and possibly bag itself.
   #60
headliner
Chicago, IL, USA
C?ID=18119
Awesome that you have it out of your head !
:thumbs:
