Airbag igniter which is it?
q76767
New Jersey, USA
C?ID=445722
Never seen one but things are very dynamic.
- check for water damage - corrosion signs, use some good magnifying equipment, very misleading,
- inspect connectors very precisely, harness side, while ago I had those small connection(pinch) wire- metal in plugs , not pinched correctly and it was causing intermittent fault , what is very interesting it was temperature related -AMAZING , would never build such a connection if wanted to
Ok so I opened up one on a parts car and the plugs that go into the airbag are fuseable link. I unplugged the plug that goes into airbag closest to dash and it's all black on outside like it popped a fuse inside or something. I'm going to cut that plug out solder and shrink wrap another one and go from there
   #22
headliner
Chicago, IL, USA
C?ID=18119
any pictures ?
must check on scrap cars we have here, pre and post
   #23
q76767
New Jersey, USA
C?ID=445722
any pictures ?
Right is one from car originally can see burn marks on it left is another one from a parts car
The other plug is burnt aswell so I need to find another one I think as my parts car us missing it
headliner
Chicago, IL, USA
C?ID=18119
Im not sure about a fusable link thing , but during detonation they usually look like "morning camping fire pit"
   #25
q76767
New Jersey, USA
C?ID=445722
I solderd one in going to junkyard to get one for other side now. I'll pop one open for you when I'm it's a really tiny link inside
   #26
headliner
Chicago, IL, USA
C?ID=18119
lets see, zoom it nice , I would think diode would actually do some work of something else but link?,
see if harness available, sometimes is very inexpensive, soldering is not best idea as well as working with harness. SAfety is quiet important
   #27
q76767
New Jersey, USA
C?ID=445722
Ok so I replaced both plugs on passenger airbag and now says correct under measuring value and code cleared! unfortunately I have another code for igniter 2 and in advanced measuring values for that igniter two it says "to small". Posting a full scan below. I'm thinking maybe in dash air bag igniter is faulty since that code didn't come on till the wiring to it was repaired? I can go get a airbag from local junkyard for under $100. Thanks for help so far very much appreciated!
Wednesday,13,December,2023,12:48:22:58701
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VW2K7AJ3DM404090   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VW2K7AJ3DM404090   Mileage: 201050km-124926miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 AA    HW: 06G 906 055 B
   Component: 2.0l / 85 KW     01 1204
   Revision: T5H06---    Serial number:
   Coding: 0001015
   Shop #: WSC 00066 000 00000
   VCID: 6889B1EEAE7D8F9A873-803C
   VINID: 0E69C26C745A0D474400400900CE71A204
Readiness: 0110 0101
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           2329
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 7F5B0AB2DBF32822569-802A
   Revision: 00H31001
   Coding: B14B200C512208FE8D0B04ED8A191061A71000
   VCID: 7DA7F0BADDFF3A32445-8028
8 Faults Found:
                    Fault Status: 00101101
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.15
                    Time: 05:03:11
                    Count: 12
                    Count: 4608
                    Count: 8193
                    Count: 48896
                    Count: 511
                    Count: 127
03388 - Engine Control Module - Pressure Information
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.15
                    Time: 05:03:11
                    Count: 12
                    Count: 4864
                    Count: 8251
                    Count: 49152
                    Count: 509
                    Count: 127
01177 - Engine Control Unit
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.15
                    Time: 05:03:11
                    Count: 12
                    Count: 4864
                    Count: 8250
                    Count: 49152
                    Count: 509
                    Count: 127
01169 - Door Contact Switch Driver Side (F2)
                    Reset counter: 203
                    Mileage: 194539 km
                    Date: 2018.01.25
                    Time: 02:56:10
                    Count: 32768
                    Count: 20992
                    Count: 147
                    Count: 49921
                    Count: 1
                    Count: 55
02846 - Button for Tire Pressure Monitoring Display (E492)
                    Fault Frequency: 252
                    Reset counter: 203
                    Mileage: 164670 km
                    Date: 2022.11.13
                    Time: 21:33:01
                    Count: 16391
                    Count: 32780
                    Count: 8192
                    Count: 157
                    Count: 45312
                    Count: 256
                    Count: 256
                    Count: 67
03543 - Mechanical Malfunction in Suspension
                    Reset counter: 217
                    Mileage: 147219 km
                    Date: 2022.01.10
                    Time: 00:04:34
                    Count: 12
                    Count: 29184
                    Count: 16389
                    Count: 46848
                    Count: 65024
                    Count: 65535
                    Count: 78
                    Reset counter: 163
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 20:58:54
                    Count: 3
                    Count: 13
                    Count: 28672
                    Count: 16390
                    Count: 33792
                    Count: 65025
                    Count: 254
                    Count: 128
                    Reset counter: 163
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 00:00:25
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 25600
                    Count: 65280
                    Count: 122
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BD    HW: 5C0 820 047 BD
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001250705
   VCID: 6393A6C2575BECC2521-8036
00229 - Refrigerant Pressure
                    Fault Status: 00100001
                    Reset counter: 200
                    Mileage: 200090 km
                    Date: 2018.03.27
                    Time: 03:13:15
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 20:59:26
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 00:00:01
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371317120913
   Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
   VCID: 2F3B1AF2471318A2869-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3465
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
01758 - Bulbs for Brake Lamps
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 00:17:40
03431 - Activation of Left Parking Light
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 00:13:22
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 163
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 00:13:22
                    Reset counter: 203
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.05
                    Time: 20:59:25
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM092CY+   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3431159EAEB53B7AFBB-8060
   Serial number: 6940000Y120000M5WG02
   Coding: 303032
   Serial number: 3572MSME086F1072ZZZW
   Serial number: 3582MSME77171372ZZZT
   Serial number: 3516KSME6B0C5A1FZZZ6
   Serial number: 3526KSME361F671FZZZ1
   Serial number: 3556LSME1E112F26ZZZ-
   Serial number: 3566LSME7D13771EZZZ5
9437978 - Igniter 2  for Passenger's Airbag
          B1003 1A [10001001] - Resistance Too Low
                    Mileage: 201057 km
                    Date: 2023.12.13
                    Time: 00:02:03
   Part No SW: 5C6 920 952     HW: 5C6 920 952
   Component: KOMBI         H06 0705
   Coding: 270201
   Shop #: WSC 00066 000 00122
   VCID: 698FB4EAB9F7B69298D-803C
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltage too low]
                    Reset counter: 203
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D98E9AAD475ADF3-8024
   Component: IMMO          H06 0705
   VCID: 6A8DCBE6BCF1BD8A917-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3464556
   Coding: 05000400010006
   VCID: 2313E6C21BDBACC2121-8076
                    Reset counter: 203
End----(Elapsed Time: 01:01, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
q76767
New Jersey, USA
C?ID=445722
Here is the picture of one plugs taken apart that you asked for.
headliner
Chicago, IL, USA
C?ID=18119
exactly, thats a way they look, heat and gases,
   #30
q76767
New Jersey, USA
C?ID=445722
I replaced both the plugs short to ground code is gone but with that gone I have resistance to low ignitor 2. Does it seem like airbag under dash is bad?
   #31
headliner
Chicago, IL, USA
C?ID=18119
not sure , your doing. if harness correct and resistance too low igniter malfunction. rocket itself
   #32
q76767
New Jersey, USA
C?ID=445722
Harness is correct I believe, took plugs from same year shrink wrapped the plugs onto existing wires. I may try a new airbag and hope that does it
   #33
headliner
Chicago, IL, USA
C?ID=18119
if module is good , harness is even better, only thing left is ROCKET. It happens that you meet faulty. PLEASE be aware that these ROCKETs has strong bag at motor exhaust and can do HARM, do not play if not trained.
  • Agree
q76767
New Jersey, USA
C?ID=445722
I feel like module is good as it's only one code I'm getting and I didn't get it till I fixed the harness. I've had battery disconnected for a few hours so won't have any juice in system so I don't forsee being an issue taking it out
   #35
headliner
Chicago, IL, USA
C?ID=18119
Igniter is electric circuit that when protons and electrons with neutrons do their thing it will get warm, warmer , hot and then rocket does its thing. I would not go any further with igniters and experiments on DIY.
   #36
headliner
Chicago, IL, USA
C?ID=18119
LOL . stay with procedures and facts , less with feelings. I felt like friday today :)
   #37
q76767
New Jersey, USA
C?ID=445722
What would you recommend doing? I have replaced Airbags in cars before so it won't be my first time doing it
   #38
q76767
New Jersey, USA
C?ID=445722
   #39
headliner
Chicago, IL, USA
C?ID=18119
FRONT AIRBAG IGNITER 2!
did you do visual inspection to connection on FRONT AIRBAG IGNITER #2 , if yes you need new Rocket with bag
   #40
q76767
New Jersey, USA
C?ID=445722
Yes connection on wire side looks I guess I'll grab a new dash airbag in morning
