Airbag igniter which is it?
q76767
New Jersey, USA
C?ID=445722
I have a code for the airbag igniter on passenger side on my 13 Jetta s 2.0 is there a way to tell which igniter it would be? Had a code for the seatbelt igniter as well played with the clip under seat and it went away. Thanks for any insights on this!
Tuesday,12,December,2023,15:30:39:58701
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VW2K7AJ3DM404090   License Plate:
Mileage: 201050km-124926mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VW2K7AJ3DM404090   Mileage: 201050km-124926miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 AA    HW: 06G 906 055 B
   Component: 2.0l / 85 KW     01 1204
   Revision: T5H06---    Serial number:
   Coding: 0001015
   Shop #: WSC 00066 000 00000
   VCID: 6889B1EEAE7D8F9A873-803C
   VINID: 0E69C26C745A0D474400400900CE71A204
Readiness: 0110 0101
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           2329
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 7F5B0AB2DBF32822569-802A
   Revision: 00H31001
   Coding: B14B200C512208FE8D0B04ED8A191061A71000
   VCID: 7DA7F0BADDFF3A32445-8028
7 Faults Found:
                    Fault Status: 00101101
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.14
                    Time: 05:03:11
                    Count: 12
                    Count: 4608
                    Count: 8193
                    Count: 48896
                    Count: 511
                    Count: 127
03388 - Engine Control Module - Pressure Information
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.14
                    Time: 05:03:11
                    Count: 12
                    Count: 4864
                    Count: 8251
                    Count: 49152
                    Count: 509
                    Count: 127
01177 - Engine Control Unit
                    Reset counter: 197
                    Mileage: 199355 km
                    Date: 2018.03.14
                    Time: 05:03:11
                    Count: 12
                    Count: 4864
                    Count: 8250
                    Count: 49152
                    Count: 509
                    Count: 127
01169 - Door Contact Switch Driver Side (F2)
                    Reset counter: 203
                    Mileage: 194539 km
                    Date: 2018.01.24
                    Time: 02:56:10
                    Count: 32768
                    Count: 20992
                    Count: 147
                    Count: 49921
                    Count: 1
                    Count: 55
02846 - Button for Tire Pressure Monitoring Display (E492)
                    Fault Frequency: 252
                    Reset counter: 203
                    Mileage: 164670 km
                    Date: 2022.11.12
                    Time: 21:33:01
                    Count: 16391
                    Count: 32780
                    Count: 8192
                    Count: 157
                    Count: 45312
                    Count: 256
                    Count: 256
                    Count: 67
                    Reset counter: 163
                    Mileage: 201057 km
                    Date: 2018.05.04
                    Time: 00:00:25
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 25600
                    Count: 65280
                    Count: 122
03543 - Mechanical Malfunction in Suspension
                    Reset counter: 217
                    Mileage: 147219 km
                    Date: 2022.01.09
                    Time: 00:04:34
                    Count: 12
                    Count: 29184
                    Count: 16389
                    Count: 46848
                    Count: 65024
                    Count: 65535
                    Count: 78
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BD    HW: 5C0 820 047 BD
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001250705
   VCID: 6393A6C2575BECC2521-8036
00229 - Refrigerant Pressure
                    Fault Status: 00100001
                    Reset counter: 200
                    Mileage: 200090 km
                    Date: 2018.03.26
                    Time: 03:13:15
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371317120913
   Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
   VCID: 2F3B1AF2471318A2869-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3465
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
01758 - Bulbs for Brake Lamps
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.04
                    Time: 00:17:40
03431 - Activation of Left Parking Light
                    Reset counter: 203
                    Mileage: 201057 km
                    Date: 2018.05.04
                    Time: 00:13:22
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 163
                    Mileage: 201057 km
                    Date: 2018.05.04
                    Time: 00:13:22
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM092CY+   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3431159EAEB53B7AFBB-8060
   Serial number: 6940000Y120000M5WG02
   Coding: 303032
   Serial number: 3572MSME086F1072ZZZW
   Serial number: 3582MSME77171372ZZZT
   Serial number: 3516KSME6B0C5A1FZZZ6
   Serial number: 3526KSME361F671FZZZ1
   Serial number: 3556LSME1E112F26ZZZ-
   Serial number: 3566LSME7D13771EZZZ5
9437713 - Igniter for Passenger's Airbag
          B1002 11 [10001001] - Short to Ground
                    Mileage: 201057 km
                    Date: 2023.12.12
                    Time: 02:38:59
   Part No SW: 5C6 920 952     HW: 5C6 920 952
   Component: KOMBI         H06 0705
   Coding: 270201
   Shop #: WSC 00066 000 00122
   VCID: 698FB4EAB9F7B69298D-803C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D98E9AAD475ADF3-8024
   Component: IMMO          H06 0705
   VCID: 6A8DCBE6BCF1BD8A917-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3464556
   Coding: 05000400010006
   VCID: 2313E6C21BDBACC2121-8076
End----------(Elapsed Time: 01:01, VBatt start/end: 14.1V/14.0V)
I'm pretty confident that's the igniter for the airbag in the dash.
"Short to Ground" bothers me more than say, "Resistance too high" or "Resistance too low" would. Do not clear that fault with anyone in the path of that airbag. @Jef may want to chime in here.
q76767
New Jersey, USA
C?ID=445722
Ok definitely won't and will wait to hear more thank you!
headliner
Chicago, IL, USA
C?ID=18119
airbags are tricky and dangerous! be careful do not measure resistance of airbag itself it might fire off unit!
q76767
New Jersey, USA
C?ID=445722
To ad to it the driver side seat belt igniter was unplugged for some reason. Could it be they unplugged the passeger airbag aswell in the dash?
headliner
Chicago, IL, USA
C?ID=18119
auction car?
if Y anything is possible, you can see value in measuring blocks, at least at older 2000 you could
q76767
New Jersey, USA
C?ID=445722
auction car?
Yup auction car. I'll try to find measuring blocks in am
headliner
Chicago, IL, USA
C?ID=18119
adventures of salvage world! maybe insurance company paid for all new new igniters and decided to junk all car, it happens.
No "Blocks". It's a UDS module. Use Advanced Measuring Values.
headliner
Chicago, IL, USA
C?ID=18119
Its good that you are here UWe , Im little older user and must admit have a work to do info update. Many things got little ... Ay Iy ish
But remember that luxury when you could see if things see igniters. :rolleyes:
Jef
HQ
That is one button click away from deployment!!!! Do not attempt to clear the DTC until further notice!
You need to view the live data for the igniter and VISUALLY inspect the wiring harness for damage.
  • MAS00003-ENG102113 - Front passenger airbag igniter - Measured values
Pull that location up under Advanced Measuring Values and it most likely it is going to be showing "short circuit to Ground (GND)". You need to see about visually locating the issue and repair as per the factory repair manual. I'm guessing a wire has been damaged, maybe chaffed along a metal edge or something. You may be able to pull the glove box off and get some degree of visual inspection on the harness.
Your goal is to get the live data to show "correct". Then, and only then, should you see about clearing the DTC.
Oh, you still can, it's just that finding them measuring values works a bit differently now.
headliner
Chicago, IL, USA
C?ID=18119
I have noticed quiet changes, thanks guy for the tool, otherwise it wouldB like fortress
q76767
New Jersey, USA
C?ID=445722
Ok I pulled up that measuring value and it's getting short circuit to ground like you said. I pulled the glove box the wire on airbag closer to pass door was off at some point, can see pick marks on retaining clip. Two plugs go to in dash airbag so I'm pretty much just looking for damage on any of those wires?
headliner
Chicago, IL, USA
C?ID=18119
get some real diagram info and track wires from igniter plugs to module. Not, remember exactly but on one side: harness or igniter there is a mechanism to connect 2 terminals- safety mechanism, probably igniter. Get tiny pins, make sure that got connected right and trace wiring for continuity according to wiring documentation.
BE AWARE not to touch igniters (airbag units or belt tensioner) those small meter voltage might deploy em and harm!!!
Make sure that your electronic modules etc match vehicle vin .
q76767
New Jersey, USA
C?ID=445722
How do I see if the modules match vin?
headliner
Chicago, IL, USA
C?ID=18119
some data from logs, some visual expertise, some internet and some dealer calls, forum discussion
you be good, but nobody says it will be easy :)
q76767
New Jersey, USA
C?ID=445722
Someone else on here had the same problem and they said there is a fuseable link for passenger airbag plug that was tripped in there's. I'm looking for that now aswell
headliner
Chicago, IL, USA
C?ID=18119
Never seen one but things are very dynamic.
- check for water damage - corrosion signs, use some good magnifying equipment, very misleading,
- inspect connectors very precisely, harness side, while ago I had those small connection(pinch) wire- metal in plugs , not pinched correctly and it was causing intermittent fault , what is very interesting it was temperature related -AMAZING , would never build such a connection if wanted to
